marcjwebb 0 Posted July 6, 2020 Share Posted July 6, 2020 Hi all, I have just managed to get my hands on an Acer H340, but want to change the motherboard to something a little more powerful and up to date. what mini ITX boards are stable and working with Xpenology? Quote Link to post Share on other sites
flyride 452 Posted July 6, 2020 Share Posted July 6, 2020 (edited) Take a look at this and this and you will get a good sense of what folks are successfully using. EDIT: also https://xpenology.com/forum/topic/13333-tutorialreference-6x-loaders-and-platforms/ may be helpful to you Edited July 6, 2020 by flyride Quote Link to post Share on other sites
marcjwebb 0 Posted July 7, 2020 Author Share Posted July 7, 2020 awesome thank you for these, I shall have a good old read Quote Link to post Share on other sites
boy2litle 0 Posted August 22, 2020 Share Posted August 22, 2020 Speaking about upgrading your motherboard. What will happen with the stability of your system? I know that for each 1TB of storage space, you should have 1GB of RAM. My motherboard (MIH61R MB 10097-1) and the CPU (Intel Core i3-2100 3.1 GHz) most probably it will have to be changed in the near future (my motherboard only supports max 8GB of DDR3, and I have installed 8GB), when I will expand beyond 8TB of storage. Will my NAS will still run perfectly? Will I have to reinstall it from zero? What will happen with the data on the HDDs, should they be wiped? Thanks in advance for your answers! PS: I've searched for an answer on the forum nothing come up(most of them are about upgrading to a different DSM), because this topic is about changing your motherboard, I've tought that is somehow related with my topic, so posted in here, not not create a new one and keep this forum tidy. Quote Link to post Share on other sites
flyride 452 Posted August 23, 2020 Share Posted August 23, 2020 1 hour ago, boy2litle said: I know that for each 1TB of storage space, you should have 1GB of RAM. My motherboard (MIH61R MB 10097-1) and the CPU (Intel Core i3-2100 3.1 GHz) most probably it will have to be changed in the near future (my motherboard only supports max 8GB of DDR3, and I have installed 8GB), when I will expand beyond 8TB of storage. Will my NAS will still run perfectly? Will I have to reinstall it from zero? What will happen with the data on the HDDs, should they be wiped? Changing motherboards should not be a reinstall from zero (your words). You should not wipe your drives. You need a compatible network card on your new motherboard, or an add-in NIC compatible with the DSM you are running. Your disks need to be connected in the same manner and order as your old motherboard. And you need to be able to configure the boot environment identically to your previous install. If all of those things happen, it should come right up. It's worth 1) having a backup and 2) testing a migration with your hardware BEFORE using your production disks. 1 Quote Link to post Share on other sites
