DHD Posted October 2, 2013 Share #101 Posted October 2, 2013 Hi everyone. I managed to update my setup using the img and pat file supplied in this thread. Thank you very much worked a treat. Just wondering though if anyone else has noticed the following. Some one from China keeps trying to SSH into the Box. ( I say china as thats where the IP is originating from)? Change sn by edit vender file will resolve this problem. Quote Link to comment Share on other sites More sharing options...
rolf Posted October 10, 2013 Share #102 Posted October 10, 2013 The download link is dead, anyone please upload again? Thanks Quote Link to comment Share on other sites More sharing options...
darkest_star Posted October 10, 2013 Share #103 Posted October 10, 2013 I am also interested in the original x86 download package. Could someone please upload it again? Thank you very much!!!! Quote Link to comment Share on other sites More sharing options...
gfacek Posted October 14, 2013 Share #104 Posted October 14, 2013 Yes...upload please! I need that file too! Quote Link to comment Share on other sites More sharing options...
Trantor Posted October 14, 2013 Share #105 Posted October 14, 2013 I have the original (RS3413xs_3211-x86-20130525.rar) file posted by odie. I will re-upload it to my server shortly EDIT : I only made mirror for the odie's file. No support/help with this Download link : http://xpenology.trantor.be/x86.php Quote Link to comment Share on other sites More sharing options...
gfacek Posted October 17, 2013 Share #106 Posted October 17, 2013 Hi, I've some problems with this release on my NAS. I have an old Qnap SS-839 Pro with an Intel Atom N270 and only 32-bit-support. I replaced the standard 128MB-IDE-DOM with a new one (2GB). This release starts like a charm in a virtual machine, but on my I'm stuck on booting the first bootimage (DS411-1067-x86-20130525.img). The NAS Linux seems to be starting, but then the screen goes black and the system hangs. I don't know exactly when it hangs, but when I compare the bootup, it can't be this far to the login-prompt. Can anyone provide some help here? Is it possible to replace the kernel with a working one...like ubuntu? I've some experience with linux, but I'm not an expert...e.g. I've never compiled my own kernel. Many thanks in advance. Regards, Tobi Quote Link to comment Share on other sites More sharing options...
ad911 Posted October 18, 2013 Share #107 Posted October 18, 2013 Hi, I've some problems with this release on my NAS. I have an old Qnap SS-839 Pro with an Intel Atom N270 and only 32-bit-support. I replaced the standard 128MB-IDE-DOM with a new one (2GB). This release starts like a charm in a virtual machine, but on my I'm stuck on booting the first bootimage (DS411-1067-x86-20130525.img). The NAS Linux seems to be starting, but then the screen goes black and the system hangs. I don't know exactly when it hangs, but when I compare the bootup, it can't be this far to the login-prompt. Can anyone provide some help here? Is it possible to replace the kernel with a working one...like ubuntu? I've some experience with linux, but I'm not an expert...e.g. I've never compiled my own kernel. Many thanks in advance. Regards, Tobi you don't need to login the console, read carefully the installation steps Quote Link to comment Share on other sites More sharing options...
gfacek Posted October 18, 2013 Share #108 Posted October 18, 2013 Thanks for your reply! I knew that. In fact, I tried to install on an virtual machine, too. There all works flawless! On the Qnap-NAS I did not try to login. I just ment the screen goes black a few lines before the login-promt. Maybe this helps to find out, what at the starting-process causes my problem. Quote Link to comment Share on other sites More sharing options...
jonsi007 Posted October 22, 2013 Share #109 Posted October 22, 2013 Hello! The Transmission 2.82 does not running, someone has encountered this error, just go to the 2:50 version run. Quote Link to comment Share on other sites More sharing options...
extenue Posted November 15, 2013 Share #110 Posted November 15, 2013 SAbNZBD+ , NZBGet does not work as well Quote Link to comment Share on other sites More sharing options...
ollebulle Posted November 18, 2013 Share #111 Posted November 18, 2013 I'm unable to install this in Virtualbox. Have anyone managed to get this running? Successful until; 07.Login into DSM from Web UI, create the HDD volume/space you want. (the SA will show the DSM version as 1.0.1000 now) Here it only prints: Wrong HDD number [11] Wrong HDD number [12] I've managed to run other versions in my Virtualbox environment but I'll need a working x86 version. Thanks in advance, Olle Quote Link to comment Share on other sites More sharing options...
mark105 Posted January 17, 2014 Share #112 Posted January 17, 2014 seems i have been bitten by the sata_mv issue that has been fixed in the main release i think. The DSM 2.3 kernel in this guide works all fine and my Thecus boots all ok but when i get to step 12 and go to boot into the DSM 4.2 kernel my drives spin up but dont seem to reach running state and the nas just freezes. The kernel in 4.2 is not as verbose when booting as the 2.3 kernel so i dont have any specific errors. Any ideas here? Quote Link to comment Share on other sites More sharing options...
colombodk Posted February 4, 2014 Share #113 Posted February 4, 2014 Using RS3413xs_3211-x86-20130525, a 32MB USB drive, a Commell LV-675 and a Promise TX4310 controller I had problems getting the hard drive recognized. I tried all four SATA-ports the controller; on port 3 and 4, the installation would not continue with the disk format, but when connected to port 2 everything worked! Once installed, ports 3 and 4 worked. Perhaps folks having problems with SIL-based controllers when installing should try with all the available SATA-port? A newer version than RS3413xs_3211-x86-20130525 is also available in China; the newer version dated 20130802 supports EXT4 and WOL, as far as I can tell. I have found it on the Chinese NAS-site here: http://nas1.cn/thread-68929-1-3.html It can be downloaded from here (very slow!): http://pan.baidu.com/wap/link?uk=791559 ... 61&third=0 Google-translate lists the features as follows: 1.DSM already pre-installed, you can start the brush into the RAW file (2) support EXT4 file system format 3 Support Sandisk CZ33 PID / VID and ax88179 USB 3.0 card 4. grab physical NIC address 5 support WOL Other than the boot-drive, the newer version doesn't use a .pat-file, but instead it looks like it contains a pre-configured hard-drive image in EXT4 format, compressed to an .IMG-file to be put onto a harddrive. Login details/user/pass: admin. Has anyone tried the newer version dated 20130802? Quote Link to comment Share on other sites More sharing options...
olafd Posted February 22, 2014 Share #114 Posted February 22, 2014 Hi, i'm fairly new to xpenology. i have managed to run it in virtual box just to see if i can get it working. now i was trying to re-use an ancient dell precision 650 workstation with two x86 XEON CPUs and 2gb RAM to run xpenology, following the steps as outlined here by the thread starter. i can boot the image from usb fine and connect to it via the Synology Assistant. when i start the installation, supplying DS411-1067-x86-20130525.pat to SA, i get a server error with code no. 38. on the servers console i can see the following messages: EXT3-fs: unable to read superblock EXT2-fs: unable to read superblock FAT: unable to read boot sector NTFS-fs error (device md0): ntfs_fill_super(): Unable to determine device size. the problem migth be that the RAID adapter that's in the box might not be supported. it's a DELL Perc 320/DC card with 4 SCSI drives attached. i think it's actually an adaptec controller as the bios configuration and setup menus look a lot like the old adaptec scsi setup menus. can anybody tell me if i have any chance in using this setup? if not, i might have to buy a PCI SATA card to replace the Perc adapter but i'd like to avoid that for the time being. don't want to throw to much money at the box without knowing if the whole setup will work in the end… thanks, o Quote Link to comment Share on other sites More sharing options...
lori_2001 Posted April 16, 2014 Share #115 Posted April 16, 2014 Hi, can somebody reupload DS411-1067-x86-20130525.pat? Thanks in advance. Quote Link to comment Share on other sites More sharing options...
lori_2001 Posted April 16, 2014 Share #116 Posted April 16, 2014 The img file is included in RS3413xs_3211-x86-20130525.rar, so it is ok. Quote Link to comment Share on other sites More sharing options...
davurleon Posted September 29, 2014 Share #117 Posted September 29, 2014 Hi! I am sorry if this is a double post or something, but I have searched wide and afar I think and not found a solution. I am trying to install on a Thecus N5200, I am following the guide for x86 as outlined by Trantor, but I always come to a halt with "Booting kernel" after having installed the RS3613xs pat file (step 12), after that I cannot reach the unit, almost as if the NIC is not working (not glowing green, only red/orange) but the NIC works until then, so I think it is weird if that is the problem? Anyone have a good suggestion? Quote Link to comment Share on other sites More sharing options...
javierc Posted February 24, 2015 Share #118 Posted February 24, 2015 Hi, where can I download the files to do the tutorial of this post? DS411-1067-x86-20130525.img DS411-1067-x86-20130525.pat Regards Quote Link to comment Share on other sites More sharing options...
MANtiCORE Posted April 3, 2015 Share #119 Posted April 3, 2015 all links is dead... I cant register on chineese sites, but found archive on mega - _https://mega.co.nz/#!AgQFQTrK!EfnarURuG_1IV1SyA_0FW3lWVi9MKVE6ZYdjN2R4aTo enjoy, pplz )) Quote Link to comment Share on other sites More sharing options...
philou Posted November 9, 2015 Share #120 Posted November 9, 2015 Dear, it is possible to reply in mega or other the DMS please ? Synology RS3413xs+ DSM 4.2-3211 x86 Thank you !!! Quote Link to comment Share on other sites More sharing options...
andymiller6891 Posted January 25, 2016 Share #121 Posted January 25, 2016 any chance of an x64 version of this??? Quote Link to comment Share on other sites More sharing options...
AllGamer Posted May 6, 2016 Share #122 Posted May 6, 2016 All the links to the x86 version are dead. Does anyone have a working link? I've an old Dual P3 1000 Mhz with 1GB RAM i'd like to install XPEnology x86 into it. Quote Link to comment Share on other sites More sharing options...
stevepin Posted June 12, 2016 Share #123 Posted June 12, 2016 Great stuff here on xpenology! Reading along on how to install, where can I find download links? The very few found in the posts are dead Please your help Quote Link to comment Share on other sites More sharing options...
Oliver Zganec Posted March 24 Share #124 Posted March 24 hi, I still need that file RS3413xs_3211-x86-20130525.rar , have somebody it possible? I have an old d945gsejt mobo... BR TNX!!!! Quote Link to comment Share on other sites More sharing options...
