Failed to Update from 6.1.5 to 6.2.2 (24922) / need help
HI @ all!
I rencently tried to update my xpenology syno from 6.1.5 to 6.2.2 (24922). My old loader was Juns 1.0.2b und noch I am on 1.03. I configured the new start stick as always und copied the main settings from the old grub.cfg to the new one. After flashing the new stick the baremetal starts and the "migration" screen appears. I update manually via Synology Assistant and WebUi to 6.2.2 24922. Everything was fine, no error. Unfortunately the Diskstation does not start in normal mode. It seem to "stuck" somewhere and will not show up on my router or Synology Assistant. If if start the system via the Juns "reinstall"-tab the systems starts, gets an ip and I can access the recovery WebUi. But also after the recovery the system does not start normal. Are there any hints?
System:
Baremetal
Intel Core i3 4130T 2x 2.90GHz So.1150
ASRock B85m-ITX Intel B85 So.1150 Dual Channel DDR3 Mini-ITX Retail
8GB (1x 8192MB) Kingston ValueRAM DDR3-1600 DIMM CL11-11-11 Single
Configured as 3615xs with 2x2TB storage - so no clue. Did I miss something?
Regards!
Edited by BlackHawk1942
DSM 6.2.3
if would have used this you would have not needed new drivers, the nic driver (alx.ko) is already supported by jun's package and the driver packed with 1.03b are again working with 6.2.3 as synology reverted the change from 6.2.2 that made new driver nessasery
also your cpu "qualifies" for using 918+ (loader 1.04b) and you could use hardware transcoding, but if you dont need this 3615/17 is ok
This thread just fixed my dumbness
usually its laziness (reading for hours) but if you say so ;-)
