Napalmd Posted June 19, 2020 Share #1 Posted June 19, 2020 (edited) Hi this happened yesterday and a reboot fixed the problem but today it didn't fix. Volume appears in crash mode, and read only mode. I logged in from ssh and looked at the logs, I saw this in dmesg after the reboot: Quote [ 58.067202] CPU: 0 PID: 11964 Comm: btrfs-cleaner Tainted: PF C O 3.10.105 #24922 [ 58.067203] Hardware name: Intel Corporation S3210SH/S3210SH, BIOS S3200X38.86B.00.00.0052.112920101508 11/29/2010 [ 58.067205] ffffffff814c5a5d ffffffff810355c6 ffff8800557e68b0 ffff8800379cfae8 [ 58.067207] 00000000fffffffb ffffffffa0ac8740 0000000000000419 ffffffff81035627 [ 58.067209] ffffffffa0acad48 ffff880000000020 ffff8800379cfaf8 ffff8800379cfab8 [ 58.067212] Call Trace: [ 58.067218] [<ffffffff814c5a5d>] ? dump_stack+0xc/0x15 [ 58.067221] [<ffffffff810355c6>] ? warn_slowpath_common+0x56/0x70 [ 58.067225] [<ffffffff81035627>] ? warn_slowpath_fmt+0x47/0x50 [ 58.067236] [<ffffffffa0a33ff5>] ? btrfs_del_csums+0x285/0x3c0 [btrfs] [ 58.067244] [<ffffffffa0a0ea7d>] ? __btrfs_abort_transaction+0xdd/0x130 [btrfs] [ 58.067254] [<ffffffffa0abd010>] ? add_to_free_space_tree+0xe0/0x100 [btrfs] [ 58.067264] [<ffffffffa0a23860>] ? __btrfs_free_extent+0xa70/0xd60 [btrfs] [ 58.067274] [<ffffffffa0a28bf3>] ? __btrfs_run_delayed_refs+0x443/0x11a0 [btrfs] [ 58.067284] [<ffffffffa0a2e473>] ? btrfs_run_delayed_refs+0xb3/0x2c0 [btrfs] [ 58.067294] [<ffffffffa0a2a510>] ? walk_up_tree+0xe0/0x200 [btrfs] [ 58.067304] [<ffffffffa0a40b8a>] ? btrfs_should_end_transaction+0x3a/0x60 [btrfs] [ 58.067314] [<ffffffffa0a2c4d0>] ? btrfs_drop_snapshot+0x390/0x950 [btrfs] [ 58.067326] [<ffffffffa0a53976>] ? btrfs_run_defrag_inodes+0x96/0x350 [btrfs] [ 58.067337] [<ffffffffa0a42888>] ? btrfs_clean_one_deleted_snapshot+0xb8/0x110 [btrfs] [ 58.067347] [<ffffffffa0a381c0>] ? cleaner_kthread+0x1f0/0x260 [btrfs] [ 58.067357] [<ffffffffa0a37fd0>] ? btree_invalidatepage+0x90/0x90 [btrfs] [ 58.067360] [<ffffffff81051f2f>] ? kthread+0xaf/0xc0 [ 58.067362] [<ffffffff81051e80>] ? kthread_create_on_node+0x110/0x110 [ 58.067365] [<ffffffff814ccc0d>] ? ret_from_fork+0x5d/0xb0 [ 58.067367] [<ffffffff81051e80>] ? kthread_create_on_node+0x110/0x110 [ 58.067368] ---[ end trace 27ae842d91e705b3 ]--- [ 58.067371] BTRFS: error (device dm-0) in add_to_free_space_tree:1049: errno=-5 IO failure [ 58.076599] BTRFS info (device dm-0): forced readonly [ 58.076601] BTRFS: error (device dm-0) in __btrfs_free_extent:6872: errno=-5 IO failure [ 58.085534] BTRFS: error (device dm-0) in btrfs_run_delayed_refs:2978: errno=-5 IO failure then in messages log I found many of these Quote BTRFS error (device dm-0): BTRFS: dm-0 failed to repair parent transid verify failure on 7833087508480, mirror = 2 2020-06-19T02:00:07+01:00 Servidor kernel: [50922.132991] parent transid verify failed on 7833087508480 wanted 9200 found 9148 2020-06-19T02:00:07+01:00 Servidor kernel: [50922.132993] parent transid verify failed on 7833087508480 wanted 9200 found 9148 I tried to do a btrfs --repair but it didn't work and didn't took note of the error. now the server is shutdown and I have to decide what to do next This is a: DSM 6.2.2-24922 Update 4 - Loader version and model: JUN'S LOADER v1.03b - DS3615xs - Using custom extra.lzma: YES - Installation type: BAREMETAL - Intel Server Board S3200SH + Core2Duo E7500 Installed just 2 months ago with shr2 and 6x4tb drives dmesg messages2 Edited June 19, 2020 by Napalmd add photos Quote Link to comment Share on other sites More sharing options...
0 harmakhis Posted June 20, 2020 Share #2 Posted June 20, 2020 hi, follow this tutorial Quote Link to comment Share on other sites More sharing options...
0 Napalmd Posted June 20, 2020 Author Share #3 Posted June 20, 2020 Thanks but I don't think it is the same problem. my raid is fine. it is now resyncing because of a power loss. my problem is the btrfs partition with errors. mdadm --detail /dev/md2 /dev/md2: Version : 1.2 Creation Time : Wed Dec 3 15:53:41 2014 Raid Level : raid6 Array Size : 15609134592 (14886.03 GiB 15983.75 GB) Used Dev Size : 3902283648 (3721.51 GiB 3995.94 GB) Raid Devices : 6 Total Devices : 6 Persistence : Superblock is persistent Update Time : Sat Jun 20 13:29:51 2020 State : clean, resyncing Active Devices : 6 Working Devices : 6 Failed Devices : 0 Spare Devices : 0 Layout : left-symmetric Chunk Size : 64K Resync Status : 59% complete Name : Servidor:2 (local to host Servidor) UUID : 3b1a196c:033ef402:0127fb72:d5d248a6 Events : 5874045 Number Major Minor RaidDevice State 5 8 21 0 active sync /dev/sdb5 1 8 5 1 active sync /dev/sda5 2 8 37 2 active sync /dev/sdc5 7 8 53 3 active sync /dev/sdd5 4 8 69 4 active sync /dev/sde5 6 8 85 5 active sync /dev/sdf5 Quote Link to comment Share on other sites More sharing options...
0 Napalmd Posted June 20, 2020 Author Share #4 Posted June 20, 2020 raid sync come out with no problems: root@Servidor:/tmp# cat /proc/mdstat Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF1] md2 : active raid6 sdb5[5] sdf5[6] sde5[4] sdd5[7] sdc5[2] sda5[1] 15609134592 blocks super 1.2 level 6, 64k chunk, algorithm 2 [6/6] [UUUUUU] md1 : active raid1 sda2[0] sdb2[1] sdc2[2] sdd2[3] sde2[4] sdf2[5] 2097088 blocks [12/6] [UUUUUU______] md0 : active raid1 sda1[0] sdb1[1] sdc1[4] sdd1[2] sde1[3] sdf1[5] 2490176 blocks [12/6] [UUUUUU______] unused devices: <none> root@Servidor:/tmp# cat /proc/mdstat Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF1] md2 : active raid6 sdb5[5] sdf5[6] sde5[4] sdd5[7] sdc5[2] sda5[1] 15609134592 blocks super 1.2 level 6, 64k chunk, algorithm 2 [6/6] [UUUUUU] md1 : active raid1 sda2[0] sdb2[1] sdc2[2] sdd2[3] sde2[4] sdf2[5] 2097088 blocks [12/6] [UUUUUU______] md0 : active raid1 sda1[0] sdb1[1] sdc1[4] sdd1[2] sde1[3] sdf1[5] 2490176 blocks [12/6] [UUUUUU______] unused devices: <none> after that I did this command to unmount volume1 syno_poweroff_task -d then this to mount the logic volume vgchange -ay and then this check: root@Servidor:/tmp# btrfs check /dev/vg1000/lv Syno caseless feature on. Checking filesystem on /dev/vg1000/lv UUID: f850dff8-f678-4c95-bff2-667ffc8ff747 checking extents parent transid verify failed on 7833087508480 wanted 9200 found 9148 parent transid verify failed on 7833087508480 wanted 9200 found 9148 parent transid verify failed on 7833087508480 wanted 9200 found 9148 parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure leaf parent key incorrect 7833105842176 bad block 7833105842176 Errors found in extent allocation tree or chunk allocation checking free space tree parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure parent transid verify failed on 7833087508480 wanted 9200 found 9148 Ignoring transid failure leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted leaf parent key incorrect 7833105842176 could not load free space tree: Operation not permitted found 11437993906176 bytes used err is -22 total csum bytes: 49704 total tree bytes: 78594048 total fs tree bytes: 16384 total extent tree bytes: 77676544 btree space waste bytes: 9937509 file data blocks allocated: 0 referenced 0 I guess I have a really bad problem here right? I already copied recent files changed and I have a old backup of the files but I was wondering if I could salvage this, or should I get rid of it all and reinstall with ext4 partition? Quote Link to comment Share on other sites More sharing options...
0 Napalmd Posted June 20, 2020 Author Share #5 Posted June 20, 2020 I cand mount the volume now, but I don't know if I am doing more damage to the filesystem should I make a btrfs scrub? I really don't know what to do now. maybe I'll make extensive smart test on all drives. root@Servidor:/tmp# mount /dev/vg1000/lv /volume1 root@Servidor:/tmp# ll /volume1 total 936 drwxr-xr-x 1 root root 174 Jun 20 01:09 . drwxr-xr-x 26 root root 4096 Jun 20 01:09 .. drwxr-xr-x 1 root root 18 Apr 2 17:16 @appstore drwxr-xr-x 1 admin users 76 Mar 29 16:21 @database drwxrwxrwx 1 root root 54 Jun 18 12:00 @eaDir drwxr-xr-x 1 root root 3774 Apr 2 00:21 Fotografia drwxr-xr-x 1 root root 24 Mar 29 16:21 @S2S drwxr-xr-x 1 root root 212 Jun 19 09:49 @sharesnap drwxr-xr-x 1 root root 84 Mar 29 16:21 @SynoFinder-log -rw------- 1 root root 953752 Jun 9 10:36 @thumbd.core.gz drwxrwxrwt 1 root root 34 Jun 20 01:09 @tmp drwxr-xr-x 1 root root 228 Apr 25 18:44 Video root@Servidor:/tmp# mount /dev/md0 on / type ext4 (rw,relatime,journal_checksum,barrier,data=ordered) none on /dev type devtmpfs (rw,nosuid,noexec,relatime,size=1010956k,nr_inodes=252739,mode=755) none on /dev/pts type devpts (rw,nosuid,noexec,relatime,gid=5,mode=620,ptmxmode=000) none on /proc type proc (rw,nosuid,nodev,noexec,relatime) none on /sys type sysfs (rw,nosuid,nodev,noexec,relatime) /tmp on /tmp type tmpfs (rw,relatime) /run on /run type tmpfs (rw,nosuid,nodev,relatime,mode=755) /dev/shm on /dev/shm type tmpfs (rw,nosuid,nodev,relatime) none on /sys/fs/cgroup type tmpfs (rw,relatime,size=4k,mode=755) cgmfs on /run/cgmanager/fs type tmpfs (rw,relatime,size=100k,mode=755) cgroup on /sys/fs/cgroup/cpuset type cgroup (rw,relatime,cpuset,release_agent=/run/cgmanager/agents/cgm-release-agent.cpuset,clone_children) cgroup on /sys/fs/cgroup/cpu type cgroup (rw,relatime,cpu,release_agent=/run/cgmanager/agents/cgm-release-agent.cpu) cgroup on /sys/fs/cgroup/cpuacct type cgroup (rw,relatime,cpuacct,release_agent=/run/cgmanager/agents/cgm-release-agent.cpuacct) cgroup on /sys/fs/cgroup/memory type cgroup (rw,relatime,memory,release_agent=/run/cgmanager/agents/cgm-release-agent.memory) cgroup on /sys/fs/cgroup/devices type cgroup (rw,relatime,devices,release_agent=/run/cgmanager/agents/cgm-release-agent.devices) cgroup on /sys/fs/cgroup/freezer type cgroup (rw,relatime,freezer,release_agent=/run/cgmanager/agents/cgm-release-agent.freezer) cgroup on /sys/fs/cgroup/blkio type cgroup (rw,relatime,blkio,release_agent=/run/cgmanager/agents/cgm-release-agent.blkio) none on /proc/bus/usb type devtmpfs (rw,nosuid,noexec,relatime,size=1010956k,nr_inodes=252739,mode=755) none on /sys/kernel/debug type debugfs (rw,relatime) securityfs on /sys/kernel/security type securityfs (rw,relatime) none on /config type configfs (rw,relatime) /dev/mapper/vg1000-lv on /volume1 type btrfs (rw,relatime,space_cache=v2,ordered_extent_throttle=400000,metadata_ratio=50) root@Servidor:/tmp# umount /volume1 Quote Link to comment Share on other sites More sharing options...
0 flyride Posted June 20, 2020 Share #6 Posted June 20, 2020 If your files are accessible read-only, I would not continue trying to repair the filesystem. BTRFS is designed to self-heal while running and if it can't, the underlying corruption probably can't reliably be removed. This is different than ext4 where the only way to correct a problem is through the administrative launch of e2fsck. I would save your files elsewhere, delete the btrfs volume, rebuild it, and copy your files back on. All BTRFS documentation recommend the same. 1 Quote Link to comment Share on other sites More sharing options...
0 Napalmd Posted June 21, 2020 Author Share #7 Posted June 21, 2020 I will do that, but in the meantime I tried to mount the volume in a ubuntu live following synology website instructions, but couldn't, it gave me error wrong fs type, bad option, bad superblock. so I rebooted again to synology. it mounted the volume in read only. I did: syno_poweroff_task -d vgchange -ay mount /dev/vg1000/lv /volume1 btrfs scrub start /volume1 btrfs scrub status /volume1 scrub status for f850dff8-f678-4c95-bff2-667ffc8ff747 scrub started at Sun Jun 21 14:58:16 2020, running for 00:10:55 total bytes scrubbed: 389.50GiB with 0 errors I followed this guide for the last comands https://ownyourbits.com/2019/03/03/how-to-recover-a-btrfs-partition/ Quote Link to comment Share on other sites More sharing options...
0 Napalmd Posted June 21, 2020 Author Share #8 Posted June 21, 2020 Just an update. the scrub failed after about 8tb scanned with no errors, then the partition got mounted read only with errors in log: [17129.062094] BTRFS: bad tree block start 9533940502566446060 7968269844480 [17150.566382] BTRFS: bad tree block start 9533940502566446060 7968269844480 [17150.566692] BTRFS: bad tree block start 9533940502566446060 7968269844480 [17150.567000] BTRFS: bad tree block start 9533940502566446060 7968269844480 [17167.924873] verify_parent_transid: 14 callbacks suppressed [17167.924876] parent transid verify failed on 21004288 wanted 11024 found 8744 [17167.978074] parent transid verify failed on 21004288 wanted 11024 found 8744 [17168.062648] parent transid verify failed on 21004288 wanted 11024 found 8744 [17168.062651] parent transid verify failed on 21004288 wanted 11024 found 8744 [17168.062653] parent transid verify failed on 21004288 wanted 11024 found 8744 [17168.062655] parent transid verify failed on 21004288 wanted 11024 found 8744 [17168.062656] parent transid verify failed on 21004288 wanted 11024 found 8744 [17168.062658] parent transid verify failed on 21004288 wanted 11024 found 8744 [17168.062660] parent transid verify failed on 21004288 wanted 11024 found 8744 [17168.062661] parent transid verify failed on 21004288 wanted 11024 found 8744 [17168.062666] BTRFS error (device dm-0): BTRFS: dm-0 failed to repair parent transid verify failure on 21004288, mirror = 1 [17168.143761] BTRFS error (device dm-0): BTRFS: dm-0 failed to repair parent transid verify failure on 21004288, mirror = 2 root@Servidor:/# btrfs inspect-internal dump-super -f /dev/vg1000/lv superblock: bytenr=65536, device=/dev/vg1000/lv --------------------------------------------------------- csum 0x78417bf4 [match] bytenr 65536 flags 0x1 ( WRITTEN ) magic _BHRfS_M [match] fsid f850dff8-f678-4c95-bff2-667ffc8ff747 label 2020.03.29-15:21:18 v24922 generation 11024 root 7979541921792 sys_array_size 129 chunk_root_generation 10780 root_level 1 chunk_root 20971520 chunk_root_level 1 log_root 0 log_root_transid 0 log_root_level 0 total_bytes 15983750152192 bytes_used 11437993906176 sectorsize 4096 nodesize 16384 leafsize 16384 stripesize 4096 root_dir 6 num_devices 1 compat_flags 0x8000000000000000 compat_ro_flags 0x3 ( FREE_SPACE_TREE | FREE_SPACE_TREE_VALID ) incompat_flags 0x16b ( MIXED_BACKREF | DEFAULT_SUBVOL | COMPRESS_LZO | BIG_METADATA | EXTENDED_IREF | SKINNY_METADATA ) csum_type 0 csum_size 4 cache_generation 18446744073709551615 uuid_tree_generation 11024 dev_item.uuid 24970fb7-de22-4706-8ad2-37a5e16fe640 dev_item.fsid f850dff8-f678-4c95-bff2-667ffc8ff747 [match] dev_item.type 0 dev_item.total_bytes 15983750152192 dev_item.bytes_used 11858421481472 dev_item.io_align 4096 dev_item.io_width 4096 dev_item.sector_size 4096 dev_item.devid 1 dev_item.dev_group 0 dev_item.seek_speed 0 dev_item.bandwidth 0 dev_item.generation 0 sys_chunk_array[2048]: item 0 key (FIRST_CHUNK_TREE CHUNK_ITEM 20971520) chunk length 8388608 owner 2 stripe_len 65536 type SYSTEM|DUP num_stripes 2 stripe 0 devid 1 offset 20971520 dev uuid: 24970fb7-de22-4706-8ad2-37a5e16fe640 stripe 1 devid 1 offset 29360128 dev uuid: 24970fb7-de22-4706-8ad2-37a5e16fe640 backup_roots[4]: backup 0: backup_tree_root: 7968267894784 gen: 11023 level: 1 backup_chunk_root: 20971520 gen: 10780 level: 1 backup_extent_root: 7968267485184 gen: 11023 level: 2 backup_fs_root: 0 gen: 0 level: 0 backup_dev_root: 7968268140544 gen: 11023 level: 1 backup_csum_root: 7968267567104 gen: 11023 level: 1 backup_total_bytes: 15983750152192 backup_bytes_used: 11437993906176 backup_num_devices: 1 backup 1: backup_tree_root: 7979541921792 gen: 11024 level: 1 backup_chunk_root: 20971520 gen: 10780 level: 1 backup_extent_root: 7979541774336 gen: 11024 level: 2 backup_fs_root: 29638656 gen: 8 level: 0 backup_dev_root: 7979542020096 gen: 11024 level: 1 backup_csum_root: 7968267567104 gen: 11023 level: 1 backup_total_bytes: 15983750152192 backup_bytes_used: 11437993906176 backup_num_devices: 1 backup 2: backup_tree_root: 7956994949120 gen: 11021 level: 1 backup_chunk_root: 20971520 gen: 10780 level: 1 backup_extent_root: 7956994834432 gen: 11021 level: 2 backup_fs_root: 29638656 gen: 8 level: 0 backup_dev_root: 7956993409024 gen: 11019 level: 1 backup_csum_root: 7945718988800 gen: 11017 level: 1 backup_total_bytes: 15983750152192 backup_bytes_used: 11437993906176 backup_num_devices: 1 backup 3: backup_tree_root: 7956995506176 gen: 11022 level: 1 backup_chunk_root: 20971520 gen: 10780 level: 1 backup_extent_root: 7956995342336 gen: 11022 level: 2 backup_fs_root: 29638656 gen: 8 level: 0 backup_dev_root: 7956993409024 gen: 11019 level: 1 backup_csum_root: 7956995653632 gen: 11023 level: 1 backup_total_bytes: 15983750152192 backup_bytes_used: 11437993906176 backup_num_devices: 1 I think I'll swap the motherboard, I have one generic intel with i3-2100 it was for another thing but now will be for this, because I don't know what could cause it and don't want it to happen again.... Quote Link to comment Share on other sites More sharing options...
0 kidalabama Posted August 7, 2020 Share #9 Posted August 7, 2020 don't use btrfs xpenology in virtualbox. Quote Link to comment Share on other sites More sharing options...
0 IG-88 Posted August 7, 2020 Share #10 Posted August 7, 2020 (edited) 2 hours ago, kidalabama said: don't use btrfs xpenology in virtualbox. any reason or motivation for writing this here? because On 6/19/2020 at 6:07 PM, Napalmd said: - Installation type: BAREMETAL - Intel Server Board S3200SH + Core2Duo E7500 Installed just 2 months ago with shr2 and 6x4tb drives i use btrfs in my test vm's for xpenology, never seen any problems and why should it make a difference if it run's in virtualbox? Edited August 7, 2020 by IG-88 Quote Link to comment Share on other sites More sharing options...
0 flyride Posted August 7, 2020 Share #11 Posted August 7, 2020 I agree that is a strange comment since it's Syno's recommended default filesystem for some time now. Quote Link to comment Share on other sites More sharing options...
0 kidalabama Posted August 8, 2020 Share #12 Posted August 8, 2020 (edited) because recovery commands not running. only electricity corruption. not hard drive failure. all my data crashed. and can't recover. not enough documentation. data recovery firms want 6000 eur. 4 5TB virtual drive(vdi) raid0 and btrfs. Edited August 8, 2020 by kidalabama Quote Link to comment Share on other sites More sharing options...
0 IG-88 Posted August 8, 2020 Share #13 Posted August 8, 2020 4 hours ago, kidalabama said: 4 5TB virtual drive(vdi) raid0 and btrfs. one difference comes to mind when thinking again, the host os (windows) can be used for caching and that might be a little out of the equation of linux/btrfs and when the power fails unexpectedly there might be a good amount of data missing (my vm's are just for testing and compiling drivers and i do have a backup so i guess i can leave the caching on) i dont know much about btrfs but i had expected it to be recoverable in this situation maybe i should try this out by overwriting some big block of sectors with zeros an see what files i can get out after it 1 Quote Link to comment Share on other sites More sharing options...
0 kidalabama Posted August 9, 2020 Share #14 Posted August 9, 2020 23 hours ago, IG-88 said: Tekrar düşünürken akla bir fark geliyor, ana bilgisayar işletim sistemi (windows) önbelleğe almak için kullanılabilir ve bu linux / btrfs denkleminin biraz dışında olabilir. ve güç beklenmedik bir şekilde kesildiğinde önemli miktarda veri eksik olabilir (benim sanal makinelerim sadece sürücüleri test etmek ve derlemek içindir ve bir yedeğim var, bu yüzden önbelleği açık bırakabilirim) btrfs hakkında pek bir şey bilmiyorum ama bu durumda kurtarılabilir olmasını bekliyordum Belki bunu büyük bir sektör bloğunun üzerine sıfırlar yazarak denemeliyim ve ondan sonra hangi dosyaları alabileceğimi görün Yes that is true host io cache crashing btrfs system. If you are disable host i/o cache system very very very slow. i can't understanda virtualisation system anything. Quote Link to comment Share on other sites More sharing options...
Napalmd
This is a:
dmesg messages2
Edited by Napalmdadd photos
13 answers to this question
