aniel
help expanding a shr one disk volume
am trying to follow
and
 in regards to:
but i cant seem to be able to extend the volume to use the whole disk on a cloned partition, if anybody know how to do this or know what am doing wrong i will appreciate it.
Share this post
6 answers to this question
Which part specifically are you having trouble with?  Can you post some commands and results?
Share this post
thank you very much for replying. attached is a screenshot of where i am getting stuck and the same thing happens whether i clone the disk (vmdk, vhd virtual disk) or i use the "migration assistant" which i think also clone the volume.
Share this post
You have an non-standard configuration on this disk.  In the example, partition #3 and #5 overlap.  This may be a primary/extended partition configuration (which is not supported by DSM as far as I know).
It MIGHT work if you also deleted partition #3 and then explicitly added the new partition at LBA 9453280, but if the internal configuration at the start of an extended partition is not the same as a primary, it might also make your data inaccessible.
Honestly, I have no idea if it would work.  Have a backup.
Share this post
Am using a 1 disk shr configuration and data is non important in this case
Edited by aniel
Share this post
am happy to report that after doing what u recommended it worked. i went ahead and deleted partition 3, the added a new primary partition with firs sector "9453280" and follow the rest of steps for lvm and that did the trick, thank you very much, god bless you.
Edited by aniel
Share this post
one more question. how could i resize/shrink the volume.
Share this post
Answer this question...
