warappa 0 Posted June 18, 2020 Share Posted June 18, 2020 (edited) It tried many ways to make DSM setup use my pre-formatted GPT disk (no partitions, formatted with MiniTool Partition Wizard). Even if I provide it with a GPT disk, as soon as it finishes install the disk is MBR (parted reports "msdos"). DSM reformats it as MBR during setup. If I then take the disk, plug it in my PC and convert it to GPT (MiniTool Partition Wizard) and plug disk again into NAS, the NAS won't boot anymore. (I have no graphic card built in so I can't see any errors). Does this mean that my NAS won't be able to use disks with more than 2TB? Loader: 1.0.3b (Jun) Image: DSM_DS3617xs_25426 Hardware: Acer EasyStore H340 Edited June 18, 2020 by warappa Quote Link to post Share on other sites
flyride 453 Posted June 18, 2020 Share Posted June 18, 2020 if the drive is <2TB, it will be set up with MBR. If the drive is bigger than the mbr limit, it will be set up with gpt Is the drive you are testing with smaller than the MBR limit? Quote Link to post Share on other sites
warappa 0 Posted June 18, 2020 Author Share Posted June 18, 2020 Hi @flyride, yes, it is below this size, but it's just a test HDD for now (256GB). It will be 2x 4TB in the final build. Good to know that it will switch to GPT if required. A little bit surprised why GPT is not the default in 2020... Tanks for your insight! Quote Link to post Share on other sites
flyride 453 Posted June 18, 2020 Share Posted June 18, 2020 I think it's to help with backward/forward compatibility of disk sets between older and newer Synology hardware. Quote Link to post Share on other sites
