Transcoding and Face Recognition(People and Subjects) Issue Fix in Once
Jlozde
I had couple of troubles with my installition with a good google search, I have found out couple of fixes. I have combined them into one script. This will be easier for many beginners. I am not really good Bash script writer but this is just fine. I have tried couple of times.
Tried on DSM 6.2.3 with Juns 1.04 Loader on a Vm.
Use it with caution.
https://github.com/Jlozde/Xpenology-6.2.3-EasyFix
Usage:
  1. wget https://raw.githubusercontent.com/Jlozde/xpenology-6.2.3-easyfix/master/patch.sh
  2. chmod +x patch.sh
  3. ./patch.sh
  4. reboot & reindex
Thanks to;
Edited by Jlozde
  • Like 3
  • Thanks 2
  • 3 months later...
  • 1 month later...
  • 1 month later...
Detected DSM version: 6.2.3 25426-3
Patch for DSM Version (6.2.3 25426-3) AVAILABLE!
/usr/syno/bin/synocodectool
Restored synocodectool and valid backup detected (DSM 6.2.1-23824-0_6.2.3-25426-3) . Patching...
xxd: /usr/syno/bin/synocodectool: Text file busy
Please help!!!
Please help!!!
It looks like /usr/syno/bin/synocodectool is used. So please disable apps can use that like moments, video and so... and try again.
  • 1 month later...
I run the script with no problem, sadly now my NAS doesn't start anymore.
The screen looks completely normal, then it says look at find.synology.com but in the network no nas is visible. I also cant reach it direct with the fixed IP.
Anyone an idea what could happened? I am pretty ******* right now, dont understand what could go that wrong....
  • 1 month later...
hey all
i have apply this patch to my N54L
transcoding and HEIC picture in moments work fine now (thanks first )
but the Face Recognition(People and Subjects) are still blank
i have already reboot and re-index still the same
anyone have the similar situation?
machine info
N54L with DMS 6.2.3-25426 update 3
loader ds3615xs with 1.03b
moments 1.3.6-0716
  • 5 weeks later...
Hello, that half works for me.
  I still encounter the problem on thumbnails and frame recognition, but I no longer have a problem with video transcoding.
  However, I did get the "success" message after running the command: ./patch.sh. I rebooted, reindexed, checked the status of my serial number with the command "sudo vi /usr/syno/etc/codec/activation.conf" (the serial number now seems "valid"), but it doesn't does not work.
  Has anyone encountered the same problem please ?
  Thank you.
  PS :
  Jun’s Loader v1.04b DS918+
  DSM 6.2.2-24922 Update 6
  • 3 weeks later...
Hello,
  am I the only to encounter this problem please ?
  Video Transcoding is working on Video Station, but no thumbnails and face recognition on Moments.
  Thank you.
  Kévin
  PS :
IN DSM7.0 DS918
2021-08-19T12:57:25+08:00 U820 synofoto-face-extraction[5952]: /source/synophoto-plugin-face/src/face_plugin/lib/face_detection.cpp:214 Error: (face plugin) load network failed
2021-08-19T12:57:25+08:00 U820 synofoto-face-extraction[5952]: uncaught thread task exception /source/synofoto/src/daemon/plugin/plugin_worker.cpp:90 plugin init failed: /var/packages/SynologyPhotos/target/usr/lib/libsynophoto-plugin-face.so
Can you upgrade
