smilenkovski 2 Posted June 13, 2020 Share Posted June 13, 2020 After my WD HDD reporting bad blocks very often, I decide to replace with Ironwolf 8TB drive, I had a spare sata and bought two Seagate Ironwolf disks.. I have backup of my files and start from scratch. Installed dsm 6.2.3, made a pool , volume. Dsm start Parity consistency check and I ' ve got this message several time: An unknown error occurred, so hard disk 1 was restarted. If you often see this message, please disable disk write cache. on both disks. After disabling the write cache there are no messages, but after reading here and there I think that that is a no way to go. Any advice? Quote Link to post Share on other sites
IG-88 665 Posted June 13, 2020 Share Posted June 13, 2020 anything about your hardware (board, cpu, added storage controller), the dsm type (918+?) or a added extra.lzma? Quote Link to post Share on other sites
smilenkovski 2 Posted June 13, 2020 Author Share Posted June 13, 2020 Sorry, newbie error MB Gigabyte H370M-DS3H CPU intel i3 8100 Sata controler onboard. Bootoloader 1.04b 918+ extra lzma v0.11_test Quote Link to post Share on other sites
