thecatman 0 Posted June 11, 2020 Share Posted June 11, 2020 Hi! I have some problems to run four dsm on esxi 6.7. Do you think should i change the mac address? to connect to the dsm via firefox i have to do several attempts unless you connect immediately after the restart of the virtual machine. with synology assistant I find only the latest dsm that I restarted. if i had to change the mac address for each virtual machine, both in the grub.cfg file and in the virtual network card setting, then will dsm work regularly? sorry for my english. thanks. Quote Link to post Share on other sites
