WARNING - do not flash LSI-9201-16i HBA with P20
snoopy78
HI @ all,
just a warning for those who, like me, use the LSI 9201-16i HBA.
DO NOT! flash the latest FW P20, as there is an bug in it (LSI confirmed this AFTER my system crashed).
Use of the P19 FW seems to be fine and is recommended by LSI.
Issue is reporting I/O errors randomly on your drives, so at one point the DSM will throw all volumes out and mark the drives as faulty, which makes an normal recovery via WebGui impossible.
Manual revovery via CLI is needed and can be successful.
BR
snoopy78
i haven't made it by myself.. luckily one of my colleagues were able to help me ^^
my setup for each volume is max. 4 drives using SHR, so we had to do follwoing things:
( one of my desaster szenarios was to have an spare System with HBA and xpenology available which we used, but original system should be fine too )
my drives (4) were labelled as sdg5/sdh5/sdgi5/sdj5
=> stop the LVM
=> add the drives back to raid
=> rebuild
=> restart LVM/Server
these should be the commands for my system...!! be adviced, know what you do or ALL is gone !!
mdadm --manage --stop /dev/vg1002/lv
mdadm --examine /dev/sdg5
mdadm --examine /dev/sdi5
mdadm --examine /dev/sdh5
mdadm --examine /dev/sdj5
vgchange -an vg1001
mdadm --stop /dev/md3
mdadm --query --detail /dev/md3
cat /proc/mdstat
mdadm --verbose --create /dev/md3 --chunk=64 --level=5 --raid-devices=4 /dev/sdi5 /dev/sdj5 missing /dev/sdh5
mdadm --manage /dev/md3 --add /dev/sdg5
cat /proc/mdstat
THIS is LSI's reply to my issue report:
There is an issue with P20. We are expecting a fixed version any day now.
I recommend you downgrade to P19 until then.
You have to erase P20 to downgrade and this can only be done in DOS or UEFI.
Doc attached.
Data Center Solutions Group
Avago
4165 Shackleford Road
Norcross, GA 30093
BR
  • 7 months later...
when you donwload the firmware (f.e. DOS version) then there is a manual included....
f.e. 9201-16i
http://docs.avagotech.com/docs/12350436
all required commands are in there too
just ned to delete the firmware before installing the new one as AVAGO/LSI told me
Doc attached.
http://sc836.lindem.de/update.pdf
br
snoopy78
In DOS i get the follow error when trying to launch SASFLSH.exe:
ERROR: Failed to initialize PAL. Exiting Program
...and EFI Shell hangs when trying to --listall... I guess I'll have to try DOS on a NON-UEFI PC.
Edit: Flashed the HBA from DOS on a NON-UEFI PC and it worked right out of the box. Hopefully the change in FW doesn't screw up the volume. Thanks for the tip on downgrading, highly appreciated! :smile:
I'll try to stress test the HBA later this weekend to see if this actually fixes the I/O issues...
Nope, all drives are new and tested.
The only thing it might be is a bad cable... even though I've now replaced all of them too without solving the issue...
No idea, but as this only happens on the initiation of a data scrub or other really high I/O activities, I guess it's nothing to really worry about for now. Will look into it in the days to come.
This is a heat-related issue.
It has nothing to do with firmware revision except that perhaps P20 is more sensitive to high-heat conditions. At the same time, it could just be that P20 'runs' that much more hot.
In any case, install a fan on to or over top of your HBA's PU.
