Schnapps Posted May 22, 2013 #1 Posted May 22, 2013 Hi guys, I've decided to open a thread specially for the UPS problems. Maybe by collaborating we can make these issues go away. My issue: APC ES700 is not known by my XPEnology
TheSpherE Posted May 22, 2013 #2 Posted May 22, 2013 Back-UPS ES 550 not seen ... Here : https://drive.google.com/folderview?id= ... aring#list i have try : microserver-dsm-4.2-02.05.2013.img modules-4.2-02.05.2013.tar.gz
Schnapps Posted May 22, 2013 Author #3 Posted May 22, 2013 Well... 1). i don't have a Microserver 2). don't know what to do with the 2 files. do you want me to write that img to my nas installation? 3). what to do with the modules? How to load them? What for?
damien51 Posted May 23, 2013 #4 Posted May 23, 2013 i bought an usb3 controlleur low profile card and plug my ups on it. problem solved (hp nl40)
ixzit Posted June 18, 2013 #5 Posted June 18, 2013 i bought an usb3 controlleur low profile card and plug my ups on it. problem solved (hp nl40) thx , it works (hp n36l+dlink usb3 card+eaton 5110 ups)
abesus Posted June 19, 2013 #6 Posted June 19, 2013 i bought an usb3 controlleur low profile card and plug my ups on it. problem solved (hp nl40) thx , it works (hp n36l+dlink usb3 card+eaton 5110 ups) Could you give the full name of working usb3 controller (full model name). Thanks in advance
ixzit Posted June 19, 2013 #7 Posted June 19, 2013 Could you give the full name of working usb3 controller (full model name). Thanks in advance D-Link DUB-1310
totalnas Posted June 27, 2013 #8 Posted June 27, 2013 Hi, To fix your UPS problems, first read: http://xpenology.com/forum/viewtopic.php?f=2&t=917 Aditionally, check the UPS with a recent LiveCD distribution of Linux (like Ubuntu). If your UPS is detected/supported in Linux, you can enable it on the XPEnology!
stanza Posted June 30, 2013 #9 Posted June 30, 2013 Also might be worth checking the usb module is correct post #2 here http://xpenology.com/forum/viewtopic.php?f=2&t=915
jncave Posted June 30, 2013 #10 Posted June 30, 2013 I have got my N54L to recognise my APC 350 by following the instructions from totalnas here http://xpenology.com/forum/viewtopic.php?f=2&t=915
