strat 0 Posted May 15, 2020 Share Posted May 15, 2020 I've currently got a DS918+ and have been extremely happy with it. However it's almost at capacity. I've come across some very cheap 6TB SAS drives so plan to build an Xpenology build with 8 X 6TB SAS drives to replace the DS918+. A few questions if I may: I'm planning on the following build AsRock J3455B-ITX 16GB DDR3L Perc H310 in IT Mode 8 X 6TB SAS 3.5" Drives SilverStone DS380 Silverstone SFX 450W Power Supply The Asrock has the same CPU as the DS918+. Will I have any issues with: Hardware Transcoding (Plex) Running Docker (I assume not) Surveillance Station (I have an official license for 3 cams. Not sure if it can be moved across? If it works?) Is there anything I need to be aware of? Limitations compared to my DS918+? I know the specs are almost exactly the same, I just need to know if there are any concerns I should be aware of? Would love some advice before I pull the trigger on the parts. Thanks so much. Cheers Quote Link to post Share on other sites
yetithebouncer 0 Posted May 15, 2020 Share Posted May 15, 2020 Why not buy the ASRock J3455-ITX, has 4x sata3 slots? and M2 for future use maybe? Quote Link to post Share on other sites
strat 0 Posted May 15, 2020 Author Share Posted May 15, 2020 11 minutes ago, yetithebouncer said: Why not buy the ASRock J3455-ITX, has 4x sata3 slots? and M2 for future use maybe? Thanks for the suggestion. I primarily went with the B version as it's available at a local store. I was able to find the version you're suggesting for only slightly more, however it looks like it only has PCIE X1 rather than X16. The Perc H310 SAS card I have is X4 I believe so won't fit in the J3455 board.. And while M2 is nice, it's not something I can see myself needing in this nas. Thanks for the suggestion though. Quote Link to post Share on other sites
IG-88 773 Posted May 15, 2020 Share Posted May 15, 2020 1 hour ago, strat said: AsRock J3455B-ITX ... Perc H310 in IT Mode the pcie slot is just pcie 2.0 2x slot, so you will not see more then 1000MByte/s for all disks on this controller you might be better off with y micro atx board, more pcie slots and with a gigabyte 365M HD3 its just slightly deeper then a itx and its wider for 4 pcie slot (it also has 6xsata and m.2) 1 hour ago, strat said: Perc H310 SAS card I have is X4 I believe imho 8x Quote Link to post Share on other sites
