harmakhis Posted May 9, 2020 #1 Posted May 9, 2020 hi, followed those two tutorials https://www.dsebastien.net/2015/05/19/recovering-a-raid-array-in-e-state-on-a-synology-nas/ https://blogs.dbcloudsvc.com/life/fixed-the-crashed-basic-volume-of-synology-nas/ and applying on my BASIC 1HDD crashed volume # Stop all NAS services except from SSH > sudo syno_poweroff_task -d $ sudo mdadm --detail /dev/md5 /dev/md5: Version : 1.2 Creation Time : Mon May 4 20:54:01 2020 Raid Level : raid1 Array Size : 5331334464 (5084.36 GiB 5459.29 GB) Used Dev Size : 5331334464 (5084.36 GiB 5459.29 GB) Raid Devices : 1 Total Devices : 1 Persistence : Superblock is persistent Update Time : Sun May 10 00:40:01 2020 State : clean, FAILED Active Devices : 1 Working Devices : 1 Failed Devices : 0 Spare Devices : 0 Name : SynoNas:5 UUID : 6bbaadf9:fccd6e69:66518019:2ee66ad8 Events : 22 Number Major Minor RaidDevice State 0 8 35 0 faulty active sync /dev/sdc3 $ sudo mdadm --examine /dev/sdc3 /dev/sdc3: Magic : a92b4efc Version : 1.2 Feature Map : 0x0 Array UUID : 6bbaadf9:fccd6e69:66518019:2ee66ad8 Name : SynoNas:5 Creation Time : Mon May 4 20:54:01 2020 Raid Level : raid1 Raid Devices : 1 Avail Dev Size : 10662668960 (5084.36 GiB 5459.29 GB) Array Size : 5331334464 (5084.36 GiB 5459.29 GB) Used Dev Size : 10662668928 (5084.36 GiB 5459.29 GB) Data Offset : 2048 sectors Super Offset : 8 sectors Unused Space : before=1968 sectors, after=32 sectors State : clean Device UUID : 524c0a00:3ef4e283:2d9a4151:0764a8ed Update Time : Sun May 10 00:40:01 2020 Checksum : 1f2a1c29 - correct Events : 22 $cat /proc/mdstat md5 : active raid1 sdc3[0](E) 5331334464 blocks super 1.2 [1/1] [E] $ sudo mdadm --stop /dev/md5 mdadm: stopped /dev/md5 $ sudo mdadm -Cf /dev/md5 -e1.2 -n1 -l1 /dev/sdc3 -u6bbaadf9:fccd6e69:66518019:2ee66ad8 mdadm: /dev/sdc3 appears to be part of a raid array: level=raid1 devices=1 ctime=Mon May 4 20:54:01 2020 Continue creating array? y mdadm: array /dev/md5 started. admin@SynoJeux:/$ cat /proc/mdstat Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF1] md5 : active raid1 sdc3[0] 5331334464 blocks super 1.2 [1/1] $ sudo e2fsck -pvf -C0 /dev/md5 and voilaaaaaaa 1 1 Quote
dave Posted July 27, 2020 #2 Posted July 27, 2020 (edited) Thank you very much! 👍🤟 I had the same issue and your tutorial help me to resolve it ! And BTW, give me a better understanding of the raid operation. Only things I changed was the create command : sudo mdadm --create --force /dev/md4 --level=1 --metadata=1.2 --raid-devices=1 /dev/sde3 for a better understanding 😊 Edited July 27, 2020 by dave Quote
nadiva Posted September 3, 2024 #3 Posted September 3, 2024 I've used this solution. The stop commands will stop even SSH, it didn't even work from Cockpit VM console as reboot happened. Luckily we have Arc recovery mode to do just the 2 last commands: synospace --stop-all-spaces synopoweroff -d mdadm -Sf /dev/md0 mdadm -AfR /dev/md0 /dev/sata1p1 [E] -> [U] instantly. Quote
