HondaFireblade Posted May 7, 2020 #1 Posted May 7, 2020 Hi i've a problem with usb 3.0 to eth adapter (Realtek idVendor = 0x0bda idProduct = 0x8153). In info center i see the adapter but i see only the lan1 (eth on the mobo). Why? Can you help me? Thanks Quote
0 IG-88 Posted May 9, 2020 #2 Posted May 9, 2020 seems to be a RTL8153 (usb 3.0 gigabit ethernet) driver would be r8152.ko my crystal ball gazing is a little rusty - mmhh, there is lots of mist and just some vague shapes - but i guess you will need a better extra.lzma with more and newer drivers? https://xpenology.com/forum/forum/91-additional-compiled-modules/ also a reboot might be needed after adding a usb network adapter Quote
0 HondaFireblade Posted May 17, 2020 Author #3 Posted May 17, 2020 Thank, I've copied the file in /usr/lib/modules and now it's ok. Quote
HondaFireblade
Hi
Thanks
2 answers to this question
