DSM DSM 6.2.1 running on ESXi, how to power off from host?
mrme01
Hi folks,
I finally managed to get DSM running!
My server cannot be on 24/7, and it would be inconvenient to have to log into multiple web interfaces just to shut down the box. Is there any way to gracefully shutdown my DSM VM from ESXi?
Google doesn't seem to return much, if at all. Nor does the search function on the forums.
Thanks! :-)
Actually the package that is cross compiled to do this was authored by VMWare, is called vmtools and it is available on most guest OS’s.
I can understand the confusion if you are not familiar with it (but somehow familiar with the function).
No sarcasm here either. All good!
