Driver extension jun 1.03b/1.04b for DSM6.2.3 for 918+ / 3615xs / 3617xs
6 minutes ago, DSfuchs said:
Must I take an other J3455 systemboard, or a Loader v1.03b DS3615xs? if so, which file version should it be (rd.gz zImage extra.lzma extra2.lzma) on partition 2 of the boot-stick.
is there a non-virtualized Xpenology solution for 2.5GbE realtek nic?
1 hour ago, IG-88 said:
me too, you dont give much detail about your hardware, what cpu/systemboard, any additional controllers? is the r8125 a added 2nd nic or onboard?
try using synology assistant and check the versions of loader
recoverable can be a mismatch of installed dsm and loader, like having 6.2.3 on disk and bootig with a vanilla loader from jun's image that contains the kernel of 6.2.0
letting dsm fix it does result in a bootable system - but maybe your state is different
if you see 6.2.4 with assistant then start from scratch, copy img of the loader again and remove partitions from disk
for what reason you put a diffrent dsm 6.2.2 on the loader? it sure does not work as the drivers for 6.2.2 and 6.2.3 are different
just stick to the versions in this thread, if you want to copy a kernel to the loader then use a matching 6.2.3 files
I hope my new information below is helpful.
1 hour ago, DSfuchs said:
I'm looking for any configuration that runs from scratch/zero with RTL8125 nic.
my suggestion would have been to install with the onboard nic and after dsm is running checking the r8125
its much easier to look for problems in a running system by checking /var/log/dmesg
the alternative might be a serial console and some system dont have a com port anymore and its also more difficult to do
adding changing driver can be easy, copy newer extra.lzma to the loader, boot and you are done
if dsm/xpenology is to cumbersome maybe try open media vault, dsm is a closed appliance, omv is a real linux based on a major distribution
- versions of loader is 6.2.2.24922 according to your instructions on page 1
no, the whole thread and even the topic is about 6.2.3, there is a extra thread for 6.2.2 and in the 1st post in this 6.2.3 thread i tried to explain the difference and that its not meant to be used wit 6.2.2, when you update from 6.2.2 to 6.2.3 you will need new drivers as the 6.2.2 drivers are incompatible and the drivers (added drivers) are in the extra.lzma
i refer to the 6.2.2 as of reading it and that's about the procedure when updating or how to handle the files in general
its not a howto or tutorial more grown and pieces added,
no, might even be harder as 1.03b needs csm mode in uefi bios and also legacy/non-uefi usb boot device
sure, the extra.lzma's from the 1st post have r8125 drivers, not the latest but at least most of the r8125 cards will work and some people use r8125 cards
6.2.3 is still the my project. 2.5GbE USB-Sticks are working well Xpenology and my native ARM DS214+ with the available spk.
Now I will have a look to a running system by checking /var/log/dmesg
Yes, but it works only for the first boot and installation.
These few people all seem to be using virtualized Xpenology to me.
if using jun's loader with its 6.2.0 kernel then it would imply the driver is not working with 6.2.3 as when installing the kernel of 6.2.3 gets copied to the loader and on next boot it's kernel 6.2.3 with the driver (extra.lzma), but the thing is the driver is made for 6.2.3, it might work with 6.2.0 but should work with 6.2.3
it would be possible to see that in dmesg if 6..2.3 starts and r8125 is just used as additional 2nd nic
I only tried to start with the instructions on page 1. This has nothing to do with 6.2.3. That is where the journey should go. Please indicate any combination that should work. I try all of them.
Any information here going 6.2.3 with DS3615xs loader?
i already answered this
https://xpenology.com/forum/topic/28321-driver-extension-jun-103b104b-for-dsm623-for-918-3615xs-3617xs/?do=findComment&comment=198248
it does, this whole thread is about 6.2.3, not any other older version, there are other threads with dsm version numbers like this one specific for 6.2.2
https://xpenology.com/forum/topic/21663-driver-extension-jun-103b104b-for-dsm622-for-3615xs-3617xs-918/
i did that:
On 4/20/2020 at 2:56 AM, IG-88 said:
i only did test a new created loader from 1.04b image file with zImage and rd.gz from "DSM_DS918+_25426.pat" and the new extra.extra2, it will also work with the 6.2.0 kernel that is by default in the 1.04b image
I try all of them.
its a complex matter and synology has no intentions to make it smooth for us
as already stated, its not a tutorial or step by step how to, you could also read 1st posts of the threads for loader 1.03b/1.04b to get a better picture, on long term its better to understand why its working or not
Hi @IG-88,
I have a quick general question, to the best of your knowledge, is there case where overwriting the rd.gz and zImage files with the ones from the Synology PAT (DSM) files could cause issues? Could we default to overwriting the usb partition 2 rd.gz and zImage files regardless of installation type (every time we create a bootable usb device)?
Hopefully this question makes sense and if you need any elaboration let me know.
Thanks
On 3/31/2021 at 4:07 AM, timi691222 said:
Can DS918+ add LSI-9305 driver?
the driver in 0.13.3 supports the following
1000:0064
1000:0065
1000:006E
1000:0070
1000:0072
1000:0074
1000:0076
1000:0077
1000:007E
1000:0080
1000:0081
1000:0082
1000:0083
1000:0084
1000:0085
1000:0086
1000:0087
1000:0090
1000:0091
1000:0094
1000:0095
1000:0096
1000:0097
and here is the list
https://pci-ids.ucw.cz/read/PC/1000
your is this one https://pci-ids.ucw.cz/read/PC/1000/00c4 ?
the lsi sas drivers in 918+ are problematic as you can see in the 1st post, i would recommend using 3617 as it comes with newer drivers from synology
this would be whats supported in 3617 right now (and with smart and serial and without problems about that it might kill your raid if disk hibernation in on)
so you 1000:00c3 would be supported in 3617
1000:0064
1000:0065
1000:006E
1000:0070
1000:0072
1000:0074
1000:0076
1000:0077
1000:007E
1000:0080
1000:0081
1000:0082
1000:0083
1000:0084
1000:0085
1000:0086
1000:0087
1000:0090
1000:0091
1000:0094
1000:0095
1000:0096
1000:0097
1000:00AA
1000:00AB
1000:00AC
1000:00AD
1000:00AE
1000:00AF
1000:00C0
1000:00C1
1000:00C2
1000:00C3
1000:00C4
1000:00C5
1000:00C6
1000:00C7
1000:00C8
1000:00C9
1000:00D0
1000:00D1
1000:00D2
1000:02B0
On 3/31/2021 at 4:56 PM, sojab0on said:
cant we try to pass the nvidia dedicated gpu dev ids trough in an extra driver for the jun loader and test it with passtrough of a gpu to see if that can make it work for transcoding as well
please use the forum search to find the attempts in that direction, its not that easy, its more then just a driver (*.ko file) that would be needed
i have this one on my list but there might bo one or two more threads
https://xpenology.com/forum/topic/22272-nvidia-runtime-library/
it looked like it was possible to just use the drivers from a "compatible" dsm version but as already stated it gets way more complicated as ffmpeg and other are involved,way more then i'm willing to do as i don't need that, i provided drivers and ways on how to build them, so other people with enough time to spare can push this forward if there is enough will to do it
every case where it does not match the installed version (on disk, raid1 over all disks) it a issue
usually dsm will not boot and offer a repair that usually copy's the kernel files from disk back to the loader
i do mention this i the 1st post (afaik), as i'm only offering the extra/extra2 its up to the user to copy the (6.2.3) files to the loader, before using it
how would you want to do that automatically? in theory its possible to offer pre-made (modded) loader with newer kernel files and matching extra/extra2
i'm not doing this for legal reasons, any one is free to offer this, either jun nor me have copyrights on that stuff and as long as there is a decent description with that loader making clear in what way its different from jun's original and giving the version of the extra/extra2 thats used i dont think there is anything to complain about
i dont mind if anyone uses the extra/extra2, i would prefer to see a version number, not my name, to be used with it to give people a way to see if its the recent version and being able to read about problems and quirks
i've seen my extra/extra2 been used in some stuff from china (like 1019+ loader) and i dont mind that, its free to use for everyone and if anyone tells people its his work then i dont mind too
at some point i started to add checksums to the download to make sure people can check if its the version from me or anything modded and i may add some version text file to the extra/extra2 to make it easier to check what version is in use (extra/extra2 can easily be unpacked with 7zip to check a text file)
so if you feel the need to offer loaders for pre configured for 6.2.3 feel free to do so and open a thread in the loader section (might need to be approved by a mod so it can be a few days before everyone can see it)
btw before doing so PM me, i have a way to overcome the read/write problems in win10 so the offered loader would also be easier to handle as both partitions could be used freely in win10, auto mount drive letters and working without "as administrator" (as in older win10 version)
 Thanks @IG-88, i've been working on automating the creation of the Xpenology bootable usb drive in OSX using Ansible and as I was automating the process I thought "why not just overwrite the rd.gz and zImage files every time you create the USB disk". So my question was out of concern that I could possibly hit an edge case where this wasn't the fact. From what I understand from your response is, this shouldn't be an issue.
I went out and bought a i3-10100 because it was reported to work on 918+ for transcoding Plex.
Unfortunately i cannot get it to work at all.
Steps I've done:
1. installed 918+ using the 1.04b loader and 13.3 driver file (because I have a 8125 2.5 GB nic.) Install goes off without a hitch, works perfectly.
2. I downloaded the most recent update to the i915.ko file "918plusdsm623u3i915mod2_1"
3. Extracted it, copied over an folder share then to /usr/lib/modules/. I give it the same properties as all the other .ko files (644) and changed ownership of it to root/root.
4. Rebooted, system does show the loader grub and the following screen. About 5s later the screen shuts off. And the system is not responsive at all. I am guessing the system hangs.
So i reinstalled the system and instead of copying to /usr/lib/modules, I copy it to /root and then set the chmod and chown as the others. Then as I have seen others in this thread do, i used the insmod command to install it. The screen goes black and that is all she wrote, system is now locked up again.
I have tried all 3 versions of the moded i915.ko file and they all result in the same crash/lock.
If I put in a discreet video card, the system boots and runs normally. I can then remove the i915.ko and Xpenology works again without issue.
Is the 13.3 driver set at fault here? Do i need to use an older version? I don't know how far back I would need to go to keep the rtl8125 driver.
Edited by rok1
  • Like 2
The same CPU and the same problem. It's a headache!😥
Edited by Three
that it happens with all 3 versions makes it odd, only one version containing the right device id should do anything the other should just just pass as it has no device 9bc8 in the driver to lock on
it does work that way with synology's original i915.ko or you would not be able to boot at all
the version you used is from/for U3 (not tested if it makes a difference when using it with plain 6.2.3), check if you have 6.2.3 u3 installed
the "older " version are for original 6.2.3 and u2 (as in the description of the downloads)
Edited by IG-88
Definitely have u3 installed (but tried manually installing the baseline 6.2.3 and subsequent updates by blocking internet, then using one of the earlier mod drivers from the first post, same outcome). A fresh install of XPE automatically downloads/updates 6.2.3u3. (although I think I was getting 6.2.4 from install at one point this morning as the system would fail to boot on first reboot, I went through about 10 reinstalls before I just started with the 6.2.3 pat from Synology and let it update to u3 on its own.)
The good news is I can recover the system easily by installing a discreet gpu as it disables the onboard iGPU, so all is not lost for testing. The lockup I experienced with this 10100 is the same that happened with the 10700. I wish Xpe would do proper log management (renaming .1, .2 etc) so we could see where it's hitting a snag
part of the driver is loading:
root@Xpenology:~# lsmod | grep i915
i915                 1238212  0
drm_kms_helper        119660  1 i915
drm                   304204  2 i915,drm_kms_helper
iosf_mbi                4234  1 i915
fb                     34811  2 i915,drm_kms_helper
video                  25321  1 i915
backlight               6096  2 i915,video
button                  4692  1 i915
i2c_algo_bit            5328  2 sfc,i915
I take that back, I was able to recover logs from when when it locked up. You can look and see if any of it is relevant.
oops panic
Edited by rok1
this gpu is different 9bc5 and thats the same as the already confirmed non working from 10900
for the 10100 you can try if it make a difference when you disable vt-d in bios and if the video out is connected to a monitor or not
i dont know if newer i915 driver iterations might have a separate firmware for the comet lake's gpu's, if so we could try to load these dmc firmware instead of the old kaby lake we are using now (i'm not sure about the cnl firmware already in the driver and where that one is used)
maybe "cnl_dmc_ver1_07.bin" or "icl_dmc_ver1_09.bin" could be used
https://git.kernel.org/pub/scm/linux/kernel/git/firmware/linux-firmware.git/tree/i915
i would need to read a little about the newer gpu's
I have read on the web that the 10th gen and newer have different firmware from 9series and earlier, and that might be part of the problem.
that what i'm not so sure about, as its still gpu gen 9.5 in comet lake
https://en.wikichip.org/wiki/intel/microarchitectures/comet_lake#Architecture
intel has no new DMC (Display Microcontroller) firmware for CML only GUC (Graphics microController) and HUC  (HEVC/H.265 microController) and synology only uses DMC firmware with its driver (firmware files in *.pat)
the i915 driver itself references to more kbl firmware files then just the DMC file (kbl_dmc_ver1_04.bin)
kbl_guc_ver9_39.bin
kbl_huc_ver02_00_1810.bin
they where not needed for i3-9100 cpu's to have transcoding working so not to expect that it will be the case for the same gen gpu in comet lake
Hey, all! Has anyone managed to enable HW decoding on i3-10100T (0x9BC8) builds? Here has some negative feedback.
Hardware:
CPU: i3-10100T
MB: Asrock H470M ITX-ac (has built-in rtl8125gb and intel 219-v ethernet ports)
BIOS: CPU C state disabled, VT-d enabled, Primary video output set to onboard and no dGPU installed
Software:
USB bootloader: DS918+_6.23-25426-1.04b.img (installed v0.13.3 extra.lzma/extra2.lzma prior to installation)
System: 6.23-25426-up3
How I replaced i915.ko
  1. Create a share folder and put i915.ko (for 9BC8 up3) into it
  2. sudo -i
    # enter password
    rm /usr/lib/modules/i915.ko
    cp /volume1/share/i915.ko /usr/lib/modules/i915.ko
    chmod 644 /usr/lib/modules/i915.ko
    chown -R root:root /usr/lib/modules/i915.ko
    reboot
Issue:
  1. Rebooting screen
  2. Showing BIOS boot-up screen
  3. Jun's mod selection screen
  4. Jun's mod Intro screen (saying this mod is brought to you by...)
  5. (After about 10 seconds)
  6. Screen turns black but not losing signal, Ethernet leds are still lit
What I have tried:
  1. Arp-scan the local network, not found
  2. Disconnected the display, reboot, and re-scan, not found
  3. Redo all procedures, the same.
The symptom seems to be similar with i9-10900 as described in #1
Quote
-> one user negative feedback for a i9-10900 (8086:9BC5) system does not boot anymore - seems to be a solid hands off?
Any suggestions, folks? More information upon request!
THANK YOU IN ADVANCE!
Edited by Sark
2 hours ago, Sark said:
What I have tried:
Also tried
  • blacklisting host update.synology.com on gateway to forbid automatically updating from 6.23-25426 to update 3, as someone has managed to Synology HW Decoding (Emby) success with i3-10100 and he indicated he's using 6.23-25426 neither update 2 or 3.
  • re-format the disk, re-install DSM .pat and replace i915.ko, same result, black screen and ip not found. : (
Edited by Sark
On 4/6/2021 at 9:51 PM, Sark said:
i checked the i915.ko files offered there (only checked the u3 files) and they where binary the same as the files offered in the 1st post (also same file date, i guess they just used my files and repacked them to match pci id's instead of dsm version)
there is still the possibility that there are different 10100 cpu around (different SKU's, like seen with the i5-9400)
i found some material but i need to check it out and compare information's but i guess there might only be one type of 10100 because on ark intel there is only one pci id for the gpu
its not that much of a problem for you to test it with dsm 6.2.0 and the matching modded driver
you just take you usb, replace the zImage and rd.gz on the 2nd partition with the files from the 6.2.0 (v23739) *.pat file - make copy's of the files there so you can revert it - and then use it to install 6.2.0 to a single empty disk
if you are done testing just put the kernel files from before back on the usb and reconnect you disks
(even if you boot you "old" disks with the usb that has 6.2.0 kernel files, dsm would offer to fix it an in a few seconds it would be up and running again)
