Driver extension jun 1.03b/1.04b for DSM6.2.3 for 918+ / 3615xs / 3617xs
38 minutes ago, robert36 said:
i now must find other firmware and put into /usr/lib/firmware
thats what the module is looking for
iwlwifi-100-5.ucode
iwlwifi-1000-5.ucode
iwlwifi-135-6.ucode
iwlwifi-105-6.ucode
iwlwifi-2030-6.ucode
iwlwifi-2000-6.ucode
iwlwifi-5150-2.ucode
iwlwifi-5000-5.ucode
iwlwifi-6000g2b-6.ucode
iwlwifi-6000g2a-5.ucode
iwlwifi-6050-5.ucode
iwlwifi-6000-4.ucode
iwlwifi-7265D-13.ucode
iwlwifi-7265-13.ucode
iwlwifi-3160-13.ucode
iwlwifi-7260-13.ucode
iwlwifi-8000-13.ucode
Yes, you are right...it drops in dmesg error about:
failed to load module iwlmvm (error 256), is dynamic loading enabled?
So we need new kernel from Synology that have dynamic loading enabled....otherwise we are stuck here without support.
Next thing i will do is to try to compile NVIDIA drivers for my GTX 1050 TI 4GB OC gpu to be able to transcode x.265 on that GPU (savings on HDD because i have 1080p x265).
I download from NVIDIA WebSite NVIDIA-Linux-x86_64-450.80.02.run and extraced the /kernel folder to /root/linux-4.4.x/drivers/nvidia and now i need syntax how to compile this module as kernel module including cross compiler? If i just type into ssh: make it compiles fine without errors...but this will not work because i did not include cross compiler that i have set up as instructed in tutorial...so i have set alias for cross compiler:
wget https://sourceforge.net/projects/dsgpl/files/Synology%20NAS%20GPL%20Source/24922branch/apollolake-source/linux-4.4.x.txz/download -O linux-4.4.x.txz
wget https://sourceforge.net/projects/dsgpl/files/Tool%20Chain/DSM%206.2.3%20Tool%20Chains/Intel%20x86%20Linux%204.4.59%20%28Apollolake%29/apollolake-gcc493_glibc220_linaro_x86_64-GPL.txz/download -O apollolake-gcc493_glibc220_linaro_x86_64-GPL.txz
tar xvf linux-4.4.x.txz
tar xvf apollolake-gcc493_glibc220_linaro_x86_64-GPL.txz
alias dsm6make='make ARCH=x86_64 CROSS_COMPILE=/root/x86_64-pc-linux-gnu/bin/x86_64-pc-linux-gnu-'
cd linux-4.4.x
cp synoconfigs/apollolake .config
so how to include this to compile newer nvidia drivers? I know i need runtime after driver is compiled, but this is next thinkg i will do and compile if needed.
Currently if is possible to cross compile with make?
EDIT: i found the way:
make KSRC="/root/linux-4.4.x" CROSS_COMPILE="/root/x86_64-pc-linux-gnu/bin/x86_64-pc-linux-gnu-" ARCH="x86_64"
But now i must define to use synology kernel not ubuntu kernel that i im compiling drivers..what variable do i need to modify to use linux kernel from synology?
insmod: ERROR: could not insert module /usr/lib/modules/update/nvidia.ko: Invalid module format
root@synology:~# dmesg | grep nvidia
[13095.896625] nvidia: version magic '4.4.0-186-generic SMP mod_unload modversions ' should be '4.4.59+ SMP preempt mod_unload '
Edited by robert36
Here i found about NVIDIA driver to add to docker to be able to use hardware acceleration (try on jellyfin its free)
Figured it out eventually (reddit to the rescue).
This is what I did, for future reference:
#ADDING NVIDIA TO DOCKER:
nano /etc/modprobe.d/blacklist-nouveau.conf
#Add these lines:
blacklist nouveau
options nouveau modeset=0
REBOOT
update-initramfs -u
apt-get install gcc
apt-get install binutils
apt-get install make
apt-get install linux-source
mkdir /opt/nvidia && cd /opt/nvidia
curl -s -L https://nvidia.github.io/nvidia-docker/gpgkey 15 | \
sudo apt-key add - distribution=$(. /etc/os-release;echo $ID$VERSION_ID)
curl -s -L https://nvidia.github.io/nvidia-docker/$distribution/nvidia-docker.list 7 | \
sudo tee /etc/apt/sources.list.d/nvidia-docker.list
sudo apt-get update
sudo wget nvidia-drivers-url (in my case, http://us.download.nvidia.com/XFree86/Linux-x86_64/440.44/NVIDIA-Linux-x86_64-440.44.run 5)
chmod +x ./NVIDIA-Linux-x86_64-440.44.run
#Verify that drivers were installed
nvidia-sim
sudo apt install nvidia-docker2 nvidia-container-runtime
sudo systemctl daemon-reload
sudo systemctl restart docker
#then create the docker with
sudo docker run -d
–runtime=nvidia
–name=SERVERNAME
–network=host
-p 32400:32400
-e TZ=Europe/Oslo
-e PLEX_CLAIM="$token"
-e NVIDIA_VISIBLE_DEVICES=all
-e NVIDIA_DRIVER_CAPABILITIES=compute,video,utility
–mount type=tmpfs,destination=/transcode,tmpfs-mode=777,tmpfs-size=20G
-v /mnt/plex/plexdata:/config
-v /media/movies:/media/movies
–device=/dev/dri/card0:/dev/dri/card0
–device=/dev/dri/renderD128:/dev/dri/renderD128
plexinc/pms-docker:plexpass
chown in container (not sure if neccessary for GPU, but doing it just in case)
sudo docker exec -d CONTAINERNAME chown -Rv plex:plex /transcode
sudo docker exec -d CONTAINERNAME chown -Rv plex:plex /dec/dri/card0
sudo docker exec -d CONTAINERNAME chown -Rv plex:plex /dec/dri/renderD128
Edited by robert36
did you load all in t the right order?
when loading the modules in the right order (dependencies) then this should be no problem, my error was a different one
i guess it should be like this?
insmod /usr/lib/modules/cfg80211.ko
insmod /usr/lib/modules/mac80211.ko
insmod /usr/lib/modules/update/iwlwifi.ko
insmod /usr/lib/modules/update/iwlmvm.ko
insmod /usr/lib/modules/update/iwldvm.ko
but won't we need the driver 1st in dsm to be working?
–device=/dev/dri/card0:/dev/dri/card0 –device=/dev/dri/renderD128:/dev/dri/renderD128
these are VAAPI devices, i have not seen them when loading the nvidia drivers
after
insmod /urs/lib/modules/nvidia.ko
insmod /urs/lib/modules/nvidia-uvm
insmod /urs/lib/modules/nvidia-drm
/usr/bin/nvidia-smi -pm 1
i only got
/dev/nvidia0
/dev/nvidiactl
i compiled the nvidia kernel drivers by unpacking the file from nvidia
got int
/NVIDIA-Linux-x86_64-440.44/kernel
(i did not put anything into the kernel source)
and did the normal cross compile in my chmod environment inside a dsm vm
make ARCH=x86_64 CROSS_COMPILE=/test4/x86_64-pc-linux-gnu/bin/x86_64-pc-linux-gnu-
Edited by IG-88
Would it be possible to get 1.04b juns extra with just i915 driver removed?
Had some problems with v0.13.3 r8125 driver back then when trying 6.2.3 i think.
Spoiler
[Thu Sep 10 02:17:13 2020] warn_alloc_failed: 4 callbacks suppressed
[Thu Sep 10 02:17:13 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:17:13 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:17:13 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:17:13 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:17:13 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:17:13 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:17:13 2020] Call Trace:
[Thu Sep 10 02:17:13 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:17:13 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:17:13 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:17:13 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:17:13 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:17:13 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:17:13 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:17:13 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:17:13 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:17:13 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:17:13 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:17:13 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Thu Sep 10 02:17:13 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Thu Sep 10 02:17:13 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Thu Sep 10 02:17:13 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Thu Sep 10 02:17:13 2020] Mem-Info:
[Thu Sep 10 02:17:13 2020] active_anon:20689 inactive_anon:36729 isolated_anon:0
                            active_file:594262 inactive_file:2992447 isolated_file:0
                            unevictable:862 dirty:2462 writeback:987 unstable:0
                            slab_reclaimable:111554 slab_unreclaimable:38166
                            mapped:18741 shmem:10288 pagetables:12759 bounce:0
                            free:66461 free_pcp:726 free_cma:0
[Thu Sep 10 02:17:13 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:17:13 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:17:13 2020] DMA32 free:91444kB min:13976kB low:17468kB high:20964kB active_anon:50184kB inactive_anon:85024kB active_file:434396kB inactive_file:2561016kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:2428kB writeback:1320kB mapped:38352kB shmem:36292kB slab_reclaimable:68760kB slab_unreclaimable:34604kB kernel_stack:1600kB pagetables:14084kB unstable:0kB bounce:0kB free_pcp:1376kB local_pcp:640kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:17:13 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:17:13 2020] Normal free:158520kB min:51492kB low:64364kB high:77236kB active_anon:32572kB inactive_anon:61892kB active_file:1942652kB inactive_file:9408772kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:7420kB writeback:2628kB mapped:36612kB shmem:4860kB slab_reclaimable:377456kB slab_unreclaimable:118060kB kernel_stack:7200kB pagetables:36952kB unstable:0kB bounce:0kB free_pcp:1528kB local_pcp:556kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:17:13 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:17:13 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:17:13 2020] DMA32: 15149*4kB (UME) 3466*8kB (UME) 195*16kB (ME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 91444kB
[Thu Sep 10 02:17:13 2020] Normal: 6912*4kB (UM) 6545*8kB (UME) 3976*16kB (UME) 458*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 158280kB
[Thu Sep 10 02:17:13 2020] 3599384 total pagecache pages
[Thu Sep 10 02:17:13 2020] 2302 pages in swap cache
[Thu Sep 10 02:17:13 2020] Swap cache stats: add 122469, delete 120168, find 3376907/3390233
[Thu Sep 10 02:17:13 2020] Free swap  = 11482948kB
[Thu Sep 10 02:17:13 2020] Total swap = 11878316kB
[Thu Sep 10 02:17:13 2020] 4165912 pages RAM
[Thu Sep 10 02:17:13 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:17:13 2020] 90558 pages reserved
[Thu Sep 10 02:17:20 2020] warn_alloc_failed: 40 callbacks suppressed
[Thu Sep 10 02:17:20 2020] cloud-cached: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:17:20 2020] CPU: 1 PID: 17133 Comm: cloud-cached Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:17:20 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:17:20 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:17:20 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:17:20 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:17:20 2020] Call Trace:
[Thu Sep 10 02:17:20 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:17:20 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:17:20 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:17:20 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:17:20 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:17:20 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:17:20 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:17:20 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:17:20 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:17:20 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:17:20 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:17:20 2020]  <EOI> Mem-Info:
[Thu Sep 10 02:17:20 2020] active_anon:22738 inactive_anon:36716 isolated_anon:0
                            active_file:594394 inactive_file:2992410 isolated_file:0
                            unevictable:862 dirty:3922 writeback:0 unstable:0
                            slab_reclaimable:111616 slab_unreclaimable:38191
                            mapped:18740 shmem:10287 pagetables:12759 bounce:0
                            free:63939 free_pcp:1092 free_cma:0
[Thu Sep 10 02:17:20 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:17:20 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:17:20 2020] DMA32 free:90180kB min:13976kB low:17468kB high:20964kB active_anon:50420kB inactive_anon:84976kB active_file:434424kB inactive_file:2561040kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:5644kB writeback:0kB mapped:38352kB shmem:36296kB slab_reclaimable:68764kB slab_unreclaimable:34644kB kernel_stack:1616kB pagetables:13884kB unstable:0kB bounce:0kB free_pcp:2452kB local_pcp:672kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:17:20 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:17:20 2020] Normal free:149696kB min:51492kB low:64364kB high:77236kB active_anon:40532kB inactive_anon:61888kB active_file:1943152kB inactive_file:9408600kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:10044kB writeback:0kB mapped:36608kB shmem:4852kB slab_reclaimable:377700kB slab_unreclaimable:118120kB kernel_stack:7152kB pagetables:37152kB unstable:0kB bounce:0kB free_pcp:1908kB local_pcp:360kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:17:20 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:17:20 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:17:20 2020] DMA32: 15081*4kB (UME) 3385*8kB (UME) 188*16kB (UME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 90412kB
[Thu Sep 10 02:17:20 2020] Normal: 5089*4kB (UM) 6477*8kB (UME) 3970*16kB (UME) 436*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 149644kB
[Thu Sep 10 02:17:20 2020] 3599405 total pagecache pages
[Thu Sep 10 02:17:20 2020] 2302 pages in swap cache
[Thu Sep 10 02:17:20 2020] Swap cache stats: add 122469, delete 120168, find 3378250/3391576
[Thu Sep 10 02:17:20 2020] Free swap  = 11482948kB
[Thu Sep 10 02:17:20 2020] Total swap = 11878316kB
[Thu Sep 10 02:17:20 2020] 4165912 pages RAM
[Thu Sep 10 02:17:20 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:17:20 2020] 90558 pages reserved
[Thu Sep 10 02:17:25 2020] warn_alloc_failed: 92 callbacks suppressed
[Thu Sep 10 02:17:25 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:17:25 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:17:25 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:17:25 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:17:25 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:17:25 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:17:25 2020] Call Trace:
[Thu Sep 10 02:17:25 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:17:25 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:17:25 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:17:25 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:17:25 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:17:25 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:17:25 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:17:25 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:17:25 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:17:25 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:17:25 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:17:25 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Thu Sep 10 02:17:25 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Thu Sep 10 02:17:25 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Thu Sep 10 02:17:25 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Thu Sep 10 02:17:25 2020] Mem-Info:
[Thu Sep 10 02:17:25 2020] active_anon:20899 inactive_anon:36716 isolated_anon:0
                            active_file:594688 inactive_file:2992649 isolated_file:0
                            unevictable:862 dirty:3142 writeback:8 unstable:0
                            slab_reclaimable:111666 slab_unreclaimable:38223
                            mapped:18741 shmem:10288 pagetables:12832 bounce:0
                            free:65067 free_pcp:1241 free_cma:0
[Thu Sep 10 02:17:25 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:17:25 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:17:25 2020] DMA32 free:92924kB min:13976kB low:17468kB high:20964kB active_anon:50068kB inactive_anon:84976kB active_file:435020kB inactive_file:2558904kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:3128kB writeback:0kB mapped:38356kB shmem:36300kB slab_reclaimable:68804kB slab_unreclaimable:34592kB kernel_stack:1600kB pagetables:12920kB unstable:0kB bounce:0kB free_pcp:2740kB local_pcp:668kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:17:25 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:17:25 2020] Normal free:151464kB min:51492kB low:64364kB high:77236kB active_anon:33528kB inactive_anon:61888kB active_file:1943732kB inactive_file:9411692kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:9440kB writeback:32kB mapped:36608kB shmem:4852kB slab_reclaimable:377860kB slab_unreclaimable:118300kB kernel_stack:7200kB pagetables:38408kB unstable:0kB bounce:0kB free_pcp:2224kB local_pcp:596kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:17:25 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:17:25 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:17:25 2020] DMA32: 15481*4kB (UME) 3503*8kB (UME) 187*16kB (UME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 92940kB
[Thu Sep 10 02:17:25 2020] Normal: 5664*4kB (UM) 6371*8kB (UME) 3963*16kB (UME) 457*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 151656kB
[Thu Sep 10 02:17:25 2020] 3599914 total pagecache pages
[Thu Sep 10 02:17:25 2020] 2302 pages in swap cache
[Thu Sep 10 02:17:25 2020] Swap cache stats: add 122469, delete 120168, find 3379204/3392530
[Thu Sep 10 02:17:25 2020] Free swap  = 11482948kB
[Thu Sep 10 02:17:25 2020] Total swap = 11878316kB
[Thu Sep 10 02:17:25 2020] 4165912 pages RAM
[Thu Sep 10 02:17:25 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:17:25 2020] 90558 pages reserved
[Thu Sep 10 02:19:23 2020] warn_alloc_failed: 71 callbacks suppressed
[Thu Sep 10 02:19:23 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:19:23 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:19:23 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:19:23 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:19:23 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:19:23 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:19:23 2020] Call Trace:
[Thu Sep 10 02:19:23 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:19:23 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:19:23 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:19:23 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:19:23 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:19:23 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:19:23 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:19:23 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:19:23 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:19:23 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:19:23 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:19:23 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Thu Sep 10 02:19:23 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Thu Sep 10 02:19:23 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Thu Sep 10 02:19:23 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Thu Sep 10 02:19:23 2020] Mem-Info:
[Thu Sep 10 02:19:23 2020] active_anon:20618 inactive_anon:36770 isolated_anon:0
                            active_file:596437 inactive_file:2989428 isolated_file:0
                            unevictable:862 dirty:2479 writeback:5 unstable:0
                            slab_reclaimable:112696 slab_unreclaimable:38231
                            mapped:18672 shmem:10287 pagetables:12812 bounce:0
                            free:65674 free_pcp:1248 free_cma:0
[Thu Sep 10 02:19:23 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:19:23 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:19:23 2020] DMA32 free:94648kB min:13976kB low:17468kB high:20964kB active_anon:49808kB inactive_anon:85068kB active_file:434812kB inactive_file:2558268kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:2752kB writeback:0kB mapped:38232kB shmem:36324kB slab_reclaimable:69340kB slab_unreclaimable:34528kB kernel_stack:1552kB pagetables:12124kB unstable:0kB bounce:0kB free_pcp:2416kB local_pcp:648kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:19:23 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:19:23 2020] Normal free:152168kB min:51492kB low:64364kB high:77236kB active_anon:32664kB inactive_anon:62012kB active_file:1950936kB inactive_file:9399444kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:7164kB writeback:20kB mapped:36456kB shmem:4824kB slab_reclaimable:381444kB slab_unreclaimable:118396kB kernel_stack:7216kB pagetables:39124kB unstable:0kB bounce:0kB free_pcp:2576kB local_pcp:720kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:19:23 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:19:23 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:19:23 2020] DMA32: 15675*4kB (UME) 3650*8kB (UME) 175*16kB (ME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 94700kB
[Thu Sep 10 02:19:23 2020] Normal: 6200*4kB (UME) 6596*8kB (UME) 4038*16kB (UM) 310*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 152096kB
[Thu Sep 10 02:19:23 2020] 3598465 total pagecache pages
[Thu Sep 10 02:19:23 2020] 2301 pages in swap cache
[Thu Sep 10 02:19:23 2020] Swap cache stats: add 122469, delete 120169, find 3397180/3410507
[Thu Sep 10 02:19:23 2020] Free swap  = 11482952kB
[Thu Sep 10 02:19:23 2020] Total swap = 11878316kB
[Thu Sep 10 02:19:23 2020] 4165912 pages RAM
[Thu Sep 10 02:19:23 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:19:23 2020] 90558 pages reserved
[Thu Sep 10 02:20:48 2020] warn_alloc_failed: 2 callbacks suppressed
[Thu Sep 10 02:20:48 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:20:48 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:20:48 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:20:48 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:20:48 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:20:48 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:20:48 2020] Call Trace:
[Thu Sep 10 02:20:48 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:20:48 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:20:48 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:20:48 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:20:48 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:20:48 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:20:48 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:20:48 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:20:48 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:20:48 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:20:48 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:20:48 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Thu Sep 10 02:20:48 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Thu Sep 10 02:20:48 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Thu Sep 10 02:20:48 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Thu Sep 10 02:20:48 2020] Mem-Info:
[Thu Sep 10 02:20:48 2020] active_anon:20975 inactive_anon:36694 isolated_anon:0
                            active_file:598135 inactive_file:2986975 isolated_file:0
                            unevictable:862 dirty:3745 writeback:5 unstable:0
                            slab_reclaimable:113488 slab_unreclaimable:38244
                            mapped:18741 shmem:10288 pagetables:12757 bounce:0
                            free:65510 free_pcp:1079 free_cma:0
[Thu Sep 10 02:20:48 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:20:48 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:20:48 2020] DMA32 free:91088kB min:13976kB low:17468kB high:20964kB active_anon:50416kB inactive_anon:85068kB active_file:435480kB inactive_file:2558632kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:7308kB writeback:0kB mapped:38352kB shmem:36292kB slab_reclaimable:69820kB slab_unreclaimable:34496kB kernel_stack:1584kB pagetables:13776kB unstable:0kB bounce:0kB free_pcp:2156kB local_pcp:668kB free_cma:0kB writeback_tmp:0kB pages_scanned:112 all_unreclaimable? no
[Thu Sep 10 02:20:48 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:20:48 2020] Normal free:155072kB min:51492kB low:64364kB high:77236kB active_anon:33484kB inactive_anon:61708kB active_file:1957060kB inactive_file:9389268kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:7672kB writeback:20kB mapped:36612kB shmem:4860kB slab_reclaimable:384132kB slab_unreclaimable:118480kB kernel_stack:7216kB pagetables:37252kB unstable:0kB bounce:0kB free_pcp:2160kB local_pcp:696kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:20:48 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:20:48 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:20:48 2020] DMA32: 15208*4kB (UME) 3464*8kB (UME) 159*16kB (UME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 91088kB
[Thu Sep 10 02:20:48 2020] Normal: 6401*4kB (UME) 6901*8kB (UME) 4088*16kB (UME) 276*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 155052kB
[Thu Sep 10 02:20:48 2020] 3597711 total pagecache pages
[Thu Sep 10 02:20:48 2020] 2301 pages in swap cache
[Thu Sep 10 02:20:48 2020] Swap cache stats: add 122469, delete 120169, find 3410923/3424251
[Thu Sep 10 02:20:48 2020] Free swap  = 11482952kB
[Thu Sep 10 02:20:48 2020] Total swap = 11878316kB
[Thu Sep 10 02:20:48 2020] 4165912 pages RAM
[Thu Sep 10 02:20:48 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:20:48 2020] 90558 pages reserved
[Thu Sep 10 02:21:02 2020] warn_alloc_failed: 8 callbacks suppressed
[Thu Sep 10 02:21:02 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:21:02 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:21:02 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:21:02 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:21:02 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:21:02 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:21:02 2020] Call Trace:
[Thu Sep 10 02:21:02 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:21:02 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:21:02 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:21:02 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:21:02 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:21:02 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:21:02 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:21:02 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:21:02 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:21:02 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:21:02 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:21:02 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Thu Sep 10 02:21:02 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Thu Sep 10 02:21:02 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Thu Sep 10 02:21:02 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Thu Sep 10 02:21:02 2020] Mem-Info:
[Thu Sep 10 02:21:02 2020] active_anon:20639 inactive_anon:36718 isolated_anon:0
                            active_file:597702 inactive_file:2986328 isolated_file:0
                            unevictable:862 dirty:3432 writeback:52 unstable:0
                            slab_reclaimable:113596 slab_unreclaimable:38226
                            free:66815 free_pcp:1119 free_cma:0
[Thu Sep 10 02:21:02 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:21:02 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:21:02 2020] DMA32 free:93940kB min:13976kB low:17468kB high:20964kB active_anon:50452kB inactive_anon:85092kB active_file:435608kB inactive_file:2555548kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:6596kB writeback:48kB mapped:38352kB shmem:36316kB slab_reclaimable:69884kB slab_unreclaimable:34508kB kernel_stack:1584kB pagetables:13060kB unstable:0kB bounce:0kB free_pcp:2912kB local_pcp:716kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:21:02 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:21:02 2020] Normal free:157440kB min:51492kB low:64364kB high:77236kB active_anon:32104kB inactive_anon:61780kB active_file:1955200kB inactive_file:9389764kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:7132kB writeback:160kB mapped:36612kB shmem:4836kB slab_reclaimable:384500kB slab_unreclaimable:118396kB kernel_stack:7232kB pagetables:37968kB unstable:0kB bounce:0kB free_pcp:1564kB local_pcp:228kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:21:02 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:21:02 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:21:02 2020] DMA32: 14983*4kB (UME) 3913*8kB (UME) 167*16kB (UME) 1*32kB (E) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 93940kB
[Thu Sep 10 02:21:02 2020] Normal: 6942*4kB (UME) 6875*8kB (UME) 4102*16kB (UME) 285*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 157520kB
[Thu Sep 10 02:21:02 2020] 3596631 total pagecache pages
[Thu Sep 10 02:21:02 2020] 2301 pages in swap cache
[Thu Sep 10 02:21:02 2020] Swap cache stats: add 122469, delete 120169, find 3412821/3426149
[Thu Sep 10 02:21:02 2020] Free swap  = 11482952kB
[Thu Sep 10 02:21:02 2020] Total swap = 11878316kB
[Thu Sep 10 02:21:02 2020] 4165912 pages RAM
[Thu Sep 10 02:21:02 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:21:02 2020] 90558 pages reserved
[Thu Sep 10 02:21:11 2020] warn_alloc_failed: 88 callbacks suppressed
[Thu Sep 10 02:21:11 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:21:11 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:21:11 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:21:11 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:21:11 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:21:11 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:21:11 2020] Call Trace:
[Thu Sep 10 02:21:11 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:21:11 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:21:11 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:21:11 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:21:11 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:21:11 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:21:11 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:21:11 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:21:11 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:21:11 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:21:11 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:21:11 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Thu Sep 10 02:21:11 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Thu Sep 10 02:21:11 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Thu Sep 10 02:21:11 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Thu Sep 10 02:21:11 2020] Mem-Info:
[Thu Sep 10 02:21:11 2020] active_anon:20547 inactive_anon:36718 isolated_anon:0
                            active_file:597768 inactive_file:2986212 isolated_file:0
                            unevictable:862 dirty:4446 writeback:0 unstable:0
                            slab_reclaimable:113676 slab_unreclaimable:38208
                            free:66798 free_pcp:1218 free_cma:0
[Thu Sep 10 02:21:11 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:21:11 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:21:11 2020] DMA32 free:93948kB min:13976kB low:17468kB high:20964kB active_anon:49696kB inactive_anon:85088kB active_file:435656kB inactive_file:2556284kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:8228kB writeback:0kB mapped:38352kB shmem:36312kB slab_reclaimable:69960kB slab_unreclaimable:34512kB kernel_stack:1584kB pagetables:13060kB unstable:0kB bounce:0kB free_pcp:2712kB local_pcp:720kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:21:11 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:21:11 2020] Normal free:157364kB min:51492kB low:64364kB high:77236kB active_anon:32492kB inactive_anon:61784kB active_file:1955416kB inactive_file:9388564kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:9556kB writeback:0kB mapped:36612kB shmem:4840kB slab_reclaimable:384744kB slab_unreclaimable:118320kB kernel_stack:7216kB pagetables:37968kB unstable:0kB bounce:0kB free_pcp:2160kB local_pcp:460kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:21:11 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:21:11 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:21:11 2020] DMA32: 15121*4kB (UME) 3845*8kB (UME) 169*16kB (UME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 93948kB
[Thu Sep 10 02:21:11 2020] Normal: 7123*4kB (UME) 6823*8kB (UME) 4125*16kB (UME) 258*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 157332kB
[Thu Sep 10 02:21:11 2020] 3596581 total pagecache pages
[Thu Sep 10 02:21:11 2020] 2301 pages in swap cache
[Thu Sep 10 02:21:11 2020] Swap cache stats: add 122469, delete 120169, find 3414030/3427358
[Thu Sep 10 02:21:11 2020] Free swap  = 11482952kB
[Thu Sep 10 02:21:11 2020] Total swap = 11878316kB
[Thu Sep 10 02:21:11 2020] 4165912 pages RAM
[Thu Sep 10 02:21:11 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:21:11 2020] 90558 pages reserved
[Thu Sep 10 02:21:24 2020] warn_alloc_failed: 13 callbacks suppressed
[Thu Sep 10 02:21:24 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:21:24 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:21:24 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:21:24 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:21:24 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:21:24 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:21:24 2020] Call Trace:
[Thu Sep 10 02:21:24 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:21:24 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:21:24 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:21:24 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:21:24 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:21:24 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:21:24 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:21:24 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:21:24 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:21:24 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:21:24 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:21:24 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Thu Sep 10 02:21:24 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Thu Sep 10 02:21:24 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Thu Sep 10 02:21:24 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Thu Sep 10 02:21:24 2020] Mem-Info:
[Thu Sep 10 02:21:24 2020] active_anon:20716 inactive_anon:36722 isolated_anon:0
                            active_file:598571 inactive_file:2985875 isolated_file:0
                            unevictable:862 dirty:4202 writeback:128 unstable:0
                            slab_reclaimable:113821 slab_unreclaimable:38236
                            mapped:18741 shmem:10288 pagetables:12603 bounce:0
                            free:66174 free_pcp:1033 free_cma:0
[Thu Sep 10 02:21:24 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:21:24 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:21:24 2020] DMA32 free:92644kB min:13976kB low:17468kB high:20964kB active_anon:49812kB inactive_anon:85112kB active_file:435872kB inactive_file:2556172kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:3624kB writeback:220kB mapped:38352kB shmem:36312kB slab_reclaimable:70016kB slab_unreclaimable:34504kB kernel_stack:1648kB pagetables:14172kB unstable:0kB bounce:0kB free_pcp:2452kB local_pcp:404kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:21:24 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:21:24 2020] Normal free:156172kB min:51492kB low:64364kB high:77236kB active_anon:33052kB inactive_anon:61776kB active_file:1958412kB inactive_file:9387328kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:13184kB writeback:292kB mapped:36612kB shmem:4840kB slab_reclaimable:385268kB slab_unreclaimable:118440kB kernel_stack:7136kB pagetables:36240kB unstable:0kB bounce:0kB free_pcp:1680kB local_pcp:220kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:21:24 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:21:24 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:21:24 2020] DMA32: 15016*4kB (UME) 3754*8kB (UME) 167*16kB (UM) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 92768kB
[Thu Sep 10 02:21:24 2020] Normal: 5692*4kB (UME) 6992*8kB (UME) 4140*16kB (UME) 347*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 156048kB
[Thu Sep 10 02:21:24 2020] 3597116 total pagecache pages
[Thu Sep 10 02:21:24 2020] 2301 pages in swap cache
[Thu Sep 10 02:21:24 2020] Swap cache stats: add 122469, delete 120169, find 3415983/3429311
[Thu Sep 10 02:21:24 2020] Free swap  = 11482952kB
[Thu Sep 10 02:21:24 2020] Total swap = 11878316kB
[Thu Sep 10 02:21:24 2020] 4165912 pages RAM
[Thu Sep 10 02:21:24 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:21:24 2020] 90558 pages reserved
[Thu Sep 10 02:21:30 2020] warn_alloc_failed: 14 callbacks suppressed
[Thu Sep 10 02:21:30 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:21:30 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:21:30 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:21:30 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:21:30 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:21:30 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:21:30 2020] Call Trace:
[Thu Sep 10 02:21:30 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:21:30 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:21:30 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:21:30 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:21:30 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:21:30 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:21:30 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:21:30 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:21:30 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:21:30 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:21:30 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:21:30 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Thu Sep 10 02:21:30 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Thu Sep 10 02:21:30 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Thu Sep 10 02:21:30 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Thu Sep 10 02:21:30 2020] Mem-Info:
[Thu Sep 10 02:21:30 2020] active_anon:20839 inactive_anon:36702 isolated_anon:0
                            active_file:597967 inactive_file:2985273 isolated_file:0
                            unevictable:862 dirty:3247 writeback:148 unstable:0
                            slab_reclaimable:113849 slab_unreclaimable:38198
                            mapped:18795 shmem:10287 pagetables:12676 bounce:0
                            free:67295 free_pcp:1038 free_cma:0
[Thu Sep 10 02:21:30 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:21:30 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:21:30 2020] DMA32 free:92828kB min:13976kB low:17468kB high:20964kB active_anon:50512kB inactive_anon:85032kB active_file:435708kB inactive_file:2556168kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:2728kB writeback:8kB mapped:38572kB shmem:36312kB slab_reclaimable:70028kB slab_unreclaimable:34504kB kernel_stack:1600kB pagetables:13824kB unstable:0kB bounce:0kB free_pcp:2432kB local_pcp:704kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:21:30 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:21:30 2020] Normal free:160472kB min:51492kB low:64364kB high:77236kB active_anon:32844kB inactive_anon:61776kB active_file:1956160kB inactive_file:9384924kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:10260kB writeback:584kB mapped:36608kB shmem:4836kB slab_reclaimable:385368kB slab_unreclaimable:118288kB kernel_stack:7152kB pagetables:36880kB unstable:0kB bounce:0kB free_pcp:1720kB local_pcp:196kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:21:30 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:21:30 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:21:30 2020] DMA32: 14969*4kB (UME) 3801*8kB (UME) 165*16kB (UM) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 92924kB
[Thu Sep 10 02:21:30 2020] Normal: 6665*4kB (UME) 6913*8kB (UME) 4174*16kB (UME) 367*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 160492kB
[Thu Sep 10 02:21:30 2020] 3595912 total pagecache pages
[Thu Sep 10 02:21:30 2020] 2301 pages in swap cache
[Thu Sep 10 02:21:30 2020] Swap cache stats: add 122469, delete 120169, find 3416683/3430011
[Thu Sep 10 02:21:30 2020] Free swap  = 11482952kB
[Thu Sep 10 02:21:30 2020] Total swap = 11878316kB
[Thu Sep 10 02:21:30 2020] 4165912 pages RAM
[Thu Sep 10 02:21:30 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:21:30 2020] 90558 pages reserved
[Thu Sep 10 02:21:35 2020] warn_alloc_failed: 3 callbacks suppressed
[Thu Sep 10 02:21:35 2020] syncd: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:21:35 2020] CPU: 1 PID: 17189 Comm: syncd Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:21:35 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:21:35 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:21:35 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:21:35 2020]  ffffffff8186f0f0 ffff88040cbd2000 ffff880400000030 ffff880321a12d60
[Thu Sep 10 02:21:35 2020] Call Trace:
[Thu Sep 10 02:21:35 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:21:35 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:21:35 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:21:35 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:21:35 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:21:35 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:21:35 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:21:35 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:21:35 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:21:35 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:21:35 2020]  <EOI> Mem-Info:
[Thu Sep 10 02:21:35 2020] active_anon:20724 inactive_anon:36719 isolated_anon:0
                            active_file:598032 inactive_file:2985282 isolated_file:0
                            unevictable:862 dirty:3642 writeback:73 unstable:0
                            slab_reclaimable:113892 slab_unreclaimable:38216
                            mapped:18740 shmem:10287 pagetables:12603 bounce:0
                            free:67427 free_pcp:936 free_cma:0
[Thu Sep 10 02:21:35 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:21:35 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:21:35 2020] DMA32 free:93956kB min:13976kB low:17468kB high:20964kB active_anon:50492kB inactive_anon:85036kB active_file:435736kB inactive_file:2556208kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:3664kB writeback:0kB mapped:38352kB shmem:36316kB slab_reclaimable:70056kB slab_unreclaimable:34516kB kernel_stack:1600kB pagetables:12776kB unstable:0kB bounce:0kB free_pcp:2092kB local_pcp:648kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:21:35 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:21:35 2020] Normal free:159872kB min:51492kB low:64364kB high:77236kB active_anon:32404kB inactive_anon:61840kB active_file:1956392kB inactive_file:9384920kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:10904kB writeback:292kB mapped:36608kB shmem:4832kB slab_reclaimable:385512kB slab_unreclaimable:118348kB kernel_stack:7152kB pagetables:37636kB unstable:0kB bounce:0kB free_pcp:1652kB local_pcp:632kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:21:35 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:21:35 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:21:35 2020] DMA32: 15008*4kB (UME) 3917*8kB (UME) 168*16kB (UME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 94056kB
[Thu Sep 10 02:21:35 2020] Normal: 6743*4kB (UM) 6933*8kB (UME) 4124*16kB (UME) 348*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 159556kB
[Thu Sep 10 02:21:35 2020] 3595913 total pagecache pages
[Thu Sep 10 02:21:35 2020] 2301 pages in swap cache
[Thu Sep 10 02:21:35 2020] Swap cache stats: add 122469, delete 120169, find 3417655/3430983
[Thu Sep 10 02:21:35 2020] Free swap  = 11482952kB
[Thu Sep 10 02:21:35 2020] Total swap = 11878316kB
[Thu Sep 10 02:21:35 2020] 4165912 pages RAM
[Thu Sep 10 02:21:35 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:21:35 2020] 90558 pages reserved
[Thu Sep 10 02:29:46 2020] warn_alloc_failed: 15 callbacks suppressed
[Thu Sep 10 02:29:46 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:29:46 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:29:46 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:29:46 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:29:46 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:29:46 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:29:46 2020] Call Trace:
[Thu Sep 10 02:29:46 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:29:46 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:29:46 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:29:46 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:29:46 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:29:46 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:29:46 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:29:46 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:29:46 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:29:46 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:29:46 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:29:46 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Thu Sep 10 02:29:46 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Thu Sep 10 02:29:46 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Thu Sep 10 02:29:46 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Thu Sep 10 02:29:46 2020] Mem-Info:
[Thu Sep 10 02:29:46 2020] active_anon:20644 inactive_anon:36686 isolated_anon:0
                            active_file:603174 inactive_file:2973685 isolated_file:0
                            unevictable:862 dirty:3613 writeback:36 unstable:0
                            slab_reclaimable:118485 slab_unreclaimable:38110
                            mapped:18741 shmem:10288 pagetables:12681 bounce:0
                            free:69365 free_pcp:1169 free_cma:0
[Thu Sep 10 02:29:46 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:29:46 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:29:46 2020] DMA32 free:94620kB min:13976kB low:17468kB high:20964kB active_anon:49560kB inactive_anon:84968kB active_file:438000kB inactive_file:2551876kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:4456kB writeback:0kB mapped:38352kB shmem:36292kB slab_reclaimable:72620kB slab_unreclaimable:34628kB kernel_stack:1568kB pagetables:12144kB unstable:0kB bounce:0kB free_pcp:2636kB local_pcp:708kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:29:46 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:29:46 2020] Normal free:166960kB min:51492kB low:64364kB high:77236kB active_anon:33016kB inactive_anon:61776kB active_file:1974696kB inactive_file:9342864kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:9996kB writeback:220kB mapped:36612kB shmem:4860kB slab_reclaimable:401320kB slab_unreclaimable:117812kB kernel_stack:7200kB pagetables:38580kB unstable:0kB bounce:0kB free_pcp:2040kB local_pcp:620kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:29:46 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:29:46 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:29:46 2020] DMA32: 15209*4kB (UME) 4091*8kB (UME) 66*16kB (M) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 94620kB
[Thu Sep 10 02:29:46 2020] Normal: 7251*4kB (UME) 7903*8kB (UM) 4411*16kB (UME) 124*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 166772kB
[Thu Sep 10 02:29:46 2020] 3589463 total pagecache pages
[Thu Sep 10 02:29:46 2020] 2304 pages in swap cache
[Thu Sep 10 02:29:46 2020] Swap cache stats: add 122500, delete 120197, find 3502404/3515768
[Thu Sep 10 02:29:46 2020] Free swap  = 11483064kB
[Thu Sep 10 02:29:46 2020] Total swap = 11878316kB
[Thu Sep 10 02:29:46 2020] 4165912 pages RAM
[Thu Sep 10 02:29:46 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:29:46 2020] 90558 pages reserved
[Thu Sep 10 02:29:56 2020] warn_alloc_failed: 15 callbacks suppressed
[Thu Sep 10 02:29:56 2020] syncd: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:29:56 2020] CPU: 1 PID: 19514 Comm: syncd Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:29:56 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:29:56 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:29:56 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:29:56 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:29:56 2020] Call Trace:
[Thu Sep 10 02:29:56 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:29:56 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:29:56 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:29:56 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:29:56 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:29:56 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:29:56 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:29:56 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:29:56 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:29:56 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:29:56 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:29:56 2020]  <EOI> Mem-Info:
[Thu Sep 10 02:29:56 2020] active_anon:20879 inactive_anon:36678 isolated_anon:0
                            active_file:604106 inactive_file:2973733 isolated_file:0
                            unevictable:862 dirty:3362 writeback:0 unstable:0
                            slab_reclaimable:118591 slab_unreclaimable:38167
                            free:68022 free_pcp:1078 free_cma:0
[Thu Sep 10 02:29:56 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:29:56 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:29:56 2020] DMA32 free:94000kB min:13976kB low:17468kB high:20964kB active_anon:49256kB inactive_anon:85024kB active_file:438096kB inactive_file:2552732kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:3192kB writeback:0kB mapped:38352kB shmem:36292kB slab_reclaimable:72640kB slab_unreclaimable:34604kB kernel_stack:1568kB pagetables:12140kB unstable:0kB bounce:0kB free_pcp:2504kB local_pcp:648kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:29:56 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:29:56 2020] Normal free:162208kB min:51492kB low:64364kB high:77236kB active_anon:34260kB inactive_anon:61688kB active_file:1978328kB inactive_file:9342200kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:10256kB writeback:0kB mapped:36612kB shmem:4860kB slab_reclaimable:401724kB slab_unreclaimable:118064kB kernel_stack:7216kB pagetables:38584kB unstable:0kB bounce:0kB free_pcp:1808kB local_pcp:256kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:29:56 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:29:56 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:29:56 2020] DMA32: 15010*4kB (UME) 4117*8kB (UME) 64*16kB (M) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 94000kB
[Thu Sep 10 02:29:56 2020] Normal: 6574*4kB (UME) 7847*8kB (UME) 4391*16kB (UM) 88*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 162144kB
[Thu Sep 10 02:29:56 2020] 3590442 total pagecache pages
[Thu Sep 10 02:29:56 2020] 2303 pages in swap cache
[Thu Sep 10 02:29:56 2020] Swap cache stats: add 122500, delete 120198, find 3504649/3518014
[Thu Sep 10 02:29:56 2020] Free swap  = 11483068kB
[Thu Sep 10 02:29:56 2020] Total swap = 11878316kB
[Thu Sep 10 02:29:56 2020] 4165912 pages RAM
[Thu Sep 10 02:29:56 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:29:56 2020] 90558 pages reserved
[Thu Sep 10 02:31:22 2020] warn_alloc_failed: 47 callbacks suppressed
[Thu Sep 10 02:31:22 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:31:22 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:31:22 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:31:22 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:31:22 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:31:22 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:31:22 2020] Call Trace:
[Thu Sep 10 02:31:22 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:31:22 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:31:22 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:31:22 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:31:22 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:31:22 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:31:22 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:31:22 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:31:22 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:31:22 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:31:22 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:31:22 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Thu Sep 10 02:31:22 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Thu Sep 10 02:31:22 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Thu Sep 10 02:31:22 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Thu Sep 10 02:31:22 2020] Mem-Info:
[Thu Sep 10 02:31:22 2020] active_anon:20927 inactive_anon:36677 isolated_anon:0
                            active_file:604568 inactive_file:2972842 isolated_file:0
                            unevictable:862 dirty:4430 writeback:0 unstable:0
                            slab_reclaimable:119347 slab_unreclaimable:38225
                            mapped:18730 shmem:10288 pagetables:12568 bounce:0
                            free:67616 free_pcp:1291 free_cma:0
[Thu Sep 10 02:31:22 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:31:22 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:31:22 2020] DMA32 free:93404kB min:13976kB low:17468kB high:20964kB active_anon:50960kB inactive_anon:84968kB active_file:438700kB inactive_file:2550092kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:4720kB writeback:0kB mapped:38308kB shmem:36296kB slab_reclaimable:73072kB slab_unreclaimable:34544kB kernel_stack:1600kB pagetables:12512kB unstable:0kB bounce:0kB free_pcp:2696kB local_pcp:636kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:31:22 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:31:22 2020] Normal free:161180kB min:51492kB low:64364kB high:77236kB active_anon:32748kB inactive_anon:61740kB active_file:1979572kB inactive_file:9341276kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:13000kB writeback:0kB mapped:36612kB shmem:4856kB slab_reclaimable:404316kB slab_unreclaimable:118356kB kernel_stack:7200kB pagetables:37760kB unstable:0kB bounce:0kB free_pcp:2468kB local_pcp:640kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:31:22 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:31:22 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:31:22 2020] DMA32: 14103*4kB (UME) 4561*8kB (UME) 46*16kB (ME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 93636kB
[Thu Sep 10 02:31:22 2020] Normal: 7796*4kB (M) 7742*8kB (UME) 4261*16kB (UM) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 161296kB
[Thu Sep 10 02:31:22 2020] 3590015 total pagecache pages
[Thu Sep 10 02:31:22 2020] 2305 pages in swap cache
[Thu Sep 10 02:31:22 2020] Swap cache stats: add 122504, delete 120200, find 3522710/3536081
[Thu Sep 10 02:31:22 2020] Free swap  = 11483076kB
[Thu Sep 10 02:31:22 2020] Total swap = 11878316kB
[Thu Sep 10 02:31:22 2020] 4165912 pages RAM
[Thu Sep 10 02:31:22 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:31:22 2020] 90558 pages reserved
[Thu Sep 10 02:31:29 2020] warn_alloc_failed: 23 callbacks suppressed
[Thu Sep 10 02:31:29 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:31:29 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:31:29 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:31:29 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:31:29 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:31:29 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:31:29 2020] Call Trace:
[Thu Sep 10 02:31:29 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:31:29 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:31:29 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:31:29 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:31:29 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:31:29 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:31:29 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:31:29 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:31:29 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:31:29 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:31:29 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:31:29 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Thu Sep 10 02:31:29 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Thu Sep 10 02:31:29 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Thu Sep 10 02:31:29 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Thu Sep 10 02:31:29 2020] Mem-Info:
[Thu Sep 10 02:31:29 2020] active_anon:21196 inactive_anon:36682 isolated_anon:0
                            active_file:604709 inactive_file:2973212 isolated_file:0
                            unevictable:862 dirty:3374 writeback:20 unstable:0
                            slab_reclaimable:119410 slab_unreclaimable:38266
                            mapped:19871 shmem:10288 pagetables:12985 bounce:0
                            free:66382 free_pcp:1167 free_cma:0
[Thu Sep 10 02:31:29 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:31:29 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:31:29 2020] DMA32 free:93840kB min:13976kB low:17468kB high:20964kB active_anon:50472kB inactive_anon:84968kB active_file:438756kB inactive_file:2550084kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:4016kB writeback:0kB mapped:39508kB shmem:36296kB slab_reclaimable:73088kB slab_unreclaimable:34532kB kernel_stack:1584kB pagetables:12480kB unstable:0kB bounce:0kB free_pcp:2592kB local_pcp:660kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:31:29 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:31:29 2020] Normal free:155808kB min:51492kB low:64364kB high:77236kB active_anon:34312kB inactive_anon:61760kB active_file:1980080kB inactive_file:9342764kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:9480kB writeback:80kB mapped:39976kB shmem:4856kB slab_reclaimable:404552kB slab_unreclaimable:118532kB kernel_stack:7280kB pagetables:39460kB unstable:0kB bounce:0kB free_pcp:2076kB local_pcp:484kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:31:29 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:31:29 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:31:29 2020] DMA32: 14112*4kB (UME) 4582*8kB (UME) 42*16kB (M) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 93776kB
[Thu Sep 10 02:31:29 2020] Normal: 6999*4kB (M) 7634*8kB (UM) 4166*16kB (M) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 155724kB
[Thu Sep 10 02:31:29 2020] 3590530 total pagecache pages
[Thu Sep 10 02:31:29 2020] 2309 pages in swap cache
[Thu Sep 10 02:31:29 2020] Swap cache stats: add 122510, delete 120202, find 3523881/3537258
[Thu Sep 10 02:31:29 2020] Free swap  = 11483084kB
[Thu Sep 10 02:31:29 2020] Total swap = 11878316kB
[Thu Sep 10 02:31:29 2020] 4165912 pages RAM
[Thu Sep 10 02:31:29 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:31:29 2020] 90558 pages reserved
[Thu Sep 10 02:31:35 2020] warn_alloc_failed: 24 callbacks suppressed
[Thu Sep 10 02:31:35 2020] syncd: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:31:35 2020] CPU: 1 PID: 26366 Comm: syncd Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:31:35 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:31:35 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:31:35 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:31:35 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:31:35 2020] Call Trace:
[Thu Sep 10 02:31:35 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:31:35 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:31:35 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:31:35 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:31:35 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:31:35 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:31:35 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:31:35 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:31:35 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:31:35 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:31:35 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:31:35 2020]  <EOI> Mem-Info:
[Thu Sep 10 02:31:35 2020] active_anon:21378 inactive_anon:36716 isolated_anon:0
                            active_file:604776 inactive_file:2973192 isolated_file:0
                            unevictable:862 dirty:4286 writeback:0 unstable:0
                            slab_reclaimable:119470 slab_unreclaimable:38211
                            mapped:19824 shmem:10288 pagetables:12955 bounce:0
                            free:66031 free_pcp:1172 free_cma:0
[Thu Sep 10 02:31:35 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:31:35 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:31:35 2020] DMA32 free:92396kB min:13976kB low:17468kB high:20964kB active_anon:50748kB inactive_anon:84964kB active_file:438860kB inactive_file:2550328kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:4740kB writeback:0kB mapped:39332kB shmem:36292kB slab_reclaimable:73116kB slab_unreclaimable:34524kB kernel_stack:1600kB pagetables:13264kB unstable:0kB bounce:0kB free_pcp:2704kB local_pcp:660kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:31:35 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:31:35 2020] Normal free:155848kB min:51492kB low:64364kB high:77236kB active_anon:34764kB inactive_anon:61900kB active_file:1980244kB inactive_file:9342440kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:12404kB writeback:0kB mapped:39964kB shmem:4860kB slab_reclaimable:404764kB slab_unreclaimable:118320kB kernel_stack:7184kB pagetables:38556kB unstable:0kB bounce:0kB free_pcp:1984kB local_pcp:224kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:31:35 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:31:35 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:31:35 2020] DMA32: 13965*4kB (UME) 4483*8kB (UME) 42*16kB (ME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 92396kB
[Thu Sep 10 02:31:35 2020] Normal: 7190*4kB (UME) 7579*8kB (UME) 4144*16kB (M) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 155696kB
[Thu Sep 10 02:31:35 2020] 3590577 total pagecache pages
[Thu Sep 10 02:31:35 2020] 2309 pages in swap cache
[Thu Sep 10 02:31:35 2020] Swap cache stats: add 122512, delete 120204, find 3525016/3538395
[Thu Sep 10 02:31:35 2020] Free swap  = 11483092kB
[Thu Sep 10 02:31:35 2020] Total swap = 11878316kB
[Thu Sep 10 02:31:35 2020] 4165912 pages RAM
[Thu Sep 10 02:31:35 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:31:35 2020] 90558 pages reserved
[Thu Sep 10 02:31:42 2020] warn_alloc_failed: 16 callbacks suppressed
[Thu Sep 10 02:31:42 2020] syncd: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:31:42 2020] CPU: 1 PID: 26366 Comm: syncd Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:31:42 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:31:42 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:31:42 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:31:42 2020]  ffffffff8186f0f0 ffff88040cbd2000 ffff880400000030 ffff8800c1727920
[Thu Sep 10 02:31:42 2020] Call Trace:
[Thu Sep 10 02:31:42 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:31:42 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:31:42 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:31:42 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:31:42 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:31:42 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:31:42 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:31:42 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:31:42 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:31:42 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:31:42 2020]  <EOI> Mem-Info:
[Thu Sep 10 02:31:42 2020] active_anon:21201 inactive_anon:36780 isolated_anon:0
                            active_file:605048 inactive_file:2974095 isolated_file:0
                            unevictable:862 dirty:4489 writeback:0 unstable:0
                            slab_reclaimable:119509 slab_unreclaimable:38217
                            mapped:18800 shmem:10287 pagetables:12790 bounce:0
                            free:65461 free_pcp:958 free_cma:0
[Thu Sep 10 02:31:42 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:31:42 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:31:42 2020] DMA32 free:93632kB min:13976kB low:17468kB high:20964kB active_anon:51200kB inactive_anon:84964kB active_file:438912kB inactive_file:2549720kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:4348kB writeback:0kB mapped:38452kB shmem:36292kB slab_reclaimable:73132kB slab_unreclaimable:34524kB kernel_stack:1600kB pagetables:12604kB unstable:0kB bounce:0kB free_pcp:2332kB local_pcp:360kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:31:42 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:31:42 2020] Normal free:152332kB min:51492kB low:64364kB high:77236kB active_anon:33604kB inactive_anon:62156kB active_file:1981280kB inactive_file:9346660kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:13608kB writeback:0kB mapped:36748kB shmem:4856kB slab_reclaimable:404904kB slab_unreclaimable:118344kB kernel_stack:7216kB pagetables:38556kB unstable:0kB bounce:0kB free_pcp:1500kB local_pcp:236kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:31:42 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:31:42 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:31:42 2020] DMA32: 13963*4kB (UME) 4641*8kB (UME) 42*16kB (ME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 93652kB
[Thu Sep 10 02:31:42 2020] Normal: 6566*4kB (UME) 7531*8kB (UME) 4094*16kB (M) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 152016kB
[Thu Sep 10 02:31:42 2020] 3591797 total pagecache pages
[Thu Sep 10 02:31:42 2020] 2309 pages in swap cache
[Thu Sep 10 02:31:42 2020] Swap cache stats: add 122537, delete 120229, find 3526688/3540093
[Thu Sep 10 02:31:42 2020] Free swap  = 11483192kB
[Thu Sep 10 02:31:42 2020] Total swap = 11878316kB
[Thu Sep 10 02:31:42 2020] 4165912 pages RAM
[Thu Sep 10 02:31:42 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:31:42 2020] 90558 pages reserved
[Thu Sep 10 02:31:51 2020] warn_alloc_failed: 44 callbacks suppressed
[Thu Sep 10 02:31:51 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:31:51 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:31:51 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:31:51 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:31:51 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:31:51 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:31:51 2020] Call Trace:
[Thu Sep 10 02:31:51 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:31:51 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:31:51 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:31:51 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:31:51 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:31:51 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:31:51 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:31:51 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:31:51 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:31:51 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:31:51 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:31:51 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Thu Sep 10 02:31:51 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Thu Sep 10 02:31:51 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Thu Sep 10 02:31:51 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Thu Sep 10 02:31:51 2020] Mem-Info:
[Thu Sep 10 02:31:51 2020] active_anon:20899 inactive_anon:36744 isolated_anon:0
                            active_file:605124 inactive_file:2973329 isolated_file:0
                            unevictable:862 dirty:3960 writeback:1 unstable:0
                            slab_reclaimable:119603 slab_unreclaimable:38246
                            mapped:18741 shmem:10288 pagetables:12604 bounce:0
                            free:66168 free_pcp:1128 free_cma:0
[Thu Sep 10 02:31:51 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:31:51 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:31:51 2020] DMA32 free:93908kB min:13976kB low:17468kB high:20964kB active_anon:50124kB inactive_anon:85140kB active_file:438936kB inactive_file:2549772kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:4784kB writeback:0kB mapped:38352kB shmem:36296kB slab_reclaimable:73144kB slab_unreclaimable:34516kB kernel_stack:1584kB pagetables:12656kB unstable:0kB bounce:0kB free_pcp:2756kB local_pcp:628kB free_cma:0kB writeback_tmp:0kB pages_scanned:32 all_unreclaimable? no
[Thu Sep 10 02:31:51 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:31:51 2020] Normal free:154884kB min:51492kB low:64364kB high:77236kB active_anon:33472kB inactive_anon:61836kB active_file:1981560kB inactive_file:9343544kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:11056kB writeback:4kB mapped:36612kB shmem:4856kB slab_reclaimable:405268kB slab_unreclaimable:118468kB kernel_stack:7136kB pagetables:37760kB unstable:0kB bounce:0kB free_pcp:1756kB local_pcp:648kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:31:51 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:31:51 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:31:51 2020] DMA32: 14015*4kB (UME) 4641*8kB (UME) 45*16kB (ME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 93908kB
[Thu Sep 10 02:31:51 2020] Normal: 6907*4kB (UME) 7665*8kB (UME) 4113*16kB (UME) 2*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 154820kB
[Thu Sep 10 02:31:51 2020] 3591061 total pagecache pages
[Thu Sep 10 02:31:51 2020] 2308 pages in swap cache
[Thu Sep 10 02:31:51 2020] Swap cache stats: add 122537, delete 120230, find 3528278/3541683
[Thu Sep 10 02:31:51 2020] Free swap  = 11483196kB
[Thu Sep 10 02:31:51 2020] Total swap = 11878316kB
[Thu Sep 10 02:31:51 2020] 4165912 pages RAM
[Thu Sep 10 02:31:51 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:31:51 2020] 90558 pages reserved
[Thu Sep 10 02:32:01 2020] warn_alloc_failed: 136 callbacks suppressed
[Thu Sep 10 02:32:01 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 02:32:01 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 02:32:01 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 02:32:01 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 02:32:01 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 02:32:01 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 02:32:01 2020] Call Trace:
[Thu Sep 10 02:32:01 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 02:32:01 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 02:32:01 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 02:32:01 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 02:32:01 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 02:32:01 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 02:32:01 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 02:32:01 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 02:32:01 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 02:32:01 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 02:32:01 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 02:32:01 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Thu Sep 10 02:32:01 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Thu Sep 10 02:32:01 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Thu Sep 10 02:32:01 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Thu Sep 10 02:32:01 2020] Mem-Info:
[Thu Sep 10 02:32:01 2020] active_anon:20935 inactive_anon:36734 isolated_anon:0
                            active_file:605287 inactive_file:2971833 isolated_file:0
                            unevictable:862 dirty:4416 writeback:89 unstable:0
                            slab_reclaimable:119697 slab_unreclaimable:38300
                            mapped:18740 shmem:10287 pagetables:12758 bounce:0
                            free:66983 free_pcp:1167 free_cma:0
[Thu Sep 10 02:32:01 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 02:32:01 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 02:32:01 2020] DMA32 free:94264kB min:13976kB low:17468kB high:20964kB active_anon:49916kB inactive_anon:85128kB active_file:438968kB inactive_file:2549796kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:5620kB writeback:0kB mapped:38352kB shmem:36292kB slab_reclaimable:73196kB slab_unreclaimable:34528kB kernel_stack:1600kB pagetables:12656kB unstable:0kB bounce:0kB free_pcp:2480kB local_pcp:608kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:32:01 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 02:32:01 2020] Normal free:157788kB min:51492kB low:64364kB high:77236kB active_anon:33824kB inactive_anon:61808kB active_file:1982180kB inactive_file:9337536kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:12044kB writeback:356kB mapped:36608kB shmem:4856kB slab_reclaimable:405592kB slab_unreclaimable:118672kB kernel_stack:7216kB pagetables:38376kB unstable:0kB bounce:0kB free_pcp:2188kB local_pcp:464kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 02:32:01 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 02:32:01 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 02:32:01 2020] DMA32: 14340*4kB (UME) 4537*8kB (UME) 38*16kB (ME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 94264kB
[Thu Sep 10 02:32:01 2020] Normal: 7032*4kB (UM) 7665*8kB (UM) 4171*16kB (UME) 59*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 158072kB
[Thu Sep 10 02:32:01 2020] 3589751 total pagecache pages
[Thu Sep 10 02:32:01 2020] 2308 pages in swap cache
[Thu Sep 10 02:32:01 2020] Swap cache stats: add 122537, delete 120230, find 3531302/3544710
[Thu Sep 10 02:32:01 2020] Free swap  = 11483196kB
[Thu Sep 10 02:32:01 2020] Total swap = 11878316kB
[Thu Sep 10 02:32:01 2020] 4165912 pages RAM
[Thu Sep 10 02:32:01 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 02:32:01 2020] 90558 pages reserved
[Thu Sep 10 03:07:54 2020] warn_alloc_failed: 30 callbacks suppressed
[Thu Sep 10 03:07:54 2020] SYNO.FileStatio: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 03:07:54 2020] CPU: 1 PID: 11398 Comm: SYNO.FileStatio Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 03:07:54 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 03:07:54 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 03:07:54 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 03:07:54 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 03:07:54 2020] Call Trace:
[Thu Sep 10 03:07:54 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 03:07:54 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 03:07:54 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 03:07:54 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 03:07:54 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 03:07:54 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 03:07:54 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 03:07:54 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 03:07:54 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 03:07:54 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 03:07:54 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 03:07:54 2020]  <EOI> Mem-Info:
[Thu Sep 10 03:07:54 2020] active_anon:21649 inactive_anon:37462 isolated_anon:0
                            active_file:675851 inactive_file:2897005 isolated_file:0
                            unevictable:862 dirty:3824 writeback:0 unstable:0
                            slab_reclaimable:124378 slab_unreclaimable:38264
                            mapped:19864 shmem:10285 pagetables:13197 bounce:0
                            free:65144 free_pcp:870 free_cma:0
[Thu Sep 10 03:07:54 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 03:07:54 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 03:07:54 2020] DMA32 free:98060kB min:13976kB low:17468kB high:20964kB active_anon:49032kB inactive_anon:84628kB active_file:471352kB inactive_file:2513112kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:5212kB writeback:0kB mapped:39448kB shmem:36276kB slab_reclaimable:75864kB slab_unreclaimable:34748kB kernel_stack:1552kB pagetables:11952kB unstable:0kB bounce:0kB free_pcp:2172kB local_pcp:684kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 03:07:54 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 03:07:54 2020] Normal free:146636kB min:51492kB low:64364kB high:77236kB active_anon:37564kB inactive_anon:65220kB active_file:2232052kB inactive_file:9074908kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:10084kB writeback:0kB mapped:40008kB shmem:4864kB slab_reclaimable:421648kB slab_unreclaimable:118308kB kernel_stack:7264kB pagetables:40836kB unstable:0kB bounce:0kB free_pcp:1308kB local_pcp:696kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 03:07:54 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 03:07:54 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 03:07:54 2020] DMA32: 749*4kB (UME) 9067*8kB (UME) 1046*16kB (UME) 180*32kB (UM) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 98028kB
[Thu Sep 10 03:07:54 2020] Normal: 3376*4kB (UME) 9177*8kB (UME) 2293*16kB (UME) 705*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 146168kB
[Thu Sep 10 03:07:54 2020] 3585543 total pagecache pages
[Thu Sep 10 03:07:54 2020] 2307 pages in swap cache
[Thu Sep 10 03:07:54 2020] Swap cache stats: add 122679, delete 120373, find 3878117/3891644
[Thu Sep 10 03:07:54 2020] Free swap  = 11483324kB
[Thu Sep 10 03:07:54 2020] Total swap = 11878316kB
[Thu Sep 10 03:07:54 2020] 4165912 pages RAM
[Thu Sep 10 03:07:54 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 03:07:54 2020] 90558 pages reserved
[Thu Sep 10 03:08:02 2020] warn_alloc_failed: 63 callbacks suppressed
[Thu Sep 10 03:08:02 2020] syncd: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 03:08:02 2020] CPU: 1 PID: 17179 Comm: syncd Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 03:08:02 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 03:08:02 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 03:08:02 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 03:08:02 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 03:08:02 2020] Call Trace:
[Thu Sep 10 03:08:02 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 03:08:02 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 03:08:02 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 03:08:02 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 03:08:02 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 03:08:02 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 03:08:02 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 03:08:02 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 03:08:02 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 03:08:02 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 03:08:02 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 03:08:02 2020]  <EOI>  [<ffffffff81576e59>] ? _raw_spin_unlock_irqrestore+0x9/0x20
[Thu Sep 10 03:08:02 2020]  [<ffffffff8107ff9d>] __wake_up_sync_key+0x4d/0x60
[Thu Sep 10 03:08:02 2020]  [<ffffffff81491bbd>] sock_def_readable+0x3d/0x80
[Thu Sep 10 03:08:02 2020]  [<ffffffff8153a9aa>] unix_stream_sendmsg+0x1da/0x3c0
[Thu Sep 10 03:08:02 2020]  [<ffffffff8148dc34>] sock_sendmsg+0x34/0x40
[Thu Sep 10 03:08:02 2020]  [<ffffffff8148e438>] SYSC_sendto+0x118/0x150
[Thu Sep 10 03:08:02 2020]  [<ffffffff810a6ac0>] ? ktime_get_ts64+0x40/0xf0
[Thu Sep 10 03:08:02 2020]  [<ffffffff8148ea29>] SyS_sendto+0x9/0x10
[Thu Sep 10 03:08:02 2020]  [<ffffffff8157740a>] entry_SYSCALL_64_fastpath+0x1e/0x92
[Thu Sep 10 03:08:02 2020] Mem-Info:
[Thu Sep 10 03:08:02 2020] active_anon:20691 inactive_anon:37075 isolated_anon:0
                            active_file:677240 inactive_file:2896315 isolated_file:0
                            unevictable:862 dirty:4820 writeback:0 unstable:0
                            slab_reclaimable:124445 slab_unreclaimable:38281
                            mapped:18056 shmem:10285 pagetables:12759 bounce:0
                            free:65760 free_pcp:1186 free_cma:0
[Thu Sep 10 03:08:02 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 03:08:02 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 03:08:02 2020] DMA32 free:96204kB min:13976kB low:17468kB high:20964kB active_anon:49128kB inactive_anon:84624kB active_file:472564kB inactive_file:2513380kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:5944kB writeback:0kB mapped:38348kB shmem:36272kB slab_reclaimable:75880kB slab_unreclaimable:34736kB kernel_stack:1552kB pagetables:11952kB unstable:0kB bounce:0kB free_pcp:2608kB local_pcp:604kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 03:08:02 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 03:08:02 2020] Normal free:150956kB min:51492kB low:64364kB high:77236kB active_anon:33636kB inactive_anon:63676kB active_file:2236396kB inactive_file:9071880kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:13336kB writeback:0kB mapped:33876kB shmem:4868kB slab_reclaimable:421900kB slab_unreclaimable:118388kB kernel_stack:7280kB pagetables:39084kB unstable:0kB bounce:0kB free_pcp:2136kB local_pcp:708kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 03:08:02 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 03:08:02 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 03:08:02 2020] DMA32: 401*4kB (UM) 9067*8kB (UME) 1041*16kB (UME) 169*32kB (UME) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 96204kB
[Thu Sep 10 03:08:02 2020] Normal: 3893*4kB (UME) 9261*8kB (UME) 2338*16kB (UME) 741*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 150780kB
[Thu Sep 10 03:08:02 2020] 3586159 total pagecache pages
[Thu Sep 10 03:08:02 2020] 2307 pages in swap cache
[Thu Sep 10 03:08:02 2020] Swap cache stats: add 122679, delete 120373, find 3878963/3892490
[Thu Sep 10 03:08:02 2020] Free swap  = 11483324kB
[Thu Sep 10 03:08:02 2020] Total swap = 11878316kB
[Thu Sep 10 03:08:02 2020] 4165912 pages RAM
[Thu Sep 10 03:08:02 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 03:08:02 2020] 90558 pages reserved
[Thu Sep 10 03:08:08 2020] warn_alloc_failed: 89 callbacks suppressed
[Thu Sep 10 03:08:08 2020] syncd: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 03:08:08 2020] CPU: 1 PID: 17188 Comm: syncd Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 03:08:08 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 03:08:08 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 03:08:08 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 03:08:08 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 03:08:08 2020] Call Trace:
[Thu Sep 10 03:08:08 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 03:08:08 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 03:08:08 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 03:08:08 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 03:08:08 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 03:08:08 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 03:08:08 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 03:08:08 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 03:08:08 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 03:08:08 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 03:08:08 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 03:08:08 2020]  <EOI> Mem-Info:
[Thu Sep 10 03:08:08 2020] active_anon:21202 inactive_anon:37060 isolated_anon:0
                            active_file:676886 inactive_file:2896590 isolated_file:0
                            unevictable:862 dirty:3817 writeback:0 unstable:0
                            slab_reclaimable:124485 slab_unreclaimable:38251
                            free:65477 free_pcp:1007 free_cma:0
[Thu Sep 10 03:08:08 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 03:08:08 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 03:08:08 2020] DMA32 free:94700kB min:13976kB low:17468kB high:20964kB active_anon:50692kB inactive_anon:84624kB active_file:472216kB inactive_file:2513612kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:4060kB writeback:0kB mapped:38348kB shmem:36272kB slab_reclaimable:75940kB slab_unreclaimable:34712kB kernel_stack:1568kB pagetables:11988kB unstable:0kB bounce:0kB free_pcp:2468kB local_pcp:624kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 03:08:08 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 03:08:08 2020] Normal free:151328kB min:51492kB low:64364kB high:77236kB active_anon:34116kB inactive_anon:63616kB active_file:2235328kB inactive_file:9072748kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:11208kB writeback:0kB mapped:33876kB shmem:4868kB slab_reclaimable:422000kB slab_unreclaimable:118292kB kernel_stack:7248kB pagetables:39048kB unstable:0kB bounce:0kB free_pcp:1560kB local_pcp:608kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 03:08:08 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 03:08:08 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 03:08:08 2020] DMA32: 675*4kB (UM) 8888*8kB (UM) 1012*16kB (UM) 146*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 94668kB
[Thu Sep 10 03:08:08 2020] Normal: 3626*4kB (UM) 9221*8kB (UME) 2325*16kB (UME) 803*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 151168kB
[Thu Sep 10 03:08:08 2020] 3586033 total pagecache pages
[Thu Sep 10 03:08:08 2020] 2307 pages in swap cache
[Thu Sep 10 03:08:08 2020] Swap cache stats: add 122679, delete 120373, find 3879608/3893135
[Thu Sep 10 03:08:08 2020] Free swap  = 11483324kB
[Thu Sep 10 03:08:08 2020] Total swap = 11878316kB
[Thu Sep 10 03:08:08 2020] 4165912 pages RAM
[Thu Sep 10 03:08:08 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 03:08:08 2020] 90558 pages reserved
[Thu Sep 10 03:08:20 2020] warn_alloc_failed: 68 callbacks suppressed
[Thu Sep 10 03:08:20 2020] syncd: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 03:08:20 2020] CPU: 1 PID: 26366 Comm: syncd Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 03:08:20 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 03:08:20 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 03:08:20 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 03:08:20 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 03:08:20 2020] Call Trace:
[Thu Sep 10 03:08:20 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 03:08:20 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 03:08:20 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 03:08:20 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 03:08:20 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 03:08:20 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 03:08:20 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 03:08:20 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 03:08:20 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 03:08:20 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 03:08:20 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 03:08:20 2020]  <EOI> Mem-Info:
[Thu Sep 10 03:08:20 2020] active_anon:20703 inactive_anon:37073 isolated_anon:0
                            active_file:675261 inactive_file:2896575 isolated_file:0
                            unevictable:862 dirty:3735 writeback:0 unstable:0
                            slab_reclaimable:124562 slab_unreclaimable:38219
                            free:67603 free_pcp:1031 free_cma:0
[Thu Sep 10 03:08:20 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 03:08:20 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 03:08:20 2020] DMA32 free:94592kB min:13976kB low:17468kB high:20964kB active_anon:49780kB inactive_anon:84640kB active_file:470904kB inactive_file:2516268kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:6504kB writeback:0kB mapped:38348kB shmem:36272kB slab_reclaimable:76036kB slab_unreclaimable:34704kB kernel_stack:1552kB pagetables:11988kB unstable:0kB bounce:0kB free_pcp:1712kB local_pcp:704kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 03:08:20 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 03:08:20 2020] Normal free:159940kB min:51492kB low:64364kB high:77236kB active_anon:33032kB inactive_anon:63652kB active_file:2230140kB inactive_file:9070032kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:8436kB writeback:0kB mapped:33876kB shmem:4868kB slab_reclaimable:422212kB slab_unreclaimable:118172kB kernel_stack:7264kB pagetables:39048kB unstable:0kB bounce:0kB free_pcp:2412kB local_pcp:560kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 03:08:20 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 03:08:20 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 03:08:20 2020] DMA32: 960*4kB (UME) 8836*8kB (UME) 1003*16kB (UME) 133*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 94832kB
[Thu Sep 10 03:08:20 2020] Normal: 8156*4kB (UME) 9061*8kB (UME) 2220*16kB (UME) 604*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 159960kB
[Thu Sep 10 03:08:20 2020] 3584448 total pagecache pages
[Thu Sep 10 03:08:20 2020] 2308 pages in swap cache
[Thu Sep 10 03:08:20 2020] Swap cache stats: add 122684, delete 120377, find 3881411/3894942
[Thu Sep 10 03:08:20 2020] Free swap  = 11483340kB
[Thu Sep 10 03:08:20 2020] Total swap = 11878316kB
[Thu Sep 10 03:08:20 2020] 4165912 pages RAM
[Thu Sep 10 03:08:20 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 03:08:20 2020] 90558 pages reserved
[Thu Sep 10 03:48:31 2020] warn_alloc_failed: 43 callbacks suppressed
[Thu Sep 10 03:48:31 2020] syncd: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 03:48:31 2020] CPU: 1 PID: 19510 Comm: syncd Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 03:48:31 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 03:48:31 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 03:48:31 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 03:48:31 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Thu Sep 10 03:48:31 2020] Call Trace:
[Thu Sep 10 03:48:31 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 03:48:31 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 03:48:31 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Thu Sep 10 03:48:31 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 03:48:31 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 03:48:31 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 03:48:31 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 03:48:31 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 03:48:31 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 03:48:31 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 03:48:31 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 03:48:31 2020]  <EOI>  [<ffffffff81184b84>] ? posix_same_owner+0x24/0x40
[Thu Sep 10 03:48:31 2020]  [<ffffffff811857e2>] ? posix_locks_conflict+0x12/0x60
[Thu Sep 10 03:48:31 2020]  [<ffffffff81185b53>] __posix_lock_file+0x83/0x610
[Thu Sep 10 03:48:31 2020]  [<ffffffff811865da>] vfs_lock_file+0x2a/0x30
[Thu Sep 10 03:48:31 2020]  [<ffffffff81186883>] do_lock_file_wait.part.30+0x33/0xb0
[Thu Sep 10 03:48:31 2020]  [<ffffffff81277611>] ? apparmor_file_lock+0x21/0x30
[Thu Sep 10 03:48:31 2020]  [<ffffffff81187a15>] fcntl_setlk+0xf5/0x2a0
[Thu Sep 10 03:48:31 2020]  [<ffffffff8114ce9e>] SyS_fcntl+0x2ce/0x490
[Thu Sep 10 03:48:31 2020]  [<ffffffff8157740a>] entry_SYSCALL_64_fastpath+0x1e/0x92
[Thu Sep 10 03:48:31 2020] Mem-Info:
[Thu Sep 10 03:48:31 2020] active_anon:22246 inactive_anon:37021 isolated_anon:0
                            active_file:734661 inactive_file:2816283 isolated_file:0
                            unevictable:862 dirty:4856 writeback:16 unstable:0
                            slab_reclaimable:144576 slab_unreclaimable:38401
                            mapped:19181 shmem:10285 pagetables:13015 bounce:0
                            free:66740 free_pcp:799 free_cma:0
[Thu Sep 10 03:48:31 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 03:48:31 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 03:48:31 2020] DMA32 free:103004kB min:13976kB low:17468kB high:20964kB active_anon:52668kB inactive_anon:84888kB active_file:492400kB inactive_file:2472520kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:4556kB writeback:0kB mapped:39448kB shmem:36256kB slab_reclaimable:86500kB slab_unreclaimable:34624kB kernel_stack:1536kB pagetables:12124kB unstable:0kB bounce:0kB free_pcp:2128kB local_pcp:584kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 03:48:31 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 03:48:31 2020] Normal free:148076kB min:51492kB low:64364kB high:77236kB active_anon:36316kB inactive_anon:63196kB active_file:2446244kB inactive_file:8792612kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:14868kB writeback:64kB mapped:37276kB shmem:4884kB slab_reclaimable:491804kB slab_unreclaimable:118980kB kernel_stack:7216kB pagetables:39936kB unstable:0kB bounce:0kB free_pcp:1036kB local_pcp:260kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 03:48:31 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 03:48:31 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 03:48:31 2020] DMA32: 2093*4kB (UME) 10177*8kB (UME) 822*16kB (UME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 102940kB
[Thu Sep 10 03:48:31 2020] Normal: 7836*4kB (UME) 9626*8kB (UME) 2463*16kB (UME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 147760kB
[Thu Sep 10 03:48:31 2020] 3563645 total pagecache pages
[Thu Sep 10 03:48:31 2020] 2333 pages in swap cache
[Thu Sep 10 03:48:31 2020] Swap cache stats: add 122851, delete 120519, find 4213495/4227229
[Thu Sep 10 03:48:31 2020] Free swap  = 11483804kB
[Thu Sep 10 03:48:31 2020] Total swap = 11878316kB
[Thu Sep 10 03:48:31 2020] 4165912 pages RAM
[Thu Sep 10 03:48:31 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 03:48:31 2020] 90558 pages reserved
[Thu Sep 10 13:12:18 2020] warn_alloc_failed: 86 callbacks suppressed
[Thu Sep 10 13:12:18 2020] kworker/u8:3: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 13:12:18 2020] CPU: 1 PID: 27049 Comm: kworker/u8:3 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 13:12:18 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 13:12:18 2020] Workqueue: btrfs-endio-write btrfs_endio_write_helper [btrfs]
[Thu Sep 10 13:12:18 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 13:12:18 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 13:12:18 2020]  ffffffff8186f0f0 ffff88041f283ca0 ffffffff00000030 ffff8803dd897fc0
[Thu Sep 10 13:12:18 2020] Call Trace:
[Thu Sep 10 13:12:18 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 13:12:18 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 13:12:18 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 13:12:18 2020]  [<ffffffff814a8f98>] ? __netif_receive_skb+0x18/0x60
[Thu Sep 10 13:12:18 2020]  [<ffffffff814a9015>] ? netif_receive_skb_internal+0x35/0xa0
[Thu Sep 10 13:12:18 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 13:12:18 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 13:12:18 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 13:12:18 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 13:12:18 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 13:12:18 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 13:12:18 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 13:12:18 2020]  <EOI>  [<ffffffff812c8934>] ? __memmove+0x24/0x1a0
[Thu Sep 10 13:12:18 2020]  [<ffffffffa0b953fc>] ? copy_pages+0x7c/0x80 [btrfs]
[Thu Sep 10 13:12:18 2020]  [<ffffffffa0b9f4d1>] memcpy_extent_buffer+0xb1/0x100 [btrfs]
[Thu Sep 10 13:12:18 2020]  [<ffffffffa0b9f5fc>] memmove_extent_buffer+0xdc/0x120 [btrfs]
[Thu Sep 10 13:12:18 2020]  [<ffffffffa0b4cfd4>] btrfs_extend_item+0x144/0x210 [btrfs]
[Thu Sep 10 13:12:18 2020]  [<ffffffffa0b6719b>] btrfs_csum_file_blocks+0x54b/0x580 [btrfs]
[Thu Sep 10 13:12:18 2020]  [<ffffffffa0b77899>] add_pending_csums.isra.60+0x49/0x70 [btrfs]
[Thu Sep 10 13:12:18 2020]  [<ffffffffa0b7f260>] btrfs_finish_ordered_io+0x340/0x690 [btrfs]
[Thu Sep 10 13:12:18 2020]  [<ffffffffa0b7f860>] finish_ordered_fn+0x10/0x20 [btrfs]
[Thu Sep 10 13:12:18 2020]  [<ffffffffa0babf3d>] normal_work_helper+0x19d/0x1b0 [btrfs]
[Thu Sep 10 13:12:18 2020]  [<ffffffffa0bac15d>] btrfs_endio_write_helper+0xd/0x10 [btrfs]
[Thu Sep 10 13:12:18 2020]  [<ffffffff8105fe92>] process_one_work+0x142/0x360
[Thu Sep 10 13:12:18 2020]  [<ffffffff8106055a>] worker_thread+0x4a/0x450
[Thu Sep 10 13:12:18 2020]  [<ffffffff81060510>] ? max_active_store+0x60/0x60
[Thu Sep 10 13:12:18 2020]  [<ffffffff810652d6>] kthread+0xc6/0xe0
[Thu Sep 10 13:12:18 2020]  [<ffffffff81065210>] ? kthread_create_on_node+0x180/0x180
[Thu Sep 10 13:12:18 2020]  [<ffffffff815777bf>] ret_from_fork+0x3f/0x80
[Thu Sep 10 13:12:18 2020] Mem-Info:
[Thu Sep 10 13:12:18 2020] active_anon:22238 inactive_anon:36362 isolated_anon:0
                            active_file:209587 inactive_file:3298879 isolated_file:0
                            unevictable:862 dirty:287213 writeback:21487 unstable:0
                            slab_reclaimable:63639 slab_unreclaimable:38540
                            mapped:17705 shmem:10306 pagetables:12494 bounce:0
                            free:193523 free_pcp:851 free_cma:0
[Thu Sep 10 13:12:18 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 13:12:18 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 13:12:18 2020] DMA32 free:610764kB min:13976kB low:17468kB high:20964kB active_anon:53340kB inactive_anon:84568kB active_file:547068kB inactive_file:1950944kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:5640kB writeback:752kB mapped:39944kB shmem:36232kB slab_reclaimable:47548kB slab_unreclaimable:34484kB kernel_stack:1488kB pagetables:11176kB unstable:0kB bounce:0kB free_pcp:1256kB local_pcp:120kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 13:12:18 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 13:12:18 2020] Normal free:147448kB min:51492kB low:64364kB high:77236kB active_anon:35612kB inactive_anon:60880kB active_file:291280kB inactive_file:11244572kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:1142920kB writeback:84904kB mapped:30876kB shmem:4992kB slab_reclaimable:207008kB slab_unreclaimable:119676kB kernel_stack:6960kB pagetables:38800kB unstable:0kB bounce:0kB free_pcp:2148kB local_pcp:228kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 13:12:18 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 13:12:18 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 13:12:18 2020] DMA32: 15900*4kB (UME) 28934*8kB (UME) 19736*16kB (UME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 610848kB
[Thu Sep 10 13:12:18 2020] Normal: 22621*4kB (UME) 7113*8kB (UM) 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 147388kB
[Thu Sep 10 13:12:18 2020] 3521040 total pagecache pages
[Thu Sep 10 13:12:18 2020] 2226 pages in swap cache
[Thu Sep 10 13:12:18 2020] Swap cache stats: add 123540, delete 121315, find 8159077/8173858
[Thu Sep 10 13:12:18 2020] Free swap  = 11486700kB
[Thu Sep 10 13:12:18 2020] Total swap = 11878316kB
[Thu Sep 10 13:12:18 2020] 4165912 pages RAM
[Thu Sep 10 13:12:18 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 13:12:18 2020] 90558 pages reserved
[Thu Sep 10 13:12:26 2020] warn_alloc_failed: 9 callbacks suppressed
[Thu Sep 10 13:12:26 2020] md3_defer0: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 13:12:26 2020] CPU: 1 PID: 11533 Comm: md3_defer0 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 13:12:26 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 13:12:26 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 13:12:26 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 13:12:26 2020]  ffffffff8186f0f0 ffff88041f283ca0 ffffffff00000030 ffff8803de54abe0
[Thu Sep 10 13:12:26 2020] Call Trace:
[Thu Sep 10 13:12:26 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 13:12:26 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 13:12:26 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 13:12:26 2020]  [<ffffffff814a8f98>] ? __netif_receive_skb+0x18/0x60
[Thu Sep 10 13:12:26 2020]  [<ffffffff814a9015>] ? netif_receive_skb_internal+0x35/0xa0
[Thu Sep 10 13:12:26 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 13:12:26 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 13:12:26 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 13:12:26 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 13:12:26 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 13:12:26 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 13:12:26 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 13:12:26 2020]  <EOI>  [<ffffffff8143caaa>] ? syno_flush_deferred_bios+0x19a/0x200
[Thu Sep 10 13:12:26 2020]  [<ffffffff814531f3>] md_thread+0x103/0x110
[Thu Sep 10 13:12:26 2020]  [<ffffffff81080050>] ? wait_woken+0x80/0x80
[Thu Sep 10 13:12:26 2020]  [<ffffffff814530f0>] ? find_pers+0x70/0x70
[Thu Sep 10 13:12:26 2020]  [<ffffffff810652d6>] kthread+0xc6/0xe0
[Thu Sep 10 13:12:26 2020]  [<ffffffff81065210>] ? kthread_create_on_node+0x180/0x180
[Thu Sep 10 13:12:26 2020]  [<ffffffff815777bf>] ret_from_fork+0x3f/0x80
[Thu Sep 10 13:12:26 2020] Mem-Info:
[Thu Sep 10 13:12:26 2020] active_anon:22142 inactive_anon:36167 isolated_anon:0
                            active_file:200052 inactive_file:3423654 isolated_file:0
                            unevictable:862 dirty:352761 writeback:13211 unstable:0
                            slab_reclaimable:62121 slab_unreclaimable:38461
                            mapped:17014 shmem:10298 pagetables:12129 bounce:0
                            free:80264 free_pcp:651 free_cma:0
[Thu Sep 10 13:12:26 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 13:12:26 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 13:12:26 2020] DMA32 free:229256kB min:13976kB low:17468kB high:20964kB active_anon:53412kB inactive_anon:84572kB active_file:545916kB inactive_file:2332340kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:506972kB writeback:956kB mapped:39064kB shmem:36232kB slab_reclaimable:47276kB slab_unreclaimable:34524kB kernel_stack:1520kB pagetables:11668kB unstable:0kB bounce:0kB free_pcp:856kB local_pcp:248kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 13:12:26 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 13:12:26 2020] Normal free:75920kB min:51492kB low:64364kB high:77236kB active_anon:35156kB inactive_anon:60096kB active_file:254292kB inactive_file:11362276kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:904072kB writeback:51888kB mapped:28992kB shmem:4960kB slab_reclaimable:201208kB slab_unreclaimable:119320kB kernel_stack:6976kB pagetables:36848kB unstable:0kB bounce:0kB free_pcp:1748kB local_pcp:732kB free_cma:0kB writeback_tmp:0kB pages_scanned:256 all_unreclaimable? no
[Thu Sep 10 13:12:26 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 13:12:26 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 13:12:26 2020] DMA32: 10241*4kB (UE) 10708*8kB (UME) 5129*16kB (UME) 636*32kB (UM) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 229044kB
[Thu Sep 10 13:12:26 2020] Normal: 15969*4kB (UME) 1496*8kB (UME) 5*16kB (U) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 75924kB
[Thu Sep 10 13:12:26 2020] 3636297 total pagecache pages
[Thu Sep 10 13:12:26 2020] 2216 pages in swap cache
[Thu Sep 10 13:12:26 2020] Swap cache stats: add 123561, delete 121346, find 8159961/8174753
[Thu Sep 10 13:12:26 2020] Free swap  = 11486672kB
[Thu Sep 10 13:12:26 2020] Total swap = 11878316kB
[Thu Sep 10 13:12:26 2020] 4165912 pages RAM
[Thu Sep 10 13:12:26 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 13:12:26 2020] 90558 pages reserved
[Thu Sep 10 13:12:36 2020] warn_alloc_failed: 11 callbacks suppressed
[Thu Sep 10 13:12:36 2020] kworker/u8:3: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 13:12:36 2020] CPU: 1 PID: 27049 Comm: kworker/u8:3 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 13:12:36 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 13:12:36 2020] Workqueue: writeback wb_workfn (flush-btrfs-1)
[Thu Sep 10 13:12:36 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 13:12:36 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 13:12:36 2020]  ffffffff8186f0f0 ffff88041f283ca0 ffffffff00000030 ffff8803da6a7b20
[Thu Sep 10 13:12:36 2020] Call Trace:
[Thu Sep 10 13:12:36 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 13:12:36 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 13:12:36 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 13:12:36 2020]  [<ffffffff814a8f98>] ? __netif_receive_skb+0x18/0x60
[Thu Sep 10 13:12:36 2020]  [<ffffffff814a9015>] ? netif_receive_skb_internal+0x35/0xa0
[Thu Sep 10 13:12:36 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 13:12:36 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 13:12:36 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 13:12:36 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 13:12:36 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 13:12:36 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 13:12:36 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 13:12:36 2020]  <EOI>  [<ffffffff810e40ba>] ? find_get_pages_tag+0x5a/0x180
[Thu Sep 10 13:12:36 2020]  [<ffffffff810f0c3c>] pagevec_lookup_tag+0x1c/0x30
[Thu Sep 10 13:12:36 2020]  [<ffffffffa0b99944>] extent_write_cache_pages.isra.47.constprop.64+0xf4/0x3b0 [btrfs]
[Thu Sep 10 13:12:36 2020]  [<ffffffffa0b9bd19>] extent_writepages+0x49/0x60 [btrfs]
[Thu Sep 10 13:12:36 2020]  [<ffffffffa0b7a6e0>] ? btrfs_submit_direct+0x920/0x920 [btrfs]
[Thu Sep 10 13:12:36 2020]  [<ffffffffa0b77046>] btrfs_writepages+0x26/0x30 [btrfs]
[Thu Sep 10 13:12:36 2020]  [<ffffffff810eff79>] do_writepages+0x19/0x30
[Thu Sep 10 13:12:36 2020]  [<ffffffff81165b84>] __writeback_single_inode+0x34/0x170
[Thu Sep 10 13:12:36 2020]  [<ffffffff81166252>] writeback_sb_inodes+0x2a2/0x5a0
[Thu Sep 10 13:12:36 2020]  [<ffffffff811665dc>] __writeback_inodes_wb+0x8c/0xc0
[Thu Sep 10 13:12:36 2020]  [<ffffffff81166891>] wb_writeback+0x1e1/0x1f0
[Thu Sep 10 13:12:36 2020]  [<ffffffff81166de4>] wb_workfn+0x1d4/0x280
[Thu Sep 10 13:12:36 2020]  [<ffffffff8105fe92>] process_one_work+0x142/0x360
[Thu Sep 10 13:12:36 2020]  [<ffffffff8106055a>] worker_thread+0x4a/0x450
[Thu Sep 10 13:12:36 2020]  [<ffffffff81060510>] ? max_active_store+0x60/0x60
[Thu Sep 10 13:12:36 2020]  [<ffffffff810652d6>] kthread+0xc6/0xe0
[Thu Sep 10 13:12:36 2020]  [<ffffffff81065210>] ? kthread_create_on_node+0x180/0x180
[Thu Sep 10 13:12:36 2020]  [<ffffffff815777bf>] ret_from_fork+0x3f/0x80
[Thu Sep 10 13:12:36 2020] Mem-Info:
[Thu Sep 10 13:12:36 2020] active_anon:22105 inactive_anon:36200 isolated_anon:0
                            active_file:198595 inactive_file:3444938 isolated_file:0
                            unevictable:862 dirty:375036 writeback:13784 unstable:0
                            slab_reclaimable:60737 slab_unreclaimable:38375
                            mapped:17145 shmem:10298 pagetables:12129 bounce:0
                            free:62242 free_pcp:545 free_cma:0
[Thu Sep 10 13:12:36 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 13:12:36 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 13:12:36 2020] DMA32 free:132772kB min:13976kB low:17468kB high:20964kB active_anon:53356kB inactive_anon:84572kB active_file:544924kB inactive_file:2432968kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:277248kB writeback:292kB mapped:39408kB shmem:36232kB slab_reclaimable:46400kB slab_unreclaimable:34452kB kernel_stack:1504kB pagetables:11176kB unstable:0kB bounce:0kB free_pcp:796kB local_pcp:336kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 13:12:36 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 13:12:36 2020] Normal free:100316kB min:51492kB low:64364kB high:77236kB active_anon:35064kB inactive_anon:60228kB active_file:249456kB inactive_file:11346784kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:1222896kB writeback:54844kB mapped:29172kB shmem:4960kB slab_reclaimable:196548kB slab_unreclaimable:119048kB kernel_stack:6976kB pagetables:37340kB unstable:0kB bounce:0kB free_pcp:1384kB local_pcp:740kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 13:12:36 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 13:12:36 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 13:12:36 2020] DMA32: 10370*4kB (UE) 10790*8kB (UME) 284*16kB (U) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 132344kB
[Thu Sep 10 13:12:36 2020] Normal: 22159*4kB (UME) 1420*8kB (UME) 9*16kB (U) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 100140kB
[Thu Sep 10 13:12:36 2020] 3656067 total pagecache pages
[Thu Sep 10 13:12:36 2020] 2216 pages in swap cache
[Thu Sep 10 13:12:36 2020] Swap cache stats: add 123561, delete 121346, find 8160766/8175559
[Thu Sep 10 13:12:36 2020] Free swap  = 11486672kB
[Thu Sep 10 13:12:36 2020] Total swap = 11878316kB
[Thu Sep 10 13:12:36 2020] 4165912 pages RAM
[Thu Sep 10 13:12:36 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 13:12:36 2020] 90558 pages reserved
[Thu Sep 10 13:12:57 2020] warn_alloc_failed: 8 callbacks suppressed
[Thu Sep 10 13:12:57 2020] kworker/u8:2: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 13:12:57 2020] CPU: 1 PID: 4718 Comm: kworker/u8:2 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 13:12:57 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 13:12:57 2020] Workqueue: btrfs-worker btrfs_worker_helper [btrfs]
[Thu Sep 10 13:12:57 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 13:12:57 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 13:12:57 2020]  ffffffff8186f0f0 ffff88041f283ca0 ffffffff00000030 ffff880061710940
[Thu Sep 10 13:12:57 2020] Call Trace:
[Thu Sep 10 13:12:57 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 13:12:57 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 13:12:57 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 13:12:57 2020]  [<ffffffff814a8f98>] ? __netif_receive_skb+0x18/0x60
[Thu Sep 10 13:12:57 2020]  [<ffffffff814a9015>] ? netif_receive_skb_internal+0x35/0xa0
[Thu Sep 10 13:12:57 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 13:12:57 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 13:12:57 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 13:12:57 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 13:12:57 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 13:12:57 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 13:12:57 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 13:12:57 2020]  <EOI>  [<ffffffff81576e7f>] ? _raw_spin_unlock_irq+0xf/0x20
[Thu Sep 10 13:12:57 2020]  [<ffffffff81448524>] raid5_get_active_stripe+0xc4/0x670
[Thu Sep 10 13:12:57 2020]  [<ffffffff81448c67>] make_request+0x197/0xbe0
[Thu Sep 10 13:12:57 2020]  [<ffffffff81080050>] ? wait_woken+0x80/0x80
[Thu Sep 10 13:12:57 2020]  [<ffffffff8145981d>] md_make_request+0x19d/0x460
[Thu Sep 10 13:12:57 2020]  [<ffffffff8146889c>] ? dm_make_request+0x8c/0xe0
[Thu Sep 10 13:12:57 2020]  [<ffffffff81299da5>] generic_make_request+0xf5/0x2c0
[Thu Sep 10 13:12:57 2020]  [<ffffffff81299ff2>] submit_bio+0x82/0x180
[Thu Sep 10 13:12:57 2020]  [<ffffffffa0bf6de1>] ? btrfs_crc32c+0x51/0x70 [btrfs]
[Thu Sep 10 13:12:57 2020]  [<ffffffffa0ba7676>] btrfs_map_bio+0x1c6/0x330 [btrfs]
[Thu Sep 10 13:12:57 2020]  [<ffffffffa0b76a8c>] __btrfs_submit_bio_done+0x1c/0x40 [btrfs]
[Thu Sep 10 13:12:57 2020]  [<ffffffffa0b68f80>] run_one_async_done+0xa0/0xc0 [btrfs]
[Thu Sep 10 13:12:57 2020]  [<ffffffffa0babeb9>] normal_work_helper+0x119/0x1b0 [btrfs]
[Thu Sep 10 13:12:57 2020]  [<ffffffffa0bac07d>] btrfs_worker_helper+0xd/0x10 [btrfs]
[Thu Sep 10 13:12:57 2020]  [<ffffffff8105fe92>] process_one_work+0x142/0x360
[Thu Sep 10 13:12:57 2020]  [<ffffffff8106055a>] worker_thread+0x4a/0x450
[Thu Sep 10 13:12:57 2020]  [<ffffffff81060510>] ? max_active_store+0x60/0x60
[Thu Sep 10 13:12:57 2020]  [<ffffffff810652d6>] kthread+0xc6/0xe0
[Thu Sep 10 13:12:57 2020]  [<ffffffff81065210>] ? kthread_create_on_node+0x180/0x180
[Thu Sep 10 13:12:57 2020]  [<ffffffff815777bf>] ret_from_fork+0x3f/0x80
[Thu Sep 10 13:12:57 2020] Mem-Info:
[Thu Sep 10 13:12:57 2020] active_anon:22172 inactive_anon:36083 isolated_anon:0
                            active_file:191913 inactive_file:3453633 isolated_file:0
                            unevictable:862 dirty:349770 writeback:16641 unstable:0
                            slab_reclaimable:59591 slab_unreclaimable:38296
                            mapped:16721 shmem:10285 pagetables:12129 bounce:0
                            free:60841 free_pcp:996 free_cma:0
[Thu Sep 10 13:12:57 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 13:12:57 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 13:12:57 2020] DMA32 free:109248kB min:13976kB low:17468kB high:20964kB active_anon:53316kB inactive_anon:84572kB active_file:548516kB inactive_file:2454148kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:11552kB writeback:516kB mapped:39408kB shmem:36232kB slab_reclaimable:44092kB slab_unreclaimable:34368kB kernel_stack:1472kB pagetables:11176kB unstable:0kB bounce:0kB free_pcp:1968kB local_pcp:536kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 13:12:57 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 13:12:57 2020] Normal free:118236kB min:51492kB low:64364kB high:77236kB active_anon:35372kB inactive_anon:59760kB active_file:219136kB inactive_file:11360384kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:1387236kB writeback:66048kB mapped:27476kB shmem:4908kB slab_reclaimable:194272kB slab_unreclaimable:118816kB kernel_stack:6960kB pagetables:37340kB unstable:0kB bounce:0kB free_pcp:2016kB local_pcp:764kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 13:12:57 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 13:12:57 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 13:12:57 2020] DMA32: 8741*4kB (UE) 9239*8kB (U) 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 108876kB
[Thu Sep 10 13:12:57 2020] Normal: 29270*4kB (UME) 91*8kB (UM) 19*16kB (UM) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 118112kB
[Thu Sep 10 13:12:57 2020] 3658149 total pagecache pages
[Thu Sep 10 13:12:57 2020] 2212 pages in swap cache
[Thu Sep 10 13:12:57 2020] Swap cache stats: add 123620, delete 121409, find 8162698/8177508
[Thu Sep 10 13:12:57 2020] Free swap  = 11486528kB
[Thu Sep 10 13:12:57 2020] Total swap = 11878316kB
[Thu Sep 10 13:12:57 2020] 4165912 pages RAM
[Thu Sep 10 13:12:57 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 13:12:57 2020] 90558 pages reserved
[Thu Sep 10 13:13:29 2020] warn_alloc_failed: 1 callbacks suppressed
[Thu Sep 10 13:13:29 2020] md3_defer1: page allocation failure: order:4, mode:0x2084020
[Thu Sep 10 13:13:29 2020] CPU: 1 PID: 11534 Comm: md3_defer1 Tainted: P           OE   4.4.59+ #25426
[Thu Sep 10 13:13:29 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Thu Sep 10 13:13:29 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Thu Sep 10 13:13:29 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Thu Sep 10 13:13:29 2020]  ffffffff8186f0f0 ffff88041f283ca0 ffffffff00000030 ffff8800c156cfa0
[Thu Sep 10 13:13:29 2020] Call Trace:
[Thu Sep 10 13:13:29 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Thu Sep 10 13:13:29 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Thu Sep 10 13:13:29 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Thu Sep 10 13:13:29 2020]  [<ffffffff814a8f98>] ? __netif_receive_skb+0x18/0x60
[Thu Sep 10 13:13:29 2020]  [<ffffffff814a9015>] ? netif_receive_skb_internal+0x35/0xa0
[Thu Sep 10 13:13:29 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Thu Sep 10 13:13:29 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Thu Sep 10 13:13:29 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Thu Sep 10 13:13:29 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Thu Sep 10 13:13:29 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Thu Sep 10 13:13:29 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Thu Sep 10 13:13:29 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Thu Sep 10 13:13:29 2020]  <EOI>  [<ffffffff81576e7f>] ? _raw_spin_unlock_irq+0xf/0x20
[Thu Sep 10 13:13:29 2020]  [<ffffffff813b8296>] scsi_request_fn+0xd6/0x580
[Thu Sep 10 13:13:29 2020]  [<ffffffff812976de>] __blk_run_queue+0x2e/0x40
[Thu Sep 10 13:13:29 2020]  [<ffffffff8129ba98>] blk_flush_plug_list+0x1c8/0x240
[Thu Sep 10 13:13:29 2020]  [<ffffffff8129bdf7>] blk_finish_plug+0x27/0x40
[Thu Sep 10 13:13:29 2020]  [<ffffffff8143cadd>] syno_flush_deferred_bios+0x1cd/0x200
[Thu Sep 10 13:13:29 2020]  [<ffffffff814531f3>] md_thread+0x103/0x110
[Thu Sep 10 13:13:29 2020]  [<ffffffff81080050>] ? wait_woken+0x80/0x80
[Thu Sep 10 13:13:29 2020]  [<ffffffff814530f0>] ? find_pers+0x70/0x70
[Thu Sep 10 13:13:29 2020]  [<ffffffff810652d6>] kthread+0xc6/0xe0
[Thu Sep 10 13:13:29 2020]  [<ffffffff81065210>] ? kthread_create_on_node+0x180/0x180
[Thu Sep 10 13:13:29 2020]  [<ffffffff815777bf>] ret_from_fork+0x3f/0x80
[Thu Sep 10 13:13:29 2020] Mem-Info:
[Thu Sep 10 13:13:29 2020] active_anon:22159 inactive_anon:36081 isolated_anon:0
                            active_file:156239 inactive_file:3504164 isolated_file:0
                            unevictable:862 dirty:353629 writeback:12876 unstable:0
                            slab_reclaimable:61104 slab_unreclaimable:38320
                            mapped:16673 shmem:10284 pagetables:12129 bounce:0
                            free:44422 free_pcp:1071 free_cma:0
[Thu Sep 10 13:13:29 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Thu Sep 10 13:13:29 2020] lowmem_reserve[]: 0 3366 15875 15875
[Thu Sep 10 13:13:29 2020] DMA32 free:88800kB min:13976kB low:17468kB high:20964kB active_anon:53380kB inactive_anon:84584kB active_file:426632kB inactive_file:2596840kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:91020kB writeback:8580kB mapped:39408kB shmem:36236kB slab_reclaimable:42684kB slab_unreclaimable:34548kB kernel_stack:1488kB pagetables:11188kB unstable:0kB bounce:0kB free_pcp:2544kB local_pcp:720kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 13:13:29 2020] lowmem_reserve[]: 0 0 12508 12508
[Thu Sep 10 13:13:29 2020] Normal free:73008kB min:51492kB low:64364kB high:77236kB active_anon:35256kB inactive_anon:59740kB active_file:198324kB inactive_file:11419816kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:1323496kB writeback:42924kB mapped:27284kB shmem:4900kB slab_reclaimable:201732kB slab_unreclaimable:118732kB kernel_stack:6992kB pagetables:37328kB unstable:0kB bounce:0kB free_pcp:1740kB local_pcp:644kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Thu Sep 10 13:13:29 2020] lowmem_reserve[]: 0 0 0 0
[Thu Sep 10 13:13:29 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Thu Sep 10 13:13:29 2020] DMA32: 10949*4kB (UME) 4302*8kB (UE) 664*16kB (UE) 1*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 88868kB
[Thu Sep 10 13:13:29 2020] Normal: 14804*4kB (UE) 1004*8kB (UE) 348*16kB (UM) 1*32kB (M) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 72848kB
[Thu Sep 10 13:13:29 2020] 3672874 total pagecache pages
[Thu Sep 10 13:13:29 2020] 2193 pages in swap cache
[Thu Sep 10 13:13:29 2020] Swap cache stats: add 123671, delete 121479, find 8165992/8180834
[Thu Sep 10 13:13:29 2020] Free swap  = 11486504kB
[Thu Sep 10 13:13:29 2020] Total swap = 11878316kB
[Thu Sep 10 13:13:29 2020] 4165912 pages RAM
[Thu Sep 10 13:13:29 2020] 0 pages HighMem/MovableOnly
[Thu Sep 10 13:13:29 2020] 90558 pages reserved
1 hour ago, Mincemeat said:
Would it be possible to get 1.04b juns extra with just i915 driver removed?
its possible to make that, it does not exist yet
Had some problems with v0.13.3 r8125 driver back then when trying 6.2.3 i think.
jun's extra.lzma does not contain a driver r8125.ko, so if you are looking for a better driver you won't find it that way
does the system boot when you remove the 8125 card?
6.2.3 was working, those errors were when transferring data over usb eth.
Then i downgraded to 6.2.2 and using r8152-apollolake-2.12.0-2.spk bb-qq driver currently.
edit: Did the upgrade, seen the i915 conflict, uninstalled spk and replaced extra with v0.13.3 but it was couple of months ago.
Edited by Mincemeat
these are different drivers
do you talk about a pcie card or a usb device
from your (incomplete) dmesg file its r8152, so it should be a usb device
if the r8152 driver in my extra/extra2 is not working i would prefer to give you a new test extra/extra2 wit a recent version (2.14.0) of that driver and you test it
Its a RTL8156 usb eth. Found one log but its still not fully complete.
Spoiler
[Wed Sep  9 01:13:57 2020] pci_bus 0000:00: root bus resource [bus 00-3e]
[Wed Sep  9 01:13:57 2020] pci 0000:00:00.0: [8086:0c00] type 00 class 0x060000
[Wed Sep  9 01:13:57 2020] pci 0000:00:02.0: [8086:0412] type 00 class 0x030000
[Wed Sep  9 01:13:57 2020] pci 0000:00:02.0: reg 0x10: [mem 0xf7400000-0xf77fffff 64bit]
[Wed Sep  9 01:13:57 2020] pci 0000:00:02.0: reg 0x18: [mem 0xe0000000-0xefffffff 64bit pref]
[Wed Sep  9 01:13:57 2020] pci 0000:00:02.0: reg 0x20: [io  0xf000-0xf03f]
[Wed Sep  9 01:13:57 2020] pci 0000:00:03.0: [8086:0c0c] type 00 class 0x040300
[Wed Sep  9 01:13:57 2020] pci 0000:00:03.0: reg 0x10: [mem 0xf7d34000-0xf7d37fff 64bit]
[Wed Sep  9 01:13:57 2020] pci 0000:00:14.0: [8086:8c31] type 00 class 0x0c0330
[Wed Sep  9 01:13:57 2020] pci 0000:00:14.0: reg 0x10: [mem 0xf7d20000-0xf7d2ffff 64bit]
[Wed Sep  9 01:13:57 2020] pci 0000:00:14.0: PME# supported from D3hot D3cold
[Wed Sep  9 01:13:57 2020] pci 0000:00:14.0: System wakeup disabled by ACPI
[Wed Sep  9 01:13:57 2020] pci 0000:00:16.0: [8086:8c3a] type 00 class 0x078000
[Wed Sep  9 01:13:57 2020] pci 0000:00:16.0: reg 0x10: [mem 0xf7d3f000-0xf7d3f00f 64bit]
[Wed Sep  9 01:13:57 2020] pci 0000:00:16.0: PME# supported from D0 D3hot D3cold
[Wed Sep  9 01:13:57 2020] pci 0000:00:19.0: [8086:153b] type 00 class 0x020000
[Wed Sep  9 01:13:57 2020] pci 0000:00:19.0: reg 0x10: [mem 0xf7d00000-0xf7d1ffff]
[Wed Sep  9 01:13:57 2020] pci 0000:00:19.0: reg 0x14: [mem 0xf7d3d000-0xf7d3dfff]
[Wed Sep  9 01:13:57 2020] pci 0000:00:19.0: reg 0x18: [io  0xf080-0xf09f]
[Wed Sep  9 01:13:57 2020] pci 0000:00:19.0: PME# supported from D0 D3hot D3cold
[Wed Sep  9 01:13:57 2020] pci 0000:00:19.0: System wakeup disabled by ACPI
[Wed Sep  9 01:13:57 2020] pci 0000:00:1a.0: [8086:8c2d] type 00 class 0x0c0320
[Wed Sep  9 01:13:57 2020] pci 0000:00:1a.0: reg 0x10: [mem 0xf7d3c000-0xf7d3c3ff]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1a.0: PME# supported from D0 D3hot D3cold
[Wed Sep  9 01:13:57 2020] pci 0000:00:1a.0: System wakeup disabled by ACPI
[Wed Sep  9 01:13:57 2020] pci 0000:00:1b.0: [8086:8c20] type 00 class 0x040300
[Wed Sep  9 01:13:57 2020] pci 0000:00:1b.0: reg 0x10: [mem 0xf7d30000-0xf7d33fff 64bit]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1b.0: PME# supported from D0 D3hot D3cold
[Wed Sep  9 01:13:57 2020] pci 0000:00:1b.0: System wakeup disabled by ACPI
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.0: [8086:8c10] type 01 class 0x060400
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.0: System wakeup disabled by ACPI
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.3: [8086:8c16] type 01 class 0x060400
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.3: PME# supported from D0 D3hot D3cold
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.3: System wakeup disabled by ACPI
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.4: [8086:8c18] type 01 class 0x060400
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.4: PME# supported from D0 D3hot D3cold
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.4: System wakeup disabled by ACPI
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.6: [8086:8c1c] type 01 class 0x060400
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.6: PME# supported from D0 D3hot D3cold
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.6: System wakeup disabled by ACPI
[Wed Sep  9 01:13:57 2020] pci 0000:00:1d.0: [8086:8c26] type 00 class 0x0c0320
[Wed Sep  9 01:13:57 2020] pci 0000:00:1d.0: reg 0x10: [mem 0xf7d3b000-0xf7d3b3ff]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1d.0: PME# supported from D0 D3hot D3cold
[Wed Sep  9 01:13:57 2020] pci 0000:00:1d.0: System wakeup disabled by ACPI
[Wed Sep  9 01:13:57 2020] pci 0000:00:1f.0: [8086:8c44] type 00 class 0x060100
[Wed Sep  9 01:13:57 2020] pci 0000:00:1f.2: [8086:8c02] type 00 class 0x010601
[Wed Sep  9 01:13:57 2020] pci 0000:00:1f.2: reg 0x10: [io  0xf0d0-0xf0d7]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1f.2: reg 0x14: [io  0xf0c0-0xf0c3]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1f.2: reg 0x18: [io  0xf0b0-0xf0b7]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1f.2: reg 0x1c: [io  0xf0a0-0xf0a3]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1f.2: reg 0x20: [io  0xf060-0xf07f]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1f.2: reg 0x24: [mem 0xf7d3a000-0xf7d3a7ff]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1f.2: PME# supported from D3hot
[Wed Sep  9 01:13:57 2020] pci 0000:00:1f.3: [8086:8c22] type 00 class 0x0c0500
[Wed Sep  9 01:13:57 2020] pci 0000:00:1f.3: reg 0x10: [mem 0xf7d39000-0xf7d390ff 64bit]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1f.3: reg 0x20: [io  0xf040-0xf05f]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.0: PCI bridge to [bus 01]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.3: PCI bridge to [bus 02]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.3:   bridge window [io  0xe000-0xefff]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.3:   bridge window [mem 0xf7800000-0xf7afffff]
[Wed Sep  9 01:13:57 2020] pci 0000:03:00.0: [1b4b:9230] type 00 class 0x010601
[Wed Sep  9 01:13:57 2020] pci 0000:03:00.0: reg 0x10: [io  0xd050-0xd057]
[Wed Sep  9 01:13:57 2020] pci 0000:03:00.0: reg 0x14: [io  0xd040-0xd043]
[Wed Sep  9 01:13:57 2020] pci 0000:03:00.0: reg 0x18: [io  0xd030-0xd037]
[Wed Sep  9 01:13:57 2020] pci 0000:03:00.0: reg 0x1c: [io  0xd020-0xd023]
[Wed Sep  9 01:13:57 2020] pci 0000:03:00.0: reg 0x20: [io  0xd000-0xd01f]
[Wed Sep  9 01:13:57 2020] pci 0000:03:00.0: reg 0x24: [mem 0xf7c10000-0xf7c107ff]
[Wed Sep  9 01:13:57 2020] pci 0000:03:00.0: reg 0x30: [mem 0xf7c00000-0xf7c0ffff pref]
[Wed Sep  9 01:13:57 2020] pci 0000:03:00.0: PME# supported from D3hot
[Wed Sep  9 01:13:57 2020] pci 0000:03:00.0: System wakeup disabled by ACPI
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.4: PCI bridge to [bus 03]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.4:   bridge window [io  0xd000-0xdfff]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.4:   bridge window [mem 0xf7c00000-0xf7cfffff]
[Wed Sep  9 01:13:57 2020] pci 0000:04:00.0: [8086:244e] type 01 class 0x060401
[Wed Sep  9 01:13:57 2020] pci 0000:04:00.0: supports D1 D2
[Wed Sep  9 01:13:57 2020] pci 0000:04:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[Wed Sep  9 01:13:57 2020] pci 0000:04:00.0: System wakeup disabled by ACPI
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.6: PCI bridge to [bus 04-05]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.6:   bridge window [io  0xc000-0xcfff]
[Wed Sep  9 01:13:57 2020] pci 0000:00:1c.6:   bridge window [mem 0xf7b00000-0xf7bfffff]
[Wed Sep  9 01:13:57 2020] pci 0000:05:01.0: [1106:3044] type 00 class 0x0c0010
[Wed Sep  9 01:13:57 2020] pci 0000:05:01.0: reg 0x10: [mem 0xf7b00000-0xf7b007ff]
[Wed Sep  9 01:13:57 2020] pci 0000:05:01.0: reg 0x14: [io  0xc000-0xc07f]
[Wed Sep  9 01:13:57 2020] pci 0000:05:01.0: supports D2
[Wed Sep  9 01:13:57 2020] pci 0000:05:01.0: PME# supported from D2 D3hot D3cold
[Wed Sep  9 01:13:57 2020] pci 0000:04:00.0: PCI bridge to [bus 05] (subtractive decode)
[Wed Sep  9 01:13:57 2020] pci 0000:04:00.0:   bridge window [io  0xc000-0xcfff]
[Wed Sep  9 01:13:57 2020] pci 0000:04:00.0:   bridge window [mem 0xf7b00000-0xf7bfffff]
[Wed Sep  9 01:13:57 2020] pci 0000:04:00.0:   bridge window [io  0xc000-0xcfff] (subtractive decode)
[Wed Sep  9 01:13:57 2020] pci 0000:04:00.0:   bridge window [mem 0xf7b00000-0xf7bfffff] (subtractive decode)
[Wed Sep  9 01:13:57 2020] pci_bus 0000:00: on NUMA node 0
[Wed Sep  9 01:13:57 2020] ACPI: PCI Interrupt Link [LNKA] (IRQs 3 4 5 6 10 *11 12 14 15), disabled.
[Wed Sep  9 01:13:57 2020] ACPI: PCI Interrupt Link [LNKB] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[Wed Sep  9 01:13:57 2020] ACPI: PCI Interrupt Link [LNKC] (IRQs 3 4 5 6 10 *11 12 14 15), disabled.
[Wed Sep  9 01:13:57 2020] ACPI: PCI Interrupt Link [LNKD] (IRQs 3 4 5 6 *10 11 12 14 15), disabled.
[Wed Sep  9 01:13:57 2020] ACPI: PCI Interrupt Link [LNKE] (IRQs 3 4 *5 6 10 11 12 14 15), disabled.
[Wed Sep  9 01:13:57 2020] ACPI: PCI Interrupt Link [LNKF] (IRQs 3 4 5 6 10 11 12 14 15) *0, disabled.
[Wed Sep  9 01:13:57 2020] ACPI: PCI Interrupt Link [LNKG] (IRQs *3 4 5 6 10 11 12 14 15), disabled.
[Wed Sep  9 01:13:57 2020] ACPI: PCI Interrupt Link [LNKH] (IRQs 3 4 5 6 *10 11 12 14 15), disabled.
[Wed Sep  9 01:13:57 2020] ACPI: Enabled 4 GPEs in block 00 to 3F
[Wed Sep  9 01:13:57 2020] vgaarb: setting as boot device: PCI:0000:00:02.0
[Wed Sep  9 01:13:57 2020] vgaarb: device added: PCI:0000:00:02.0,decodes=io+mem,owns=io+mem,locks=none
[Wed Sep  9 01:13:57 2020] vgaarb: loaded
[Wed Sep  9 01:13:57 2020] vgaarb: bridge control possible 0000:00:02.0
[Wed Sep  9 01:13:57 2020] SCSI subsystem initialized
[Wed Sep  9 01:13:57 2020] libata version 3.00 loaded.
[Wed Sep  9 01:13:57 2020] pps_core: LinuxPPS API ver. 1 registered
[Wed Sep  9 01:13:57 2020] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[Wed Sep  9 01:13:57 2020] PTP clock support registered
[Wed Sep  9 01:13:57 2020] EFI Variables Facility v0.08 2004-May-17
[Wed Sep  9 01:13:57 2020] pstore: Registered efi as persistent store backend
[Wed Sep  9 01:13:57 2020] PCI: Using ACPI for IRQ routing
[Wed Sep  9 01:13:57 2020] PCI: pci_cache_line_size set to 64 bytes
[Wed Sep  9 01:13:57 2020] e820: reserve RAM buffer [mem 0x00058000-0x0005ffff]
[Wed Sep  9 01:13:57 2020] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[Wed Sep  9 01:13:57 2020] e820: reserve RAM buffer [mem 0xbd338000-0xbfffffff]
[Wed Sep  9 01:13:57 2020] e820: reserve RAM buffer [mem 0xbde6a000-0xbfffffff]
[Wed Sep  9 01:13:57 2020] e820: reserve RAM buffer [mem 0xda0b6000-0xdbffffff]
[Wed Sep  9 01:13:57 2020] e820: reserve RAM buffer [mem 0xda18f000-0xdbffffff]
[Wed Sep  9 01:13:57 2020] e820: reserve RAM buffer [mem 0xdb000000-0xdbffffff]
[Wed Sep  9 01:13:57 2020] e820: reserve RAM buffer [mem 0x41f600000-0x41fffffff]
[Wed Sep  9 01:13:57 2020] clocksource: Switched to clocksource hpet
[Wed Sep  9 01:13:57 2020] AppArmor: AppArmor Filesystem Enabled
[Wed Sep  9 01:13:57 2020] pnp: PnP ACPI init
[Wed Sep  9 01:13:57 2020] system 00:00: [mem 0xfed40000-0xfed44fff] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:00: Plug and Play ACPI device, IDs PNP0c01 (active)
[Wed Sep  9 01:13:57 2020] system 00:01: [io  0x0680-0x069f] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:01: [io  0xffff] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:01: [io  0x1c00-0x1cfe] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:01: [io  0x1d00-0x1dfe] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:01: [io  0x1e00-0x1efe] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:01: [io  0x1f00-0x1ffe] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:01: [io  0x1800-0x18fe] could not be reserved
[Wed Sep  9 01:13:57 2020] system 00:01: [io  0x164e-0x164f] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:01: Plug and Play ACPI device, IDs PNP0c02 (active)
[Wed Sep  9 01:13:57 2020] pnp 00:02: Plug and Play ACPI device, IDs PNP0b00 (active)
[Wed Sep  9 01:13:57 2020] system 00:03: [io  0x1854-0x1857] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:03: Plug and Play ACPI device, IDs INT3f0d PNP0c02 (active)
[Wed Sep  9 01:13:57 2020] system 00:04: [io  0x0a00-0x0a0f] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:04: [io  0x0a30-0x0a3f] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:04: [io  0x0a20-0x0a2f] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:04: Plug and Play ACPI device, IDs PNP0c02 (active)
[Wed Sep  9 01:13:57 2020] pnp 00:05: [dma 0 disabled]
[Wed Sep  9 01:13:57 2020] pnp 00:05: Plug and Play ACPI device, IDs PNP0501 (active)
[Wed Sep  9 01:13:57 2020] system 00:06: [io  0x04d0-0x04d1] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:06: Plug and Play ACPI device, IDs PNP0c02 (active)
[Wed Sep  9 01:13:57 2020] system 00:07: [mem 0xfed1c000-0xfed1ffff] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:07: [mem 0xfed10000-0xfed17fff] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:07: [mem 0xfed18000-0xfed18fff] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:07: [mem 0xfed19000-0xfed19fff] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:07: [mem 0xf8000000-0xfbffffff] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:07: [mem 0xfed20000-0xfed3ffff] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:07: [mem 0xfed90000-0xfed93fff] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:07: [mem 0xfed45000-0xfed8ffff] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:07: [mem 0xff000000-0xffffffff] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:07: [mem 0xfee00000-0xfeefffff] could not be reserved
[Wed Sep  9 01:13:57 2020] system 00:07: [mem 0xf7fdf000-0xf7fdffff] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:07: [mem 0xf7fe0000-0xf7feffff] has been reserved
[Wed Sep  9 01:13:57 2020] system 00:07: Plug and Play ACPI device, IDs PNP0c02 (active)
[Wed Sep  9 01:13:57 2020] pnp: PnP ACPI: found 8 devices
[Wed Sep  9 01:13:57 2020] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[Wed Sep  9 01:13:57 2020] pci_bus 0000:00: resource 4 [io  0x0000-0x0cf7 window]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:00: resource 5 [io  0x0d00-0xffff window]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:00: resource 7 [mem 0x000d0000-0x000d3fff window]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:00: resource 8 [mem 0x000d4000-0x000d7fff window]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:00: resource 9 [mem 0x000d8000-0x000dbfff window]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:00: resource 10 [mem 0x000dc000-0x000dffff window]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:00: resource 11 [mem 0xdfa00000-0xfeafffff window]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:02: resource 0 [io  0xe000-0xefff]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:02: resource 1 [mem 0xf7800000-0xf7afffff]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:03: resource 0 [io  0xd000-0xdfff]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:03: resource 1 [mem 0xf7c00000-0xf7cfffff]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:04: resource 0 [io  0xc000-0xcfff]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:04: resource 1 [mem 0xf7b00000-0xf7bfffff]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:05: resource 0 [io  0xc000-0xcfff]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:05: resource 1 [mem 0xf7b00000-0xf7bfffff]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:05: resource 4 [io  0xc000-0xcfff]
[Wed Sep  9 01:13:57 2020] pci_bus 0000:05: resource 5 [mem 0xf7b00000-0xf7bfffff]
[Wed Sep  9 01:13:57 2020] NET: Registered protocol family 2
[Wed Sep  9 01:13:57 2020] TCP established hash table entries: 131072 (order: 8, 1048576 bytes)
[Wed Sep  9 01:13:57 2020] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes)
[Wed Sep  9 01:13:57 2020] TCP: Hash tables configured (established 131072 bind 65536)
[Wed Sep  9 01:13:57 2020] UDP hash table entries: 8192 (order: 6, 262144 bytes)
[Wed Sep  9 01:13:57 2020] UDP-Lite hash table entries: 8192 (order: 6, 262144 bytes)
[Wed Sep  9 01:13:57 2020] NET: Registered protocol family 1
[Wed Sep  9 01:13:57 2020] RPC: Registered named UNIX socket transport module.
[Wed Sep  9 01:13:57 2020] RPC: Registered udp transport module.
[Wed Sep  9 01:13:57 2020] RPC: Registered tcp transport module.
[Wed Sep  9 01:13:57 2020] RPC: Registered tcp NFSv4.1 backchannel transport module.
[Wed Sep  9 01:13:57 2020] pci 0000:00:02.0: Video device with shadowed ROM
[Wed Sep  9 01:13:57 2020] PCI: CLS 64 bytes, default 64
[Wed Sep  9 01:13:57 2020] Trying to unpack rootfs image as initramfs...
[Wed Sep  9 01:13:57 2020] Freeing initrd memory: 27900K (ffff8800364c1000 - ffff880038000000)
[Wed Sep  9 01:13:57 2020] pdzfky: module verification failed: signature and/or required key missing - tainting kernel
[Wed Sep  9 01:13:57 2020] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[Wed Sep  9 01:13:57 2020] software IO TLB [mem 0xc67ad000-0xca7ad000] (64MB) mapped at [ffff8800c67ad000-ffff8800ca7acfff]
[Wed Sep  9 01:13:57 2020] RAPL PMU detected, API unit is 2^-32 Joules, 4 fixed counters 655360 ms ovfl timer
[Wed Sep  9 01:13:57 2020] hw unit of domain pp0-core 2^-14 Joules
[Wed Sep  9 01:13:57 2020] hw unit of domain package 2^-14 Joules
[Wed Sep  9 01:13:57 2020] hw unit of domain dram 2^-14 Joules
[Wed Sep  9 01:13:57 2020] hw unit of domain pp1-gpu 2^-14 Joules
[Wed Sep  9 01:13:57 2020] audit: initializing netlink subsys (disabled)
[Wed Sep  9 01:13:57 2020] audit: type=2000 audit(1599606838.934:1): initialized
[Wed Sep  9 01:13:57 2020] Initialise system trusted keyring
[Wed Sep  9 01:13:57 2020] VFS: Disk quotas dquot_6.6.0
[Wed Sep  9 01:13:57 2020] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[Wed Sep  9 01:13:57 2020] NFS: Registering the id_resolver key type
[Wed Sep  9 01:13:57 2020] Key type id_resolver registered
[Wed Sep  9 01:13:57 2020] Key type id_legacy registered
[Wed Sep  9 01:13:57 2020] async_tx: api initialized (async)
[Wed Sep  9 01:13:57 2020] Key type asymmetric registered
[Wed Sep  9 01:13:57 2020] Asymmetric key parser 'x509' registered
[Wed Sep  9 01:13:57 2020] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 251)
[Wed Sep  9 01:13:57 2020] io scheduler noop registered
[Wed Sep  9 01:13:57 2020] io scheduler deadline registered
[Wed Sep  9 01:13:57 2020] io scheduler cfq registered (default)
[Wed Sep  9 01:13:57 2020] Serial: 8250/16550 driver, 4 ports, IRQ sharing enabled
[Wed Sep  9 01:13:58 2020] serial8250: ttyS0 at I/O 0x3f8 (irq = 4, base_baud = 115200) is a 16550A
[Wed Sep  9 01:13:58 2020] console [ttyS0] enabled
[Wed Sep  9 01:13:58 2020] serial8250: ttyS1 at I/O 0x2f8 (irq = 3, base_baud = 115200) is a 8250
[Wed Sep  9 01:13:58 2020] Linux agpgart interface v0.103
[Wed Sep  9 01:13:58 2020] brd: module loaded
[Wed Sep  9 01:13:58 2020] Loading iSCSI transport class v2.0-870.
[Wed Sep  9 01:13:58 2020] ahci 0000:00:1f.2: version 3.0
[Wed Sep  9 01:13:58 2020] ahci 0000:00:1f.2: AHCI 0001.0300 32 slots 6 ports 6 Gbps 0x3f impl SATA mode
[Wed Sep  9 01:13:58 2020] ahci 0000:00:1f.2: flags: 64bit ncq led clo pio slum part ems apst
[Wed Sep  9 01:13:58 2020] scsi host0: ahci
[Wed Sep  9 01:13:58 2020] scsi host1: ahci
[Wed Sep  9 01:13:58 2020] scsi host2: ahci
[Wed Sep  9 01:13:58 2020] scsi host3: ahci
[Wed Sep  9 01:13:58 2020] scsi host4: ahci
[Wed Sep  9 01:13:58 2020] scsi host5: ahci
[Wed Sep  9 01:13:58 2020] ata1: SATA max UDMA/133 abar m2048@0xf7d3a000 port 0xf7d3a100 irq 24
[Wed Sep  9 01:13:58 2020] ata2: SATA max UDMA/133 abar m2048@0xf7d3a000 port 0xf7d3a180 irq 24
[Wed Sep  9 01:13:58 2020] ata3: SATA max UDMA/133 abar m2048@0xf7d3a000 port 0xf7d3a200 irq 24
[Wed Sep  9 01:13:58 2020] ata4: SATA max UDMA/133 abar m2048@0xf7d3a000 port 0xf7d3a280 irq 24
[Wed Sep  9 01:13:58 2020] ata5: SATA max UDMA/133 abar m2048@0xf7d3a000 port 0xf7d3a300 irq 24
[Wed Sep  9 01:13:58 2020] ata6: SATA max UDMA/133 abar m2048@0xf7d3a000 port 0xf7d3a380 irq 24
[Wed Sep  9 01:13:58 2020] ata1: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[Wed Sep  9 01:13:58 2020] ata1.00: ATA-10: TOSHIBA MG07ACA12TE, 0101, max UDMA/133
[Wed Sep  9 01:13:58 2020] ata1.00: 23437770752 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[Wed Sep  9 01:13:58 2020] ata1.00: SN:
[Wed Sep  9 01:13:58 2020] ata1.00: configured for UDMA/133
[Wed Sep  9 01:13:58 2020] scsi 0:0:0:0: Direct-Access     TOSHIBA  MG07ACA12TE              0101 PQ: 0 ANSI: 5
[Wed Sep  9 01:13:58 2020] sd 0:0:0:0: [sda] 23437770752 512-byte logical blocks: (12.0 TB/10.9 TiB)
[Wed Sep  9 01:13:58 2020] sd 0:0:0:0: [sda] 4096-byte physical blocks
[Wed Sep  9 01:13:58 2020] sd 0:0:0:0: [sda] Write Protect is off
[Wed Sep  9 01:13:58 2020] sd 0:0:0:0: [sda] Mode Sense: 00 3a 00 00
[Wed Sep  9 01:13:58 2020] sd 0:0:0:0: [sda] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[Wed Sep  9 01:13:58 2020]  sda: sda1 sda2 sda5 sda6 sda7 sda8 sda9 sda10
[Wed Sep  9 01:13:58 2020] sd 0:0:0:0: [sda] Attached SCSI disk
[Wed Sep  9 01:13:58 2020] ata2: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[Wed Sep  9 01:13:58 2020] ata2.00: disabling queued TRIM support
[Wed Sep  9 01:13:58 2020] ata2.00: ATA-10: ST10000DM0004-1ZC101, DN01, max UDMA/133
[Wed Sep  9 01:13:58 2020] ata2.00: 19532873728 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[Wed Sep  9 01:13:58 2020] ata2.00: SN:
[Wed Sep  9 01:13:58 2020] ata2.00: configured for UDMA/133
[Wed Sep  9 01:13:58 2020] scsi 1:0:0:0: Direct-Access     ATA      ST10000DM0004-1ZC101     DN01 PQ: 0 ANSI: 5
[Wed Sep  9 01:13:58 2020] sd 1:0:0:0: [sdb] 19532873728 512-byte logical blocks: (10.0 TB/9.10 TiB)
[Wed Sep  9 01:13:58 2020] sd 1:0:0:0: [sdb] 4096-byte physical blocks
[Wed Sep  9 01:13:58 2020] sd 1:0:0:0: [sdb] Write Protect is off
[Wed Sep  9 01:13:58 2020] sd 1:0:0:0: [sdb] Mode Sense: 00 3a 00 00
[Wed Sep  9 01:13:58 2020] sd 1:0:0:0: [sdb] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[Wed Sep  9 01:13:58 2020]  sdb: sdb1 sdb2 sdb5 sdb6 sdb7 sdb8 sdb9 sdb10
[Wed Sep  9 01:13:58 2020] sd 1:0:0:0: [sdb] Attached SCSI disk
[Wed Sep  9 01:13:58 2020] tsc: Refined TSC clocksource calibration: 3392.145 MHz
[Wed Sep  9 01:13:58 2020] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x30e55212bb0, max_idle_ns: 440795241820 ns
[Wed Sep  9 01:13:59 2020] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[Wed Sep  9 01:13:59 2020] ata3.00: disabling queued TRIM support
[Wed Sep  9 01:13:59 2020] ata3.00: ATA-10: ST10000DM0004-1ZC101, DN01, max UDMA/133
[Wed Sep  9 01:13:59 2020] ata3.00: 19532873728 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[Wed Sep  9 01:13:59 2020] ata3.00: SN:
[Wed Sep  9 01:13:59 2020] ata3.00: configured for UDMA/133
[Wed Sep  9 01:13:59 2020] scsi 2:0:0:0: Direct-Access     ATA      ST10000DM0004-1ZC101     DN01 PQ: 0 ANSI: 5
[Wed Sep  9 01:13:59 2020] sd 2:0:0:0: [sdc] 19532873728 512-byte logical blocks: (10.0 TB/9.10 TiB)
[Wed Sep  9 01:13:59 2020] sd 2:0:0:0: [sdc] 4096-byte physical blocks
[Wed Sep  9 01:13:59 2020] sd 2:0:0:0: [sdc] Write Protect is off
[Wed Sep  9 01:13:59 2020] sd 2:0:0:0: [sdc] Mode Sense: 00 3a 00 00
[Wed Sep  9 01:13:59 2020] sd 2:0:0:0: [sdc] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[Wed Sep  9 01:13:59 2020]  sdc: sdc1 sdc2 sdc5 sdc6 sdc7 sdc8 sdc9 sdc10
[Wed Sep  9 01:13:59 2020] sd 2:0:0:0: [sdc] Attached SCSI disk
[Wed Sep  9 01:13:59 2020] ata4: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[Wed Sep  9 01:13:59 2020] ata4.00: ATA-9: WDC WD80EFZX-68UW8N0, 83.H0A83, max UDMA/133
[Wed Sep  9 01:13:59 2020] ata4.00: 15628053168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[Wed Sep  9 01:13:59 2020] ata4.00: configured for UDMA/133
[Wed Sep  9 01:13:59 2020] scsi 3:0:0:0: Direct-Access     WDC      WD80EFZX-68UW8N0         0A83 PQ: 0 ANSI: 5
[Wed Sep  9 01:13:59 2020] sd 3:0:0:0: [sdd] 15628053168 512-byte logical blocks: (8.00 TB/7.28 TiB)
[Wed Sep  9 01:13:59 2020] sd 3:0:0:0: [sdd] 4096-byte physical blocks
[Wed Sep  9 01:13:59 2020] sd 3:0:0:0: [sdd] Write Protect is off
[Wed Sep  9 01:13:59 2020] sd 3:0:0:0: [sdd] Mode Sense: 00 3a 00 00
[Wed Sep  9 01:13:59 2020] sd 3:0:0:0: [sdd] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[Wed Sep  9 01:13:59 2020]  sdd: sdd1 sdd2 sdd5 sdd6 sdd7 sdd8 sdd9
[Wed Sep  9 01:13:59 2020] sd 3:0:0:0: [sdd] Attached SCSI disk
[Wed Sep  9 01:13:59 2020] ata5: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[Wed Sep  9 01:13:59 2020] ata5.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[Wed Sep  9 01:13:59 2020] ata5.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[Wed Sep  9 01:13:59 2020] ata5.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[Wed Sep  9 01:13:59 2020] ata5.00: ATA-9: WDC WD40EFRX-68WT0N0, 80.00A80, max UDMA/133
[Wed Sep  9 01:13:59 2020] ata5.00: 7814037168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[Wed Sep  9 01:13:59 2020] ata5.00: SN:
[Wed Sep  9 01:13:59 2020] ata5.00: configured for UDMA/133
[Wed Sep  9 01:13:59 2020] scsi 4:0:0:0: Direct-Access     WDC      WD40EFRX-68WT0N0         0A80 PQ: 0 ANSI: 5
[Wed Sep  9 01:13:59 2020] sd 4:0:0:0: [sde] 7814037168 512-byte logical blocks: (4.00 TB/3.64 TiB)
[Wed Sep  9 01:13:59 2020] sd 4:0:0:0: [sde] 4096-byte physical blocks
[Wed Sep  9 01:13:59 2020] sd 4:0:0:0: [sde] Write Protect is off
[Wed Sep  9 01:13:59 2020] sd 4:0:0:0: [sde] Mode Sense: 00 3a 00 00
[Wed Sep  9 01:13:59 2020] sd 4:0:0:0: [sde] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[Wed Sep  9 01:13:59 2020]  sde: sde1 sde2 sde5 sde6 sde7 sde8
[Wed Sep  9 01:13:59 2020] sd 4:0:0:0: [sde] Attached SCSI disk
[Wed Sep  9 01:13:59 2020] clocksource: Switched to clocksource tsc
[Wed Sep  9 01:14:00 2020] ata6: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[Wed Sep  9 01:14:00 2020] ata6.00: ACPI cmd ef/10:06:00:00:00:00 (SET FEATURES) succeeded
[Wed Sep  9 01:14:00 2020] ata6.00: ACPI cmd f5/00:00:00:00:00:00 (SECURITY FREEZE LOCK) filtered out
[Wed Sep  9 01:14:00 2020] ata6.00: ACPI cmd b1/c1:00:00:00:00:00 (DEVICE CONFIGURATION OVERLAY) filtered out
[Wed Sep  9 01:14:00 2020] ata6.00: ATA-8: WDC WD20EARX-00PASB0, 51.0AB51, max UDMA/133
[Wed Sep  9 01:14:00 2020] ata6.00: 3907029168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[Wed Sep  9 01:14:00 2020] ata6.00: SN:
[Wed Sep  9 01:14:00 2020] ata6.00: configured for UDMA/133
[Wed Sep  9 01:14:00 2020] scsi 5:0:0:0: Direct-Access     WDC      WD20EARX-00PASB0         AB51 PQ: 0 ANSI: 5
[Wed Sep  9 01:14:00 2020] sd 5:0:0:0: [sdf] 3907029168 512-byte logical blocks: (2.00 TB/1.82 TiB)
[Wed Sep  9 01:14:00 2020] sd 5:0:0:0: [sdf] 4096-byte physical blocks
[Wed Sep  9 01:14:00 2020] sd 5:0:0:0: [sdf] Write Protect is off
[Wed Sep  9 01:14:00 2020] sd 5:0:0:0: [sdf] Mode Sense: 00 3a 00 00
[Wed Sep  9 01:14:00 2020] sd 5:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[Wed Sep  9 01:14:00 2020] ahci 0000:03:00.0: controller can do FBS, turning on CAP_FBS
[Wed Sep  9 01:14:00 2020] Change defer qc mode on external port for compatibility
[Wed Sep  9 01:14:00 2020] ahci 0000:03:00.0: AHCI 0001.0200 32 slots 8 ports 6 Gbps 0xff impl SATA mode
[Wed Sep  9 01:14:00 2020] ahci 0000:03:00.0: flags: 64bit ncq fbs pio
[Wed Sep  9 01:14:00 2020] scsi host6: ahci
[Wed Sep  9 01:14:00 2020] scsi host7: ahci
[Wed Sep  9 01:14:00 2020] scsi host8: ahci
[Wed Sep  9 01:14:00 2020] scsi host9: ahci
[Wed Sep  9 01:14:00 2020] scsi host10: ahci
[Wed Sep  9 01:14:00 2020] scsi host11: ahci
[Wed Sep  9 01:14:00 2020] scsi host12: ahci
[Wed Sep  9 01:14:00 2020] scsi host13: ahci
[Wed Sep  9 01:14:00 2020] ata7: SATA max UDMA/133 abar m2048@0xf7c10000 port 0xf7c10100 irq 25
[Wed Sep  9 01:14:00 2020] ata8: SATA max UDMA/133 abar m2048@0xf7c10000 port 0xf7c10180 irq 25
[Wed Sep  9 01:14:00 2020] ata9: SATA max UDMA/133 abar m2048@0xf7c10000 port 0xf7c10200 irq 25
[Wed Sep  9 01:14:00 2020] ata10: SATA max UDMA/133 abar m2048@0xf7c10000 port 0xf7c10280 irq 25
[Wed Sep  9 01:14:00 2020] ata11: SATA max UDMA/133 abar m2048@0xf7c10000 port 0xf7c10300 irq 25
[Wed Sep  9 01:14:00 2020] ata12: SATA max UDMA/133 abar m2048@0xf7c10000 port 0xf7c10380 irq 25
[Wed Sep  9 01:14:00 2020] ata13: SATA max UDMA/133 abar m2048@0xf7c10000 port 0xf7c10400 irq 25
[Wed Sep  9 01:14:00 2020] ata14: SATA max UDMA/133 abar m2048@0xf7c10000 port 0xf7c10480 irq 25
[Wed Sep  9 01:14:00 2020]  sdf: sdf1 sdf2 sdf3 < sdf5 sdf6 >
[Wed Sep  9 01:14:00 2020] sd 5:0:0:0: [sdf] Attached SCSI disk
[Wed Sep  9 01:14:00 2020] ata7: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[Wed Sep  9 01:14:00 2020] ata7.00: ATA-8: WDC WD30EZRX-00MMMB0, 80.00A80, max UDMA/133
[Wed Sep  9 01:14:00 2020] ata7.00: 5860533168 sectors, multi 16: LBA48 NCQ (depth 31/32), AA
[Wed Sep  9 01:14:00 2020] ata7.00: SN:
[Wed Sep  9 01:14:00 2020] ata7.00: configured for UDMA/133
[Wed Sep  9 01:14:00 2020] scsi 6:0:0:0: Direct-Access     WDC      WD30EZRX-00MMMB0         0A80 PQ: 0 ANSI: 5
[Wed Sep  9 01:14:00 2020] sd 6:0:0:0: [sdg] 5860533168 512-byte logical blocks: (3.00 TB/2.73 TiB)
[Wed Sep  9 01:14:00 2020] sd 6:0:0:0: [sdg] 4096-byte physical blocks
[Wed Sep  9 01:14:00 2020] sd 6:0:0:0: [sdg] Write Protect is off
[Wed Sep  9 01:14:00 2020] sd 6:0:0:0: [sdg] Mode Sense: 00 3a 00 00
[Wed Sep  9 01:14:00 2020] sd 6:0:0:0: [sdg] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[Wed Sep  9 01:14:00 2020] random: nonblocking pool is initialized
[Wed Sep  9 01:14:00 2020]  sdg: sdg1 sdg2 sdg5 sdg6 sdg7
[Wed Sep  9 01:14:00 2020] sd 6:0:0:0: [sdg] Attached SCSI disk
[Wed Sep  9 01:14:00 2020] ata8: SATA link down (SStatus 0 SControl 300)
[Wed Sep  9 01:14:00 2020] ata8: No present pin info for SATA link down event
[Wed Sep  9 01:14:01 2020] ata9: SATA link down (SStatus 0 SControl 300)
[Wed Sep  9 01:14:01 2020] ata9: No present pin info for SATA link down event
[Wed Sep  9 01:14:01 2020] ata10: SATA link down (SStatus 0 SControl 300)
[Wed Sep  9 01:14:01 2020] ata10: No present pin info for SATA link down event
[Wed Sep  9 01:14:01 2020] ata11: SATA link down (SStatus 0 SControl 300)
[Wed Sep  9 01:14:01 2020] ata11: No present pin info for SATA link down event
[Wed Sep  9 01:14:02 2020] ata12: SATA link down (SStatus 0 SControl 300)
[Wed Sep  9 01:14:02 2020] ata12: No present pin info for SATA link down event
[Wed Sep  9 01:14:02 2020] ata13: SATA link down (SStatus 0 SControl 300)
[Wed Sep  9 01:14:02 2020] ata13: No present pin info for SATA link down event
[Wed Sep  9 01:14:02 2020] ata14: SATA link up 1.5 Gbps (SStatus 113 SControl 300)
[Wed Sep  9 01:14:02 2020] ata14.00: ATAPI: MARVELL VIRTUALL, 1.09, max UDMA/66
[Wed Sep  9 01:14:02 2020] ata14.00: configured for UDMA/66
[Wed Sep  9 01:14:02 2020] ata14.00: Find SSD disks. [MARVELL VIRTUALL]
[Wed Sep  9 01:14:02 2020] ata14.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6
[Wed Sep  9 01:14:02 2020] ata14.00: irq_stat 0x40000001
[Wed Sep  9 01:14:02 2020] ata14.00: cmd a0/00:00:00:fc:00/00:00:00:00:00/a0 tag 2 pio 252 in
                                    opcode=0x12 12 01 00 00 fc 00res 00/00:00:00:00:00/00:00:00:00:00/00 Emask 0x3 (HSM violation)
[Wed Sep  9 01:14:02 2020] ata14: hard resetting link
[Wed Sep  9 01:14:02 2020] ata14: EH complete
[Wed Sep  9 01:14:03 2020] scsi 13:0:0:0: Processor         Marvell  Console                  1.01 PQ: 0 ANSI: 5
[Wed Sep  9 01:14:03 2020] i8042: PNP: No PS/2 controller found. Probing ports directly.
[Wed Sep  9 01:14:03 2020] serio: i8042 KBD port at 0x60,0x64 irq 1
[Wed Sep  9 01:14:03 2020] serio: i8042 AUX port at 0x60,0x64 irq 12
[Wed Sep  9 01:14:03 2020] i2c /dev entries driver
[Wed Sep  9 01:14:03 2020] i801_smbus 0000:00:1f.3: enabling device (0001 -> 0003)
[Wed Sep  9 01:14:03 2020] i801_smbus 0000:00:1f.3: SMBus using polling
[Wed Sep  9 01:14:03 2020] md: linear personality registered for level -1
[Wed Sep  9 01:14:03 2020] md: raid0 personality registered for level 0
[Wed Sep  9 01:14:03 2020] md: raid1 personality registered for level 1
[Wed Sep  9 01:14:03 2020] md: raid10 personality registered for level 10
[Wed Sep  9 01:14:03 2020] md: raid6 personality registered for level 6
[Wed Sep  9 01:14:03 2020] md: raid5 personality registered for level 5
[Wed Sep  9 01:14:03 2020] md: raid4 personality registered for level 4
[Wed Sep  9 01:14:03 2020] device-mapper: ioctl: 4.34.0-ioctl (2015-10-28) initialised: dm-devel@redhat.com
[Wed Sep  9 01:14:03 2020] NET: Registered protocol family 17
[Wed Sep  9 01:14:03 2020] Key type dns_resolver registered
[Wed Sep  9 01:14:03 2020] registered taskstats version 1
[Wed Sep  9 01:14:03 2020] Loading compiled-in untrusted X.509 certificates
[Wed Sep  9 01:14:03 2020] Loading compiled-in X.509 certificates
[Wed Sep  9 01:14:03 2020] Loaded X.509 cert 'Synology SDG kernel module signing key: 7bd0b0d6bcd31651c22ce3978bdc8c8bdc417329'
[Wed Sep  9 01:14:03 2020] Loaded X.509 cert 'Synology Root Certification Authority: f2c075361f168425f8b5ef31b796406c3aab2089'
[Wed Sep  9 01:14:03 2020] Loaded X.509 cert 'Synology Kernel Module Signing Certification Authority: 600839b5d127e0e11d817a31f0575d323a7c0e28'
[Wed Sep  9 01:14:03 2020] Loaded X.509 cert 'Synology kernel module signing key: 4646ce54489669338118a3b1286da156ac366fa5'
[Wed Sep  9 01:14:03 2020] page_owner is disabled
[Wed Sep  9 01:14:03 2020] AppArmor: AppArmor sha1 policy hashing enabled
[Wed Sep  9 01:14:03 2020] hctosys: unable to open rtc device (rtc0)
[Wed Sep  9 01:14:03 2020] Freeing unused kernel memory: 864K (ffffffff81879000 - ffffffff81951000)
[Wed Sep  9 01:14:03 2020] Write protecting the kernel read-only data: 8192k
[Wed Sep  9 01:14:03 2020] Freeing unused kernel memory: 520K (ffff88000157e000 - ffff880001600000)
[Wed Sep  9 01:14:03 2020] Freeing unused kernel memory: 200K (ffff8800017ce000 - ffff880001800000)
[Wed Sep  9 01:14:03 2020] ACPI: bus type USB registered
[Wed Sep  9 01:14:03 2020] usbcore: registered new interface driver usbfs
[Wed Sep  9 01:14:03 2020] usbcore: registered new interface driver hub
[Wed Sep  9 01:14:03 2020] usbcore: registered new interface driver ethub
[Wed Sep  9 01:14:03 2020] usbcore: registered new device driver usb
[Wed Sep  9 01:14:03 2020] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[Wed Sep  9 01:14:03 2020] xhci_hcd 0000:00:14.0: xHCI Host Controller
[Wed Sep  9 01:14:03 2020] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 1
[Wed Sep  9 01:14:03 2020] xhci_hcd 0000:00:14.0: hcc params 0x200077c1 hci version 0x100 quirks 0x00009010
[Wed Sep  9 01:14:03 2020] xhci_hcd 0000:00:14.0: cache line size of 64 is not supported
[Wed Sep  9 01:14:03 2020] hub 1-0:1.0: USB hub found
[Wed Sep  9 01:14:03 2020] hub 1-0:1.0: 14 ports detected
[Wed Sep  9 01:14:03 2020] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 2
[Wed Sep  9 01:14:03 2020] usb usb2: We don't know the algorithms for LPM for this host, disabling LPM.
[Wed Sep  9 01:14:03 2020] hub 2-0:1.0: USB hub found
[Wed Sep  9 01:14:03 2020] hub 2-0:1.0: 6 ports detected
[Wed Sep  9 01:14:03 2020] usbcore: registered new interface driver usb-storage
[Wed Sep  9 01:14:03 2020] VMware PVSCSI driver - version 1.0.5.0-k
[Wed Sep  9 01:14:03 2020] megaraid cmm: 2.20.2.7 (Release Date: Sun Jul 16 00:01:03 EST 2006)
[Wed Sep  9 01:14:03 2020] megaraid: 2.20.5.1 (Release Date: Thu Nov 16 15:32:35 EST 2006)
[Wed Sep  9 01:14:03 2020] Fusion MPT base driver 3.04.20
[Wed Sep  9 01:14:03 2020] Copyright (c) 1999-2008 LSI Corporation
[Wed Sep  9 01:14:03 2020] Fusion MPT SPI Host driver 3.04.20
[Wed Sep  9 01:14:03 2020] Fusion MPT misc device (ioctl) driver 3.04.20
[Wed Sep  9 01:14:03 2020] mptctl: Registered with Fusion MPT base driver
[Wed Sep  9 01:14:03 2020] mptctl: /dev/mptctl @ (major,minor=10,220)
[Wed Sep  9 01:14:03 2020] megasas: 06.808.16.00-rc1
[Wed Sep  9 01:14:03 2020] Fusion MPT SAS Host driver 3.04.20
[Wed Sep  9 01:14:03 2020] mpt3sas version 09.102.00.00 loaded
[Wed Sep  9 01:14:03 2020] rtc_cmos 00:02: RTC can wake from S4
[Wed Sep  9 01:14:03 2020] rtc_cmos 00:02: rtc core: registered rtc_cmos as rtc0
[Wed Sep  9 01:14:03 2020] rtc_cmos 00:02: alarms up to one month, y3k, 242 bytes nvram
[Wed Sep  9 01:14:03 2020] 3ware 9000 Storage Controller device driver for Linux v2.26.02.014.
[Wed Sep  9 01:14:03 2020] LSI 3ware SAS/SATA-RAID Controller device driver for Linux v3.26.02.000.
[Wed Sep  9 01:14:03 2020] Adaptec aacraid driver 1.2-1[41010]-ms
[Wed Sep  9 01:14:03 2020] GDT-HA: Storage RAID Controller Driver. Version: 3.05
[Wed Sep  9 01:14:03 2020] RocketRAID 3xxx/4xxx Controller driver v1.10.0
[Wed Sep  9 01:14:03 2020] isci: Intel(R) C600 SAS Controller Driver - version 1.2.0
[Wed Sep  9 01:14:03 2020] aic94xx: Adaptec aic94xx SAS/SATA driver version 1.0.3 loaded
[Wed Sep  9 01:14:03 2020] apollolake_synobios: module license 'Synology Inc.' taints kernel.
[Wed Sep  9 01:14:03 2020] Disabling lock debugging due to kernel taint
[Wed Sep  9 01:14:03 2020] 2020-9-8 23:14:4 UTC
[Wed Sep  9 01:14:03 2020] synobios: load, major number 201
[Wed Sep  9 01:14:03 2020] Brand: Synology
[Wed Sep  9 01:14:03 2020] Model: DS-918+
[Wed Sep  9 01:14:03 2020] This is default settings: set group disks wakeup number to 1, spinup time deno 1
[Wed Sep  9 01:14:03 2020] synobios cpu_arch proc entry initialized
[Wed Sep  9 01:14:03 2020] synobios crypto_hw proc entry initialized
[Wed Sep  9 01:14:03 2020] synobios syno_platform proc entry initialized
[Wed Sep  9 01:14:03 2020] synobios open /dev/ttyS1 success
[Wed Sep  9 01:14:03 2020] synobios: unload
[Wed Sep  9 01:14:03 2020] md: Autodetecting RAID arrays.
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sda5
[Wed Sep  9 01:14:03 2020] md: sda5 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sda6
[Wed Sep  9 01:14:03 2020] md: sda6 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sda7
[Wed Sep  9 01:14:03 2020] md: sda7 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sda8
[Wed Sep  9 01:14:03 2020] md: sda8 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sda9
[Wed Sep  9 01:14:03 2020] md: sda9 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sda10
[Wed Sep  9 01:14:03 2020] md: sda10 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] usb 1-10: new high-speed USB device number 2 using xhci_hcd
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdb5
[Wed Sep  9 01:14:03 2020] md: sdb5 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdb6
[Wed Sep  9 01:14:03 2020] md: sdb6 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdb7
[Wed Sep  9 01:14:03 2020] md: sdb7 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdb8
[Wed Sep  9 01:14:03 2020] md: sdb8 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdb9
[Wed Sep  9 01:14:03 2020] md: sdb9 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdb10
[Wed Sep  9 01:14:03 2020] md: sdb10 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] usb 1-10: not running at top speed
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdc5
[Wed Sep  9 01:14:03 2020] md: sdc5 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdc6
[Wed Sep  9 01:14:03 2020] md: sdc6 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdc7
[Wed Sep  9 01:14:03 2020] md: sdc7 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdc8
[Wed Sep  9 01:14:03 2020] md: sdc8 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdc9
[Wed Sep  9 01:14:03 2020] md: sdc9 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdc10
[Wed Sep  9 01:14:03 2020] md: sdc10 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdd5
[Wed Sep  9 01:14:03 2020] md: sdd5 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdd6
[Wed Sep  9 01:14:03 2020] md: sdd6 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdd7
[Wed Sep  9 01:14:03 2020] md: sdd7 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdd8
[Wed Sep  9 01:14:03 2020] md: sdd8 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:03 2020] md: invalid raid superblock magic on sdd9
[Wed Sep  9 01:14:04 2020] md: sdd9 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:04 2020] md: invalid raid superblock magic on sde5
[Wed Sep  9 01:14:04 2020] md: sde5 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:04 2020] md: invalid raid superblock magic on sde6
[Wed Sep  9 01:14:04 2020] md: sde6 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:04 2020] md: invalid raid superblock magic on sde7
[Wed Sep  9 01:14:04 2020] md: sde7 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:04 2020] usb 1-10: new high-speed USB device number 2 using xhci_hcd
[Wed Sep  9 01:14:04 2020] md: invalid raid superblock magic on sde8
[Wed Sep  9 01:14:04 2020] md: sde8 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:04 2020] md: invalid raid superblock magic on sdf5
[Wed Sep  9 01:14:04 2020] md: sdf5 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:04 2020] md: invalid raid superblock magic on sdf6
[Wed Sep  9 01:14:04 2020] md: sdf6 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:04 2020] usb 1-10: not running at top speed
[Wed Sep  9 01:14:04 2020] md: invalid raid superblock magic on sdg5
[Wed Sep  9 01:14:04 2020] md: sdg5 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:04 2020] md: invalid raid superblock magic on sdg6
[Wed Sep  9 01:14:04 2020] md: sdg6 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:04 2020] md: invalid raid superblock magic on sdg7
[Wed Sep  9 01:14:04 2020] md: sdg7 does not have a valid v0.90 superblock, not importing!
[Wed Sep  9 01:14:04 2020] md: Scanned 46 and added 14 devices.
[Wed Sep  9 01:14:04 2020] md: autorun ...
[Wed Sep  9 01:14:04 2020] md: considering sda1 ...
[Wed Sep  9 01:14:04 2020] md:  adding sda1 ...
[Wed Sep  9 01:14:04 2020] md: sda2 has different UUID to sda1
[Wed Sep  9 01:14:04 2020] md:  adding sdb1 ...
[Wed Sep  9 01:14:04 2020] md: sdb2 has different UUID to sda1
[Wed Sep  9 01:14:04 2020] md:  adding sdc1 ...
[Wed Sep  9 01:14:04 2020] md: sdc2 has different UUID to sda1
[Wed Sep  9 01:14:04 2020] md:  adding sdd1 ...
[Wed Sep  9 01:14:04 2020] md: sdd2 has different UUID to sda1
[Wed Sep  9 01:14:04 2020] md:  adding sde1 ...
[Wed Sep  9 01:14:04 2020] md: sde2 has different UUID to sda1
[Wed Sep  9 01:14:04 2020] md:  adding sdf1 ...
[Wed Sep  9 01:14:04 2020] md: sdf2 has different UUID to sda1
[Wed Sep  9 01:14:04 2020] md:  adding sdg1 ...
[Wed Sep  9 01:14:04 2020] md: sdg2 has different UUID to sda1
[Wed Sep  9 01:14:04 2020] md: created md0
[Wed Sep  9 01:14:04 2020] md: bind<sdg1>
[Wed Sep  9 01:14:04 2020] md: bind<sdf1>
[Wed Sep  9 01:14:04 2020] md: bind<sde1>
[Wed Sep  9 01:14:04 2020] md: bind<sdd1>
[Wed Sep  9 01:14:04 2020] md: bind<sdc1>
[Wed Sep  9 01:14:04 2020] md: bind<sdb1>
[Wed Sep  9 01:14:04 2020] md: bind<sda1>
[Wed Sep  9 01:14:04 2020] md: running: <sda1><sdb1><sdc1><sdd1><sde1><sdf1><sdg1>
[Wed Sep  9 01:14:04 2020] md/raid1:md0: active with 7 out of 16 mirrors
[Wed Sep  9 01:14:04 2020] md0: detected capacity change from 0 to 2549940224
[Wed Sep  9 01:14:04 2020] md: considering sda2 ...
[Wed Sep  9 01:14:04 2020] md:  adding sda2 ...
[Wed Sep  9 01:14:04 2020] md:  adding sdb2 ...
[Wed Sep  9 01:14:04 2020] md:  adding sdc2 ...
[Wed Sep  9 01:14:04 2020] md:  adding sdd2 ...
[Wed Sep  9 01:14:04 2020] md:  adding sde2 ...
[Wed Sep  9 01:14:04 2020] md:  adding sdf2 ...
[Wed Sep  9 01:14:04 2020] md:  adding sdg2 ...
[Wed Sep  9 01:14:04 2020] md: created md1
[Wed Sep  9 01:14:04 2020] md: bind<sdg2>
[Wed Sep  9 01:14:04 2020] md: bind<sdf2>
[Wed Sep  9 01:14:04 2020] md: bind<sde2>
[Wed Sep  9 01:14:04 2020] md: bind<sdd2>
[Wed Sep  9 01:14:04 2020] md: bind<sdc2>
[Wed Sep  9 01:14:04 2020] md: bind<sdb2>
[Wed Sep  9 01:14:04 2020] md: bind<sda2>
[Wed Sep  9 01:14:04 2020] md: running: <sda2><sdb2><sdc2><sdd2><sde2><sdf2><sdg2>
[Wed Sep  9 01:14:04 2020] md/raid1:md1: active with 7 out of 16 mirrors
[Wed Sep  9 01:14:04 2020] md1: detected capacity change from 0 to 2147418112
[Wed Sep  9 01:14:04 2020] md: ... autorun DONE.
[Wed Sep  9 01:14:05 2020] usb 1-10: new high-speed USB device number 2 using xhci_hcd
[Wed Sep  9 01:14:05 2020] EXT4-fs (md0): barriers disabled
[Wed Sep  9 01:14:05 2020] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts:
[Wed Sep  9 01:14:05 2020] usb 1-10: not running at top speed
[Wed Sep  9 01:14:06 2020] usb 1-10: new high-speed USB device number 2 using xhci_hcd
[Wed Sep  9 01:14:06 2020] usb 1-10: not running at top speed
[Wed Sep  9 01:14:06 2020] Got empty serial number. Generate serial number from product.
[Wed Sep  9 01:14:06 2020] hub 1-10:1.0: USB hub found
[Wed Sep  9 01:14:06 2020] hub 1-10:1.0: 4 ports detected
[Wed Sep  9 01:14:06 2020] usb 2-6: new SuperSpeed USB device number 2 using xhci_hcd
[Wed Sep  9 01:14:06 2020] drivers/usb/core/hub.c (2897) Same device found. Change serial to ffffffd1ffffffb2ffffffdbffffffa0
[Wed Sep  9 01:14:06 2020] hub 2-6:1.0: USB hub found
[Wed Sep  9 01:14:06 2020] hub 2-6:1.0: 4 ports detected
[Wed Sep  9 01:14:06 2020] usb 1-14: new high-speed USB device number 3 using xhci_hcd
[Wed Sep  9 01:14:06 2020] usb 1-14: ep 0x81 - rounding interval to 128 microframes, ep desc says 255 microframes
[Wed Sep  9 01:14:06 2020] usb 1-14: ep 0x2 - rounding interval to 128 microframes, ep desc says 255 microframes
[Wed Sep  9 01:14:06 2020] usb-storage 1-14:1.0: USB Mass Storage device detected
[Wed Sep  9 01:14:06 2020] scsi host14: usb-storage 1-14:1.0
[Wed Sep  9 01:14:06 2020] usb 2-1: new SuperSpeed USB device number 3 using xhci_hcd
[Wed Sep  9 01:14:07 2020] EXT4-fs (md0): mounted filesystem with ordered data mode. Opts: barrier=1
[Wed Sep  9 01:14:07 2020] scsi 14:0:0:0: Direct-Access     UFD      USB Flash Drive          1100 PQ: 0 ANSI: 0 CCS
[Wed Sep  9 01:14:07 2020] sd 14:0:0:0: [synoboot] 15663104 512-byte logical blocks: (8.02 GB/7.47 GiB)
[Wed Sep  9 01:14:07 2020] sd 14:0:0:0: [synoboot] Write Protect is off
[Wed Sep  9 01:14:07 2020] sd 14:0:0:0: [synoboot] Mode Sense: 43 00 00 00
[Wed Sep  9 01:14:07 2020] sd 14:0:0:0: [synoboot] No Caching mode page found
[Wed Sep  9 01:14:07 2020] sd 14:0:0:0: [synoboot] Assuming drive cache: write through
[Wed Sep  9 01:14:07 2020] Alternate GPT is invalid, using primary GPT.
[Wed Sep  9 01:14:07 2020]  synoboot: synoboot1 synoboot2 synoboot3
[Wed Sep  9 01:14:07 2020] sd 14:0:0:0: [synoboot] Attached SCSI removable disk
[Wed Sep  9 01:14:08 2020] EXT4-fs (md0): re-mounted. Opts: (null)
[Wed Sep  9 01:14:11 2020] sd 0:0:0:0: Attached scsi generic sg0 type 0
[Wed Sep  9 01:14:11 2020] sd 1:0:0:0: Attached scsi generic sg1 type 0
[Wed Sep  9 01:14:11 2020] sd 2:0:0:0: Attached scsi generic sg2 type 0
[Wed Sep  9 01:14:11 2020] sd 3:0:0:0: Attached scsi generic sg3 type 0
[Wed Sep  9 01:14:11 2020] sd 4:0:0:0: Attached scsi generic sg4 type 0
[Wed Sep  9 01:14:11 2020] sd 5:0:0:0: Attached scsi generic sg5 type 0
[Wed Sep  9 01:14:11 2020] sd 6:0:0:0: Attached scsi generic sg6 type 0
[Wed Sep  9 01:14:11 2020] scsi 13:0:0:0: Attached scsi generic sg7 type 3
[Wed Sep  9 01:14:11 2020] sd 14:0:0:0: Attached scsi generic sg8 type 0
[Wed Sep  9 01:14:11 2020] Adding 2097084k swap on /dev/md1.  Priority:-1 extents:1 across:2097084k
[Wed Sep  9 01:14:12 2020] zram: Added device: zram0
[Wed Sep  9 01:14:12 2020] zram: Added device: zram1
[Wed Sep  9 01:14:12 2020] zram: Added device: zram2
[Wed Sep  9 01:14:12 2020] zram: Added device: zram3
[Wed Sep  9 01:14:12 2020] zram0: detected capacity change from 0 to 2503999488
[Wed Sep  9 01:14:12 2020] Adding 2445308k swap on /dev/zram0.  Priority:1 extents:1 across:2445308k SS
[Wed Sep  9 01:14:12 2020] zram1: detected capacity change from 0 to 2503999488
[Wed Sep  9 01:14:12 2020] Adding 2445308k swap on /dev/zram1.  Priority:1 extents:1 across:2445308k SS
[Wed Sep  9 01:14:12 2020] zram2: detected capacity change from 0 to 2503999488
[Wed Sep  9 01:14:12 2020] Adding 2445308k swap on /dev/zram2.  Priority:1 extents:1 across:2445308k SS
[Wed Sep  9 01:14:12 2020] zram3: detected capacity change from 0 to 2503999488
[Wed Sep  9 01:14:12 2020] Adding 2445308k swap on /dev/zram3.  Priority:1 extents:1 across:2445308k SS
[Wed Sep  9 01:14:13 2020] NET: Registered protocol family 10
[Wed Sep  9 01:14:13 2020] sit: IPv6 over IPv4 tunneling driver
[Wed Sep  9 01:14:13 2020] init: syno-auth-check main process (6936) killed by TERM signal
[Wed Sep  9 01:14:13 2020] Monitor-Mwait will be used to enter C-1 state
[Wed Sep  9 01:14:13 2020] Monitor-Mwait will be used to enter C-2 state
[Wed Sep  9 01:14:13 2020] ACPI: acpi_idle registered with cpuidle
[Wed Sep  9 01:14:14 2020] AVX2 version of gcm_enc/dec engaged.
[Wed Sep  9 01:14:14 2020] AES CTR mode by8 optimization enabled
[Wed Sep  9 01:14:14 2020] fuse init (API version 7.23)
[Wed Sep  9 01:14:14 2020] e1000e: Intel(R) PRO/1000 Network Driver - 3.6.0-NAPI
[Wed Sep  9 01:14:14 2020] e1000e: Copyright(c) 1999 - 2019 Intel Corporation.
[Wed Sep  9 01:14:14 2020] e1000e 0000:00:19.0: Interrupt Throttling Rate (ints/sec) set to dynamic conservative mode
[Wed Sep  9 01:14:14 2020] e1000e 0000:00:19.0 eth0: (PCI Express:2.5GT/s:Width x1) 94:de:80:a5:f8:5d
[Wed Sep  9 01:14:14 2020] e1000e 0000:00:19.0 eth0: Intel(R) PRO/1000 Network Connection
[Wed Sep  9 01:14:14 2020] e1000e 0000:00:19.0 eth0: MAC: 11, PHY: 12, PBA No: FFFFFF-0FF
[Wed Sep  9 01:14:14 2020] Intel(R) Gigabit Ethernet Linux Driver - version 5.3.5.39
[Wed Sep  9 01:14:14 2020] Copyright(c) 2007 - 2019 Intel Corporation.
[Wed Sep  9 01:14:14 2020] Intel(R) 10GbE PCI Express Linux Network Driver - version 5.6.3
[Wed Sep  9 01:14:14 2020] Copyright(c) 1999 - 2019 Intel Corporation.
[Wed Sep  9 01:14:14 2020] i40e: Intel(R) Ethernet Connection XL710 Network Driver - version 1.3.46-k
[Wed Sep  9 01:14:14 2020] i40e: Copyright (c) 2013 - 2014 Intel Corporation.
[Wed Sep  9 01:14:14 2020] tn40xx: Tehuti Network Driver, 0.3.6.17.2
[Wed Sep  9 01:14:14 2020] tn40xx: Supported phys : MV88X3120 MV88X3310 MV88E2010 QT2025 TLK10232 AQR105 MUSTANG
[Wed Sep  9 01:14:14 2020] Compat-mlnx-ofed backport release: f36c870
[Wed Sep  9 01:14:14 2020] Backport based on mlnx_ofed/mlnx-ofa_kernel-4.0.git f36c870
[Wed Sep  9 01:14:14 2020] compat.git: mlnx_ofed/mlnx-ofa_kernel-4.0.git
[Wed Sep  9 01:14:14 2020] bnx2x: QLogic 5771x/578xx 10/20-Gigabit Ethernet Driver bnx2x 1.712.30-0 (2014/02/10)
[Wed Sep  9 01:14:14 2020] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input0
[Wed Sep  9 01:14:14 2020] ACPI: Power Button [PWRB]
[Wed Sep  9 01:14:14 2020] input: Power Button as /devices/LNXSYSTM:00/LNXPWRBN:00/input/input1
[Wed Sep  9 01:14:14 2020] ACPI: Power Button [PWRF]
[Wed Sep  9 01:14:14 2020] mtrr: type mismatch for e0000000,10000000 old: write-back new: write-combining
[Wed Sep  9 01:14:14 2020] Failed to add WC MTRR for [00000000e0000000-00000000efffffff]; performance may suffer.
[Wed Sep  9 01:14:14 2020] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[Wed Sep  9 01:14:14 2020] [drm] Driver supports precise vblank timestamp query.
[Wed Sep  9 01:14:14 2020] vgaarb: device changed decodes: PCI:0000:00:02.0,olddecodes=io+mem,decodes=io+mem:owns=io+mem
[Wed Sep  9 01:14:14 2020] [drm] Initialized i915 1.6.0 20171222 for 0000:00:02.0 on minor 0
[Wed Sep  9 01:14:14 2020] ACPI: Video Device [GFX0] (multi-head: yes  rom: no  post: no)
[Wed Sep  9 01:14:14 2020] acpi device:6e: registered as cooling_device4
[Wed Sep  9 01:14:14 2020] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input2
[Wed Sep  9 01:14:14 2020] [drm] Cannot find any crtc or sizes
[Wed Sep  9 01:14:14 2020] i915 0000:00:02.0: fb0: inteldrmfb frame buffer device
[Wed Sep  9 01:14:14 2020] Btrfs loaded, crc32c=crc32c-intel
[Wed Sep  9 01:14:14 2020] exFAT: Version 1.2.9
[Wed Sep  9 01:14:14 2020] jme: JMicron JMC2XX ethernet driver version 1.0.8
[Wed Sep  9 01:14:14 2020] sky2: driver version 1.30
[Wed Sep  9 01:14:14 2020] QLogic 1/10 GbE Converged/Intelligent Ethernet Driver v5.3.63
[Wed Sep  9 01:14:14 2020] QLogic/NetXen Network Driver v4.0.82
[Wed Sep  9 01:14:14 2020] Solarflare NET driver v4.0
[Wed Sep  9 01:14:14 2020] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
[Wed Sep  9 01:14:14 2020] e1000: Copyright (c) 1999-2006 Intel Corporation.
[Wed Sep  9 01:14:14 2020] pcnet32: pcnet32.c:v1.35 21.Apr.2008 tsbogend@alpha.franken.de
[Wed Sep  9 01:14:14 2020] VMware vmxnet3 virtual NIC driver - version 1.4.5.0-k-NAPI
[Wed Sep  9 01:14:14 2020] usbcore: registered new interface driver ax88179_178a
[Wed Sep  9 01:14:14 2020] usbcore: registered new interface driver asix
[Wed Sep  9 01:14:14 2020] Atheros(R) L2 Ethernet Driver - version 2.2.3
[Wed Sep  9 01:14:14 2020] Copyright (c) 2007 Atheros Corporation.
[Wed Sep  9 01:14:14 2020] bna: QLogic BR-series 10G Ethernet driver - version: 3.2.25.1
[Wed Sep  9 01:14:14 2020] usbcore: registered new interface driver cx82310_eth
[Wed Sep  9 01:14:14 2020] e100: Intel(R) PRO/100 Network Driver, 3.5.24-k2-NAPI
[Wed Sep  9 01:14:14 2020] e100: Copyright(c) 1999-2006 Intel Corporation
[Wed Sep  9 01:14:14 2020] enic: Cisco VIC Ethernet NIC Driver, ver 2.3.0.20
[Wed Sep  9 01:14:14 2020] usbcore: registered new interface driver MOSCHIP usb-ethernet driver
[Wed Sep  9 01:14:14 2020] pegasus: v0.9.3 (2013/04/25), Pegasus/Pegasus II USB Ethernet driver
[Wed Sep  9 01:14:14 2020] usbcore: registered new interface driver pegasus
[Wed Sep  9 01:14:14 2020] usbcore: registered new interface driver plusb
[Wed Sep  9 01:14:14 2020] usbcore: registered new interface driver rtl8150
[Wed Sep  9 01:14:14 2020] via_rhine: v1.10-LK1.5.1 2010-10-09 Written by Donald Becker
[Wed Sep  9 01:14:14 2020] usbcore: registered new interface driver r8152
[Wed Sep  9 01:14:14 2020] vxge: Copyright(c) 2002-2010 Exar Corp.
[Wed Sep  9 01:14:14 2020] vxge: Driver version: 2.5.3.22640-k
[Wed Sep  9 01:14:14 2020] usbcore: registered new interface driver aqc111
[Wed Sep  9 01:14:14 2020] firewire_ohci 0000:05:01.0: enabling device (0000 -> 0003)
[Wed Sep  9 01:14:14 2020] firewire_ohci 0000:05:01.0: added OHCI v1.10 device as card 0, 4 IR + 8 IT contexts, quirks 0x11
[Wed Sep  9 01:14:14 2020] 2020-9-8 23:14:15 UTC
[Wed Sep  9 01:14:14 2020] synobios: load, major number 201
[Wed Sep  9 01:14:14 2020] Brand: Synology
[Wed Sep  9 01:14:14 2020] Model: DS-918+
[Wed Sep  9 01:14:14 2020] This is default settings: set group disks wakeup number to 1, spinup time deno 1
[Wed Sep  9 01:14:14 2020] synobios cpu_arch proc entry initialized
[Wed Sep  9 01:14:14 2020] synobios crypto_hw proc entry initialized
[Wed Sep  9 01:14:14 2020] synobios syno_platform proc entry initialized
[Wed Sep  9 01:14:14 2020] synobios open /dev/ttyS1 success
[Wed Sep  9 01:14:14 2020] usb 2-1: reset SuperSpeed USB device number 3 using xhci_hcd
[Wed Sep  9 01:14:14 2020] netif_napi_add() called with weight 256 on device eth%d
[Wed Sep  9 01:14:14 2020] r8152 2-1:1.0 eth1: v2.13.0 (2020/04/20)
[Wed Sep  9 01:14:14 2020] r8152 2-1:1.0 eth1: This product is covered by one or more of the following patents:
                                        US6,570,884, US6,115,776, and US6,327,625.
[Wed Sep  9 01:14:15 2020] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[Wed Sep  9 01:14:15 2020] IPv6: ADDRCONF(NETDEV_UP): eth1: link is not ready
[Wed Sep  9 01:14:15 2020] firewire_core 0000:05:01.0: created device fw0: GUID 00342b905cad5b00, S400
[Wed Sep  9 01:14:15 2020] systemd-udevd[8793]: starting version 204
[Wed Sep  9 01:14:16 2020] Bluetooth: Core ver 2.21
[Wed Sep  9 01:14:16 2020] NET: Registered protocol family 31
[Wed Sep  9 01:14:16 2020] Bluetooth: HCI device and connection manager initialized
[Wed Sep  9 01:14:16 2020] Bluetooth: HCI socket layer initialized
[Wed Sep  9 01:14:16 2020] Bluetooth: L2CAP socket layer initialized
[Wed Sep  9 01:14:16 2020] Bluetooth: SCO socket layer initialized
[Wed Sep  9 01:14:16 2020] Bluetooth: RFCOMM TTY layer initialized
[Wed Sep  9 01:14:16 2020] Bluetooth: RFCOMM socket layer initialized
[Wed Sep  9 01:14:16 2020] Bluetooth: RFCOMM ver 1.11
[Wed Sep  9 01:14:16 2020] Bluetooth: HIDP (Human Interface Emulation) ver 1.2
[Wed Sep  9 01:14:16 2020] Bluetooth: HIDP socket layer initialized
[Wed Sep  9 01:14:16 2020] usbcore: registered new interface driver btusb
[Wed Sep  9 01:14:16 2020] md: md2 stopped.
[Wed Sep  9 01:14:16 2020] md: bind<sdb5>
[Wed Sep  9 01:14:16 2020] md: bind<sdc5>
[Wed Sep  9 01:14:16 2020] md: bind<sdd5>
[Wed Sep  9 01:14:16 2020] md: bind<sde5>
[Wed Sep  9 01:14:16 2020] md: bind<sdf5>
[Wed Sep  9 01:14:16 2020] md: bind<sdg5>
[Wed Sep  9 01:14:16 2020] md: bind<sda5>
[Wed Sep  9 01:14:16 2020] md/raid:md2: device sda5 operational as raid disk 0
[Wed Sep  9 01:14:16 2020] md/raid:md2: device sdg5 operational as raid disk 6
[Wed Sep  9 01:14:16 2020] md/raid:md2: device sdf5 operational as raid disk 5
[Wed Sep  9 01:14:16 2020] md/raid:md2: device sde5 operational as raid disk 4
[Wed Sep  9 01:14:16 2020] md/raid:md2: device sdd5 operational as raid disk 3
[Wed Sep  9 01:14:16 2020] md/raid:md2: device sdc5 operational as raid disk 2
[Wed Sep  9 01:14:16 2020] md/raid:md2: device sdb5 operational as raid disk 1
[Wed Sep  9 01:14:16 2020] md/raid:md2: allocated 7550kB
[Wed Sep  9 01:14:16 2020] md/raid:md2: raid level 5 active with 7 out of 7 devices, algorithm 2
[Wed Sep  9 01:14:16 2020] RAID conf printout:
[Wed Sep  9 01:14:16 2020]  --- level:5 rd:7 wd:7
[Wed Sep  9 01:14:16 2020]  disk 0, o:1, dev:sda5
[Wed Sep  9 01:14:16 2020]  disk 1, o:1, dev:sdb5
[Wed Sep  9 01:14:16 2020]  disk 2, o:1, dev:sdc5
[Wed Sep  9 01:14:16 2020]  disk 3, o:1, dev:sdd5
[Wed Sep  9 01:14:16 2020]  disk 4, o:1, dev:sde5
[Wed Sep  9 01:14:16 2020]  disk 5, o:1, dev:sdf5
[Wed Sep  9 01:14:16 2020]  disk 6, o:1, dev:sdg5
[Wed Sep  9 01:14:16 2020] md2: detected capacity change from 0 to 8972129009664
[Wed Sep  9 01:14:16 2020] md: md5 stopped.
[Wed Sep  9 01:14:16 2020] md: bind<sdc8>
[Wed Sep  9 01:14:16 2020] md: bind<sdd8>
[Wed Sep  9 01:14:16 2020] md: bind<sde8>
[Wed Sep  9 01:14:16 2020] md: bind<sda8>
[Wed Sep  9 01:14:16 2020] md: bind<sdb8>
[Wed Sep  9 01:14:16 2020] md/raid:md5: device sdb8 operational as raid disk 0
[Wed Sep  9 01:14:16 2020] md/raid:md5: device sda8 operational as raid disk 4
[Wed Sep  9 01:14:16 2020] md/raid:md5: device sde8 operational as raid disk 3
[Wed Sep  9 01:14:16 2020] md/raid:md5: device sdd8 operational as raid disk 2
[Wed Sep  9 01:14:16 2020] md/raid:md5: device sdc8 operational as raid disk 1
[Wed Sep  9 01:14:16 2020] md/raid:md5: allocated 5434kB
[Wed Sep  9 01:14:16 2020] md/raid:md5: raid level 5 active with 5 out of 5 devices, algorithm 2
[Wed Sep  9 01:14:16 2020]  --- level:5 rd:5 wd:5
[Wed Sep  9 01:14:16 2020]  disk 0, o:1, dev:sdb8
[Wed Sep  9 01:14:16 2020]  disk 1, o:1, dev:sdc8
[Wed Sep  9 01:14:16 2020]  disk 2, o:1, dev:sdd8
[Wed Sep  9 01:14:16 2020]  disk 3, o:1, dev:sde8
[Wed Sep  9 01:14:16 2020]  disk 4, o:1, dev:sda8
[Wed Sep  9 01:14:16 2020] md5: detected capacity change from 0 to 4000738967552
[Wed Sep  9 01:14:16 2020] md: md7 stopped.
[Wed Sep  9 01:14:17 2020] md: bind<sdc10>
[Wed Sep  9 01:14:17 2020] md: bind<sda10>
[Wed Sep  9 01:14:17 2020] md: bind<sdb10>
[Wed Sep  9 01:14:17 2020] md/raid:md7: device sdb10 operational as raid disk 0
[Wed Sep  9 01:14:17 2020] md/raid:md7: device sda10 operational as raid disk 2
[Wed Sep  9 01:14:17 2020] md/raid:md7: device sdc10 operational as raid disk 1
[Wed Sep  9 01:14:17 2020] md/raid:md7: allocated 3318kB
[Wed Sep  9 01:14:17 2020] md/raid:md7: raid level 5 active with 3 out of 3 devices, algorithm 2
[Wed Sep  9 01:14:17 2020] RAID conf printout:
[Wed Sep  9 01:14:17 2020]  --- level:5 rd:3 wd:3
[Wed Sep  9 01:14:17 2020]  disk 0, o:1, dev:sdb10
[Wed Sep  9 01:14:17 2020]  disk 1, o:1, dev:sdc10
[Wed Sep  9 01:14:17 2020]  disk 2, o:1, dev:sda10
[Wed Sep  9 01:14:17 2020] md7: detected capacity change from 0 to 3998503796736
[Wed Sep  9 01:14:17 2020] md: md4 stopped.
[Wed Sep  9 01:14:17 2020] md: bind<sdc7>
[Wed Sep  9 01:14:17 2020] md: bind<sdd7>
[Wed Sep  9 01:14:17 2020] md: bind<sde7>
[Wed Sep  9 01:14:17 2020] md: bind<sdg7>
[Wed Sep  9 01:14:17 2020] md: bind<sda7>
[Wed Sep  9 01:14:17 2020] md: bind<sdb7>
[Wed Sep  9 01:14:17 2020] md/raid:md4: device sdb7 operational as raid disk 0
[Wed Sep  9 01:14:17 2020] md/raid:md4: device sda7 operational as raid disk 5
[Wed Sep  9 01:14:17 2020] md/raid:md4: device sdg7 operational as raid disk 4
[Wed Sep  9 01:14:17 2020] md/raid:md4: device sde7 operational as raid disk 3
[Wed Sep  9 01:14:17 2020] md/raid:md4: device sdd7 operational as raid disk 2
[Wed Sep  9 01:14:17 2020] md/raid:md4: device sdc7 operational as raid disk 1
[Wed Sep  9 01:14:17 2020] md/raid:md4: allocated 6492kB
[Wed Sep  9 01:14:17 2020] md/raid:md4: raid level 5 active with 6 out of 6 devices, algorithm 2
[Wed Sep  9 01:14:17 2020]  --- level:5 rd:6 wd:6
[Wed Sep  9 01:14:17 2020]  disk 0, o:1, dev:sdb7
[Wed Sep  9 01:14:17 2020]  disk 1, o:1, dev:sdc7
[Wed Sep  9 01:14:17 2020]  disk 2, o:1, dev:sdd7
[Wed Sep  9 01:14:17 2020]  disk 3, o:1, dev:sde7
[Wed Sep  9 01:14:17 2020]  disk 4, o:1, dev:sdg7
[Wed Sep  9 01:14:17 2020]  disk 5, o:1, dev:sda7
[Wed Sep  9 01:14:17 2020] md4: detected capacity change from 0 to 5000923709440
[Wed Sep  9 01:14:17 2020] md: md6 stopped.
[Wed Sep  9 01:14:17 2020] md: bind<sdc9>
[Wed Sep  9 01:14:17 2020] md: bind<sdd9>
[Wed Sep  9 01:14:17 2020] md: bind<sda9>
[Wed Sep  9 01:14:17 2020] md: bind<sdb9>
[Wed Sep  9 01:14:17 2020] md/raid:md6: device sdb9 operational as raid disk 0
[Wed Sep  9 01:14:17 2020] md/raid:md6: device sda9 operational as raid disk 3
[Wed Sep  9 01:14:17 2020] md/raid:md6: device sdd9 operational as raid disk 2
[Wed Sep  9 01:14:17 2020] md/raid:md6: device sdc9 operational as raid disk 1
[Wed Sep  9 01:14:17 2020] md/raid:md6: allocated 4376kB
[Wed Sep  9 01:14:17 2020] md/raid:md6: raid level 5 active with 4 out of 4 devices, algorithm 2
[Wed Sep  9 01:14:17 2020]  --- level:5 rd:4 wd:4
[Wed Sep  9 01:14:17 2020]  disk 0, o:1, dev:sdb9
[Wed Sep  9 01:14:17 2020]  disk 1, o:1, dev:sdc9
[Wed Sep  9 01:14:17 2020]  disk 2, o:1, dev:sdd9
[Wed Sep  9 01:14:17 2020]  disk 3, o:1, dev:sda9
[Wed Sep  9 01:14:17 2020] md6: detected capacity change from 0 to 12002300657664
[Wed Sep  9 01:14:17 2020] md: md3 stopped.
[Wed Sep  9 01:14:17 2020] md: bind<sdc6>
[Wed Sep  9 01:14:17 2020] md: bind<sdd6>
[Wed Sep  9 01:14:17 2020] md: bind<sde6>
[Wed Sep  9 01:14:17 2020] md: bind<sdf6>
[Wed Sep  9 01:14:17 2020] md: bind<sdg6>
[Wed Sep  9 01:14:17 2020] md: bind<sda6>
[Wed Sep  9 01:14:17 2020] md: bind<sdb6>
[Wed Sep  9 01:14:17 2020] md/raid:md3: device sdb6 operational as raid disk 0
[Wed Sep  9 01:14:17 2020] md/raid:md3: device sda6 operational as raid disk 6
[Wed Sep  9 01:14:17 2020] md/raid:md3: device sdg6 operational as raid disk 5
[Wed Sep  9 01:14:17 2020] md/raid:md3: device sdf6 operational as raid disk 4
[Wed Sep  9 01:14:17 2020] md/raid:md3: device sde6 operational as raid disk 3
[Wed Sep  9 01:14:17 2020] md/raid:md3: device sdd6 operational as raid disk 2
[Wed Sep  9 01:14:17 2020] md/raid:md3: device sdc6 operational as raid disk 1
[Wed Sep  9 01:14:17 2020] md/raid:md3: allocated 7550kB
[Wed Sep  9 01:14:17 2020] md/raid:md3: raid level 5 active with 7 out of 7 devices, algorithm 2
[Wed Sep  9 01:14:17 2020]  --- level:5 rd:7 wd:7
[Wed Sep  9 01:14:17 2020]  disk 0, o:1, dev:sdb6
[Wed Sep  9 01:14:17 2020]  disk 1, o:1, dev:sdc6
[Wed Sep  9 01:14:17 2020]  disk 2, o:1, dev:sdd6
[Wed Sep  9 01:14:17 2020]  disk 3, o:1, dev:sde6
[Wed Sep  9 01:14:17 2020]  disk 4, o:1, dev:sdf6
[Wed Sep  9 01:14:17 2020]  disk 5, o:1, dev:sdg6
[Wed Sep  9 01:14:17 2020]  disk 6, o:1, dev:sda6
[Wed Sep  9 01:14:17 2020] md3: detected capacity change from 0 to 3000526307328
[Wed Sep  9 01:14:18 2020] IPv6: ADDRCONF(NETDEV_CHANGE): eth1: link becomes ready
[Wed Sep  9 01:14:18 2020] r8152 2-1:1.0 eth1: carrier on
[Wed Sep  9 01:14:40 2020] BTRFS: device label 2020.03.26-00:21:10 v24922 devid 1 transid 24564 /dev/vg1/volume_1
[Wed Sep  9 01:14:40 2020] BTRFS info (device dm-1): enabling auto syno reclaim space
[Wed Sep  9 01:14:40 2020] BTRFS info (device dm-1): using free space tree
[Wed Sep  9 01:14:40 2020] BTRFS info (device dm-1): has skinny extents
[Wed Sep  9 01:14:46 2020] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[Wed Sep  9 01:14:46 2020] Warning! ehci_hcd should always be loaded before uhci_hcd and ohci_hcd, not after
[Wed Sep  9 01:14:46 2020] ehci-pci: EHCI PCI platform driver
[Wed Sep  9 01:14:46 2020] ehci-pci 0000:00:1a.0: EHCI Host Controller
[Wed Sep  9 01:14:46 2020] ehci-pci 0000:00:1a.0: new USB bus registered, assigned bus number 3
[Wed Sep  9 01:14:46 2020] ehci-pci 0000:00:1a.0: debug port 2
[Wed Sep  9 01:14:46 2020] ehci-pci 0000:00:1a.0: cache line size of 64 is not supported
[Wed Sep  9 01:14:46 2020] ehci-pci 0000:00:1a.0: irq 16, io mem 0xf7d3c000
[Wed Sep  9 01:14:46 2020] ehci-pci 0000:00:1a.0: USB 2.0 started, EHCI 1.00
[Wed Sep  9 01:14:46 2020] hub 3-0:1.0: USB hub found
[Wed Sep  9 01:14:46 2020] hub 3-0:1.0: 2 ports detected
[Wed Sep  9 01:14:46 2020] ehci-pci 0000:00:1d.0: EHCI Host Controller
[Wed Sep  9 01:14:46 2020] ehci-pci 0000:00:1d.0: new USB bus registered, assigned bus number 4
[Wed Sep  9 01:14:46 2020] ehci-pci 0000:00:1d.0: debug port 2
[Wed Sep  9 01:14:46 2020] ehci-pci 0000:00:1d.0: cache line size of 64 is not supported
[Wed Sep  9 01:14:46 2020] ehci-pci 0000:00:1d.0: irq 23, io mem 0xf7d3b000
[Wed Sep  9 01:14:46 2020] ehci-pci 0000:00:1d.0: USB 2.0 started, EHCI 1.00
[Wed Sep  9 01:14:46 2020] hub 4-0:1.0: USB hub found
[Wed Sep  9 01:14:46 2020] hub 4-0:1.0: 2 ports detected
[Wed Sep  9 01:14:46 2020] uhci_hcd: USB Universal Host Controller Interface driver
[Wed Sep  9 01:14:46 2020] usbcore: registered new interface driver usblp
[Wed Sep  9 01:14:46 2020] usbcore: registered new interface driver usbhid
[Wed Sep  9 01:14:46 2020] usbhid: USB HID core driver
[Wed Sep  9 01:14:46 2020] iSCSI:target_core_rodsp_server.c:1027:rodsp_server_init RODSP server started, login_key(94de80a5f85d).
[Wed Sep  9 01:14:46 2020] iSCSI:extent_pool.c:766:ep_init syno_extent_pool successfully initialized
[Wed Sep  9 01:14:47 2020] usb 3-1: new high-speed USB device number 2 using ehci-pci
[Wed Sep  9 01:14:47 2020] iSCSI:target_core_device.c:617:se_dev_align_max_sectors Rounding down aligned max_sectors from 4294967295 to 4294967288
[Wed Sep  9 01:14:47 2020] iSCSI:target_core_lunbackup.c:361:init_io_buffer_head 512 buffers allocated, total 2097152 bytes successfully
[Wed Sep  9 01:14:47 2020] usb 4-1: new high-speed USB device number 2 using ehci-pci
[Wed Sep  9 01:14:47 2020] iSCSI:target_core_file.c:146:fd_attach_hba RODSP plugin for fileio is enabled.
[Wed Sep  9 01:14:47 2020] iSCSI:target_core_file.c:153:fd_attach_hba ODX Token Manager is enabled.
[Wed Sep  9 01:14:47 2020] iSCSI:target_core_multi_file.c:91:fd_attach_hba RODSP plugin for multifile is enabled.
[Wed Sep  9 01:14:47 2020] iSCSI:target_core_ep.c:786:ep_attach_hba RODSP plugin for epio is enabled.
[Wed Sep  9 01:14:47 2020] iSCSI:target_core_ep.c:793:ep_attach_hba ODX Token Manager is enabled.
[Wed Sep  9 01:14:47 2020] Got empty serial number. Generate serial number from product.
[Wed Sep  9 01:14:47 2020] drivers/usb/core/hub.c (2897) Same device found. Change serial to ffffffd1ffffffb2ffffffdbffffffa0
[Wed Sep  9 01:14:47 2020] drivers/usb/core/hub.c (2897) Same device found. Change serial to ffffffd1ffffffb2ffffffdbffffffa1
[Wed Sep  9 01:14:47 2020] hub 3-1:1.0: USB hub found
[Wed Sep  9 01:14:47 2020] hub 3-1:1.0: 6 ports detected
[Wed Sep  9 01:14:47 2020] drivers/usb/core/hub.c (2897) Same device found. Change serial to ffffffd1ffffffb2ffffffdbffffffa2
[Wed Sep  9 01:14:47 2020] hub 4-1:1.0: USB hub found
[Wed Sep  9 01:14:47 2020] hub 4-1:1.0: 8 ports detected
[Wed Sep  9 01:14:47 2020] FAT-fs (synoboot2): fat_set_state: set=1 process=synopkicompatsy pid=13852
[Wed Sep  9 01:14:47 2020] FAT-fs (synoboot2): fat_set_state: set=0 process=synopkicompatsy pid=13852
[Wed Sep  9 01:14:47 2020] loop: module loaded
[Wed Sep  9 01:14:48 2020] capability: warning: `nginx' uses 32-bit capabilities (legacy support in use)
[Wed Sep  9 01:14:49 2020] ata7.00: configured for UDMA/133
[Wed Sep  9 01:14:49 2020] ata7: EH complete
[Wed Sep  9 01:14:49 2020] sd 6:0:0:0: [sdg] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[Wed Sep  9 01:14:49 2020] ata1.00: configured for UDMA/133
[Wed Sep  9 01:14:49 2020] ata1: EH complete
[Wed Sep  9 01:14:49 2020] ata2.00: disabling queued TRIM support
[Wed Sep  9 01:14:49 2020] ata2.00: configured for UDMA/133
[Wed Sep  9 01:14:49 2020] ata2: EH complete
[Wed Sep  9 01:14:50 2020] ata3.00: disabling queued TRIM support
[Wed Sep  9 01:14:50 2020] ata3.00: configured for UDMA/133
[Wed Sep  9 01:14:50 2020] ata3: EH complete
[Wed Sep  9 01:14:50 2020] ata4.00: configured for UDMA/133
[Wed Sep  9 01:14:50 2020] ata4: EH complete
[Wed Sep  9 01:14:50 2020] ata5.00: configured for UDMA/133
[Wed Sep  9 01:14:50 2020] ata5: EH complete
[Wed Sep  9 01:14:50 2020] ata6.00: configured for UDMA/133
[Wed Sep  9 01:14:50 2020] ata6: EH complete
[Wed Sep  9 01:14:50 2020] sd 5:0:0:0: [sdf] Write cache: disabled, read cache: enabled, doesn't support DPO or FUA
[Wed Sep  9 01:14:56 2020] ata6.00: configured for UDMA/133
[Wed Sep  9 01:14:56 2020] ata6: EH complete
[Wed Sep  9 01:14:56 2020] sd 5:0:0:0: [sdf] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[Wed Sep  9 01:14:57 2020] ata7.00: configured for UDMA/133
[Wed Sep  9 01:14:57 2020] ata7: EH complete
[Wed Sep  9 01:14:57 2020] sd 6:0:0:0: [sdg] Write cache: enabled, read cache: enabled, doesn't support DPO or FUA
[Wed Sep  9 01:15:10 2020] init: synocontentextractd main process ended, respawning
[Wed Sep  9 01:20:46 2020] init: prefetch-pkgicon main process (12790) terminated with status 1
[Wed Sep  9 10:29:10 2020] perf interrupt took too long (2524 > 2500), lowering kernel.perf_event_max_sample_rate to 50000
[Wed Sep  9 15:38:34 2020] ata3.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[Wed Sep  9 15:38:34 2020] ata3.00: failed command: FLUSH CACHE EXT
[Wed Sep  9 15:38:34 2020] ata3.00: cmd ea/00:00:00:00:00/00:00:00:00:00/a0 tag 14
                                    res 40/00:01:e0:00:00/00:00:00:00:00/00 Emask 0x4 (timeout)
[Wed Sep  9 15:38:34 2020] ata3.00: status: { DRDY }
[Wed Sep  9 15:38:34 2020] ata3: hard resetting link
[Wed Sep  9 15:38:34 2020] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[Wed Sep  9 15:38:34 2020] ata3.00: disabling queued TRIM support
[Wed Sep  9 15:38:34 2020] ata3.00: configured for UDMA/133
[Wed Sep  9 15:38:34 2020] ata3.00: retrying FLUSH 0xea Emask 0x4
[Wed Sep  9 15:38:34 2020] ata3: EH complete
[Wed Sep  9 21:13:43 2020] ata3.00: exception Emask 0x0 SAct 0x0 SErr 0x0 action 0x6 frozen
[Wed Sep  9 21:13:43 2020] ata3.00: failed command: FLUSH CACHE EXT
[Wed Sep  9 21:13:43 2020] ata3.00: cmd ea/00:00:00:00:00/00:00:00:00:00/a0 tag 14
[Wed Sep  9 21:13:43 2020] ata3.00: status: { DRDY }
[Wed Sep  9 21:13:43 2020] ata3: hard resetting link
[Wed Sep  9 21:13:44 2020] ata3: SATA link up 6.0 Gbps (SStatus 133 SControl 300)
[Wed Sep  9 21:13:44 2020] ata3.00: disabling queued TRIM support
[Wed Sep  9 21:13:44 2020] ata3.00: configured for UDMA/133
[Wed Sep  9 21:13:44 2020] ata3.00: retrying FLUSH 0xea Emask 0x4
[Wed Sep  9 21:13:44 2020] ata3: EH complete
[Wed Sep  9 22:35:41 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Wed Sep  9 22:35:41 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Wed Sep  9 22:35:41 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Wed Sep  9 22:35:41 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Wed Sep  9 22:35:41 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Wed Sep  9 22:35:41 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Wed Sep  9 22:35:41 2020] Call Trace:
[Wed Sep  9 22:35:41 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Wed Sep  9 22:35:41 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Wed Sep  9 22:35:41 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Wed Sep  9 22:35:41 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Wed Sep  9 22:35:41 2020]  [<ffffffff814a8f98>] ? __netif_receive_skb+0x18/0x60
[Wed Sep  9 22:35:41 2020]  [<ffffffff814a9015>] ? netif_receive_skb_internal+0x35/0xa0
[Wed Sep  9 22:35:41 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Wed Sep  9 22:35:41 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Wed Sep  9 22:35:41 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Wed Sep  9 22:35:41 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Wed Sep  9 22:35:41 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Wed Sep  9 22:35:41 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Wed Sep  9 22:35:41 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Wed Sep  9 22:35:41 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Wed Sep  9 22:35:41 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Wed Sep  9 22:35:41 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Wed Sep  9 22:35:41 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Wed Sep  9 22:35:41 2020] Mem-Info:
[Wed Sep  9 22:35:41 2020] active_anon:50879 inactive_anon:65107 isolated_anon:0
                            active_file:694876 inactive_file:2739864 isolated_file:0
                            unevictable:862 dirty:539862 writeback:20435 unstable:0
                            slab_reclaimable:210573 slab_unreclaimable:38431
                            mapped:29246 shmem:37654 pagetables:12630 bounce:0
                            free:87370 free_pcp:397 free_cma:0
[Wed Sep  9 22:35:41 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Wed Sep  9 22:35:41 2020] lowmem_reserve[]: 0 3366 15875 15875
[Wed Sep  9 22:35:41 2020] DMA32 free:116768kB min:13976kB low:17468kB high:20964kB active_anon:49872kB inactive_anon:77320kB active_file:753756kB inactive_file:2147588kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:214772kB writeback:1712kB mapped:35704kB shmem:36224kB slab_reclaimable:149740kB slab_unreclaimable:35052kB kernel_stack:1536kB pagetables:11936kB unstable:0kB bounce:0kB free_pcp:628kB local_pcp:152kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:35:41 2020] lowmem_reserve[]: 0 0 12508 12508
[Wed Sep  9 22:35:41 2020] Normal free:216832kB min:51492kB low:64364kB high:77236kB active_anon:153644kB inactive_anon:183108kB active_file:2025748kB inactive_file:8811868kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:1944676kB writeback:80028kB mapped:81280kB shmem:114392kB slab_reclaimable:692552kB slab_unreclaimable:118672kB kernel_stack:7232kB pagetables:38584kB unstable:0kB bounce:0kB free_pcp:960kB local_pcp:104kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:35:41 2020] lowmem_reserve[]: 0 0 0 0
[Wed Sep  9 22:35:41 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Wed Sep  9 22:35:41 2020] DMA32: 25815*4kB (UME) 1667*8kB (UME) 4*16kB (M) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 116660kB
[Wed Sep  9 22:35:41 2020] Normal: 49780*4kB (UME) 2186*8kB (U) 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 216608kB
[Wed Sep  9 22:35:41 2020] 3472733 total pagecache pages
[Wed Sep  9 22:35:41 2020] 322 pages in swap cache
[Wed Sep  9 22:35:41 2020] Swap cache stats: add 36367, delete 36045, find 1450605/1451264
[Wed Sep  9 22:35:41 2020] Free swap  = 11734628kB
[Wed Sep  9 22:35:41 2020] Total swap = 11878316kB
[Wed Sep  9 22:35:41 2020] 4165912 pages RAM
[Wed Sep  9 22:35:41 2020] 0 pages HighMem/MovableOnly
[Wed Sep  9 22:35:41 2020] 90558 pages reserved
[Wed Sep  9 22:35:46 2020] warn_alloc_failed: 7179 callbacks suppressed
[Wed Sep  9 22:35:46 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Wed Sep  9 22:35:46 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Wed Sep  9 22:35:46 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Wed Sep  9 22:35:46 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Wed Sep  9 22:35:46 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Wed Sep  9 22:35:46 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Wed Sep  9 22:35:46 2020] Call Trace:
[Wed Sep  9 22:35:46 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Wed Sep  9 22:35:46 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Wed Sep  9 22:35:46 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Wed Sep  9 22:35:46 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Wed Sep  9 22:35:46 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Wed Sep  9 22:35:46 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Wed Sep  9 22:35:46 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Wed Sep  9 22:35:46 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Wed Sep  9 22:35:46 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Wed Sep  9 22:35:46 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Wed Sep  9 22:35:46 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Wed Sep  9 22:35:46 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Wed Sep  9 22:35:46 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Wed Sep  9 22:35:46 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Wed Sep  9 22:35:46 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Wed Sep  9 22:35:46 2020] Mem-Info:
[Wed Sep  9 22:35:46 2020] active_anon:50916 inactive_anon:65022 isolated_anon:0
                            active_file:662264 inactive_file:2798859 isolated_file:0
                            unevictable:862 dirty:603134 writeback:21766 unstable:0
                            slab_reclaimable:204905 slab_unreclaimable:38544
                            mapped:29203 shmem:37655 pagetables:12631 bounce:0
                            free:66431 free_pcp:914 free_cma:0
[Wed Sep  9 22:35:46 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Wed Sep  9 22:35:46 2020] lowmem_reserve[]: 0 3366 15875 15875
[Wed Sep  9 22:35:46 2020] DMA32 free:89244kB min:13976kB low:17468kB high:20964kB active_anon:49412kB inactive_anon:77292kB active_file:742132kB inactive_file:2191116kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:305912kB writeback:3628kB mapped:35792kB shmem:36224kB slab_reclaimable:145372kB slab_unreclaimable:34944kB kernel_stack:1536kB pagetables:11280kB unstable:0kB bounce:0kB free_pcp:1588kB local_pcp:184kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:35:46 2020] lowmem_reserve[]: 0 0 12508 12508
[Wed Sep  9 22:35:46 2020] Normal free:160600kB min:51492kB low:64364kB high:77236kB active_anon:154252kB inactive_anon:182796kB active_file:1906924kB inactive_file:9004320kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:2106624kB writeback:83436kB mapped:81020kB shmem:114396kB slab_reclaimable:674248kB slab_unreclaimable:119232kB kernel_stack:7216kB pagetables:39244kB unstable:0kB bounce:0kB free_pcp:2068kB local_pcp:220kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:35:46 2020] lowmem_reserve[]: 0 0 0 0
[Wed Sep  9 22:35:46 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Wed Sep  9 22:35:46 2020] DMA32: 21932*4kB (UM) 182*8kB (UM) 9*16kB (M) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 89328kB
[Wed Sep  9 22:35:46 2020] Normal: 38147*4kB (UE) 1017*8kB (UME) 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 160724kB
[Wed Sep  9 22:35:46 2020] 3499221 total pagecache pages
[Wed Sep  9 22:35:46 2020] 325 pages in swap cache
[Wed Sep  9 22:35:46 2020] Swap cache stats: add 36639, delete 36314, find 1451133/1451796
[Wed Sep  9 22:35:46 2020] Free swap  = 11733556kB
[Wed Sep  9 22:35:46 2020] Total swap = 11878316kB
[Wed Sep  9 22:35:46 2020] 4165912 pages RAM
[Wed Sep  9 22:35:46 2020] 0 pages HighMem/MovableOnly
[Wed Sep  9 22:35:46 2020] 90558 pages reserved
[Wed Sep  9 22:35:51 2020] warn_alloc_failed: 5254 callbacks suppressed
[Wed Sep  9 22:35:51 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Wed Sep  9 22:35:51 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Wed Sep  9 22:35:51 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Wed Sep  9 22:35:51 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Wed Sep  9 22:35:51 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Wed Sep  9 22:35:51 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Wed Sep  9 22:35:51 2020] Call Trace:
[Wed Sep  9 22:35:51 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Wed Sep  9 22:35:51 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Wed Sep  9 22:35:51 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Wed Sep  9 22:35:51 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Wed Sep  9 22:35:51 2020]  [<ffffffff814a8f98>] ? __netif_receive_skb+0x18/0x60
[Wed Sep  9 22:35:51 2020]  [<ffffffff814a9015>] ? netif_receive_skb_internal+0x35/0xa0
[Wed Sep  9 22:35:51 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Wed Sep  9 22:35:51 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Wed Sep  9 22:35:51 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Wed Sep  9 22:35:51 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Wed Sep  9 22:35:51 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Wed Sep  9 22:35:51 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Wed Sep  9 22:35:51 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Wed Sep  9 22:35:51 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Wed Sep  9 22:35:51 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Wed Sep  9 22:35:51 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Wed Sep  9 22:35:51 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Wed Sep  9 22:35:51 2020] Mem-Info:
[Wed Sep  9 22:35:51 2020] active_anon:49781 inactive_anon:64214 isolated_anon:0
                            active_file:626867 inactive_file:2842144 isolated_file:0
                            unevictable:862 dirty:589979 writeback:24021 unstable:0
                            slab_reclaimable:202572 slab_unreclaimable:38456
                            mapped:29161 shmem:37643 pagetables:12298 bounce:0
                            free:62778 free_pcp:1125 free_cma:0
[Wed Sep  9 22:35:51 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Wed Sep  9 22:35:51 2020] lowmem_reserve[]: 0 3366 15875 15875
[Wed Sep  9 22:35:51 2020] DMA32 free:88768kB min:13976kB low:17468kB high:20964kB active_anon:49312kB inactive_anon:77256kB active_file:721892kB inactive_file:2213648kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:257040kB writeback:13384kB mapped:35704kB shmem:36224kB slab_reclaimable:143996kB slab_unreclaimable:34892kB kernel_stack:1568kB pagetables:11224kB unstable:0kB bounce:0kB free_pcp:1696kB local_pcp:680kB free_cma:0kB writeback_tmp:0kB pages_scanned:32 all_unreclaimable? no
[Wed Sep  9 22:35:51 2020] lowmem_reserve[]: 0 0 12508 12508
[Wed Sep  9 22:35:51 2020] Normal free:146464kB min:51492kB low:64364kB high:77236kB active_anon:149812kB inactive_anon:179600kB active_file:1785576kB inactive_file:9154928kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:2102876kB writeback:82700kB mapped:80940kB shmem:114348kB slab_reclaimable:666292kB slab_unreclaimable:118932kB kernel_stack:7232kB pagetables:37968kB unstable:0kB bounce:0kB free_pcp:2804kB local_pcp:708kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:35:51 2020] lowmem_reserve[]: 0 0 0 0
[Wed Sep  9 22:35:51 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Wed Sep  9 22:35:51 2020] DMA32: 21955*4kB (UME) 79*8kB (UM) 6*16kB (UM) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 88548kB
[Wed Sep  9 22:35:51 2020] Normal: 36298*4kB (UME) 173*8kB (U) 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 146576kB
[Wed Sep  9 22:35:51 2020] 3507041 total pagecache pages
[Wed Sep  9 22:35:51 2020] 300 pages in swap cache
[Wed Sep  9 22:35:51 2020] Swap cache stats: add 38326, delete 38026, find 1451160/1451824
[Wed Sep  9 22:35:51 2020] Free swap  = 11726812kB
[Wed Sep  9 22:35:51 2020] Total swap = 11878316kB
[Wed Sep  9 22:35:51 2020] 4165912 pages RAM
[Wed Sep  9 22:35:51 2020] 0 pages HighMem/MovableOnly
[Wed Sep  9 22:35:51 2020] 90558 pages reserved
[Wed Sep  9 22:35:56 2020] warn_alloc_failed: 5892 callbacks suppressed
[Wed Sep  9 22:35:56 2020] xz: page allocation failure: order:4, mode:0x2084020
[Wed Sep  9 22:35:56 2020] CPU: 1 PID: 26116 Comm: xz Tainted: P           OE   4.4.59+ #25426
[Wed Sep  9 22:35:56 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Wed Sep  9 22:35:56 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Wed Sep  9 22:35:56 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Wed Sep  9 22:35:56 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Wed Sep  9 22:35:56 2020] Call Trace:
[Wed Sep  9 22:35:56 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Wed Sep  9 22:35:56 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Wed Sep  9 22:35:56 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Wed Sep  9 22:35:56 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Wed Sep  9 22:35:56 2020]  [<ffffffff814a8f98>] ? __netif_receive_skb+0x18/0x60
[Wed Sep  9 22:35:56 2020]  [<ffffffff814a9015>] ? netif_receive_skb_internal+0x35/0xa0
[Wed Sep  9 22:35:56 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Wed Sep  9 22:35:56 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Wed Sep  9 22:35:56 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Wed Sep  9 22:35:56 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Wed Sep  9 22:35:56 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Wed Sep  9 22:35:56 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Wed Sep  9 22:35:56 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Wed Sep  9 22:35:56 2020]  <EOI> Mem-Info:
[Wed Sep  9 22:35:56 2020] active_anon:53366 inactive_anon:67466 isolated_anon:0
                            active_file:589044 inactive_file:2876542 isolated_file:0
                            unevictable:862 dirty:584883 writeback:26680 unstable:0
                            slab_reclaimable:198357 slab_unreclaimable:38444
                            mapped:30085 shmem:37643 pagetables:12498 bounce:0
                            free:62967 free_pcp:992 free_cma:0
[Wed Sep  9 22:35:56 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Wed Sep  9 22:35:56 2020] lowmem_reserve[]: 0 3366 15875 15875
[Wed Sep  9 22:35:56 2020] DMA32 free:89184kB min:13976kB low:17468kB high:20964kB active_anon:50516kB inactive_anon:77644kB active_file:712796kB inactive_file:2222220kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:295636kB writeback:1616kB mapped:36556kB shmem:36228kB slab_reclaimable:140940kB slab_unreclaimable:34892kB kernel_stack:1792kB pagetables:11824kB unstable:0kB bounce:0kB free_pcp:1808kB local_pcp:212kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:35:56 2020] lowmem_reserve[]: 0 0 12508 12508
[Wed Sep  9 22:35:56 2020] Normal free:146804kB min:51492kB low:64364kB high:77236kB active_anon:162948kB inactive_anon:192220kB active_file:1643380kB inactive_file:9283948kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:2043896kB writeback:105104kB mapped:83784kB shmem:114344kB slab_reclaimable:652488kB slab_unreclaimable:118884kB kernel_stack:7136kB pagetables:38168kB unstable:0kB bounce:0kB free_pcp:2160kB local_pcp:80kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:35:56 2020] lowmem_reserve[]: 0 0 0 0
[Wed Sep  9 22:35:56 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Wed Sep  9 22:35:56 2020] DMA32: 22193*4kB (UME) 84*8kB (UM) 3*16kB (UM) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 89492kB
[Wed Sep  9 22:35:56 2020] Normal: 36762*4kB (U) 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 147048kB
[Wed Sep  9 22:35:56 2020] 3503741 total pagecache pages
[Wed Sep  9 22:35:56 2020] 334 pages in swap cache
[Wed Sep  9 22:35:56 2020] Swap cache stats: add 39856, delete 39522, find 1451959/1452687
[Wed Sep  9 22:35:56 2020] Free swap  = 11720928kB
[Wed Sep  9 22:35:56 2020] Total swap = 11878316kB
[Wed Sep  9 22:35:56 2020] 4165912 pages RAM
[Wed Sep  9 22:35:56 2020] 0 pages HighMem/MovableOnly
[Wed Sep  9 22:35:56 2020] 90558 pages reserved
[Wed Sep  9 22:36:01 2020] warn_alloc_failed: 4883 callbacks suppressed
[Wed Sep  9 22:36:01 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Wed Sep  9 22:36:01 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Wed Sep  9 22:36:01 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Wed Sep  9 22:36:01 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Wed Sep  9 22:36:01 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Wed Sep  9 22:36:01 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Wed Sep  9 22:36:01 2020] Call Trace:
[Wed Sep  9 22:36:01 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Wed Sep  9 22:36:01 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Wed Sep  9 22:36:01 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Wed Sep  9 22:36:01 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Wed Sep  9 22:36:01 2020]  [<ffffffff814a8f98>] ? __netif_receive_skb+0x18/0x60
[Wed Sep  9 22:36:01 2020]  [<ffffffff814a9015>] ? netif_receive_skb_internal+0x35/0xa0
[Wed Sep  9 22:36:01 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Wed Sep  9 22:36:01 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Wed Sep  9 22:36:01 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Wed Sep  9 22:36:01 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Wed Sep  9 22:36:01 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Wed Sep  9 22:36:01 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Wed Sep  9 22:36:01 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Wed Sep  9 22:36:01 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Wed Sep  9 22:36:01 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Wed Sep  9 22:36:01 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Wed Sep  9 22:36:01 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Wed Sep  9 22:36:01 2020] Mem-Info:
[Wed Sep  9 22:36:01 2020] active_anon:47949 inactive_anon:62539 isolated_anon:0
                            active_file:553376 inactive_file:2924587 isolated_file:0
                            unevictable:862 dirty:613392 writeback:26682 unstable:0
                            slab_reclaimable:195816 slab_unreclaimable:38489
                            mapped:29176 shmem:37640 pagetables:12385 bounce:0
                            free:63345 free_pcp:918 free_cma:0
[Wed Sep  9 22:36:01 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Wed Sep  9 22:36:01 2020] lowmem_reserve[]: 0 3366 15875 15875
[Wed Sep  9 22:36:01 2020] DMA32 free:88812kB min:13976kB low:17468kB high:20964kB active_anon:50104kB inactive_anon:77140kB active_file:684460kB inactive_file:2254412kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:318348kB writeback:32568kB mapped:35840kB shmem:36224kB slab_reclaimable:139140kB slab_unreclaimable:34800kB kernel_stack:1632kB pagetables:11232kB unstable:0kB bounce:0kB free_pcp:1996kB local_pcp:632kB free_cma:0kB writeback_tmp:0kB pages_scanned:152 all_unreclaimable? no
[Wed Sep  9 22:36:01 2020] lowmem_reserve[]: 0 0 12508 12508
[Wed Sep  9 22:36:01 2020] Normal free:148688kB min:51492kB low:64364kB high:77236kB active_anon:141692kB inactive_anon:173016kB active_file:1529044kB inactive_file:9443936kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:2135220kB writeback:74160kB mapped:80864kB shmem:114336kB slab_reclaimable:644124kB slab_unreclaimable:119156kB kernel_stack:7216kB pagetables:38308kB unstable:0kB bounce:0kB free_pcp:1676kB local_pcp:200kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:36:01 2020] lowmem_reserve[]: 0 0 0 0
[Wed Sep  9 22:36:01 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Wed Sep  9 22:36:01 2020] DMA32: 21461*4kB (UME) 364*8kB (UM) 4*16kB (M) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 88820kB
[Wed Sep  9 22:36:01 2020] Normal: 36442*4kB (UE) 129*8kB (UE) 115*16kB (UME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 148640kB
[Wed Sep  9 22:36:01 2020] 3516046 total pagecache pages
[Wed Sep  9 22:36:01 2020] 319 pages in swap cache
[Wed Sep  9 22:36:01 2020] Swap cache stats: add 42144, delete 41825, find 1452123/1452859
[Wed Sep  9 22:36:01 2020] Free swap  = 11711808kB
[Wed Sep  9 22:36:01 2020] Total swap = 11878316kB
[Wed Sep  9 22:36:01 2020] 4165912 pages RAM
[Wed Sep  9 22:36:01 2020] 0 pages HighMem/MovableOnly
[Wed Sep  9 22:36:01 2020] 90558 pages reserved
[Wed Sep  9 22:36:08 2020] warn_alloc_failed: 3665 callbacks suppressed
[Wed Sep  9 22:36:08 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Wed Sep  9 22:36:08 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Wed Sep  9 22:36:08 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Wed Sep  9 22:36:08 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Wed Sep  9 22:36:08 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Wed Sep  9 22:36:08 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Wed Sep  9 22:36:08 2020] Call Trace:
[Wed Sep  9 22:36:08 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Wed Sep  9 22:36:08 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Wed Sep  9 22:36:08 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Wed Sep  9 22:36:08 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Wed Sep  9 22:36:08 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Wed Sep  9 22:36:08 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Wed Sep  9 22:36:08 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Wed Sep  9 22:36:08 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Wed Sep  9 22:36:08 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Wed Sep  9 22:36:08 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Wed Sep  9 22:36:08 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Wed Sep  9 22:36:08 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Wed Sep  9 22:36:08 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Wed Sep  9 22:36:08 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Wed Sep  9 22:36:08 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Wed Sep  9 22:36:08 2020] Mem-Info:
[Wed Sep  9 22:36:08 2020] active_anon:47955 inactive_anon:62248 isolated_anon:0
                            active_file:539130 inactive_file:2938524 isolated_file:0
                            unevictable:862 dirty:500725 writeback:26665 unstable:0
                            slab_reclaimable:194447 slab_unreclaimable:38407
                            mapped:29149 shmem:37640 pagetables:12064 bounce:0
                            free:66057 free_pcp:945 free_cma:0
[Wed Sep  9 22:36:08 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Wed Sep  9 22:36:08 2020] lowmem_reserve[]: 0 3366 15875 15875
[Wed Sep  9 22:36:08 2020] DMA32 free:88468kB min:13976kB low:17468kB high:20964kB active_anon:50364kB inactive_anon:77140kB active_file:675284kB inactive_file:2263904kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:303772kB writeback:6660kB mapped:35732kB shmem:36224kB slab_reclaimable:138332kB slab_unreclaimable:34784kB kernel_stack:1600kB pagetables:11220kB unstable:0kB bounce:0kB free_pcp:2596kB local_pcp:632kB free_cma:0kB writeback_tmp:0kB pages_scanned:128 all_unreclaimable? no
[Wed Sep  9 22:36:08 2020] lowmem_reserve[]: 0 0 12508 12508
[Wed Sep  9 22:36:08 2020] Normal free:159880kB min:51492kB low:64364kB high:77236kB active_anon:141456kB inactive_anon:171852kB active_file:1481236kB inactive_file:9490192kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:1699128kB writeback:100000kB mapped:80864kB shmem:114336kB slab_reclaimable:639456kB slab_unreclaimable:118844kB kernel_stack:7232kB pagetables:37036kB unstable:0kB bounce:0kB free_pcp:1184kB local_pcp:284kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:36:08 2020] lowmem_reserve[]: 0 0 0 0
[Wed Sep  9 22:36:08 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Wed Sep  9 22:36:08 2020] DMA32: 21704*4kB (UM) 191*8kB (UM) 8*16kB (UM) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 88472kB
[Wed Sep  9 22:36:08 2020] Normal: 37201*4kB (UE) 1326*8kB (UME) 3*16kB (U) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 159460kB
[Wed Sep  9 22:36:08 2020] 3515888 total pagecache pages
[Wed Sep  9 22:36:08 2020] 329 pages in swap cache
[Wed Sep  9 22:36:08 2020] Swap cache stats: add 42393, delete 42064, find 1452716/1453465
[Wed Sep  9 22:36:08 2020] Free swap  = 11710864kB
[Wed Sep  9 22:36:08 2020] Total swap = 11878316kB
[Wed Sep  9 22:36:08 2020] 4165912 pages RAM
[Wed Sep  9 22:36:08 2020] 0 pages HighMem/MovableOnly
[Wed Sep  9 22:36:08 2020] 90558 pages reserved
[Wed Sep  9 22:36:50 2020] warn_alloc_failed: 81 callbacks suppressed
[Wed Sep  9 22:36:50 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Wed Sep  9 22:36:50 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Wed Sep  9 22:36:50 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Wed Sep  9 22:36:50 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Wed Sep  9 22:36:50 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Wed Sep  9 22:36:50 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Wed Sep  9 22:36:50 2020] Call Trace:
[Wed Sep  9 22:36:50 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Wed Sep  9 22:36:50 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Wed Sep  9 22:36:50 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Wed Sep  9 22:36:50 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Wed Sep  9 22:36:50 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Wed Sep  9 22:36:50 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Wed Sep  9 22:36:50 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Wed Sep  9 22:36:50 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Wed Sep  9 22:36:50 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Wed Sep  9 22:36:50 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Wed Sep  9 22:36:50 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Wed Sep  9 22:36:50 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Wed Sep  9 22:36:50 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Wed Sep  9 22:36:50 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Wed Sep  9 22:36:50 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Wed Sep  9 22:36:50 2020] Mem-Info:
[Wed Sep  9 22:36:50 2020] active_anon:48232 inactive_anon:62391 isolated_anon:0
                            active_file:547531 inactive_file:2932529 isolated_file:0
                            unevictable:862 dirty:1839 writeback:87 unstable:0
                            slab_reclaimable:193658 slab_unreclaimable:38167
                            mapped:29647 shmem:37640 pagetables:12298 bounce:0
                            free:63938 free_pcp:1052 free_cma:0
[Wed Sep  9 22:36:50 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Wed Sep  9 22:36:50 2020] lowmem_reserve[]: 0 3366 15875 15875
[Wed Sep  9 22:36:50 2020] DMA32 free:89276kB min:13976kB low:17468kB high:20964kB active_anon:51404kB inactive_anon:77324kB active_file:680200kB inactive_file:2258060kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:484kB writeback:156kB mapped:35896kB shmem:36224kB slab_reclaimable:137804kB slab_unreclaimable:34876kB kernel_stack:1536kB pagetables:11232kB unstable:0kB bounce:0kB free_pcp:2076kB local_pcp:728kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:36:50 2020] lowmem_reserve[]: 0 0 12508 12508
[Wed Sep  9 22:36:50 2020] Normal free:150596kB min:51492kB low:64364kB high:77236kB active_anon:141524kB inactive_anon:172240kB active_file:1509924kB inactive_file:9472056kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:6872kB writeback:192kB mapped:82692kB shmem:114336kB slab_reclaimable:636828kB slab_unreclaimable:117792kB kernel_stack:7360kB pagetables:37960kB unstable:0kB bounce:0kB free_pcp:2132kB local_pcp:660kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:36:50 2020] lowmem_reserve[]: 0 0 0 0
[Wed Sep  9 22:36:50 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Wed Sep  9 22:36:50 2020] DMA32: 20799*4kB (UME) 558*8kB (UM) 101*16kB (UME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 89276kB
[Wed Sep  9 22:36:50 2020] Normal: 24342*4kB (UME) 5908*8kB (UME) 366*16kB (UM) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 150488kB
[Wed Sep  9 22:36:50 2020] 3518065 total pagecache pages
[Wed Sep  9 22:36:50 2020] 352 pages in swap cache
[Wed Sep  9 22:36:50 2020] Swap cache stats: add 42479, delete 42127, find 1455741/1456576
[Wed Sep  9 22:36:50 2020] Free swap  = 11711116kB
[Wed Sep  9 22:36:50 2020] Total swap = 11878316kB
[Wed Sep  9 22:36:50 2020] 4165912 pages RAM
[Wed Sep  9 22:36:50 2020] 0 pages HighMem/MovableOnly
[Wed Sep  9 22:36:50 2020] 90558 pages reserved
[Wed Sep  9 22:37:17 2020] warn_alloc_failed: 41 callbacks suppressed
[Wed Sep  9 22:37:17 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Wed Sep  9 22:37:17 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Wed Sep  9 22:37:17 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Wed Sep  9 22:37:17 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Wed Sep  9 22:37:17 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Wed Sep  9 22:37:17 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Wed Sep  9 22:37:17 2020] Call Trace:
[Wed Sep  9 22:37:17 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Wed Sep  9 22:37:17 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Wed Sep  9 22:37:17 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Wed Sep  9 22:37:17 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Wed Sep  9 22:37:17 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Wed Sep  9 22:37:17 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Wed Sep  9 22:37:17 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Wed Sep  9 22:37:17 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Wed Sep  9 22:37:17 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Wed Sep  9 22:37:17 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Wed Sep  9 22:37:17 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Wed Sep  9 22:37:17 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Wed Sep  9 22:37:17 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Wed Sep  9 22:37:17 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Wed Sep  9 22:37:17 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Wed Sep  9 22:37:17 2020] Mem-Info:
[Wed Sep  9 22:37:17 2020] active_anon:48042 inactive_anon:60290 isolated_anon:0
                            active_file:545078 inactive_file:2848900 isolated_file:0
                            unevictable:862 dirty:262117 writeback:0 unstable:0
                            slab_reclaimable:185854 slab_unreclaimable:38263
                            mapped:29544 shmem:37633 pagetables:11830 bounce:0
                            free:160208 free_pcp:634 free_cma:0
[Wed Sep  9 22:37:17 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Wed Sep  9 22:37:17 2020] lowmem_reserve[]: 0 3366 15875 15875
[Wed Sep  9 22:37:17 2020] DMA32 free:90564kB min:13976kB low:17468kB high:20964kB active_anon:50352kB inactive_anon:77076kB active_file:678360kB inactive_file:2264160kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:83552kB writeback:0kB mapped:35896kB shmem:36224kB slab_reclaimable:133440kB slab_unreclaimable:34828kB kernel_stack:1536kB pagetables:12028kB unstable:0kB bounce:0kB free_pcp:1300kB local_pcp:176kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:37:17 2020] lowmem_reserve[]: 0 0 12508 12508
[Wed Sep  9 22:37:17 2020] Normal free:534388kB min:51492kB low:64364kB high:77236kB active_anon:141816kB inactive_anon:164084kB active_file:1501952kB inactive_file:9131440kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:964916kB writeback:0kB mapped:82280kB shmem:114308kB slab_reclaimable:609976kB slab_unreclaimable:118224kB kernel_stack:7216kB pagetables:35292kB unstable:0kB bounce:0kB free_pcp:1236kB local_pcp:288kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:37:17 2020] lowmem_reserve[]: 0 0 0 0
[Wed Sep  9 22:37:17 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Wed Sep  9 22:37:17 2020] DMA32: 17576*4kB (UME) 1952*8kB (UE) 283*16kB (UME) 1*32kB (U) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 90480kB
[Wed Sep  9 22:37:17 2020] Normal: 55350*4kB (UE) 26728*8kB (UME) 5626*16kB (UME) 284*32kB (UME) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 534328kB
[Wed Sep  9 22:37:17 2020] 3432049 total pagecache pages
[Wed Sep  9 22:37:17 2020] 286 pages in swap cache
[Wed Sep  9 22:37:17 2020] Swap cache stats: add 44611, delete 44325, find 1457902/1458773
[Wed Sep  9 22:37:17 2020] Free swap  = 11702728kB
[Wed Sep  9 22:37:17 2020] Total swap = 11878316kB
[Wed Sep  9 22:37:17 2020] 4165912 pages RAM
[Wed Sep  9 22:37:17 2020] 0 pages HighMem/MovableOnly
[Wed Sep  9 22:37:17 2020] 90558 pages reserved
[Wed Sep  9 22:37:22 2020] warn_alloc_failed: 161 callbacks suppressed
[Wed Sep  9 22:37:22 2020] SYNO.Finder.Fil: page allocation failure: order:4, mode:0x2084020
[Wed Sep  9 22:37:22 2020] CPU: 1 PID: 27047 Comm: SYNO.Finder.Fil Tainted: P           OE   4.4.59+ #25426
[Wed Sep  9 22:37:22 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Wed Sep  9 22:37:22 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Wed Sep  9 22:37:22 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Wed Sep  9 22:37:22 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Wed Sep  9 22:37:22 2020] Call Trace:
[Wed Sep  9 22:37:22 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Wed Sep  9 22:37:22 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Wed Sep  9 22:37:22 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Wed Sep  9 22:37:22 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Wed Sep  9 22:37:22 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Wed Sep  9 22:37:22 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Wed Sep  9 22:37:22 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Wed Sep  9 22:37:22 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Wed Sep  9 22:37:22 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Wed Sep  9 22:37:22 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Wed Sep  9 22:37:22 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Wed Sep  9 22:37:22 2020]  <EOI> Mem-Info:
[Wed Sep  9 22:37:22 2020] active_anon:47082 inactive_anon:60263 isolated_anon:0
                            active_file:543392 inactive_file:2944899 isolated_file:0
                            unevictable:862 dirty:355623 writeback:16162 unstable:0
                            slab_reclaimable:180791 slab_unreclaimable:38212
                            mapped:29659 shmem:37628 pagetables:12862 bounce:0
                            free:70190 free_pcp:991 free_cma:0
[Wed Sep  9 22:37:22 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Wed Sep  9 22:37:22 2020] lowmem_reserve[]: 0 3366 15875 15875
[Wed Sep  9 22:37:22 2020] DMA32 free:88660kB min:13976kB low:17468kB high:20964kB active_anon:50220kB inactive_anon:77076kB active_file:677292kB inactive_file:2268480kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:83664kB writeback:400kB mapped:36116kB shmem:36224kB slab_reclaimable:131080kB slab_unreclaimable:34788kB kernel_stack:1536kB pagetables:12080kB unstable:0kB bounce:0kB free_pcp:2412kB local_pcp:552kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:37:22 2020] lowmem_reserve[]: 0 0 12508 12508
[Wed Sep  9 22:37:22 2020] Normal free:176220kB min:51492kB low:64364kB high:77236kB active_anon:138108kB inactive_anon:163976kB active_file:1496276kB inactive_file:9511116kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:1338828kB writeback:64248kB mapped:82520kB shmem:114288kB slab_reclaimable:592084kB slab_unreclaimable:118060kB kernel_stack:7232kB pagetables:39368kB unstable:0kB bounce:0kB free_pcp:1548kB local_pcp:48kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:37:22 2020] lowmem_reserve[]: 0 0 0 0
[Wed Sep  9 22:37:22 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Wed Sep  9 22:37:22 2020] DMA32: 17870*4kB (UME) 2039*8kB (UME) 37*16kB (UME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 88384kB
[Wed Sep  9 22:37:22 2020] Normal: 43999*4kB (U) 0*8kB 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 175996kB
[Wed Sep  9 22:37:22 2020] 3526469 total pagecache pages
[Wed Sep  9 22:37:22 2020] 332 pages in swap cache
[Wed Sep  9 22:37:22 2020] Swap cache stats: add 46086, delete 45754, find 1458891/1459824
[Wed Sep  9 22:37:22 2020] Free swap  = 11697072kB
[Wed Sep  9 22:37:22 2020] Total swap = 11878316kB
[Wed Sep  9 22:37:22 2020] 4165912 pages RAM
[Wed Sep  9 22:37:22 2020] 0 pages HighMem/MovableOnly
[Wed Sep  9 22:37:22 2020] 90558 pages reserved
[Wed Sep  9 22:37:30 2020] warn_alloc_failed: 213 callbacks suppressed
[Wed Sep  9 22:37:30 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Wed Sep  9 22:37:30 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Wed Sep  9 22:37:30 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Wed Sep  9 22:37:30 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Wed Sep  9 22:37:30 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Wed Sep  9 22:37:30 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Wed Sep  9 22:37:30 2020] Call Trace:
[Wed Sep  9 22:37:30 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Wed Sep  9 22:37:30 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Wed Sep  9 22:37:30 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Wed Sep  9 22:37:30 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Wed Sep  9 22:37:30 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Wed Sep  9 22:37:30 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Wed Sep  9 22:37:30 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Wed Sep  9 22:37:30 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Wed Sep  9 22:37:30 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Wed Sep  9 22:37:30 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Wed Sep  9 22:37:30 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Wed Sep  9 22:37:30 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Wed Sep  9 22:37:30 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Wed Sep  9 22:37:30 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Wed Sep  9 22:37:30 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Wed Sep  9 22:37:30 2020] Mem-Info:
[Wed Sep  9 22:37:30 2020] active_anon:46060 inactive_anon:59812 isolated_anon:0
                            active_file:543593 inactive_file:2956315 isolated_file:0
                            unevictable:862 dirty:263710 writeback:12980 unstable:0
                            slab_reclaimable:174829 slab_unreclaimable:38282
                            mapped:29484 shmem:37611 pagetables:12225 bounce:0
                            free:66744 free_pcp:1134 free_cma:0
[Wed Sep  9 22:37:30 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Wed Sep  9 22:37:30 2020] lowmem_reserve[]: 0 3366 15875 15875
[Wed Sep  9 22:37:30 2020] DMA32 free:90992kB min:13976kB low:17468kB high:20964kB active_anon:50212kB inactive_anon:77076kB active_file:675580kB inactive_file:2272080kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:8596kB writeback:220kB mapped:35896kB shmem:36232kB slab_reclaimable:127248kB slab_unreclaimable:34804kB kernel_stack:1664kB pagetables:12084kB unstable:0kB bounce:0kB free_pcp:2124kB local_pcp:552kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:37:30 2020] lowmem_reserve[]: 0 0 12508 12508
[Wed Sep  9 22:37:30 2020] Normal free:160104kB min:51492kB low:64364kB high:77236kB active_anon:134028kB inactive_anon:162172kB active_file:1498792kB inactive_file:9553180kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:1046244kB writeback:51700kB mapped:82040kB shmem:114212kB slab_reclaimable:572068kB slab_unreclaimable:118324kB kernel_stack:7216kB pagetables:36816kB unstable:0kB bounce:0kB free_pcp:2412kB local_pcp:484kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:37:30 2020] lowmem_reserve[]: 0 0 0 0
[Wed Sep  9 22:37:30 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Wed Sep  9 22:37:30 2020] DMA32: 18395*4kB (UME) 2141*8kB (UME) 9*16kB (UM) 3*32kB (UM) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 90948kB
[Wed Sep  9 22:37:30 2020] Normal: 35597*4kB (UME) 1728*8kB (UME) 242*16kB (UME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 160084kB
[Wed Sep  9 22:37:30 2020] 3537846 total pagecache pages
[Wed Sep  9 22:37:30 2020] 332 pages in swap cache
[Wed Sep  9 22:37:30 2020] Swap cache stats: add 47306, delete 46974, find 1459198/1460154
[Wed Sep  9 22:37:30 2020] Free swap  = 11692284kB
[Wed Sep  9 22:37:30 2020] Total swap = 11878316kB
[Wed Sep  9 22:37:30 2020] 4165912 pages RAM
[Wed Sep  9 22:37:30 2020] 0 pages HighMem/MovableOnly
[Wed Sep  9 22:37:30 2020] 90558 pages reserved
[Wed Sep  9 22:37:38 2020] warn_alloc_failed: 17 callbacks suppressed
[Wed Sep  9 22:37:38 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Wed Sep  9 22:37:38 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Wed Sep  9 22:37:38 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Wed Sep  9 22:37:38 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Wed Sep  9 22:37:38 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Wed Sep  9 22:37:38 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Wed Sep  9 22:37:38 2020] Call Trace:
[Wed Sep  9 22:37:38 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Wed Sep  9 22:37:38 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Wed Sep  9 22:37:38 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Wed Sep  9 22:37:38 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Wed Sep  9 22:37:38 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Wed Sep  9 22:37:38 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Wed Sep  9 22:37:38 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Wed Sep  9 22:37:38 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Wed Sep  9 22:37:38 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Wed Sep  9 22:37:38 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Wed Sep  9 22:37:38 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Wed Sep  9 22:37:38 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Wed Sep  9 22:37:38 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Wed Sep  9 22:37:38 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Wed Sep  9 22:37:38 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Wed Sep  9 22:37:38 2020] Mem-Info:
[Wed Sep  9 22:37:38 2020] active_anon:45954 inactive_anon:59753 isolated_anon:0
                            active_file:544881 inactive_file:2955032 isolated_file:0
                            unevictable:862 dirty:5229 writeback:12660 unstable:0
                            slab_reclaimable:174711 slab_unreclaimable:38236
                            mapped:29425 shmem:37611 pagetables:11996 bounce:0
                            free:67336 free_pcp:1148 free_cma:0
[Wed Sep  9 22:37:38 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Wed Sep  9 22:37:38 2020] lowmem_reserve[]: 0 3366 15875 15875
[Wed Sep  9 22:37:38 2020] DMA32 free:90524kB min:13976kB low:17468kB high:20964kB active_anon:50284kB inactive_anon:77076kB active_file:675696kB inactive_file:2272560kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:3036kB writeback:220kB mapped:35896kB shmem:36224kB slab_reclaimable:127180kB slab_unreclaimable:34748kB kernel_stack:1568kB pagetables:12080kB unstable:0kB bounce:0kB free_pcp:2160kB local_pcp:648kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:37:38 2020] lowmem_reserve[]: 0 0 12508 12508
[Wed Sep  9 22:37:38 2020] Normal free:162940kB min:51492kB low:64364kB high:77236kB active_anon:133532kB inactive_anon:161936kB active_file:1503828kB inactive_file:9547568kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:17880kB writeback:50420kB mapped:81804kB shmem:114220kB slab_reclaimable:571664kB slab_unreclaimable:118196kB kernel_stack:7264kB pagetables:35904kB unstable:0kB bounce:0kB free_pcp:2432kB local_pcp:332kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:37:38 2020] lowmem_reserve[]: 0 0 0 0
[Wed Sep  9 22:37:38 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Wed Sep  9 22:37:38 2020] DMA32: 18327*4kB (UME) 2112*8kB (UME) 21*16kB (UME) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 90540kB
[Wed Sep  9 22:37:38 2020] Normal: 36223*4kB (UME) 1978*8kB (UME) 150*16kB (UM) 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 163116kB
[Wed Sep  9 22:37:38 2020] 3537868 total pagecache pages
[Wed Sep  9 22:37:38 2020] 332 pages in swap cache
[Wed Sep  9 22:37:38 2020] Swap cache stats: add 47306, delete 46974, find 1459766/1460722
[Wed Sep  9 22:37:38 2020] Free swap  = 11692284kB
[Wed Sep  9 22:37:38 2020] Total swap = 11878316kB
[Wed Sep  9 22:37:38 2020] 4165912 pages RAM
[Wed Sep  9 22:37:38 2020] 0 pages HighMem/MovableOnly
[Wed Sep  9 22:37:38 2020] 90558 pages reserved
[Wed Sep  9 22:42:18 2020] warn_alloc_failed: 51 callbacks suppressed
[Wed Sep  9 22:42:18 2020] swapper/1: page allocation failure: order:4, mode:0x2084020
[Wed Sep  9 22:42:18 2020] CPU: 1 PID: 0 Comm: swapper/1 Tainted: P           OE   4.4.59+ #25426
[Wed Sep  9 22:42:18 2020] Hardware name: Gigabyte Technology Co., Ltd. Z87X-UD5H/Z87X-UD5H-CF, BIOS 10e 11/14/2017
[Wed Sep  9 22:42:18 2020]  0000000000000000 ffff88041f283c00 ffffffff812bb8cd 0000000002084020
[Wed Sep  9 22:42:18 2020]  0000000000000004 ffff88041f283c88 ffffffff810e9869 0000000000000000
[Wed Sep  9 22:42:18 2020]  ffffffff8186f0f0 0000000000000246 ffff880400000030 ffffffff8107fd41
[Wed Sep  9 22:42:18 2020] Call Trace:
[Wed Sep  9 22:42:18 2020]  <IRQ>  [<ffffffff812bb8cd>] dump_stack+0x4d/0x70
[Wed Sep  9 22:42:18 2020]  [<ffffffff810e9869>] warn_alloc_failed+0xd9/0x130
[Wed Sep  9 22:42:18 2020]  [<ffffffff8107fd41>] ? __wake_up+0x41/0x50
[Wed Sep  9 22:42:18 2020]  [<ffffffff810ec0c3>] __alloc_pages_nodemask+0x1c3/0x9e0
[Wed Sep  9 22:42:18 2020]  [<ffffffffa0fd698a>] alloc_rx_agg+0x6a/0x150 [r8152]
[Wed Sep  9 22:42:18 2020]  [<ffffffffa0ffa497>] r8152_poll+0x817/0x8a0 [r8152]
[Wed Sep  9 22:42:18 2020]  [<ffffffff814a9416>] net_rx_action+0x1c6/0x2e0
[Wed Sep  9 22:42:18 2020]  [<ffffffff8104ddd3>] __do_softirq+0xe3/0x1d0
[Wed Sep  9 22:42:18 2020]  [<ffffffff8104e006>] irq_exit+0x86/0x90
[Wed Sep  9 22:42:18 2020]  [<ffffffff81006ee0>] do_IRQ+0x50/0xd0
[Wed Sep  9 22:42:18 2020]  [<ffffffff81577f1b>] common_interrupt+0x9b/0x9b
[Wed Sep  9 22:42:18 2020]  <EOI>  [<ffffffff81478313>] ? cpuidle_enter_state+0x153/0x210
[Wed Sep  9 22:42:18 2020]  [<ffffffff814783f2>] cpuidle_enter+0x12/0x20
[Wed Sep  9 22:42:18 2020]  [<ffffffff810805ef>] cpu_startup_entry+0x1df/0x240
[Wed Sep  9 22:42:18 2020]  [<ffffffff81031433>] start_secondary+0xf3/0x100
[Wed Sep  9 22:42:18 2020] Mem-Info:
[Wed Sep  9 22:42:18 2020] active_anon:46085 inactive_anon:60327 isolated_anon:0
                            active_file:578775 inactive_file:2797937 isolated_file:0
                            unevictable:862 dirty:4047 writeback:0 unstable:0
                            slab_reclaimable:171767 slab_unreclaimable:38198
                            mapped:30952 shmem:37611 pagetables:12600 bounce:0
                            free:192244 free_pcp:1035 free_cma:0
[Wed Sep  9 22:42:18 2020] DMA free:15880kB min:60kB low:72kB high:88kB active_anon:0kB inactive_anon:0kB active_file:0kB inactive_file:0kB unevictable:0kB isolated(anon):0kB isolated(file):0kB present:15988kB managed:15880kB mlocked:0kB dirty:0kB writeback:0kB mapped:0kB shmem:0kB slab_reclaimable:0kB slab_unreclaimable:0kB kernel_stack:0kB pagetables:0kB unstable:0kB bounce:0kB free_pcp:0kB local_pcp:0kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? yes
[Wed Sep  9 22:42:18 2020] lowmem_reserve[]: 0 3366 15875 15875
[Wed Sep  9 22:42:18 2020] DMA32 free:91780kB min:13976kB low:17468kB high:20964kB active_anon:50128kB inactive_anon:77300kB active_file:685100kB inactive_file:2263088kB unevictable:552kB isolated(anon):0kB isolated(file):0kB present:3550700kB managed:3476456kB mlocked:552kB dirty:4676kB writeback:0kB mapped:36620kB shmem:36224kB slab_reclaimable:125356kB slab_unreclaimable:34972kB kernel_stack:1584kB pagetables:12004kB unstable:0kB bounce:0kB free_pcp:2192kB local_pcp:716kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:42:18 2020] lowmem_reserve[]: 0 0 12508 12508
[Wed Sep  9 22:42:18 2020] Normal free:661316kB min:51492kB low:64364kB high:77236kB active_anon:134212kB inactive_anon:164008kB active_file:1630000kB inactive_file:8928660kB unevictable:2896kB isolated(anon):0kB isolated(file):0kB present:13096960kB managed:12809080kB mlocked:2896kB dirty:11512kB writeback:0kB mapped:87188kB shmem:114220kB slab_reclaimable:561712kB slab_unreclaimable:117820kB kernel_stack:7312kB pagetables:38396kB unstable:0kB bounce:0kB free_pcp:1948kB local_pcp:444kB free_cma:0kB writeback_tmp:0kB pages_scanned:0 all_unreclaimable? no
[Wed Sep  9 22:42:18 2020] lowmem_reserve[]: 0 0 0 0
[Wed Sep  9 22:42:18 2020] DMA: 2*4kB (U) 2*8kB (U) 3*16kB (U) 2*32kB (U) 4*64kB (U) 3*128kB (U) 1*256kB (U) 1*512kB (U) 0*1024kB 1*2048kB (U) 3*4096kB (M) = 15880kB
[Wed Sep  9 22:42:18 2020] DMA32: 17533*4kB (UME) 2072*8kB (UME) 173*16kB (UME) 68*32kB (UM) 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 91652kB
[Wed Sep  9 22:42:18 2020] Normal: 79689*4kB (UME) 42812*8kB (UM) 0*16kB 0*32kB 0*64kB 0*128kB 0*256kB 0*512kB 0*1024kB 0*2048kB 0*4096kB = 661252kB
[Wed Sep  9 22:42:18 2020] 3414687 total pagecache pages
[Wed Sep  9 22:42:18 2020] 350 pages in swap cache
[Wed Sep  9 22:42:18 2020] Swap cache stats: add 47391, delete 47041, find 1484634/1485622
[Wed Sep  9 22:42:18 2020] Free swap  = 11692080kB
[Wed Sep  9 22:42:18 2020] Total swap = 11878316kB
[Wed Sep  9 22:42:18 2020] 4165912 pages RAM
[Wed Sep  9 22:42:18 2020] 0 pages HighMem/MovableOnly
[Wed Sep  9 22:42:18 2020] 90558 pages reserved
Does i915 conflict disable transcoding?
Sure I can try 2.14.0 driver, currently using 2.12.0.
Edited by Mincemeat
no the usb nic should not have to do with that
[Wed Sep  9 01:14:14 2020] usbcore: registered new interface driver r8152
[Wed Sep  9 01:14:14 2020] r8152 2-1:1.0 eth1: v2.13.0 (2020/04/20)
thats mainly the part that shows the driver is loaded and what driver it was
the driver in the extra for 6.2.2 was 2.12 and in the newer for 6.2.3 it was 2.13, either 2.14 works or i will go back to 2.12 for 6.2.3
I mean the conflict between jun driver and 6.2.3 i915 driver disables transcoding?
No idea what those errors were, transfers didnt seem to be interrupted if i remember. Still didnt want that happening, thats why i went back to 6.2.2. Probably should have tried 2.12.0 before downgrade.
then yes, the new kernel of 6.2.3 uses a different method to backport the intel i915 driver and that makes loading of jun's driver impossible and because jun's driver is located in "update" it will be used instead of synologys driver (driver in "update" are supposed to be newer and overrule the drivers in the normal directory)
Guys, I have the same issue during transfer file via the new 2.5 adapter on my xpenology. And i have successfully fixed it when i set the mtu to 4088 instead of 9000. But current speed of copying big file just ~130mb/s. I have generic one 8156 adapter from aliexpress on both devices.
The weird errors in dmesg? You using ssd to test transfer to? Mine goes around 270mb but I have 7 disks in shr2 right now, no idea how fast shr is with 4.
edit: hmm my mtu is 1500, guess thats the jumbo frame thing thats needs to be the same on all eths.
Spoiler
          UP BROADCAST RUNNING MULTICAST  MTU:1500  Metric:1
          RX packets:10716588957 errors:0 dropped:0 overruns:0 frame:0
          TX packets:9607217988 errors:0 dropped:0 overruns:0 carrier:0
          collisions:0 txqueuelen:1000
          RX bytes:7807148863873 (7.1 TiB)  TX bytes:13777539210957 (12.5 TiB)
Edited by Mincemeat
On 9/28/2020 at 11:01 PM, IG-88 said:
i did add some 9p modules, maybe i forgot one (the stuff is scattered through the config when using "menuconfig")
i just checked and the 9p, 9pnet, 9pnet_virtio are in the 3615 and 918+ for testing, not in the 3617, i will add that to my list
Hey there! I am running Xpenology in an UnRAID VM and used the 3615 1.03b loader with latest DSM. Replaced the extra.lzma in second USB partition with the one provided in your package and DSM loaded fine.
Using "lsmod" shows lots of stuff like megaraid controllers but 9p isn't mentioned anywhere and "mount -t 9p -o trans=virtio <mount-tag> <local path>" fails with "mount: unknown filesystem type '9p'"
So this driver doesn't seem to work? Or is it not included?
open the extra.lzma with 7zip and see for yourself (extra3615_v0.12_test.zip), in /usr/lib/modules are the *.ko files
in theory you should find the same files on you dsm system in /usr/lib/modules/update/ as the loader does a compare (every boot) between content of extra.lzma's *.ko files and whats in the update directory
Thanks for the quick reply! I am using extra3615_v0.11_test.zip per your first post. I can't seem to find a v0.12 via the forum search or google?
Inspecting the extra.lzma I downloaded indeed shows various 9p and virtio drivers but on the xpenology none are present in /usr/lib/modules or subdirectories. dmesg | grep 9p does not show any entries.
0.12 was just a test version for something, as you found out already 0.11 has the files too
you can extract the files manually and copy them to your dsm system for testing
Can I simply drop them in /usr/lib/modules/update and reboot? Why aren't they copied there from the extra.lzma even though they're present?
[Edit] this didn't change the output of lsmod or dmesg, also I can't load the modules with "modprobe 9p". Then again I can't load any of the modules this way...
Edited by jesta
i cant remember the code in the loader, maybe it only copies whats actually in rc.modules
you can copy the files to into update but they wont be loaded as long as you dont do any changes to DSM
kind of normal, there is nothing that would load "unknown" modules
did you read the error message? modprobe is not supported/present in DSM
DSM is a appliance and misses some things that might be seen as basic or normal
insmod can be used for loading modules but you would need to care for dependencies yourself and load modules in the right order (usually modprobe takes care of this)
the modules for virtio in the extra.lzma where meant to be used for testing by experienced people
its also possible to unpack the extra.lzma, change rc.modules to load them and repack the loader, and use the repacked extra.lzma with the loader
any (live) linux can do that with just lzma and cpio, you don't need any fancy chroot or kernel source, its just simple repacking the files as in the tutorial i wrote
look in the bottom part
2. modify the "synoboot.img"
https://xpenology.com/forum/topic/7187-how-to-build-and-inject-missing-drivers-in-jun-loader-102a/
Edited by IG-88
My 8125 isnt getting an IP address. It is loading and detecting the onboard 2.5G I think, but I see the following bits in dmesg
1.03b on 3617XS with 11.2 driver extra.lzma
[Fri Jan 15 13:11:10 2021] r8125 2.5Gigabit Ethernet driver 9.002.02-NAPI loaded
[Fri Jan 15 13:11:10 2021] unknown chip version (64000000)
[Fri Jan 15 13:11:10 2021] r8125 0000:02:00.0: irq 141 for MSI/MSI-X
[Fri Jan 15 13:11:10 2021] r8125: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[Fri Jan 15 13:11:10 2021] r8125  Copyright (C) 2019  Realtek NIC software team <nicfae@realtek.com>
                            This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
                            This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[Fri Jan 15 13:11:00 2021] pci 0000:02:00.0: [10ec:8125] type 00 class 0x020000
[Fri Jan 15 13:11:00 2021] pci 0000:02:00.0: reg 10: [io  0x3000-0x30ff]
[Fri Jan 15 13:11:00 2021] pci 0000:02:00.0: reg 18: [mem 0xb1100000-0xb110ffff 64bit]
[Fri Jan 15 13:11:00 2021] pci 0000:02:00.0: reg 20: [mem 0xb1110000-0xb1113fff 64bit]
[Fri Jan 15 13:11:00 2021] pci 0000:02:00.0: supports D1 D2
[Fri Jan 15 13:11:00 2021] pci 0000:02:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[Fri Jan 15 13:11:00 2021] pci 0000:02:00.0: System wakeup disabled by ACPI
[Fri Jan 15 13:11:12 2021] eth1: 0xffffc90016000000, a8:a1:59:4a:xx:xx, IRQ 141 (it detects the full mac fine)
sh-4.3$ lsmod | grep "8125"
r8125                 109374  0
System is a i7-10700 on an ASRock Z490M AC/ITX
Edited by rok1
the new realtek drivers did not compile aginst old kernel 3.10.105 of 3615/17
the only new i could make would be for 918+
that would be the high end 10th gen, tested only once unsuccessful
would you be willing to test a new patched driver to see if we can get the /dev/dri working (loader 1.04b 918+?)
yours is
0x9BC5, UHD Graphics (Comet Lake 3x8 GT2)
we only used one device for patching
0x3E92, UHD Graphics 630 (Coffeelake 3x8 GT2)
we could try different one's as base that are present in the driver like
0x3EA5, HD Graphics (Coffeelake 3x8 GT3)
0x3EA0, UHD Graphics (Whiskey Lake 3x8 GT2)
0x3EA2, UHD Graphics (Whiskey Lake 3x8 GT3)
maybe the Whiskey Lake UHD gets it up and running
do you have a spare disk you could use for test install 918+?
(you could test the newer 8122 driver too that way)
Sure, not an issue i have spare SSDs I can install whichever versions you need. Im hoping for the 3617 as I have 8c/16t cpu
Edit: While I'd probably not use transcoding (my Synology 1621+ can do 3 1080p streams on its own) I can still help test.
Edited by rok1
Did not know this. Modprobe didn't return any errors though so I thought it was working.
I got the modules loaded with insmod but trying to mount with "mount -t 9p -o trans=virtio <mount tag> <local path>" threw errors (special device missing/no channels available). My google skills failed at solving these errors, the top answer being a missing module (virtio_input) that isn't present in your extra.lzma.
I tried modifying the rc.modules according to this post where someone got 9p working on xpenology in docker but ofsmount fails to mount the lzma on two windows machines i tried it on...
Last try was building the kernel following the post you linked. I used this kernel source: https://sourceforge.net/projects/dsgpl/files/Synology%20NAS%20GPL%20Source/24922branch/bromolow-source/linux-3.10.x.txz/download which seems to be the latest for 3615 architecture. I couldn't get debian chroot as it's not available on DSM 6.2.x so i set up a debian VM instead. Building the kernel immediately failed with "cc1: error: code model kernel does not support PIC mode".
Last thing to try is get a utility like ofsmount for linux and try to modify the rc.modules in the debian VM but I'm not getting my hopes up that this will magically make things work...
