Restore data from BTRFS SHR1volume crashed competition
Hello.
I'm trying to restore my btfrs volume2 but it seems to be not so easy, especialy for a newbee like me
I followed some old post from this forum who gived some path to a solution but after many try and finaly doing
a btfrs Dry run restore to check if i'm able to restore, but i'm still falling on some errors.
Do I have obligation to pull out my 4 disk from my nas and connect it to a spare computer under a live CD ubuntu to get this restore/copy ?
Before I purshase a new drive of 6TB to be able to receive the 5,5To data to restore, I want to be sure i can really restore my data from this crashed volume.
Any help will be much appreciate, and a big Easter chocolate egg will be send to my angel keeper that will offer his knowledge and time to me :-) ang give a solution to copy my data in another secure place.
8 answers to this question
à l’instant, supermounter a dit :
Hello.
my array and his logical volume are apparently ok but I can't mount anymore the volume.
Each btfrs command to repare or to mount the volume always give me those responses
parent transid verify failed on 394346741760 wanted 940897 found 920148
Ignoring transid failure
Couldn't setup extent tree
Failed to recover bad superblocks
here are some of the already test made and commands:
# lvdisplay
  --- Logical volume ---
  LV Path                /dev/vg1000/lv
  LV Name                lv
  VG Name                vg1000
  LV UUID                Iv9ZJ0-oN3I-K6jV-76Px-gIbp-Fqc4-8ohokw
  LV Write Access        read/write
  LV Creation host, time ,
  LV Status              available
  # open                 0
  LV Size                7.26 TiB
  Current LE             1904185
  Segments               2
  Allocation             inherit
  Read ahead sectors     auto
  - currently set to     512
# pvdisplay
  --- Physical volume ---
  PV Name               /dev/md3
  VG Name               vg1000
  PV Size               5.44 TiB / not usable 1.56 MiB
  Allocatable           yes (but full)
  PE Size               4.00 MiB
  Total PE              1427258
  Free PE               0
  Allocated PE          1427258
  PV UUID               K64N9d-qCtH-drER-5SY9-9k8q-3dvy-3wcgD0
  PV Name               /dev/md4
  VG Name               vg1000
  PV Size               1.82 TiB / not usable 1.88 MiB
  PE Size               4.00 MiB
  Total PE              476927
  Free PE               0
  Allocated PE          476927
  PV UUID               ROBzZy-BBO4-rkY9-NMlb-znJ3-YOhH-zUm3k9
  Block device           253:0
# btrfs check  /dev/vg1000/lv
parent transid verify failed on 394340270080 wanted 940895 found 940897
extent buffer leak: start 394340171776 len 16384
Couldn't open file system
# btrfs rescue super-recover /dev/vg1000/lv
Make sure this is a btrfs disk otherwise the tool will destroy other fs, Are you sure? [y/N]: y
*** Error in `btrfs': double free or corruption (fasttop): 0x0000000002324010 ***
======= Backtrace: =========
/lib/libc.so.6(+0x72a8e)[0x7fbf00911a8e]
/lib/libc.so.6(+0x77c5e)[0x7fbf00916c5e]
/lib/libc.so.6(+0x78413)[0x7fbf00917413]
btrfs(btrfs_close_devices+0x10f)[0x45832f]
btrfs(btrfs_recover_superblocks+0x441)[0x439081]
btrfs(main+0x82)[0x410452]
/lib/libc.so.6(__libc_start_main+0xf0)[0x7fbf008bf030]
btrfs[0x410558]
======= Memory map: ========
00400000-0049b000 r-xp 00000000 09:00 5792                               /usr/sbin/btrfs
0069b000-0069f000 r--p 0009b000 09:00 5792                               /usr/sbin/btrfs
0069f000-006a1000 rw-p 0009f000 09:00 5792                               /usr/sbin/btrfs
006a1000-006c7000 rw-p 00000000 00:00 0
02324000-02366000 rw-p 00000000 00:00 0                                  [heap]
7fbf0068e000-7fbf0069f000 r-xp 00000000 09:00 6975                       /usr/lib/libgcc_s.so.1
7fbf0069f000-7fbf0089e000 ---p 00011000 09:00 6975                       /usr/lib/libgcc_s.so.1
7fbf0089e000-7fbf0089f000 rw-p 00010000 09:00 6975                       /usr/lib/libgcc_s.so.1
7fbf0089f000-7fbf00a3a000 r-xp 00000000 09:00 6422                       /usr/lib/libc-2.20-2014.11.so
7fbf00a3a000-7fbf00c3a000 ---p 0019b000 09:00 6422                       /usr/lib/libc-2.20-2014.11.so
7fbf00c3a000-7fbf00c3e000 r--p 0019b000 09:00 6422                       /usr/lib/libc-2.20-2014.11.so
7fbf00c3e000-7fbf00c40000 rw-p 0019f000 09:00 6422                       /usr/lib/libc-2.20-2014.11.so
7fbf00c40000-7fbf00c44000 rw-p 00000000 00:00 0
7fbf00c44000-7fbf00c5b000 r-xp 00000000 09:00 8027                       /usr/lib/libpthread-2.20-2014.11.so
7fbf00c5b000-7fbf00e5a000 ---p 00017000 09:00 8027                       /usr/lib/libpthread-2.20-2014.11.so
7fbf00e5a000-7fbf00e5b000 r--p 00016000 09:00 8027                       /usr/lib/libpthread-2.20-2014.11.so
7fbf00e5b000-7fbf00e5c000 rw-p 00017000 09:00 8027                       /usr/lib/libpthread-2.20-2014.11.so
7fbf00e5c000-7fbf00e60000 rw-p 00000000 00:00 0
7fbf00e60000-7fbf00e81000 r-xp 00000000 09:00 7374                       /usr/lib/liblzo2.so.2
7fbf00e81000-7fbf01080000 ---p 00021000 09:00 7374                       /usr/lib/liblzo2.so.2
7fbf01080000-7fbf01081000 rw-p 00020000 09:00 7374                       /usr/lib/liblzo2.so.2
7fbf01081000-7fbf01096000 r-xp 00000000 09:00 9689                       /usr/lib/libz.so.1.2.8
7fbf01096000-7fbf01295000 ---p 00015000 09:00 9689                       /usr/lib/libz.so.1.2.8
7fbf01295000-7fbf01296000 r--p 00014000 09:00 9689                       /usr/lib/libz.so.1.2.8
7fbf01296000-7fbf01297000 rw-p 00015000 09:00 9689                       /usr/lib/libz.so.1.2.8
7fbf01297000-7fbf012d5000 r-xp 00000000 09:00 8475                       /usr/lib/libblkid.so.1.1.0
7fbf012d5000-7fbf014d4000 ---p 0003e000 09:00 8475                       /usr/lib/libblkid.so.1.1.0
7fbf014d4000-7fbf014d8000 r--p 0003d000 09:00 8475                       /usr/lib/libblkid.so.1.1.0
7fbf014d8000-7fbf014d9000 rw-p 00041000 09:00 8475                       /usr/lib/libblkid.so.1.1.0
7fbf014d9000-7fbf014da000 rw-p 00000000 00:00 0
7fbf014da000-7fbf014de000 r-xp 00000000 09:00 6918                       /usr/lib/libuuid.so.1.3.0
7fbf014de000-7fbf016dd000 ---p 00004000 09:00 6918                       /usr/lib/libuuid.so.1.3.0
7fbf016dd000-7fbf016de000 r--p 00003000 09:00 6918                       /usr/lib/libuuid.so.1.3.0
7fbf016de000-7fbf016df000 rw-p 00004000 09:00 6918                       /usr/lib/libuuid.so.1.3.0
7fbf016df000-7fbf01700000 r-xp 00000000 09:00 9614                       /usr/lib/ld-2.20-2014.11.so
7fbf018f6000-7fbf018ff000 rw-p 00000000 00:00 0
7fbf018ff000-7fbf01900000 r--p 00020000 09:00 9614                       /usr/lib/ld-2.20-2014.11.so
7fbf01900000-7fbf01902000 rw-p 00021000 09:00 9614                       /usr/lib/ld-2.20-2014.11.so
7ffc87edb000-7ffc87efc000 rw-p 00000000 00:00 0                          [stack]
7ffc87f78000-7ffc87f79000 r-xp 00000000 00:00 0                          [vdso]
ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0                  [vsyscall]
Aborted (core dumped)
# btrfs restore -D -v  /dev/vg1000/lv /volume1/MOUNTNFS/volume2
Couldn't setup device tree
Could not open root, trying backup super
I followed good advises from @flyride found there :
and did a
# vgchange -ay
# mount -o clear_cache /dev/vg1000/lv /volume2
All my data was again accessible with SSH
this gived me the way to do a
# rsync -avzh /volume2/ /volume1/MOUNTNFS/volume2    and transfer all to a mounted volume folder from another nas to the first one.
This had took a while but at the end I got now a copy from all ma data.
Then I had removed completely my volume 2 from my DSM et recreate it. again took a while for the first consistency check
and after did a # rsync -avzh /volume1/MOUNTNFS/volume2 /volume2/ (took again days to complete the transfer)
I was happy but too fast, as my DSM now hangs a lot and I got issues with some permission/owner folders.
I realise now that it was apparently a big mistake to left rsync handle the @EADIR and @DS_STORE folders, as i didn't made  exclusions for those ones.
My DSM become often unresponsive with Filestation during some copy jobs or change owner settings of some folder, I did a # reboot from ssh
and there big scare, as the first restart the DSM didn't came back. OK, is it the end? do I need to re-install all xpenology ?
after 2 restart, still front of a DSM not showing, I decided to start without my second volume and pull off the 4 disk once shutdown.
This made the trick and the DSM came back correctly with only the volum1.
Shutdown again, put back my 4 disk volume2, and yes!! the DSM came back with my 2 volumes.
The DSM did again on a consistency check on the volume 2 and then proposed me to fix the file system from the third disk . I did the click on the repair link proposed
but again the system hang and no acces at all to DSM again.
@flyridedoes it mean that my third disk is really dead ?
does anybody can help me here, I'm lost.
after a volume crashed, now I'm facing with a degraded one that refuse to be fixed.
fter a new reboot, the DSM seen the third disk as free and initiated
I was able to repair the raid.
The disk SMART info show this into his history
Capture%20smart%20disk7.JPG?psid=1&width
some search on the web suggest that it can come from a bad sata cable...does a sata cable can become bad after 4 years of good state ?
during the repair of may array,
as I don't have an answer from anybody, I'm working now to delete all @EADIR & @DS_STORE folders from my backup data, in case of need to rsync all again to my DSM.
Capture.JPG?psid=1&width=1232&height=809
Edited by supermounter
screenshot missing
Answer this question...
