[HELP] Xpenology Volume 1 Crashed - System using ESXi 6.7
chickenstealers
16 answers to this question
Hello.
I'm facing the same problem than you, and looking for a solution from days now.
Apparently you got ext4 for your file system, then it will be more easy to refund and mount your volume.
Myn is a btfrs and is much more complicate as synology use his own btfrs repositery and this create some behavior to make the btfrs command work as expected.
Can you make those commands and send back the result ?
vpdisplay
vgdisplay
On 4/11/2020 at 1:12 AM, supermounter said:
Hello.
vpdisplay
vgdisplay
No It's btrfs filesystem not ext4
IPUserverOLD:~# btrfs restore /dev/md2 /volume1
parent transid verify failed on 138367598592 wanted 587198 found 587196
Ignoring transid failure
IPUserverOLD:~# mdadm --assemble --scan -v
mdadm: looking for devices for further assembly
mdadm: no recogniseable superblock on /dev/md2
mdadm: no recogniseable superblock on /dev/md3
mdadm: no recogniseable superblock on /dev/zram3
mdadm: no recogniseable superblock on /dev/zram2
mdadm: no recogniseable superblock on /dev/zram1
mdadm: no recogniseable superblock on /dev/zram0
mdadm: no recogniseable superblock on /dev/md1
mdadm: no recogniseable superblock on /dev/md0
mdadm: /dev/sdc3 is busy - skipping
mdadm: /dev/sdc2 is busy - skipping
mdadm: /dev/sdc1 is busy - skipping
mdadm: Cannot assemble mbr metadata on /dev/sdc
mdadm: /dev/sdb3 is busy - skipping
mdadm: /dev/sdb2 is busy - skipping
mdadm: /dev/sdb1 is busy - skipping
mdadm: Cannot assemble mbr metadata on /dev/sdb
mdadm: no recogniseable superblock on /dev/sdm3
mdadm: Cannot assemble mbr metadata on /dev/sdm2
mdadm: Cannot assemble mbr metadata on /dev/sdm1
mdadm: No arrays found in config file or automatically
IPUserverOLD:~# cat /etc/fstab
none /proc proc defaults 0 0
/dev/root / ext4 defaults 1 1
/dev/md2 /volume1 btrfs auto_reclaim_space,synoacl,relatime 0 0
/dev/md3 /volume2 btrfs auto_reclaim_space,synoacl,relatime 0 0
IPUserverOLD:~# sudo mount /dev/md2 /volume1
mount: mount /dev/md2 on /volume1 failed: Stale file handle
IPUserverOLD:~# sudo mount -o clear_cache /dev/md2 /volume1
IPUserverOLD:~# sudo mount -o recovery /dev/md2 /volume1
Volume 1 is crashed (md2)
Volume 2 is healthy (md3)
Have you manage to restore the files?
IPUserverOLD:~# pvdisplay
IPUserverOLD:~# btrfs check /dev/md2
Syno caseless feature off.
Checking filesystem on /dev/md2
UUID: 9021108d-e771-4e90-8b1c-ec4f5da3de97
checking extents
parent transid verify failed on 138367680512 wanted 587198 found 587196
leaf parent key incorrect 138367680512
bad block 138367680512
Errors found in extent allocation tree or chunk allocation
Error: could not find extent items for root 257
IPUserverOLD:~# btrfs rescue super-recover /dev/md2
All supers are valid, no need to recover
IPUserverOLD:~# btrfs restore -D -v /dev/md2 /volume1/MOUNTNFS/volume2
This is a dry-run, no files are going to be restored
Restoring /volume1/MOUNTNFS/volume2/@syno
Done searching /@syno
Reached the end of the tree searching the directory
Only @syno folder that is recover
Well, here I suffer a lot
after days of rsync to backup my data to another Nas
and rsync again backin to the recreated volume 2
I discover now others issues (seem to be not a good procedure to rsync ALL with the @EADIR and @DS_STORE folders included)
All my data are back into my volume 2 but the DSM hangs a lot when I use filestation
and some folders got now root as owner.
Once , the system completly hangs I asked a reboot with ssh and DSM didn't came back.
I had completly shutdown, remove my 4 disk (volume from the nas, restart the nas with Only volume1 and the DSM came back.
Shutdown again, put back my 4 disk and restart, the DSM came back with the 2 volumes and all my data.
But it is now making a consistency check of my volume 2 and my disk 3 say error file system, with the storage manager that propose me to fix it.
I'm waiting now the end of the consistency check before do anything else.
But I'm afraid I will need to delete my volume again and again do an rsync WITHOUT @EADIR and @DS_STORE folder this time.
what a painy a... situation and ways time here for me.
for your case what's  your result with the command  # vgchange -ay
I think you maybe not working on the correct device here as you got a VOLUME with SHR where md2 is the disk device
you need to work on the logical volume created by the raid array here this is why I ask you to do a # vgdisplay -v to see it
did you tried yet to mount the volume in read only mode without his system file cache ? # mount -o clear_cache /dev/vg1000/lv /volume1
Il y a 3 heures, supermounter a dit :
Sorry
forget the previous post I made , I'm wrong there
Here is the result
IPUserverOLD:~# vgchange -ay
IPUserverOLD:~# vgdisplay -v
    Using volume group(s) on command line.
    No volume groups found.
IPUserverOLD:~# mount -o clear_cache /dev/md2 /volume1
IPUserverOLD:~# mount -o clear_cache /dev/vg1000/lv /volume1
mount: special device /dev/vg1000/lv does not exist
Well i install xpenology using VMware ESXi 6.7
and my disk is virtual vmdk, i use two virtual disk 1TB each
1 for volume1 which is had problem with volume crash
1 for volume2 that is working
My volume only contain 1 disk each
IPUserverOLD:~# cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF1]
md2 : active raid1 sdb3[0]
      1068919808 blocks super 1.2 [1/1] [U]
md3 : active raid1 sdc3[0]
md1 : active raid1 sdb2[0] sdc2[1]
      2097088 blocks [12/2] [UU__________]
md0 : active raid1 sdb1[0] sdc1[1]
      2490176 blocks [12/2] [UU__________]
unused devices: <none>
IPUserverOLD:~# mdadm --detail /dev/md2
/dev/md2:
        Version : 1.2
  Creation Time : Fri Jun 21 11:03:51 2019
     Raid Level : raid1
     Array Size : 1068919808 (1019.40 GiB 1094.57 GB)
  Used Dev Size : 1068919808 (1019.40 GiB 1094.57 GB)
   Raid Devices : 1
  Total Devices : 1
    Persistence : Superblock is persistent
    Update Time : Thu Apr 16 15:55:40 2020
          State : clean
 Active Devices : 1
Working Devices : 1
 Failed Devices : 0
  Spare Devices : 0
           UUID : 39208021:ee300a80:79740a60:f57758f5
         Events : 77
    Number   Major   Minor   RaidDevice State
       0       8       19        0      active sync   /dev/sdb3
IPUserverOLD:~# mdadm --examine /dev/sd[abcd]3 | egrep 'Event|/dev/sd'
/dev/sdb3:
         Events : 77
/dev/sdc3:
         Events : 72
IPUserverOLD:~# mdadm -Asf && vgchange -ay
/dev/md2:
        Version : 1.2
     Raid Level : raid1
   Raid Devices : 1
  Total Devices : 1
          State : clean
 Active Devices : 1
Working Devices : 1
 Failed Devices : 0
  Spare Devices : 0
         Events : 77
In that case you only have filesystem repair options, or extract files in a recovery mode.
If you have no other plan, start here and follow the subsequent posts until resolution.
Hi, thanks for your reply
This is the result of first suggestion
sudo mount -o recovery,ro /dev/md2 /volume1
IPUserverOLD:~# sudo mount -o recovery,ro /dev/md2 /volume1
sudo btrfs rescue super /dev/md2
IPUserverOLD:~# sudo btrfs rescue super /dev/md2
sudo btrfs-find-root /dev/md2
root@IPUserverOLD:~# sudo btrfs-find-root /dev/md2
Superblock thinks the generation is 587261
Superblock thinks the level is 1
Found tree root at 165385601024 gen 587261 level 1
Well block 30048256(gen: 587252 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 31604736(gen: 587251 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 30998528(gen: 587246 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 30982144(gen: 587246 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 83244351488(gen: 587245 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 30425088(gen: 587244 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 30408704(gen: 587243 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 30261248(gen: 587243 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138005200896(gen: 587242 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 31391744(gen: 587232 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 110624768000(gen: 587227 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 31457280(gen: 587221 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 31014912(gen: 587200 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138368532480(gen: 587199 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138367811584(gen: 587196 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138367041536(gen: 587195 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138366976000(gen: 587195 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138366943232(gen: 587195 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138359455744(gen: 587194 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138357948416(gen: 587193 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138356752384(gen: 587191 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138353852416(gen: 587190 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138353360896(gen: 587189 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138352197632(gen: 587188 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138351607808(gen: 587187 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138350362624(gen: 587186 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138348380160(gen: 587185 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138347741184(gen: 587184 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138347659264(gen: 587184 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138344759296(gen: 587183 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
------ i skip so many result, i just post part of them -----
Well block 138371039232(gen: 579540 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138370449408(gen: 579539 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138369794048(gen: 579538 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138369449984(gen: 579537 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138369024000(gen: 579535 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138367467520(gen: 579533 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138191585280(gen: 579327 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 138147512320(gen: 579257 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 221593600(gen: 576729 level: 1) seems good, but generation/level doesn't match, want gen: 587261 level: 1
Well block 218923008(gen: 576721 level: 0) seems good, but generation/level doesn't match, want gen: 587261 level: 1
sudo btrfs insp dump-s -f /dev/md2
root@IPUserverOLD:~# sudo btrfs insp dump-s -f /dev/md2
superblock: bytenr=65536, device=/dev/md2
csum                    0x0f515cd5 [match]
bytenr                  65536
flags                   0x1
                        ( WRITTEN )
magic                   _BHRfS_M [match]
fsid                    9021108d-e771-4e90-8b1c-ec4f5da3de97
label                   2019.06.21-04:04:23 v23824
generation              587261
root                    165385601024
sys_array_size          129
chunk_root_generation   582947
root_level              1
chunk_root              20971520
chunk_root_level        1
log_root                0
log_root_transid        0
log_root_level          0
total_bytes             1094573883392
bytes_used              452051353600
sectorsize              4096
nodesize                16384
leafsize                16384
stripesize              4096
root_dir                6
num_devices             1
compat_flags            0x0
compat_ro_flags         0x0
incompat_flags          0x16b
                        ( MIXED_BACKREF |
                          DEFAULT_SUBVOL |
                          COMPRESS_LZO |
                          BIG_METADATA |
                          EXTENDED_IREF |
                          SKINNY_METADATA )
csum_type               0
csum_size               4
cache_generation        18446744073709551615
uuid_tree_generation    587257
dev_item.uuid           1d711bdd-14d2-4ad2-89cd-3c343a27ab81
dev_item.fsid           9021108d-e771-4e90-8b1c-ec4f5da3de97 [match]
dev_item.type           0
dev_item.total_bytes    1094573883392
dev_item.bytes_used     470315696128
dev_item.io_align       4096
dev_item.io_width       4096
dev_item.sector_size    4096
dev_item.devid          1
dev_item.dev_group      0
dev_item.seek_speed     0
dev_item.bandwidth      0
dev_item.generation     0
sys_chunk_array[2048]:
        item 0 key (FIRST_CHUNK_TREE CHUNK_ITEM 20971520)
                chunk length 8388608 owner 2 stripe_len 65536
                type SYSTEM|DUP num_stripes 2
                        stripe 0 devid 1 offset 20971520
                        dev uuid: 1d711bdd-14d2-4ad2-89cd-3c343a27ab81
                        stripe 1 devid 1 offset 29360128
backup_roots[4]:
        backup 0:
                backup_tree_root:       165385797632    gen: 587256     level: 1
                backup_chunk_root:      20971520        gen: 582947     level: 1
                backup_extent_root:     165385814016    gen: 587256     level: 2
                backup_fs_root:         29638656        gen: 8  level: 0
                backup_dev_root:        165385879552    gen: 587256     level: 1
                backup_csum_root:       138367549440    gen: 587199     level: 2
                backup_total_bytes:     1094573883392
                backup_bytes_used:      452051238912
                backup_num_devices:     1
        backup 1:
                backup_tree_root:       165385601024    gen: 587257     level: 1
                backup_extent_root:     165385617408    gen: 587257     level: 2
                backup_dev_root:        165385699328    gen: 587257     level: 1
        backup 2:
                backup_tree_root:       165387862016    gen: 587254     level: 1
                backup_extent_root:     165387878400    gen: 587254     level: 2
                backup_dev_root:        165387730944    gen: 587253     level: 1
        backup 3:
                backup_tree_root:       165385601024    gen: 587255     level: 1
                backup_extent_root:     165385617408    gen: 587255     level: 2
                backup_dev_root:        165385699328    gen: 587255     level: 1
I'm also trying this command
btrfs rescue chunk-recover /dev/md2
root@IPUserverOLD:~# btrfs rescue chunk-recover /dev/md2
Scanning: DONE in dev0
Check chunks successfully with no orphans
Chunk tree recovered successfully
and this is dmesg result
IPUserverOLD:~# dmesg | tail -f
[103406.238414] BTRFS: error (device md2) in __btrfs_free_extent:6865: errno=-2        No such entry
[103406.238653] BTRFS: error (device md2) in btrfs_run_delayed_refs:3086: errno=        -2 No such entry
[103406.238887] BTRFS warning (device md2): Skipping commit of aborted transacti        on.
[103406.238889] BTRFS: error (device md2) in cleanup_transaction:1884: errno=-2        No such entry
[103406.239166] BTRFS error (device md2): commit super ret -30
[103406.239379] BTRFS error (device md2): cleaner transaction attach returned -3        0
[103455.164837] CPU count larger than MAX_CPU 2: 2
[103455.164842] CPU count larger than MAX_CPU 2: 2
[103515.353971] CPU count larger than MAX_CPU 2: 2
[103515.353975] CPU count larger than MAX_CPU 2: 2
Result of next command based on the thread you recommend
btrfs check --init-extent-tree /dev/md2
root@IPUserverOLD:~# btrfs check --init-extent-tree /dev/md2
Creating a new extent tree
Failed to find [164311859200, 168, 16384]
btrfs unable to find ref byte nr 165385601024 parent 0 root 1  owner 1 offset 0
Failed to find [406977511424, 168, 16384]
btrfs unable to find ref byte nr 408051253248 parent 0 root 1  owner 0 offset 1
parent transid verify failed on 408051269632 wanted 587260 found 587262
Failed to find [165385633792, 168, 16384]
btrfs unable to find ref byte nr 165385682944 parent 0 root 1  owner 0 offset 1
checking extents
btrfs check --init-csum-tree /dev/md2
root@IPUserverOLD:~# btrfs check --init-csum-tree /dev/md2
Creating a new CRC tree
Reinit crc root
checking extents
parent transid verify failed on 138367565824 wanted 587198 found 587196
bad block 138367565824
Trying to repair with
btrfs check --repair /dev/md2 and mount using mount -o recovery,ro /dev/md2 /volume1 and still no luck
root@IPUserverOLD:~# btrfs check --repair /dev/md2
enabling repair mode
checking extents
root@IPUserverOLD:~# mount -o recovery,ro /dev/md2 /volume1
12 minutes ago, flyride said:
Stale file handle is an odd error message.  Have you rebooted this NAS?  Are you using NFS?  If you are, disable it.
I have rebooted the NAS, but still the same got error
NFS is disable
Also i'm using VMware ESXi 6.7 and install Xpenology inside ESXi using virtual drive
Edited by chickenstealers
3 minutes ago, flyride said:
Just for fun,
# mkdir /mnt/volume1
# mount -o recovery,ro /dev/md2 /mnt/volume1
and see if you can mount the filesystem somewhere else.
If nothing works, you may want to do a btrfs file restore
https://btrfs.wiki.kernel.org/index.php/Restore
I mount to volume2 because volume2 has 1 TB space and works well
IPUserverOLD:~# mkdir /volume2/volume1
IPUserverOLD:~# mount -o recovery,ro /dev/md2 /volume2/volume1
mount: wrong fs type, bad option, bad superblock on /dev/md2,
       missing codepage or helper program, or other error
       In some cases useful info is found in syslog - try
       dmesg | tail or so.
and this is the dmesg | tail response
[ 1516.107893] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1226): No suitable device for self healing retry read at round 2 at sector 330375376
[ 1516.108290] md/raid1:md2: syno_raid1_self_heal_set_and_submit_read_bio(1226): No suitable device for self healing retry read at round 2 at sector 330375368
[ 1516.108688] parent transid verify failed on 165385699328 wanted 587257 found 587265
[ 1516.108693] BTRFS error (device md2): BTRFS: md2 failed to repair parent transid verify failure on 165385699328, mirror = 2
[ 1516.131426] BTRFS: open_ctree failed
[ 1539.876552] CPU count larger than MAX_CPU 2: 2
[ 1539.876556] CPU count larger than MAX_CPU 2: 2
[ 1600.059867] CPU count larger than MAX_CPU 2: 2
[ 1600.059871] CPU count larger than MAX_CPU 2: 2
That doesn't work the way you think it does.  If you mounted it there, it would not be storing any data on the filesystem mounted on /volume1.  You will only confuse yourself by doing so.
But it doesn't matter, as far as I can see, your filesystem is quite damaged.  Do the restore and see if you can get your files out.
Restore is also doesn't work
IPUserverOLD:~# btrfs restore /dev/md2 /volume2/volume1
IPUserverOLD:~# btrfs-find-root /dev/md2
Superblock thinks the generation is 587267
Found tree root at 165385601024 gen 587267 level 1
Well block 30048256(gen: 587252 level: 1) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 31604736(gen: 587251 level: 1) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 30998528(gen: 587246 level: 0) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 30982144(gen: 587246 level: 0) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 83244351488(gen: 587245 level: 1) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 30425088(gen: 587244 level: 1) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 30408704(gen: 587243 level: 0) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 30261248(gen: 587243 level: 0) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 138005200896(gen: 587242 level: 1) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 31391744(gen: 587232 level: 0) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 110624768000(gen: 587227 level: 1) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 31457280(gen: 587221 level: 0) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 31014912(gen: 587200 level: 0) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 138368532480(gen: 587199 level: 1) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 138367811584(gen: 587196 level: 1) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 138367041536(gen: 587195 level: 0) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 138366976000(gen: 587195 level: 0) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 138366943232(gen: 587195 level: 0) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 138359455744(gen: 587194 level: 1) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 138357948416(gen: 587193 level: 1) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 138356752384(gen: 587191 level: 1) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 138353852416(gen: 587190 level: 1) seems good, but generation/level doesn't match, want gen: 587267 level: 1
Well block 138353360896(gen: 587189 level: 1) seems good, but generation/level doesn't match, want gen: 587267 level: 1
IPUserverOLD:~# btrfs restore -t 221593600 /dev/md2 /volume2/volume1
parent transid verify failed on 221593600 wanted 587267 found 576729
parent transid verify failed on 221102080 wanted 576729 found 584508
parent transid verify failed on 212533248 wanted 576712 found 584505
parent transid verify failed on 221626368 wanted 576729 found 576731
parent transid verify failed on 212418560 wanted 576712 found 584505
IPUserverOLD:~# cd /volume2/volume1
IPUserverOLD:/volume2/volume1# ls
@syno
IPUserverOLD:/volume2/volume1# btrfs restore -t 138383376384 /dev/md2 /volume2/volume1
parent transid verify failed on 138383376384 wanted 587267 found 579558
parent transid verify failed on 138293297152 wanted 579428 found 587147
parent transid verify failed on 138293690368 wanted 579428 found 587147
leaf parent key incorrect 138293690368
parent transid verify failed on 138279387136 wanted 579406 found 587146
@syno
Answer this question...
