PLX HELP! LSI-9211-8i issue on Nano Boat 5.0.3.2
Hi all,
Thanks for everyone hard work for making XPEnology possible.
I have my old XPEnology for a year, it was very great.
And recently I have upgraded a better motherboard [from my friend] and this case.T1gQMmXkReXXXXXXXX_!!0-item_pic.jpg_400x400.jpg
I have been using the LSI-9211-8i before migrating to this motherboard and case[since last motherboard is ITX with 2 sata only]. so the LSI-9211-8i card should have no issue.
I also upgraded to DSM 5.0-4528 update 2 successfully with the current setup.
However, the problem is the drives connecting with LSI-9211-8i card will become missing at some point of time[but it can be mounted when restart].
Please kindly advise if anyone is using the same LSI-9211-8i card with no issue. :oops:
Here is my current setup:
Boot img: Nano Boat 5.0.3.2 DSM 5.0-4528 X64http://www.xpenology.nl/xpenology-downloads/?myvar=1456
JBOD Card: LSI-9211-8i
Motherboard: P67 Transformerhttp://www.asrock.com/mb/Intel/P67%20Transformer/
CPU: Intel® Core™ i5-750 Processor http://ark.intel.com/products/42915/Intel-Core-i5-750-Processor-8M-Cache-2_66-GHz
DSM Version: DSM 5.0-4528 update 2
And here is the log from DSM when the drives go missing[the last time restarted is on 2014/11/18]:
Level	Log	Date & Time	User	Event
Error	System	2014/11/21 08:17:15	SYSTEM	System volume [swap] was degrade, current disk status [3/16], please repair it.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263584.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263720.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263568.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263552.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263184.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263696.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263536.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263520.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263160.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263504.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263488.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263200.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263096.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263664.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263472.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263640.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263072.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263320.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263280.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263560.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263256.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263544.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263248.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263528.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263192.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263512.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263208.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263496.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263128.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263480.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263352.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263464.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263656.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263456.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263432.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263704.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263064.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263648.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263392.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263424.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263632.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263288.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263296.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263416.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263408.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263376.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263384.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263624.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263304.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263592.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263264.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263360.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263328.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263232.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263688.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263216.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263336.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263240.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263272.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263576.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263400.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263616.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263168.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263680.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263152.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263136.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263672.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263120.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263176.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263104.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263312.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263088.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263344.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263112.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263144.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263224.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263608.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263080.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263048.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263448.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263056.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263440.
Warning	System	2014/11/21 08:17:13	SYSTEM	Disk [10] was removed.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263712.
Warning	System	2014/11/21 08:17:13	SYSTEM	Disk [9] was removed.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263368.
Error	System	2014/11/21 08:17:13	SYSTEM	Write error at internal disk [9] sector 2933263600.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262816.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262808.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262800.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262784.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262776.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262768.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262752.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262744.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262736.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262728.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262720.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262680.
Error	System	2014/11/21 08:17:12	SYSTEM	Volume [3] was crashed.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262672.
Error	System	2014/11/21 08:17:12	SYSTEM	System volume [swap] was degrade, current disk status [3/16], please repair it.
Error	System	2014/11/21 08:17:12	SYSTEM	System volume [Root] was degrade, current disk status [3/12], please repair it.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262592.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933263040.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933263032.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933263024.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933263016.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933263008.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262824.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933263000.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262992.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262984.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262976.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262968.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262960.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262792.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262760.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262952.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262944.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262936.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262928.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262920.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262912.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262904.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262896.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262888.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262880.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262872.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262864.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262856.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262848.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262840.
Error	System	2014/11/21 08:17:12	SYSTEM	Write error at internal disk [9] sector 2933262832.
