HP Proliant ML110 G4 won't shutdown (keep restarting) - Jun 1.03b loader
Hello guys,
I am currently running DSM 6.2-23739 Update 2 with Jun's V1.03b loader on the old server HP Proliant ML110 G4. It has been working great, the only issue is that I can't shutdown. When shutdown, the PC instead go and reboot.
HP ML110 G4 specs:
Quote
Dual-Core Intel® Xeon® processor 3040
Onboard NIC: Broadcom NetXtreme BCM5721
The drive extension had been try and place in the 2nd parition of the USB loader but no joy.
https://xpenology.com/forum/topic/21663-driver-extension-jun-103b104b-for-dsm622-for-3615xs-3617xs-918/
According to a post in the forum, Wake on LAN should be turn off but I can't find the option in BIOS. I have tried to turn if off via ssh but it doesn't work as well.
I try to to use the TP-LINK TG-3468 PCIe Gigabit (RTL8168e) and a different loader ( V1.02b) but issue still persists.
Appreciate if you could share a solution. Thanks!
if its more important then using the latest dsm version you can try older loaders with dsm vsersions 6.0 and 6.1
also look for anything that says "wake on ..." and disable it
you try to disconnect everything thats not needed like usb devices (you only need the boot drive), keyboard, mouse, monitor, ...
Thank for the advice. Wait waiting for further advice, I have tried the below things:
Loader V1.01b with and without driver extension
Loader V1.02b with and without driver extension
Loader V1.03b with and without driver extension
Checked in my BIOS and there is no option for turn off / turn on Wake on LAN. The latest BIOS for HP ML110 G4 dated 2007 ...
Also, no other device is connected to the PC except for monitor and network cable.
Hi, below is the output from serial port:
When power on:
                   GNU GRUB  version 2.02~beta2-36ubuntu3.14
 |*DS3615xs 6.2 Baremetal with Jun's Mod v1.03b                               |
 | DS3615xs 6.2 Baremetal with Jun's Mod v1.03b Reinstall                     |
 | DS3615xs 6.2 VMWare/ESXI with Jun's Mod v1.03b                             |
      Use the ^ and v keys to select which entry is highlighted.
      Press enter to boot the selected OS, `e' to edit the commands
      before booting or `c' for a command-line.
   The highlighted entry will be executed automatically in 0s.
patching file etc/rc
patching file etc/synoinfo.conf
patching file linuxrc.syno
patching file usr/sbin/init.post
START /linuxrc.syno
Insert basic USB modules...
:: Loading module usb-common ... [  OK  ]
:: Loading module usbcore ... [  OK  ]
:: Loading module ehci-hcd ... [  OK  ]
:: Loading module ehci-pci ... [  OK  ]
:: Loading module ohci-hcd ... [  OK  ]
:: Loading module uhci-hcd ... [  OK  ]
:: Loading module xhci-hcd ... [  OK  ]
:: Loading module usb-storage ... [  OK  ]
:: Loading module BusLogic ... [  OK  ]
:: Loading module vmw_pvscsi ... [  OK  ]
:: Loading module megaraid_mm ... [  OK  ]
:: Loading module megaraid_mbox ... [  OK  ]
:: Loading module megaraid ... [  OK  ]
:: Loading module scsi_transport_spi ... [  OK  ]
:: Loading module mptbase ... [  OK  ]
:: Loading module mptscsih ... [  OK  ]
:: Loading module mptspi ... [  OK  ]
:: Loading module mptsas ... [  OK  ]
:: Loading module mptctl ... [  OK  ]
:: Loading module megaraid_sas ... [  OK  ]
:: Loading module mpt2sas ... [  OK  ]
:: Loading module mpt3sas ... [  OK  ]
Insert net driver(Mindspeed only)...
Starting /usr/syno/bin/synocfgen...
/usr/syno/bin/synocfgen returns 0
All disk ready or timeout execeed
[    5.266089] md: invalid raid superblock magic on sdb3
[    5.316163] md: invalid raid superblock magic on sdc3
[    5.373097] md: invalid raid superblock magic on sdd3
[    5.412305] md: invalid raid superblock magic on sdf3
Partition Version=8
 /sbin/e2fsck exists, checking /dev/md0...
/sbin/e2fsck -pvf returns 0
Mounting /dev/md0 /tmpRoot
------------upgrade
Begin upgrade procedure
No upgrade file exists
End upgrade procedure
============upgrade
Wait 2 seconds for synology manufactory device
Fri Apr 10 04:07:59 UTC 2020
/dev/md0 /tmpRoot ext4 rw,relatime,journal_checksum,data=ordered 0 0
none /sys/kernel/debug debugfs rw,relatime 0 0
sys /sys sysfs rw,relatime 0 0
none /dev devtmpfs rw,relatime,size=1787092k,nr_inodes=446773,mode=755 0 0
proc /proc proc rw,relatime 0 0
linuxrc.syno executed successfully.
Post init
[   19.291545] md1: Failed to send sync event: (sync type: resync, finish: 0, interrupt: 0)
ds3615 login:
When power off (from DSM interface)
ds3615 login: [  399.080800] Power down.
Shortly after that, the system restart itself (it power off & power on). I have tried to shutdown via "poweroff" command but the same thing happen.
I have try installed Centos 7 and see that the PC can be shutdown properly.
  • 7 months later...
I have the same problem.
Jun 1.03b loader
DSM 6.2.3-25426
Hardware: Lenovo Ideacentre D400
(it is CPU Intel Atom 230 / 1.6 GHz · Chipset Type Intel 945GC Express)
Same problem: after Shutdown Lenovo did turn off but after few seconds it turns on!
There is no USB peripherials (no mouse or keyboard)
I even try to pull out LAN cable after Shutdown command to be sure that it did not turn on because of WakeOnLan
In BIOS I set: "Turn off" on "Power failure"
I do not see any unusual in "Log centre" but information are sparse - is there any more detailed Logs in Synology?
It drive me crazy!
I just check /var/log/dmesg
and I found something VERY interesting!
I will post part of log with my comment ">>>":
[Mon Nov 16 14:26:59 2020] iSCSI:target_core_lunbackup.c:361:init_io_buffer_head 512 buffers allocated, total 2097152 bytes successfully
[Mon Nov 16 14:27:01 2020] iSCSI:target_core_file.c:146:fd_attach_hba RODSP plugin for fileio is enabled.
[Mon Nov 16 14:27:01 2020] iSCSI:target_core_file.c:153:fd_attach_hba ODX Token Manager is enabled.
[Mon Nov 16 14:27:01 2020] iSCSI:target_core_multi_file.c:91:fd_attach_hba RODSP plugin for multifile is enabled.
[Mon Nov 16 14:27:01 2020] iSCSI:target_core_ep.c:786:ep_attach_hba RODSP plugin for epio is enabled.
[Mon Nov 16 14:27:01 2020] iSCSI:target_core_ep.c:793:ep_attach_hba ODX Token Manager is enabled.
[Mon Nov 16 14:27:03 2020] warning: `nginx' uses 32-bit capabilities (legacy support in use)
[Mon Nov 16 14:27:06 2020] FAT-fs (sdu1): FAT: nls_disk load default table
[Mon Nov 16 14:27:07 2020] FAT-fs (sdu1): FAT: nls_io load default table
[Mon Nov 16 14:27:07 2020] FAT-fs (sdu1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[Mon Nov 16 14:27:17 2020] loop: module loaded
[Mon Nov 16 14:27:18 2020] FAT-fs (sdu2): FAT: nls_disk load default table
[Mon Nov 16 14:27:18 2020] FAT-fs (sdu2): FAT: nls_io load default table
[Mon Nov 16 14:27:18 2020] FAT-fs (sdu2): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
>>> I CLICK ON SHUTDOWN FROM WEB INTERFACE AT 14:35:35 !!!
>>> THERE IS NO LOG ENTRY FOR CHOOSING SHUTDOWN
>>> I SAW THAT COMPUTER TURN OFF AT 14:36:20 and turn on after few seconds, around 14:36:23
>>> FIRST ENTRY IN THIS LOG IS BELOW: at 14:36:53
[Mon Nov 16 14:36:53 2020] Initializing cgroup subsys cpuset
[Mon Nov 16 14:36:53 2020] Initializing cgroup subsys cpuacct
[Mon Nov 16 14:36:53 2020] Linux version 3.10.105 (root@build1) (gcc version 4.9.3 20150311 (prerelease) (crosstool-NG 1.20.0) ) #25426 SMP Tue May 12 04:40:16 CST 2020
[Mon Nov 16 14:36:53 2020] Command line: syno_hdd_powerup_seq=0 HddHotplug=0 syno_hw_version=DS3615xs vender_format_version=2 console=ttyS0,115200n8 withefi elevator=eleva>
[Mon Nov 16 14:36:53 2020] KERNEL supported cpus:
[Mon Nov 16 14:36:53 2020]   Intel GenuineIntel
[Mon Nov 16 14:36:53 2020] Disabled fast string operations
[Mon Nov 16 14:36:53 2020] e820: BIOS-provided physical RAM map:
So this log does not contains any entry after SHUTDOWN is clicked from web interface!!!
Why is that?
I did try few times to shutdown Lenovo to make sure that this is no exception but rule. After choosing Shutdown I never see any entries on log...
imho its related how the kernel is compiled and thats nothing we can change (its optimized for synologys own hardware)
you can try to some apm/acpi kernel settings in grub.cfg
http://redsymbol.net/linux-kernel-boot-parameters/3.10/
in theory there is another more exotic way that need some linux skills on you side, its possible to mod the grub.cfg in a way to have a additional entry with a special poweroff kernel and on normal boot the 1st normal grub entry sets the new 4th entry as default and when shutdown restarts the system unwanted the new default 4th entry is started and will set the new default back to 1 (1st entry in grub.cfg) and then starts the poweroff kernel (that is approved to work)
that method is "easy" but there is no restart from webgui as it always will do the cycle with entry 1 and 4, the universal way with restart would mean to handle this from the synology shutdown script that is triggered  from the webgui, if setting the new default to 4th entry (poweroff kernel) and resetting that to 1st  in grub when the 4th entry is used
both ways need some tinkering and time, the 2nd is sure to work, the outcome of the kernel parameter is open
Thanks for replay.
1) kernel settings - solution
How I can set "Kernel parameters" in GRUB.CFG on Synology? I do not see "GRUB_CMDLINE_LINUX_DEFAULT" in GRUB.CFG... ?! (this is how Kernel parameters is set on Ubuntu using grub...)
2) more exotic - solution (one that I will prefere)
do you have example of grub.cfg with "4th entry"? (btw I do not care for "no restart from webgui")
