ruffpl Posted March 23, 2020 Share #1 Posted March 23, 2020 (edited) I am trying to mount hdds directly to xpenology vm in proxmox and I need to connect 7 sata drives to it. It works with sata after adding model/serial line in config file (or by "qm set" command) but the limit is 6 drives. When I try same way with scsi it mounts only first drive. I tried changing Proxmox grub config file so I could passthrough whole LSI Logic Megaraid 3108 controller to it. After that I can add it in menu, start vm but I can not find ip number and access it. How can I add these drives (DS918+)? Edited March 23, 2020 by ruffpl Quote Link to comment Share on other sites More sharing options...
fleischkarussell Posted December 11, 2020 Share #2 Posted December 11, 2020 Hello @ruffpl, I don't know if you found a solution somewhere else or if this thread is just abandoned? I'm looking for a solution aswell, even though I am using a simple ASM106x 4 Port controller. Havn't tried your fiddling with grub yet. Best regards FK Quote Link to comment Share on other sites More sharing options...
