is it possible to create a volume on the same drive where DSM OS is installed?
If i try it says something like "All data on the newly added drive will be deleted. Do you really want to continue".
So what happens if I do press "OK". Does it simply create a volume with the rest of the available space or does the system delete itself (which I can't imagine)?
LimitedModz
Hello,
2 answers to this question
