LimitedModz Posted March 7, 2020 Share #1 Posted March 7, 2020 Hello, i have a simple question, i finally managed to install xpenology after 2 hours... is the USB-Stick nessecary for the system? If i remove it the system isnt booting. Quote Link to comment Share on other sites More sharing options...
Guest Posted March 7, 2020 Share #2 Posted March 7, 2020 Hello, The key is used at each start Quote Link to comment Share on other sites More sharing options...
LimitedModz Posted March 7, 2020 Author Share #3 Posted March 7, 2020 (edited) Hello, thanks for the quick answer Maybe you can answer me another one. I've severel times read that ppl were able to install DSM 6.2.2-24922 using an ASROCK J4105. I have the same board but i'm not able to get it up running, always ends for me with the website were it says "your diskstation is being rebooted" and the timer runs out. I have no clue what i am doing wrong, i only got DSM_DS918+_23739 to run. Edit: An yes, i'm a noob. What is meant with "custom extra.lzma: real3x mod" some ppl use it with J4105 and some not. Edited March 7, 2020 by LimitedModz Quote Link to comment Share on other sites More sharing options...
premikkoci Posted March 7, 2020 Share #4 Posted March 7, 2020 You gotta modify synoboot.img to run dsm 6.2.2. successfully. Just remember that hw acceleration doesn't work on 6.2.2. with gemini lakes. 1 Quote Link to comment Share on other sites More sharing options...
LimitedModz Posted March 8, 2020 Author Share #5 Posted March 8, 2020 What do you mean exactly with: 11 hours ago, premikkoci said: You gotta modify synoboot.img I've changed the SN, MAC, VID, PID and tried it with different extra.lzma. 11 hours ago, premikkoci said: Just remember that hw acceleration doesn't work on 6.2.2. with gemini lakes. Where can I turn off hardware acceleration? Thanks for help. Quote Link to comment Share on other sites More sharing options...
premikkoci Posted March 8, 2020 Share #6 Posted March 8, 2020 There is no such a thing as hw acceleration with gemini lakes and 6.2.2. So you obviously can't turn it off. You should use syno 0.8 custom extra.lzma (created by IG-88). Keep searching 1 Quote Link to comment Share on other sites More sharing options...
LimitedModz Posted March 8, 2020 Author Share #7 Posted March 8, 2020 Hello premikkoci, thanks for your tip, I got it to work now. It's just curious that my screen is still showing: "Screen will stop updating shortly, please open http://find.synology.com to continue." Even after a reboot. I miss the part from different tutorials where it shows also: early console in decompress_kernel Deceompressing Linux... Parinsg ELF... done. Booting the kernel. Do I need to worry? Quote Link to comment Share on other sites More sharing options...
bearcat Posted March 10, 2020 Share #8 Posted March 10, 2020 @LimitedModz No need to worry, just as the msg. says: "Screen will stop updating shortly" so when it stops, it's expected 1 Quote Link to comment Share on other sites More sharing options...
