Popeye-DR Posted February 19, 2020 Share #1 Posted February 19, 2020 My system just stop communicating, and I thought that it was my MELLANOX CONNECTX-2 card. I did some troubleshooting, and the NIC is on a good conditions, but not recognized on Xpenology. I do not know if I should redo my USB, and everything that is save or configured, might be gone. Or, just change the extra files for a different ones. Now I am connected to it via the main motherboard NIC. My main concerns is that If I change any configurations on the USB, will I loose everything? Note: I am using 918+ Xpenology USB Quote Link to comment Share on other sites More sharing options...
IG-88 Posted February 20, 2020 Share #2 Posted February 20, 2020 (edited) was the system updated to dsm 6.2.2? Edited February 20, 2020 by IG-88 Quote Link to comment Share on other sites More sharing options...
Popeye-DR Posted February 20, 2020 Author Share #3 Posted February 20, 2020 Yes. when I used Synology Assistance app, it has version 6.2.2-24922 Quote Link to comment Share on other sites More sharing options...
IG-88 Posted February 20, 2020 Share #4 Posted February 20, 2020 and did you use the new 6.2.2 capable drivers from here? (i guess not) please reread you initial post and you discretion of the problem - you not even mention that you updated and lost connection after that read the following and you should be able to fix it by just copying the extra/extra2 to you (updated) usb drive Quote Link to comment Share on other sites More sharing options...
Popeye-DR Posted February 25, 2020 Author Share #5 Posted February 25, 2020 The extra918plus_v0.8_std worked. I was able to see the my MELLANOX CONNECTX-2 card, and no loose any data. On 2/19/2020 at 4:55 PM, Popeye-DR said: My system just stop communicating, and I thought that it was my MELLANOX CONNECTX-2 card. I did some troubleshooting, and the NIC is on a good conditions, but not recognized on Xpenology. I do not know if I should redo my USB, and everything that is save or configured, might be gone. Or, just change the extra files for a different ones. Now I am connected to it via the main motherboard NIC. My main concerns is that If I change any configurations on the USB, will I loose everything? Note: I am using 918+ Xpenology USB My concern was that if I made any alteration to my USB, if I would loose everything. Quote Link to comment Share on other sites More sharing options...
