Azimul 4 Posted February 10, 2020 Share Posted February 10, 2020 Hi.. I have built a custom system to use it for NAS. my build is: CPU + Mobo Combo: Asus Prime J3355i-C Mobo with Intel Celeron J3355 processor RAM: Adata 4GB DDR3 1600MHz PSU: Generic 200W Casing: Cooler Master Elite 110 HDD: 4TB Ironwolf NAS drive SSD: Adata 128GB Now I tried to install Xpenology on this machine. I used jun's loader 1.04b for DS918+ with default ramdisk. On first boot I get to the screen where system tells me to go to find.synology.com. So I visit that link from other PC and normally find DS918+ and get welcome screen. So I continue and manually install DSM 6.2.2 for DS918+ (DSM_DS918+_24922.pat). After installation finishes system reboots and tell me go to go to find.synology.com and my other PC shows "Registering" countdown screen for 10 min. It never finds Synology DS981+. So after finishing installation of DSM and system reboot it never connects to Internet. I tried to use syno and std version of extra.lzma & extra2.lzma for 1.04b loader. but No luck. If I use custom one my system can't even connect to internet in the first run. I tried to install DSM 6.2 or 6.2.1 but I couldn't. Because it's not allowing me to install other than 6.2.2. I formatted and created bootable usb several times but no luck. It sometimes goes to Restore mode. I assume that its a driver problem of my motherboard Ethernet port. after installation of DSM it can't detect my internet and doesn't get DHCP local IP No. So please tell me what can I do to install Xpenology on my system. Thank you. Quote Link to post Share on other sites
Azimul 4 Posted February 10, 2020 Author Share Posted February 10, 2020 OK.. I understand it is the problem with my Realtek NIC. So how can I reinstall DSM 6.2/6.2.1 as my system is not allowing me to install other than 6.2.2? how to full reset flash drive as well as my system for fresh install? Quote Link to post Share on other sites
Olegin 499 Posted February 10, 2020 Share Posted February 10, 2020 10 минут назад, Azimul сказал: OK.. I understand it is the problem with my Realtek NIC. So how can I reinstall DSM 6.2/6.2.1 as my system is not allowing me to install other than 6.2.2? how to full reset flash drive as well as my system for fresh install? Rewrite flash drive and format 1 и 2 partitons on hdd. Quote Link to post Share on other sites
Azimul 4 Posted February 10, 2020 Author Share Posted February 10, 2020 10 minutes ago, Olegin said: Rewrite flash drive and format 1 и 2 partitons on hdd. I can rewrite flash drive but how can I format 1 и 2 partitions on HDD? HDDs are installed inside the casing. Do I have to remove and installed on another PC to format? or there is any way format them from bios or xpenology boot? Quote Link to post Share on other sites
Olegin 499 Posted February 10, 2020 Share Posted February 10, 2020 5 минут назад, Azimul сказал: or there is any way format them from bios or xpenology boot? Boot from usb with ubuntu live CD. Quote Link to post Share on other sites
Azimul 4 Posted February 10, 2020 Author Share Posted February 10, 2020 13 minutes ago, Olegin said: Boot from usb with ubuntu live CD thank you. So i download Ubuntu ISO, burn it to USB and boot "Try Ubuntu without installing"..? Quote Link to post Share on other sites
Olegin 499 Posted February 10, 2020 Share Posted February 10, 2020 Yes. Quote Link to post Share on other sites
bearcat 83 Posted February 11, 2020 Share Posted February 11, 2020 @Azimul According to info found on Asus homepages, your board is using a Realtek RTL8111H nic, and many users in the forum seems to have no problem with that nic and the 918+ edition of DSM 6.2.2 update 3 or update 4 Quote Link to post Share on other sites
Azimul 4 Posted February 11, 2020 Author Share Posted February 11, 2020 20 minutes ago, bearcat said: @Azimul According to info found on Asus homepages, your board is using a Realtek RTL8111H nic, and many users in the forum seems to have no problem with that nic and the 918+ edition of DSM 6.2.2 update 3 or update 4 So why 6.2.2 didn't work for me..? (System can't connect to internet, it doesn't show up on "Attached Devices" in Router GUI) I have successfully installed DSM 6.2.1. Quote Link to post Share on other sites
Olegin 499 Posted February 11, 2020 Share Posted February 11, 2020 13 минуты назад, Azimul сказал: So why 6.2.2 didn't work for me..? Can you connect to the com port and upload the boot log for 6.2.2 here? Quote Link to post Share on other sites
bearcat 83 Posted February 11, 2020 Share Posted February 11, 2020 11 hours ago, Azimul said: So why 6.2.2 didn't work for me..? (System can't connect to internet, it doesn't show up on "Attached Devices" in Router GUI) I have successfully installed DSM 6.2.1. A very good question, we just need to get your system going, and find out exactly how your nic is "presenting itself" and what driver is being loaded while it works. (as there might be some differences, due to revisions / firmware etc) Do you have any kind of powersaving options in your BIOS, like C1E ? It could be worth a shot to disable those. Quote Link to post Share on other sites
Azimul 4 Posted February 11, 2020 Author Share Posted February 11, 2020 1 hour ago, bearcat said: Do you have any kind of powersaving options in your BIOS, like C1E ? It could be worth a shot to disable those. Ok.. I will check that.. my system is not connected to the monitor at the moment.. so I will check later and report here.. 1 hour ago, bearcat said: what driver is being loaded while it works. How to check that.. as I am running 6.2.1 without an issue. Quote Link to post Share on other sites
Azimul 4 Posted February 11, 2020 Author Share Posted February 11, 2020 12 hours ago, Olegin said: Can you connect to the com port and upload the boot log for 6.2.2 here? Sorry don’t know how to do that..!! Quote Link to post Share on other sites
bearcat 83 Posted February 13, 2020 Share Posted February 13, 2020 On 2/11/2020 at 9:59 PM, Azimul said: How to check that.. as I am running 6.2.1 without an issue. Use the guideline posted here Quote Link to post Share on other sites
Azimul 4 Posted February 13, 2020 Author Share Posted February 13, 2020 24 minutes ago, bearcat said: Use the guideline posted here Here is my result.. Quote Link to post Share on other sites
Azimul 4 Posted February 15, 2020 Author Share Posted February 15, 2020 Solved it.. thanks.. now running 6.2.2 1 Quote Link to post Share on other sites
bearcat 83 Posted February 15, 2020 Share Posted February 15, 2020 @Azimul Great, how did you solve it ? Quote Link to post Share on other sites
Azimul 4 Posted February 16, 2020 Author Share Posted February 16, 2020 On 2/10/2020 at 4:32 PM, Azimul said: I tried to use syno and std version of extra.lzma & extra2.lzma for 1.04b loader. but No luck. If I use custom one my system can't even connect to internet in the first run. 7 hours ago, bearcat said: Great, how did you solve it ? Well I didn't follow the guide perfectly. Previously I created the flash drive with custom extra.lzma & extra2.lzma without zImage and rd.gz files from DSM 6.2.2... so it couldn't detect my Realtek NIC. Now I was using 6.2.1 with Jun's loader. I updated my system to 6.2.2 from DSM OS.. during first reboot i manually turn off the system and removed USB Drive. Then I Inserted the USB drive to other PC, mounted partition 2 and copied and replaced just extra.lzma. Then I inserted the USB Drive to Synology system and booted the system. It showed up in my LAN and installed the 6.2.2 update successfully. 3 Quote Link to post Share on other sites
Dvalin21 26 Posted March 1, 2021 Share Posted March 1, 2021 On 2/16/2020 at 12:32 AM, Azimul said: Well I didn't follow the guide perfectly. Previously I created the flash drive with custom extra.lzma & extra2.lzma without zImage and rd.gz files from DSM 6.2.2... so it couldn't detect my Realtek NIC. Now I was using 6.2.1 with Jun's loader. I updated my system to 6.2.2 from DSM OS.. during first reboot i manually turn off the system and removed USB Drive. Then I Inserted the USB drive to other PC, mounted partition 2 and copied and replaced just extra.lzma. Then I inserted the USB Drive to Synology system and booted the system. It showed up in my LAN and installed the 6.2.2 update successfully. Which extra.lzma did you use? Quote Link to post Share on other sites
