Volume (RAID5) crash no size - Help
Hi to all,
I have a problem with RAID5 (4x2TB HDD). RAID is volume ext4.
RAID don't repair. When repairing 4th disk, it writes error with no size.
fsck and e2fsck scanning errors but can not correct them. See More Photos.
Volume1 is umount.
Does anyone have any advice?
Thanks
TuxDiskStation> sfdisk -l
/dev/sdb1	            256	        4980735	        4980480	 fd
/dev/sdb2	        4980736	        9175039	        4194304	 fd
/dev/sdb3	        9437184	     3907015007	     3897577824	  f
/dev/sdb5	        9453280	     3907015007	     3897561728	 fd
/dev/sde1	            256	        4980735	        4980480	 fd
/dev/sde2	        4980736	        9175039	        4194304	 fd
/dev/sde3	        9437184	     3907015007	     3897577824	  f
/dev/sde5	        9453280	     3907015007	     3897561728	 fd
/dev/sdf1	            256	        4980735	        4980480	 fd
/dev/sdf2	        4980736	        9175039	        4194304	 fd
/dev/sdf3	        9437184	     3907015007	     3897577824	  f
/dev/sdf5	        9453280	     3907015007	     3897561728	 fd
/dev/md01	              0	        4980351	        4980352	  0
/dev/md11	              0	        4194175	        4194176	  0
Error: /dev/md2: unrecognised disk label
get disk fail
/dev/sdu1	             63	          32129	          32067	 83
TuxDiskStation> vgdisplay
 --- Volume group ---
 VG Name               vg1000
 System ID
 Format                lvm2
 Metadata Areas        1
 Metadata Sequence No  4
 VG Access             read/write
 VG Status             resizable
 MAX LV                0
 Cur LV                1
 Open LV               0
 Max PV                0
 Cur PV                1
 Act PV                1
 VG Size               5.44 TB
 PE Size               4.00 MB
 Total PE              1427328
 Alloc PE / Size       1427328 / 5.44 TB
 Free  PE / Size       0 / 0
 VG UUID               Ea0177-I7SU-60x3-GRvg-g3iN-Q2kQ-Hjtx4A
TuxDiskStation> e2fsck -pvf -C 0 /dev/vg1000/lv
1.42.6-3776: Note: if several inode or block bitmap blocks or part
of the inode table require relocation, you may wish to try
running e2fsck with the '-b 32768' option first.  The problem
may lie only with the primary block group descriptors, and
the backup block group descriptors may be OK.
1.42.6-3776: Block bitmap for group 14912 is not in group.  (block 12643917361633850746)
1.42.6-3776: UNEXPECTED INCONSISTENCY; RUN fsck MANUALLY.
(i.e., without -a or -p options)
TuxDiskStation> e2fsck -nvf -C 0 /dev/vg1000/lv
Block bitmap for group 31214 is not in group.  (block 7596487245425364612)
Relocate? no
Inode bitmap for group 31214 is not in group.  (block 1881982346678104031)
Relocate? no
Inode table for group 31214 is not in group^C.  (block 9662426317731319658)
WARNING: SEVERE DATA LOSS POSSIBLE.
Relocate? no
1.42.6-3776: ********** WARNING: Filesystem still has errors **********
TuxDiskStation>  df -h
Filesystem                Size      Used Available Use% Mounted on
/dev/md0                  2.3G    743.3M      1.5G  32% /
/dev/md0                  2.3G    743.3M      1.5G  32% /proc/bus/pci
/tmp                    995.8M    936.0K    994.9M   0% /tmp
TuxDiskStation> mount /dev/vg1000/lv /root/
mount: mounting /dev/vg1000/lv on /root/ failed: No such device
TuxDiskStation> cat /proc/mdstat
md2 : active raid5 sde5[5] sdf5[6] sdb5[4]
     5846338944 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/3] [uU_U]
md1 : active raid1 sdb2[3] sde2[2] sdf2[1]
     2097088 blocks [12/3] [_UUU________]
md0 : active raid1 sdb1[3] sde1[0] sdf1[1]
     2490176 blocks [12/3] [uU_U________]
unused devices:
TuxDiskStation> pvdisplay
 --- Physical volume ---
 PV Name               /dev/md2
 VG Name               vg1000
 PV Size               5.44 TB / not usable 2.81 MB
 Allocatable           yes (but full)
 PE Size (KByte)       4096
 Total PE              1427328
 Free PE               0
 Allocated PE          1427328
 PV UUID               og1cK5-RBlO-ThmG-Kiyk-zXaE-cpvq-U9UgdW
593ef3b3c5d79_Snmekobrazovky2014-09-24v0_11_17.png.509202d2842d9bfc426a23fd7f03cd00.png
593ef3b3c91b4_Snmekobrazovky2014-09-24v0_11_06.png.172d557636b26de608b6db0a0e681990.png
593ef3b3cca67_Snmekobrazovky2014-09-24v0_11_38.png.610a78a073bff9eeaa8be4f4a36f5722.png
  • 4 weeks later...
Check fsck.ext4 finished error. I corrected the command
mkfs.ext4 -S /dev/vg1000/lv
Now fsck.ext4 (fsck.ext4 -v -f -y /dev/vg1000/lv) finishes scanning corrects errors, but after rebooting system, when approaching writes this:
[   68.027046] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44170 failed (57431!=9878)
[   68.027150] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44171 failed (156!=50781)
[   68.027252] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44172 failed (8939!=58410)
[   68.027355] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44173 failed (49696!=1249)
[   68.027460] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44174 failed (41854!=26047)
[   68.027558] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44175 failed (17333!=34164)
[   68.027653] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44176 failed (61496!=14073)
[   68.027748] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44177 failed (4577!=55072)
[   68.027844] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44178 failed (28863!=46718)
[   68.027939] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44179 failed (36980!=22197)
[   68.028047] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44180 failed (45571!=29890)
[   68.028144] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44181 failed (21192!=37897)
[   68.028239] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44182 failed (13206!=62807)
[   68.028333] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44183 failed (54109!=5532)
[   68.028435] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44184 failed (30584!=45497)
[   68.028539] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44185 failed (38835!=20850)
[   68.028642] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44186 failed (63213!=12332)
[   68.028747] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44187 failed (5670!=53479)
[   68.028850] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44188 failed (13393!=62096)
[   68.028953] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44189 failed (54426!=4699)
[   68.029069] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44190 failed (46532!=29445)
[   68.029173] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44191 failed (21775!=37838)
[   68.029280] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44192 failed (52214!=3383)
[   68.029383] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44193 failed (10799!=60654)
[   68.029487] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44194 failed (19313!=36272)
[   68.029590] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44195 failed (43962!=28027)
[   68.029693] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44196 failed (35277!=20236)
[   68.029796] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44197 failed (26886!=44999)
[   68.029899] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44198 failed (2136!=52889)
[   68.030003] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44199 failed (59539!=11858)
[   68.030118] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44200 failed (19638!=35447)
[   68.030224] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44201 failed (44157!=27324)
[   68.030328] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44202 failed (52515!=3042)
[   68.030430] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44203 failed (11752!=60201)
[   68.030534] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44204 failed (3999!=51550)
[   68.030638] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44205 failed (61268!=10645)
[   68.030744] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44206 failed (36362!=18635)
[   68.030847] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44207 failed (28353!=43008)
[   68.030950] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44208 failed (56652!=7053)
[   68.031068] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44209 failed (15509!=64084)
[   68.031172] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44210 failed (24011!=39690)
[   68.033370] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44211 failed (48384!=31681)
[   68.033473] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44212 failed (40823!=22966)
[   68.033576] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44213 failed (32700!=47485)
[   68.033679] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44214 failed (7906!=55331)
[   68.033781] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44215 failed (65065!=14568)
[   68.033888] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44216 failed (23052!=40141)
[   68.033991] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44217 failed (47815!=31750)
[   68.034107] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44218 failed (56217!=7512)
[   68.034212] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44219 failed (15186!=64915)
[   68.034316] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44220 failed (6437!=57316)
[   68.034419] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44221 failed (63982!=16175)
[   68.034522] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44222 failed (39088!=24177)
[   68.034624] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44223 failed (30843!=48826)
[   68.034727] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44224 failed (48234!=31403)
[   68.034832] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44225 failed (23987!=39794)
[   68.034936] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44226 failed (15597!=64044)
[   68.035053] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44227 failed (56358!=6887)
[   68.035157] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44228 failed (65105!=14480)
[   68.035261] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44229 failed (7834!=55387)
[   68.035363] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44230 failed (32708!=47365)
[   68.035465] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44231 failed (40719!=22990)
[   68.035568] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44232 failed (15146!=65003)
[   68.035671] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44233 failed (56289!=7456)
[   68.035777] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44234 failed (47807!=31870)
[   68.035874] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44235 failed (23156!=40117)
[   68.035970] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44236 failed (30723!=48834)
[   68.036078] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44237 failed (39112!=24073)
[   68.036174] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44238 failed (63894!=16215)
[   68.036270] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44239 failed (6493!=57244)
[   68.036365] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44240 failed (43728!=27665)
[   68.036459] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44241 failed (19209!=36296)
[   68.036555] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44242 failed (10839!=60566)
[   68.036649] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44243 failed (51868!=3165)
[   68.036755] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44244 failed (59627!=11818)
[   68.036859] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44245 failed (2080!=52961)
[   68.036963] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44246 failed (27006!=44991)
[   68.037081] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44247 failed (35253!=20340)
[   68.037189] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44248 failed (11664!=60241)
[   68.037294] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44249 failed (52571!=2970)
[   68.037398] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44250 failed (44037!=27332)
[   68.037500] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44251 failed (19662!=35343)
[   68.037602] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44252 failed (28345!=43128)
[   68.037708] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44253 failed (36466!=18611)
[   68.037812] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44254 failed (61228!=10733)
[   68.037915] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44255 failed (4071!=51494)
[   68.038031] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44256 failed (37150!=22495)
[   68.038138] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44257 failed (28871!=46598)
[   68.038241] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44258 failed (4505!=55128)
[   68.038343] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44259 failed (61778!=14227)
[   68.038447] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44260 failed (54053!=5604)
[   68.038549] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44261 failed (13294!=62767)
[   68.038656] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44262 failed (21168!=38001)
[   68.038758] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44263 failed (45691!=29882)
[   68.038862] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44264 failed (5726!=53407)
[   68.038965] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44265 failed (63125!=12372)
[   68.039087] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44266 failed (38859!=20746)
[   68.039189] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44267 failed (30464!=45505)
[   68.039291] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44268 failed (21879!=37814)
[   68.039394] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44269 failed (46524!=29565)
[   68.039497] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44270 failed (54498!=4643)
[   68.039603] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44271 failed (13353!=62184)
[   68.039710] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44272 failed (34724!=16741)
[   68.039813] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44273 failed (26237!=41148)
[   68.039916] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44274 failed (1827!=49634)
[   68.040032] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44275 failed (59368!=8489)
[   68.040138] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44276 failed (50591!=862)
[   68.040240] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44277 failed (9556!=58261)
[   68.040342] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44278 failed (17418!=33483)
[   68.040445] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44279 failed (42177!=25088)
[   68.040548] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44280 failed (228!=50725)
[   68.040652] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44281 failed (57391!=9966)
[   68.040756] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44282 failed (33137!=18352)
[   68.040858] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44283 failed (25018!=42875)
[   68.040961] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44284 failed (17357!=34060)
[   68.041080] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44285 failed (41734!=26055)
[   68.041182] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44286 failed (49752!=1177)
[   68.041284] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44287 failed (8851!=58450)
[   68.041386] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44288 failed (30961!=48688)
[   68.041489] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44289 failed (39208!=24553)
[   68.041595] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44290 failed (63606!=16055)
[   68.041698] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44291 failed (6333!=56956)
[   68.041800] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44292 failed (15050!=64523)
[   68.041904] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44293 failed (55809!=7360)
[   68.042017] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44294 failed (47967!=32158)
[   68.042120] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44295 failed (23444!=40277)
[   68.042223] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44296 failed (65457!=14704)
[   68.042325] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44297 failed (8058!=55739)
[   68.042430] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44298 failed (32292!=47333)
[   68.042535] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44299 failed (40687!=22574)
[   68.042641] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44300 failed (48280!=31321)
[   68.044866] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44301 failed (23635!=39570)
[   68.044971] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44302 failed (15629!=64460)
[   68.045087] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44303 failed (56774!=6919)
[   68.045192] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44304 failed (28235!=43146)
[   68.045295] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44305 failed (36754!=18771)
[   68.045399] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44306 failed (61132!=10253)
[   68.045504] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44307 failed (3591!=51398)
[   68.045606] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44308 failed (11376!=60081)
[   68.045710] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44309 failed (52411!=2682)
[   68.045813] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44310 failed (44517!=27428)
[   68.045915] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44311 failed (19758!=35823)
[   68.046033] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44312 failed (59659!=12234)
[   68.046140] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44313 failed (2496!=52993)
[   68.046243] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44314 failed (26782!=44639)
[   68.046346] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44315 failed (34901!=20116)
[   68.046450] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44316 failed (43554!=27875)
[   68.046553] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44317 failed (19177!=35880)
[   68.046656] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44318 failed (11191!=60790)
[   68.046759] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44319 failed (52092!=3517)
[   68.046862] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44320 failed (21893!=37700)
[   68.046964] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44321 failed (46172!=29341)
[   68.047085] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44322 failed (54530!=5059)
[   68.047188] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44323 failed (13769!=62216)
[   68.047291] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44324 failed (6078!=53631)
[   68.047394] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44325 failed (63349!=12724)
[   68.047498] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44326 failed (38443!=20714)
[   68.047601] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44327 failed (30432!=45089)
[   68.047705] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44328 failed (53957!=5124)
[   68.047808] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44329 failed (12814!=62671)
[   68.047911] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44330 failed (21328!=38289)
[   68.048031] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44331 failed (45979!=30042)
[   68.048134] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44332 failed (37356!=22317)
[   68.048238] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44333 failed (28967!=47078)
[   68.048342] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44334 failed (4217!=54968)
[   68.048447] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44335 failed (61618!=13939)
[   68.048549] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44336 failed (17215!=34302)
[   68.048652] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44337 failed (41702!=25639)
[   68.048754] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44338 failed (50104!=1401)
[   68.048859] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44339 failed (9075!=58802)
[   68.048965] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44340 failed (260!=51141)
[   68.049082] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44341 failed (57807!=9998)
[   68.049186] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44342 failed (32913!=18000)
[   68.049290] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44343 failed (24666!=42651)
[   68.049395] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44344 failed (50303!=702)
[   68.049498] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44345 failed (9396!=57973)
[   68.049600] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44346 failed (17898!=33579)
[   68.049702] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44347 failed (42273!=25568)
[   68.049805] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44348 failed (34646!=16791)
[   68.049908] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44349 failed (26525!=41308)
[   68.050022] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44350 failed (1731!=49154)
[   68.050126] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44351 failed (58888!=8393)
[   68.050229] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44352 failed (8729!=58584)
[   68.050333] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44353 failed (50112!=1281)
[   68.050438] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44354 failed (41630!=25695)
[   68.050541] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44355 failed (16981!=33940)
[   68.050644] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44356 failed (24610!=42723)
[   68.050747] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44357 failed (33001!=17960)
[   68.050849] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44358 failed (57783!=10102)
[   68.050955] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44359 failed (380!=51133)
[   68.051070] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44360 failed (42329!=25496)
[   68.051173] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44361 failed (17810!=33619)
[   68.051276] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44362 failed (9420!=57869)
[   68.051381] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44363 failed (50183!=710)
[   68.051482] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44364 failed (58992!=8369)
[   68.051584] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44365 failed (1723!=49274)
[   68.051690] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44366 failed (26597!=41252)
[   68.051793] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44367 failed (34606!=16879)
[   68.051898] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44368 failed (13475!=62050)
[   68.052003] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44369 failed (54650!=5051)
[   68.052121] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44370 failed (46116!=29413)
[   68.052219] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44371 failed (21743!=37422)
[   68.052314] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44372 failed (30360!=45145)
[   68.052410] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44373 failed (38483!=20626)
[   68.052504] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44374 failed (63245!=12748)
[   68.052599] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44375 failed (6086!=53511)
[   68.052695] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44376 failed (46051!=29986)
[   68.052789] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44377 failed (21288!=38377)
[   68.052885] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44378 failed (12918!=62647)
[   68.052979] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44379 failed (53949!=5244)
[   68.053094] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44380 failed (61642!=13835)
[   68.053201] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44381 failed (4097!=54976)
[   68.053307] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44382 failed (29023!=47006)
[   68.053411] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44383 failed (37268!=22357)
[   68.053514] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44384 failed (3949!=51628)
[   68.053617] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44385 failed (61108!=10357)
[   68.053719] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44386 failed (36842!=18731)
[   68.053827] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44387 failed (28449!=43488)
[   68.053931] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44388 failed (19798!=35735)
[   68.054048] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44389 failed (44445!=27484)
[   68.054152] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44390 failed (52419!=2562)
[   68.056380] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44391 failed (11272!=60105)
[   68.056489] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44392 failed (34861!=20204)
[   68.056593] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44393 failed (26854!=44583)
[   68.056697] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44394 failed (2488!=53113)
[   68.056801] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44395 failed (59763!=12210)
[   68.056906] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44396 failed (51972!=3525)
[   68.057019] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44397 failed (11215!=60686)
[   68.057122] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44398 failed (19089!=35920)
[   68.057224] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44399 failed (43610!=27803)
[   68.057326] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44400 failed (6615!=57110)
[   68.057433] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44401 failed (63502!=16079)
[   68.057537] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44402 failed (39248!=24465)
[   68.057640] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44403 failed (31131!=48986)
[   68.057745] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44404 failed (23532!=40237)
[   68.057849] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44405 failed (47911!=32230)
[   68.057952] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44406 failed (55929!=7352)
[   68.058071] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44407 failed (15026!=64627)
[   68.058174] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44408 failed (40599!=22614)
[   68.058277] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44409 failed (32348!=47261)
[   68.058383] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44410 failed (7938!=55747)
[   68.058488] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44411 failed (65481!=14600)
[   68.058590] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44412 failed (56766!=7039)
[   68.058693] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44413 failed (15733!=64436)
[   68.058801] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44414 failed (23595!=39658)
[   68.058903] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44415 failed (48352!=31265)
[   68.059017] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44416 failed (52513!=3040)
[   68.059121] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44417 failed (11512!=59961)
[   68.059225] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44418 failed (19878!=35687)
[   68.059330] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44419 failed (44397!=27564)
[   68.059434] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44420 failed (36634!=18907)
[   68.059538] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44421 failed (28625!=43280)
[   68.059641] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44422 failed (3727!=51278)
[   68.059745] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44423 failed (60996!=10373)
[   68.059848] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44424 failed (19041!=36000)
[   68.059950] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44425 failed (43690!=27755)
[   68.060068] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44426 failed (52212!=3381)
[   68.060170] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44427 failed (11071!=60926)
[   68.060274] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44428 failed (2376!=53129)
[   68.060379] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44429 failed (59779!=12098)
[   68.060480] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44430 failed (35037!=19996)
[   68.060576] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44431 failed (26646!=44759)
[   68.060672] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44432 failed (56219!=7514)
[   68.060767] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44433 failed (14914!=64643)
[   68.060862] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44434 failed (23324!=40413)
[   68.060957] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44435 failed (48087!=32022)
[   68.061066] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44436 failed (39328!=24417)
[   68.061162] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44437 failed (31083!=49066)
[   68.061257] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44438 failed (6197!=57076)
[   68.061359] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44439 failed (63742!=15935)
[   68.061462] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44440 failed (23771!=39450)
[   68.061569] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44441 failed (48144!=31441)
[   68.061673] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44442 failed (56654!=7055)
[   68.061778] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44443 failed (15749!=64324)
[   68.061882] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44444 failed (8178!=55603)
[   68.061985] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44445 failed (65337!=14840)
[   68.062102] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44446 failed (40551!=22694)
[   68.062208] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44447 failed (32428!=47213)
[   68.062312] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44448 failed (57429!=9876)
[   68.062415] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44449 failed (396!=51021)
[   68.062517] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44450 failed (24786!=42515)
[   68.062624] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44451 failed (32793!=18136)
[   68.062729] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44452 failed (41582!=25775)
[   68.062832] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44453 failed (17061!=33892)
[   68.062934] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44454 failed (9211!=58682)
[   68.063050] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44455 failed (49968!=1521)
[   68.063155] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44456 failed (26389!=41428)
[   68.063260] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44457 failed (34782!=16671)
[   68.063364] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44458 failed (59008!=8257)
[   68.063467] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44459 failed (1611!=49290)
[   68.063573] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44460 failed (9276!=58109)
[   68.063677] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44461 failed (50423!=566)
[   68.063779] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44462 failed (42409!=25448)
[   68.063882] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44463 failed (17762!=33699)
[   68.063985] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44464 failed (63215!=12334)
[   68.064104] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44465 failed (5942!=53751)
[   68.064208] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44466 failed (30312!=45225)
[   68.064311] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44467 failed (38563!=20578)
[   68.064415] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44468 failed (46292!=29205)
[   68.064521] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44469 failed (21535!=37598)
[   68.064627] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44470 failed (13633!=62336)
[   68.064732] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44471 failed (54666!=4939)
[   68.064835] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44472 failed (29103!=46958)
[   68.064938] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44473 failed (37220!=22437)
[   68.065054] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44474 failed (61498!=14075)
[   68.065162] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44475 failed (4337!=54832)
[   68.065265] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44476 failed (12934!=62535)
[   68.065368] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44477 failed (53837!=5260)
[   68.065472] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44478 failed (45843!=30162)
[   68.065575] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44479 failed (21464!=38169)
[   68.065679] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44480 failed (38857!=20744)
[   68.067914] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44481 failed (30224!=45265)
[   68.068033] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44482 failed (5966!=53647)
[   68.068137] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44483 failed (63365!=12612)
[   68.068242] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44484 failed (54770!=4915)
[   68.068345] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44485 failed (13625!=62456)
[   68.068447] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44486 failed (21607!=37542)
[   68.068549] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44487 failed (46252!=29293)
[   68.068651] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44488 failed (4233!=54856)
[   68.068757] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44489 failed (61506!=13955)
[   68.068859] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44490 failed (37148!=22493)
[   68.068955] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44491 failed (29143!=46870)
[   68.069062] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44492 failed (21408!=38241)
[   68.069159] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44493 failed (45931!=30122)
[   68.069255] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44494 failed (53813!=5364)
[   68.069350] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44495 failed (13054!=62527)
[   68.069445] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44496 failed (33139!=18354)
[   68.069541] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44497 failed (24746!=42603)
[   68.069636] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44498 failed (500!=50997)
[   68.069738] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44499 failed (57663!=10238)
[   68.069842] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44500 failed (49992!=1417)
[   68.069945] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44501 failed (9091!=58690)
[   68.070065] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44502 failed (17117!=33820)
[   68.070169] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44503 failed (41494!=25815)
[   68.070272] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44504 failed (1587!=49394)
[   68.070375] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44505 failed (59128!=8249)
[   68.070477] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44506 failed (34726!=16743)
[   68.070583] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44507 failed (26477!=41388)
[   68.070687] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44508 failed (17690!=33755)
[   68.070790] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44509 failed (42449!=25360)
[   68.070894] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44510 failed (50319!=590)
[   68.070999] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44511 failed (9284!=57989)
[   68.071117] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44512 failed (47805!=31868)
[   68.071219] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44513 failed (23396!=40357)
[   68.071322] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44514 failed (14906!=64763)
[   68.071425] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44515 failed (56049!=7216)
[   68.071528] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44516 failed (63622!=15943)
[   68.071635] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44517 failed (6221!=56972)
[   68.071738] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44518 failed (30995!=49106)
[   68.071841] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44519 failed (39384!=24345)
[   68.071947] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44520 failed (15869!=64316)
[   68.072066] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44521 failed (56630!=7159)
[   68.072169] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44522 failed (48232!=31401)
[   68.072273] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44523 failed (23715!=39522)
[   68.072376] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44524 failed (32468!=47125)
[   68.072478] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44525 failed (40479!=22750)
[   68.072584] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44526 failed (65345!=14720)
[   68.072687] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44527 failed (8074!=55627)
[   68.072790] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44528 failed (44039!=27334)
[   68.072895] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44529 failed (19934!=35615)
[   68.072999] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44530 failed (11392!=59969)
[   68.073114] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44531 failed (52299!=2698)
[   68.073217] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44532 failed (60988!=10493)
[   68.073320] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44533 failed (3831!=51254)
[   68.073422] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44534 failed (28585!=43368)
[   68.073528] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44535 failed (36706!=18851)
[   68.073632] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44536 failed (11079!=60806)
[   68.073734] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44537 failed (52108!=3405)
[   68.073838] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44538 failed (43730!=27667)
[   68.073944] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44539 failed (18969!=36056)
[   68.074060] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44540 failed (26734!=44719)
[   68.074163] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44541 failed (34981!=20068)
[   68.074265] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44542 failed (59899!=12090)
[   68.074368] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44543 failed (2352!=53233)
[   68.074473] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44544 failed (1044!=49877)
[   68.074576] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44545 failed (58829!=8972)
[   68.074679] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44546 failed (33939!=16978)
[   68.074782] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44547 failed (25688!=41625)
[   68.074885] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44548 failed (17967!=33006)
[   68.074989] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44549 failed (42724!=24613)
[   68.075105] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44550 failed (51130!=379)
[   68.075207] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44551 failed (10097!=57776)
[   68.075309] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44552 failed (33620!=17813)
[   68.075413] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44553 failed (25503!=42334)
[   68.075517] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44554 failed (705!=50176)
[   68.075619] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44555 failed (57866!=9419)
[   68.075724] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44556 failed (49277!=1724)
[   68.075827] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44557 failed (8374!=58999)
[   68.075930] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44558 failed (16872!=34601)
[   68.076048] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44559 failed (41251!=26594)
[   68.076151] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44560 failed (4782!=54383)
[   68.076252] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44561 failed (62327!=13750)
[   68.076359] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44562 failed (37417!=21736)
[   68.076467] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44563 failed (29410!=46115)
[   68.076570] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44564 failed (20629!=38484)
[   68.076673] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44565 failed (45150!=30367)
[   68.076778] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44566 failed (53504!=6081)
[   68.076881] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44567 failed (12747!=63242)
[   68.076984] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44568 failed (38382!=21295)
[   68.077100] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44569 failed (29989!=46052)
[   68.077203] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44570 failed (5243!=53946)
[   68.079432] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44571 failed (62640!=12913)
[   68.079536] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44572 failed (54983!=4102)
[   68.079639] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44573 failed (13836!=61645)
[   68.079741] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44574 failed (22354!=37267)
[   68.079845] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44575 failed (47001!=29016)
[   68.079949] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44576 failed (10592!=61345)
[   68.080070] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44577 failed (51385!=3704)
[   68.080174] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44578 failed (43495!=28454)
[   68.080278] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44579 failed (18732!=36845)
[   68.080383] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44580 failed (27483!=44442)
[   68.080488] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44581 failed (35728!=19793)
[   68.080591] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44582 failed (60110!=11279)
[   68.080694] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44583 failed (2565!=52420)
[   68.080796] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44584 failed (44576!=26849)
[   68.080899] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44585 failed (20203!=34858)
[   68.081016] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44586 failed (12213!=59764)
[   68.081120] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44587 failed (53118!=2495)
[   68.081223] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44588 failed (60681!=11208)
[   68.081327] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44589 failed (3522!=51971)
[   68.081432] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44590 failed (27804!=43613)
[   68.081535] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44591 failed (35927!=19094)
[   68.081638] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44592 failed (8123!=55674)
[   68.081740] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44593 failed (56835!=6338)
[   68.081843] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44594 failed (48989!=31132)
[   68.081949] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44595 failed (24470!=39255)
[   68.082070] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44596 failed (32225!=47904)
[   68.082175] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44597 failed (40234!=23531)
[   68.082279] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44598 failed (64628!=15029)
[   68.082383] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44599 failed (7359!=55934)
[   68.082485] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44600 failed (47258!=32347)
[   68.082587] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44601 failed (22609!=40592)
[   68.082690] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44602 failed (14607!=65486)
[   68.082794] EXT4-fs (dm-0): ext4_check_descriptors: Checksum for group 44603 failed (47687!=31878)
[   68.101179] EXT4-fs (dm-0): no journal found
  • 1 month later...
I've done to help repair fsck.ext4 running on other systems (Linux Mint). I have compiled a field LVM commands:
apt-get install mdadm lvm2
mdadm -Asf && vgchange -ay
and then individual files using: extundelete
