Pandadoo
wire connexion for Coolink Swif2 and N54L
Hello everyone,
i think after 2 hours and 120 possibilities tried, i really appreciate some help about my problem..
I have a HP N54L with DSM 6.2.2 with stock rear fan (which is noisy)
I buyed a Coolink swif2 120mm which doesn't start (without changing pins order)
I tried to follow silent pc review which explain how to reorder pins...but.. no luck....
original fan has that configuration :
From fan : green/yellow/red/black
From pinout : green/black/red/yellow
Coolink fan has that configuration
From fan : Blue (red)/Yellow/Black/Green
From pineout : Black / Yellow /Green / Blue (red)
Do you know exact order for that specific model ?
Thanks for your help..
Share this post
@Pandadoo Based on the info found from your post, it looks like this might be the way
(I might be wrong, as it has happend once or twice before ;-) so doublecheck, and if anything breaks, it's on you :-D )
Share this post
Hello Bearcat and thank you for the tip :-)
I will try , and, don't worry, if my MB fries, she will serve as hand warmer at least for few seconds :-)
  • Haha 1
Share this post
