HondaFireblade Posted January 7, 2020 Share #1 Posted January 7, 2020 Hi, can anyone help me to install the usb wifi anewish ac1750? My DSM see the hardware: |__usb1 1d6b:0002:0404 09 2.00 480MBit/s 0mA 1IF (Linux 4.4.59+ xhci-hcd xHCI Host Controller 0000:00:15.0) hub |__1-3 0d8c:0014:0100 00 1.10 12MBit/s 100mA 4IFs (C-Media Electronics Inc. USB Audio Device ffffffd1ffffffb2ffffffdbffffffad) |__1-4 0bda:8813:0000 00 2.00 480MBit/s 500mA 1IF (Realtek 802.11ac NIC 123456) |__1-6 0951:1666:0110 00 2.10 480MBit/s 300mA 1IF (Kingston DataTraveler 3.0 D0C5D3337FDEE311686001FC) |__usb2 1d6b:0003:0404 09 3.00 5000MBit/s 0mA 1IF (Linux 4.4.59+ xhci-hcd xHCI Host Controller 0000:00:15.0) hub Thanks Quote Link to comment Share on other sites More sharing options...
IG-88 Posted January 7, 2020 Share #2 Posted January 7, 2020 (edited) https://www.synology.com/en-us/compatibility?search_by=category&category=usb_wifi_dongles&p=1 Edited January 7, 2020 by IG-88 Quote Link to comment Share on other sites More sharing options...
HondaFireblade Posted January 8, 2020 Author Share #3 Posted January 8, 2020 ok so i can't use my usb wifi? I read that he should use the 8821au driver. Is it possible install it manually? If yes how? Quote Link to comment Share on other sites More sharing options...
HondaFireblade Posted January 17, 2020 Author Share #4 Posted January 17, 2020 Hi, someone can compile for me the driver? This is the link where you can download it: http://bit.ly/2LPW968 The directory is Linux-11AC. Can you create the extra.lzma file? Thanks Quote Link to comment Share on other sites More sharing options...
