Nyc_Luis Posted December 30, 2019 #1 Posted December 30, 2019 Hello as title says I need help and I am very frustrated.. I have a HP Z440 workstation desk with 32 gig memory and 2 sata HD. I choose this system as it is very fast. I tried to follow youtube instructions but get to a point where I find my synology, it finds it but it goes about 57% and fails saying it is " probably corrupt". I am using the following files: DSM_DS367xs_23739.pat Jun's_mod_v1.03b_ds3617xs.zip Can I please get home help to move this forward ? I am not sure how to go from here. Thanks luis Quote
Nyc_Luis Posted December 30, 2019 Author #2 Posted December 30, 2019 not sure if this helps but here is processor type: Intel(R) Xeon(R) cpu E5-1620 V3 @ 3.5GHZ Quote
bearcat Posted December 30, 2019 #3 Posted December 30, 2019 3 hours ago, Nyc_Luis said: I am using the following files: DSM_DS367xs_23739.pat Jun's_mod_v1.03b_ds3617xs.zip I assume that is just a spelling error ? Try using the DS3615xs files instead, as that is in general much better supported, and make sure your VID/PID is correct Quote
Nyc_Luis Posted December 30, 2019 Author #4 Posted December 30, 2019 1 hour ago, bearcat said: I assume that is just a spelling error ? Try using the DS3615xs files instead, as that is in general much better supported, and make sure your VID/PID is correct hi yes typo but i have tried both 3615 and 3617 and same thing with both. I donwloaded the files from online. maybe if you can show me download links I can try it again. Quote
IG-88 Posted December 30, 2019 #5 Posted December 30, 2019 On 12/31/2019 at 12:16 AM, Nyc_Luis said: I donwloaded the files from online. maybe if you can show me download links I can try it again there is a md5 hash file too so you can check if you file is ok https://archive.synology.com/download/DSM/release/6.2/ also the pat files are just zip files, extracting them with 7zip or similar should show corruptions too did you enter the vid/pid of your usb flash drive in the grub.cfg like in the tutorial? https://xpenology.com/forum/topic/7973-tutorial-installmigrate-dsm-52-to-61x-juns-loader/ btw your cpu would also allow using 918+ Quote
Nyc_Luis Posted December 30, 2019 Author #6 Posted December 30, 2019 3 hours ago, IG-88 said: there is a md5 hash file too so you can check if you file is ok https://archive.synology.com/download/DSM/release/6.2/ also the pat files are just zip files, extracting them with 7zip or similar should show corruptions too did you enter the vid/pid of your usb flash drive in the grub.cfg like in the tutorial? https://xpenology.com/forum/topic/7973-tutorial-installmigrate-dsm-52-to-61x-juns-loader/ btw your cpu would also allow using 918+ yes i followed the youtube videos to edit the grub file with vid/pid, serial and mac. Quote
Nyc_Luis Posted December 30, 2019 Author #7 Posted December 30, 2019 3 hours ago, IG-88 said: there is a md5 hash file too so you can check if you file is ok https://archive.synology.com/download/DSM/release/6.2/ also the pat files are just zip files, extracting them with 7zip or similar should show corruptions too did you enter the vid/pid of your usb flash drive in the grub.cfg like in the tutorial? https://xpenology.com/forum/topic/7973-tutorial-installmigrate-dsm-52-to-61x-juns-loader/ btw your cpu would also allow using 918+ So for 918+ would I need to download the following? DSM_DS918+_24922.PAT OR DSM_DS918+_23739.PAT Quote
IG-88 Posted December 30, 2019 #8 Posted December 30, 2019 any additional hardware like M.2 ssd, disk controller you can remove? i've never tried that much ram, should be no problem but you can also try to strip it down to 8GB there is also the option to do a install to one disk on a different system and then move that usb/disk pair to the hp z440 and see if it boots up (kind of skipping the install step on the hardware in question) if you have a serial port you can connect a null modem cable and get a console to see what happens (after the last message on the screen the output is directed to the serial port) Quote
IG-88 Posted December 30, 2019 #9 Posted December 30, 2019 (edited) 2 minutes ago, Nyc_Luis said: So for 918+ would I need to download the following? DSM_DS918+_24922.PAT OR DSM_DS918+_23739.PAT if you use loader 1.04b as it is you need to go with 23739 24922 need different drivers, gets a little complicated for just trying to install the 1st time, you can update later to 24922 Edited December 30, 2019 by IG-88 Quote
Prinz_Protato Posted January 3, 2020 #10 Posted January 3, 2020 (edited) I had this exact same issue I ended up using the file for the DS3617sx and have had no issues installing updates since, give that a try, going to the DS3616xs Edited January 3, 2020 by Prinz_Protato Quote
Nyc_Luis Posted January 4, 2020 Author #11 Posted January 4, 2020 On 12/30/2019 at 5:39 PM, IG-88 said: if you use loader 1.04b as it is you need to go with 23739 24922 need different drivers, gets a little complicated for just trying to install the 1st time, you can update later to 24922 ok so I am going to try it again on my hp z440 desktop. if i go with 1.04b do i need this also extra.lzma/extra2.lzma for loader 1.04b ds918+ DSM 6.2.2 v0.6_test? i downloaded the following: DSM_DS918+_23739.pat synoboot.img from (link https://mega.nz/#F!Fgk01YoT!7fN9Uxe4lpzZWPLXPMONMA (for DS918+) - v1.04b) are there any other files i need? or just follow the install and edit the files as usual? Quote
Nyc_Luis Posted January 4, 2020 Author #12 Posted January 4, 2020 (edited) On 12/30/2019 at 5:39 PM, IG-88 said: if you use loader 1.04b as it is you need to go with 23739 24922 need different drivers, gets a little complicated for just trying to install the 1st time, you can update later to 24922 *** How do I generate a serial number for DS918+ ??? Edited January 4, 2020 by Nyc_Luis Quote
IG-88 Posted January 4, 2020 #13 Posted January 4, 2020 4 hours ago, Nyc_Luis said: are there any other files i need? or just follow the install and edit the files as usual? just take the loader as it comes with v23739 if that does work for you we will talk about 24922 2 hours ago, Nyc_Luis said: *** How do I generate a serial number for DS918+ ??? you don't need this for now, just leave that is it is, you may enter you mac address if you wand, both can be changed later if you need/want it Quote
Nyc_Luis Posted January 4, 2020 Author #14 Posted January 4, 2020 So I tried it again and same errors. Failed at 52%. Here is the bios setting Incase someone can figure it out. I have tried everything, I even tried to dissabled hyper v Quote
bearcat Posted January 5, 2020 #15 Posted January 5, 2020 (edited) On 12/30/2019 at 11:17 PM, Nyc_Luis said: yes i followed the youtube videos to edit the grub file with vid/pid, serial and mac. Just to make sure: did you just use the vid/pid shown in the video, or did you read out the vid/pid from the USB stick you are using for your bootimage? Edited January 5, 2020 by bearcat highlighting 1 Quote
IG-88 Posted January 5, 2020 #16 Posted January 5, 2020 1 hour ago, bearcat said: did you just use the vid/pid shown in the video what video? Quote
painkiller895 Posted January 5, 2020 #17 Posted January 5, 2020 On 12/30/2019 at 7:16 AM, Nyc_Luis said: Hello as title says I need help and I am very frustrated.. I have a HP Z440 workstation desk with 32 gig memory and 2 sata HD. I choose this system as it is very fast. I tried to follow youtube instructions but get to a point where I find my synology, it finds it but it goes about 57% and fails saying it is " probably corrupt". I am using the following files: DSM_DS367xs_23739.pat Jun's_mod_v1.03b_ds3617xs.zip Can I please get home help to move this forward ? I am not sure how to go from here. Thanks luis running UEFI bios ? it must be used for DS918+ Loader 1.04b so it can work... Quote
bearcat Posted January 5, 2020 #18 Posted January 5, 2020 (edited) 5 minutes ago, IG-88 said: what video? The "youtube videos" referred to by @Nyc_Luis I can see have have "reacted" to my Q, but not replied yet. Edited January 5, 2020 by bearcat Quote
IG-88 Posted January 5, 2020 #19 Posted January 5, 2020 On 1/4/2020 at 6:58 PM, IG-88 said: just take the loader as it comes with v23739 on rereading that might be not presice enough, no other extra.lzma for installing a pat file at least vid/pid in the grub.cfg has to be matched with the usb drive used Quote
Nyc_Luis Posted January 6, 2020 Author #20 Posted January 6, 2020 5 hours ago, IG-88 said: on rereading that might be not presice enough, no other extra.lzma for installing a pat file at least vid/pid in the grub.cfg has to be matched with the usb drive used I did edit the grub file with the usb vid/pod and I added the MAC address of my nic Quote
