simi Posted December 10, 2019 #1 Posted December 10, 2019 Hi guys, I installed DSM 6.2.2 for a DS3615 with jun's loader 1.03b on the following hardware: - ASRock Rack C226M WS with - integrated Intel I210 and I217 network adapters - Intel i5 4570TE - 4GB ECC RAM I adjusted the grub.cfg for the USB stick's VID&PID, the NIC's MAC addresses and the serial number Everything seems to be working well except for wake on LAN, which is enabled in the BIOS and DSM. When I shut down DSM the system restarts after a few seconds. In Windows I would enable "Magic Packet" in the driver of the NIC but there is no such option in DSM. I already tried to find out the WOL status via putty by typing "ethertool eth0" or eth1, but this returns just a "Cannot get wake-on-lan settings: Operation not permitted". What I also observed: when I shut down the pc by pressing the power button, the system does not seem to restart (at least for a couple of minutes before I proceeded with testing...). Do you have any idea what I could try to get WOL running properly with activation by a magic packet only? Thanks - appreciate your help Quote
robertogp Posted June 15, 2020 #2 Posted June 15, 2020 hola,, yo tambien tengo problemas para encenderlo desde internet y no lo he solucionado,,, lastima que nadie conteste saludos roberto - buenos aires - argentina Quote
r.gilmetdinov Posted June 17, 2020 #3 Posted June 17, 2020 Use for WOL mac adress network card on the motherboard. It works for me. https://www.asrock.com/support/download/mactool.asp If you change the mac adress of the motherboard to the Synology address then WOL from the Synology utility should work. Quote
r.gilmetdinov Posted June 17, 2020 #4 Posted June 17, 2020 I downloaded windows and changed the address of the network card to the address of Synology and it worked Quote
