Hello all and thanks in advance for any help or assistance.  I think I am pretty much screwed but figured I would ask first before i make things worse.  I have a system with 12 drives, I have 1 raid 6 that correlates to volume 2 and a raid 5 that correlates to volume 1.  I moved my setup a few days ago and when I plugged it back in, my raid 5 lost 2 of the 4 drives.  1 drive was completely hosed, not readable in anything else.  The other drive seemed to just be empty and not in the raid like it was previously.  I think part of the reason for the drive just removing itself from the raid is that I use 6 onboard sata connections and have an 8 port sas lsi card.  It has actually happened before a few times but when it dropped out, I had 3 of the 4 drives still working so I could just add it back in and repair and I was good till the next outage.  This time with 2 bad drives, it just got hosed.  Either I could not or I didnt know how to add the working drive back into the raid properly so it would go from crashed to degraded and then replace the bad drive and rebuild.
Honestly I think my first mistake was moving drives around to see if it was a bad drive, or bad cable, or bad sas card.  While moving drives around I figured I would just put all the raid 5 drives on the internal sata connections and put all the raid 6 drives on the lsi sas card.  the raid 6 had 2 drives that removed themselves from the raid, but i was able to put 2 drives back in it and repair and volume 2 is good with no data loss.  I tried alot of commands ( I apologize but I do not remember them all) to get the raid 5 back.  In the end I just replaced the bad drive, so at this point I had 2 original raid 5 good drives, and 2 other drives that did not show in the raid 5.
I ended up do
mdadm --create /dev/md2 --assume-clean --level=5 --verbose --raid-devices=4 /dev/sda3 missing /dev/sdc3 /dev/sdd3
this put the raid back in a degraded stat which allowed me to repair using the newly replaced drive.  The repair completed but now volume1 which did show up under volumes as crashed, is missing under volumes.  I have tried to follow a few guides to check things out.  All of the lv/vg commands do not show anything at all.  The closest I am able to get to anything is trying to run
:~# vgcfgrestore vg1000
  Couldn't find device with uuid h448fL-VaTW-5n9w-W7FY-Gb4O-50Jb-l0ADjn.
  Couldn't find device with uuid Ppyi69-5Osn-gJtL-MTxB-aGAd-cLYJ-7hy199.
  Couldn't find device with uuid 8NeE7P-Bmf5-ErdT-zZKB-jMJ3-LspS-9C3uLg.
  Cannot restore Volume Group vg1000 with 3 PVs marked as missing.
  Restore failed.
:~# e2fsck -pvf /dev/md2
e2fsck: Bad magic number in super-block while trying to open /dev/md2
/dev/md2:
The superblock could not be read or does not describe a correct ext2
filesystem.  If the device is valid and it really contains an ext2
filesystem (and not swap or ufs or something else), then the superblock
is corrupt, and you might try running e2fsck with an alternate superblock:
    e2fsck -b 8193 <device>
:~# cat /proc/mdstat
Personalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4] [raidF1]
md3 : active raid6 sdd3[6] sdl3[5] sdk3[10] sdh3[7] sdj3[9] sdg3[8]
      7794770176 blocks super 1.2 level 6, 64k chunk, algorithm 2 [6/6] [UUUUUU]
md2 : active raid5 sdf3[4] sdb3[3] sde3[2] sda3[1]
      11706589632 blocks super 1.2 level 5, 64k chunk, algorithm 2 [4/4] [UUUU]
md1 : active raid1 sda2[0] sdb2[1] sdc2[11] sdd2[2] sde2[3] sdf2[9] sdg2[4] sdh2[5] sdi2[10] sdj2[6] sdk2[7] sdl2[8]
      2097088 blocks [12/12] [UUUUUUUUUUUU]
md0 : active raid1 sda1[1] sdb1[5] sdc1[11] sdd1[3] sde1[4] sdf1[6] sdg1[9] sdh1[7] sdi1[10] sdj1[8] sdk1[2] sdl1[0]
      2490176 blocks [12/12] [UUUUUUUUUUUU]
parted -l
Model: WDC WD40EZRX-00SPEB0 (scsi)
Disk /dev/hda: 4001GB
Sector size (logical/physical): 512B/512B
Partition Table: gpt
Disk Flags:
Number  Start   End     Size    File system     Name  Flags
 1      1049kB  2551MB  2550MB  ext4                  raid
 2      2551MB  4699MB  2147MB  linux-swap(v1)        raid
 3      4832MB  4001GB  3996GB                        raid
Disk /dev/sda: 4001GB
Disk Flags:
Model: WDC WD40EZRZ-00GXCB0 (scsi)
Disk /dev/sdb: 4001GB
Disk Flags:
Model: ATA ST3000DM001-1CH1 (scsi)
Disk /dev/sdc: 3001GB
Disk Flags:
 3      4832MB  3000GB  2996GB                        raid
Model: ATA ST2000DM001-1CH1 (scsi)
Disk /dev/sdd: 2000GB
Partition Table: msdos
Disk Flags:
Number  Start   End     Size    Type     File system  Flags
 1      1049kB  2551MB  2550MB  primary               raid
 2      2551MB  4699MB  2147MB  primary               raid
 3      4832MB  2000GB  1995GB  primary               raid
Model: ATA ST4000DM005-2DP1 (scsi)
Disk /dev/sde: 4001GB
Disk Flags:
Disk /dev/sdf: 4001GB
Disk Flags:
Model: Linux Software RAID Array (md)
Disk /dev/md0: 2550MB
Partition Table: loop
Disk Flags:
Number  Start  End     Size    File system  Flags
 1      0.00B  2550MB  2550MB  ext4
Disk /dev/md1: 2147MB
Disk Flags:
 1      0.00B  2147MB  2147MB  linux-swap(v1)
Error: /dev/md2: unrecognised disk label
Disk /dev/md2: 12.0TB
Partition Table: unknown
Disk Flags:
Disk /dev/md3: 7982GB
Disk Flags:
 1      0.00B  7982GB  7982GB  ext4
Model: WDC WD2003FYYS-02W0B (scsi)
Disk /dev/sdg: 2000GB
Disk Flags:
Disk /dev/sdh: 2000GB
Disk Flags:
Model: ATA ST3000DM001-1E61 (scsi)
Disk /dev/sdi: 3001GB
Disk Flags:
 3      4832MB  3001GB  2996GB                        raid
Disk /dev/sdj: 2000GB
Disk Flags:
Model: WDC WD30EZRX-00MMMB0 (scsi)
Disk /dev/sdk: 3001GB
Disk Flags:
Disk /dev/sdl: 2000GB
Disk Flags:
Model: Unknown (unknown)
Disk /dev/zram0: 2499MB
Sector size (logical/physical): 4096B/4096B
Disk Flags:
 1      0.00B  2499MB  2499MB  linux-swap(v1)
Disk /dev/zram1: 2499MB
Disk Flags:
Disk /dev/zram2: 2499MB
Disk Flags:
Disk /dev/zram3: 2499MB
Disk Flags:
Model: SanDisk Cruzer Fit (scsi)
Disk /dev/synoboot: 8003MB
Disk Flags:
 1      1049kB  16.8MB  15.7MB  fat16        boot    boot, esp
 2      16.8MB  48.2MB  31.5MB  fat16        image
 3      48.2MB  52.4MB  4177kB               legacy  bios_grub
:~# mdadm --detail /dev/md2
/dev/md2:
        Version : 1.2
  Creation Time : Fri Nov 29 14:05:37 2019
     Raid Level : raid5
     Array Size : 11706589632 (11164.27 GiB 11987.55 GB)
  Used Dev Size : 3902196544 (3721.42 GiB 3995.85 GB)
   Raid Devices : 4
  Total Devices : 4
    Persistence : Superblock is persistent
    Update Time : Mon Dec  2 23:52:06 2019
          State : clean
 Active Devices : 4
Working Devices : 4
 Failed Devices : 0
  Spare Devices : 0
         Layout : left-symmetric
     Chunk Size : 64K
           Name : LiquidXPe:2  (local to host LiquidXPe)
           UUID : 2e3bde16:7a255483:e4de0929:70dc3562
         Events : 137
    Number   Major   Minor   RaidDevice State
       4       8       83        0      active sync   /dev/sdf3
       1       8        3        1      active sync   /dev/sda3
       2       8       67        2      active sync   /dev/sde3
       3       8       19        3      active sync   /dev/sdb3
:~# cat /etc/lvm/backup/vg1000
# Generated by LVM2 version 2.02.38 (2008-06-11): Sun Sep 25 16:25:42 2016
contents = "Text Format Volume Group"
version = 1
description = "Created *after* executing '/sbin/lvextend --alloc inherit /dev/vg1000/lv -l100%VG'"
creation_host = "LiquidXPe"     # Linux LiquidXPe 3.10.35 #1 SMP Sat Dec 12 17:01:14 MSK 2015 x86_64
creation_time = 1474838742      # Sun Sep 25 16:25:42 2016
vg1000 {
        id = "dJc33I-psOe-q3Nu-Qdt6-lKUr-KGB3-gHOdGz"
        seqno = 19
        status = ["RESIZEABLE", "READ", "WRITE"]
        extent_size = 8192              # 4 Megabytes
        max_lv = 0
        max_pv = 0
        physical_volumes {
                pv0 {
                        id = "h448fL-VaTW-5n9w-W7FY-Gb4O-50Jb-l0ADjn"
                        device = "/dev/md2"     # Hint only
                        status = ["ALLOCATABLE"]
                        dev_size = 19438624128  # 9.05181 Terabytes
                        pe_start = 1152
                        pe_count = 2372878      # 9.05181 Terabytes
                pv1 {
                        id = "Ppyi69-5Osn-gJtL-MTxB-aGAd-cLYJ-7hy199"
                        device = "/dev/md3"     # Hint only
                        dev_size = 17581371264  # 8.18696 Terabytes
                        pe_start = 1152
                        pe_count = 2146163      # 8.18696 Terabytes
                pv2 {
                        id = "8NeE7P-Bmf5-ErdT-zZKB-jMJ3-LspS-9C3uLg"
                        device = "/dev/md4"     # Hint only
                        dev_size = 1953484672   # 931.494 Gigabytes
                        pe_start = 1152
                        pe_count = 238462       # 931.492 Gigabytes
                pv3 {
                        id = "RM205l-f2bw-BBbm-OYyg-sKK8-VHRv-4Mv9OX"
                        device = "/dev/md5"     # Hint only
                        dev_size = 9767427968   # 4.54831 Terabytes
                        pe_start = 1152
                        pe_count = 1192312      # 4.54831 Terabytes
        logical_volumes {
                lv {
                        id = "g5hc5i-t2eR-Wj1v-MTwg-3EHX-APQe-sDLOe5"
                        status = ["READ", "WRITE", "VISIBLE"]
                        segment_count = 8
                        segment1 {
                                start_extent = 0
                                extent_count = 237287   # 926.902 Gigabytes
                                type = "striped"
                                stripe_count = 1        # linear
                                stripes = [
                                        "pv0", 0
                        segment2 {
                                start_extent = 237287
                                extent_count = 715387   # 2.72898 Terabytes
                                type = "striped"
                                stripes = [
                                        "pv1", 0
                        segment3 {
                                start_extent = 952674
                                extent_count = 949152   # 3.62073 Terabytes
                                type = "striped"
                                stripes = [
                                        "pv0", 237287
                        segment4 {
                                start_extent = 1901826
                                extent_count = 238463   # 931.496 Gigabytes
                                type = "striped"
                                stripes = [
                                        "pv1", 715387
                        segment5 {
                                start_extent = 2140289
                                extent_count = 238462   # 931.492 Gigabytes
                                type = "striped"
                                stripes = [
                                        "pv2", 0
                        segment6 {
                                start_extent = 2378751
                                extent_count = 1192312  # 4.54831 Terabytes
                                type = "striped"
                                stripes = [
                                        "pv3", 0
                        segment7 {
                                start_extent = 3571063
                                extent_count = 1192313  # 4.54831 Terabytes
                                type = "striped"
                                stripes = [
                                        "pv1", 953850
                        segment8 {
                                start_extent = 4763376
                                extent_count = 1186439  # 4.52591 Terabytes
                                type = "striped"
                                stripes = [
                                        "pv0", 1186439
the lvm backup data all seems to be old, from 2016 and I have rebuilt both volumes since.  I use to be shr, but moved to a raid setup.
Again, any help would be greatly appreciated.
9 hours ago, bughatti said:
I have a [raid 5] that correlates to volume 1.  I moved my setup a few days ago and when I plugged it back in, my raid 5 lost 2 of the 4 drives.  1 drive was completely hosed, not readable in anything else.
[snip]
I ended up do mdadm --create /dev/md2 --assume-clean --level=5 --verbose --raid-devices=4 /dev/sda3 missing /dev/sdc3 /dev/sdd3
Sorry for the event and to bring you bad news.  As you know, RAID 5 spans parity across the array such that all members, less one must be present for data integrity. Your data may have been recoverable at one time, but once the repair operation was initiated with only 2 valid drives, the data on all four drives was irreparably lost.  I've highlighted the critical items above.
Edited by flyride
