web Gui and shh stoped working
deesnow
Since I have upgraded my xpenology box to DSM 6.1.7-15284 it stopped time to time. Sometimes just lost the web gui and ssh access but the shared folders are accessible, sometimes I lost everything. After a reboot every service working properly.
Can anybody suggest me a process how to identify what cause this issue. Earlier when the NAS was on 5.2 version, it was so stable, I have never experienced this kind of freezing.
10 answers to this question
34 minutes ago, bearcat said:
@deesnow From what did you upgrade?
If you came from DSM 5.x, using a different bootloader, there is an easy fix.
I dont have the .xpenoboot folder to delete.
GUI and ssh just stopped after few days, sometimes more that a week or 2, so it is something different, but thanks.
Edited by deesnow
@deesnow Ok, since I have lost my magic crystal-ball I will ask you a few questions, for someone to be able to help you:
1 - What version of DSM and bootloader did you upgrade from?
2 - Do you use DS3615 / 3617 / 916 / 918? Did you change this during your upgrade?
3 - What type of NIC do you have, and what driver is it using?
4 - Do you have any additional packages installed? (if so, did you install them before or after the upgrade?)
5 - next Q will follow later ;-)
1. Original version was 5.1 with Nanoboot, and was upgraded to 5.2 + Xpenoboot and than to 6.1 and changed to Jun's loader v1.02b DS3615xs
2. My box is 3615 . It was not changed.
3. I have an Asrock Q1900-ITX, so it should have a  Realtek RTL8111GR network card.
Spoiler
Oct 29 22:45:26 NAS kernel: [    2.546703] e1000: Intel(R) PRO/1000 Network Driver - version 7.3.21-k8-NAPI
Oct 29 22:45:26 NAS kernel: [    2.546708] e1000: Copyright (c) 1999-2006 Intel Corporation.
Oct 29 22:45:26 NAS kernel: [    2.556047] e1000e: Intel(R) PRO/1000 Network Driver - 3.2.7.1-NAPI
Oct 29 22:45:26 NAS kernel: [    2.556053] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
Oct 29 22:45:26 NAS kernel: [    2.728370] r8168  Copyright (C) 2015  Realtek NIC software team <nicfae@realtek.com>
4. I have 14 package installed. Not all of them are running but most of them.
    In the kernel log
Oct 29 22:45:26 NAS kernel: [    2.546703] e1000: Intel® PRO/1000 Network Driver - version 7.3.21-k8-NAPI
Oct 29 22:45:26 NAS kernel: [    2.546708] e1000: Copyright © 1999-2006 Intel Corporation.
Oct 29 22:45:26 NAS kernel: [    2.556047] e1000e: Intel® PRO/1000 Network Driver - 3.2.7.1-NAPI
Oct 29 22:45:26 NAS kernel: [    2.556053] e1000e: Copyright© 1999 - 2015 Intel Corporation.
Oct 29 22:45:26 NAS kernel: [    2.728370] r8168  Copyright © 2015  Realtek NIC software team
Try this, I don't know if it's the right solution but seems to be working for me!
Reboot and go on uefi bios settings, advanced -> CPU settings and disable "enhanced halt state (C1E)
Inviato dal mio SM-G950F utilizzando Tapatalk
Will do a try. Thx.
Sorry for late reply, due to an eye-surgery.
It's strange that you don't have an ".xpenoboot" folder as you upgraded from a typical "problem system" that used xpenoboot
and it was "supposed" to have both the folder and that type of problem, but computers works in mysterious ways ;-)
My "MediaBox" is running all OK with the same mainboard and nic as you have,
I did a clean install of DSM 6.1.7-15284, later updated to Update 3, as a DS3615xs, never saw any problems like those you are seeing.
@deesnow Are you sure you are on DS3615xs and not on DS3617xs? If yes then I would suggest a clean install on a separate drive and make some testings.
If this web GUI stopping is not something predictable or happens once in a while it could also be hardware related or a corruption of DSM. Although I did a tutorial on how to upgrade from DSM 5 to DSM 6 I think it best to start a clean install of DSM 6 because loaders pre-DSM 6 are structurally different.
In any case try testing with a new drive see how that goes.
Answer this question...
