I looked around the forum but all i can find is mod software to use front panel power button to turn system off.. my situation is different, when i try power down it wont physically turn system off. It disappears from network but i have to manually kill power.. if i do a restart, that works fine. Asus H310m-c csm and i5 8400 1.04 loader dsm 6.2.2 u3
Edited by merve04
well i got this problem figured out, tried various loaders.. all had same issue.. i decided to update firmware and load default settings in bios.. power off behaves correctly now.. now onto other issues...
