BambosD Posted October 31, 2019 #1 Posted October 31, 2019 Hello Everyone, my disaster backup is a branded HP Compaq with Intel Pentium D 3 GHz and 1 GB ram. (5800 series). I'm trying to boot XPEnology with some errors and issues, that's why i need some help and guidance. 1. i put second ethernet on PCI slot, since the onboard is 100Mbps. What MAC address i should use on the boot image ? onboard ethernet or PCI ethernet? 2. Do we have a compatibility issue because of the old system ? Is it worth trying or not? (now is running windows 10, mirror 4TB disaster doing Goodsync backups and is ok). Thank you. Quote
jensmander Posted October 31, 2019 #2 Posted October 31, 2019 3 hours ago, BambosD said: What MAC address i should use on the boot image ? The MAC of the second NIC (PCI) which will be used. 3 hours ago, BambosD said: Do we have a compatibility issue because of the old system ? Depends on chipset and CPU type. Maybe loader 1.02b will work without problems (DSM 6.1 only). But if you intend to use it as a pure backup "server" maybe OpenMediaVault would be an option/alternative. It offers all classic NAS features (SMB, FTP, RSYNC, etc.). It's rsync features can be used for HyperBackup of other Synologys/XPEnologys. Quote
BambosD Posted November 3, 2019 Author #3 Posted November 3, 2019 I wanted to post a feedback for the community. - The only bootloader that worked is: DS3615xs 6.1 Jun's Mod V1.02b (MBR_Genesys).img - The .pat i used is 6.1.7 DS3615xs with success. - The only way to bypass the second PCI ethernet issue, was to disable the onboard lan and use the mac address of the PCI lan card. - I had an error can't find hard disk when using the onboard sata ports (i guess compatibility issues), i resolve this by adding PCIe 1X sata card based on Marvel chipset. - The system is stable - Never had higher transfer rate than 48MB/sec. Thanks for the support. System: HP Compaq dx2200 microtower / 2X Ironwolf 2TB Quote
