fjf Posted August 9, 2014 #1 Posted August 9, 2014 I just got here and I am warming up to the idea of setting a HP N54L with Xpenology. I have a few questions for you enthusiasts: Is this box compatible with the new 6TB WD REDs hard drives?. Will it go over 16TB of a single raid volume?. With 5 drives possible, a raid 5 could get (in teory) to 24TB, and to 18TB in raid 6. Would be awesome!. Has anyone done something similar?. Would it work?.
thenexus7 Posted August 11, 2014 #2 Posted August 11, 2014 I just got here and I am warming up to the idea of setting a HP N54L with Xpenology. I have a few questions for you enthusiasts: Is this box compatible with the new 6TB WD REDs hard drives?. Will it go over 16TB of a single raid volume?. With 5 drives possible, a raid 5 could get (in teory) to 24TB, and to 18TB in raid 6. Would be awesome!. Has anyone done something similar?. Would it work?. I'm wondering the same too... would be great if we can!
skynet1970 Posted August 13, 2014 #3 Posted August 13, 2014 I just got here and I am warming up to the idea of setting a HP N54L with Xpenology. I have a few questions for you enthusiasts: Is this box compatible with the new 6TB WD REDs hard drives?. Will it go over 16TB of a single raid volume?. With 5 drives possible, a raid 5 could get (in teory) to 24TB, and to 18TB in raid 6. Would be awesome!. Has anyone done something similar?. Would it work?. WD RED 6TB HDD not the list from DSM HDD compatibility page http://www.synology.com/en-global/suppo ... l/DS3612xs . You may test it and let us know the answer .
In0cenT Posted August 13, 2014 #4 Posted August 13, 2014 I'm guessing it works, as my local store has a Synology 414 with 4x 6TB WD Red on their list... https://www.digitec.ch/de/s1/product/synology-ds414-softbundle-4-x-6tb-wd-red-netzwerkspeicher-nas-2737592
Schnapps Posted August 13, 2014 #5 Posted August 13, 2014 It shouldn't be a problem but try and buy if it working. The reason those disks are not in syno's HCL is because they didn't tested them.
fjf Posted August 14, 2014 Author #6 Posted August 14, 2014 I already have the HP N54L; It is amazingly small and cheap. I am waiting for two 6TB WD REDs. I'll do the experiment and report.
odin836 Posted August 17, 2014 #7 Posted August 17, 2014 Anyone tried (with success) the HP N54L with the 6TB WD REDs?
fjf Posted August 18, 2014 Author #8 Posted August 18, 2014 I just put 2 6TB WD REDs. The system is checking the hard disks, but so far it seems to work fine. Much to play with now!!.
odin836 Posted August 18, 2014 #9 Posted August 18, 2014 I just put 2 6TB WD REDs. The system is checking the hard disks, but so far it seems to work fine. Much to play with now!!. GREAT! Were there any issues with the HP N54L, you are running HP BIOS 2013.10.01?
fjf Posted August 18, 2014 Author #10 Posted August 18, 2014 I updated with the bios mod as described in: http://www.xpenology.nl/hp-n40ln54l-bio ... 013-10-01/ No issues at all, worked the first try
odin836 Posted August 19, 2014 #11 Posted August 19, 2014 No issues at all, worked the first try Mass storage just became a whole lot more obtainable!
She Posted August 24, 2014 #12 Posted August 24, 2014 Please inform us if everything work smooth with 6 TB drives. Please mention what kind of raid did you use. Thanks in advance
fjf Posted August 25, 2014 Author #13 Posted August 25, 2014 Working well with 2 6TB WD RED drives in a HP n54l, using SHR (the proprietary synology RAID 5). No problems so far, except that wake on lan only works within the lan, and not from outside. The drives are not too noisy. Happy . Used the tutorials on http://www.xpenology.nl/. Great web, full of resources!.
Schnapps Posted August 30, 2014 #14 Posted August 30, 2014 Working well with 2 6TB WD RED drives in a HP n54l, using SHR (the proprietary synology RAID 5). No problems so far, except that wake on lan only works within the lan, and not from outside. The drives are not too noisy. Happy . Used the tutorials on http://www.xpenology.nl/. Great web, full of resources!. WOL was meant to be used only from the LAN Do you know how I'm waking up my machines when not in LAN? I flashed OpenWRT on my router and installed the Wake on Lan package in it. There are some guides on the net on how to create port forwards and so on for you to wake up your machines from the internet. Sent from my iPhone using Tapatalk
