IG-88
2 hours ago, mydownload said:
any other idea ?
my last post had some, you can try to pick up newer hpsa controller like 420 that can be switched into hba mode but you might end up in the same spot as you are now
if it has to be baremetal i guess another nas system might work better (true nas, open media vault)
afair most people with hpsa controllers switched to hypervisor and used dsm as vm
4 hours ago, mydownload said:
So, i've started from scratch, with XPEnoboot_DS3615xs_5.2-5644.5 and DSM_DS3615xs_5644.pat. So it's installed BUT, i have only one HD instead of 4... All HD have the same config : Raid0 on my controller.
any idea why ?
I didn't correctly look at... all HD are seen like a raid partition. So, now, how can i updgrade my NAS without loosing my configuration (raid array) ?
thanks
you can boot from a usb with loader 1.03b (prepared with the correct vid/pid) and try to upgrade the installed 5.2 to 6.2, if the only system was to create partitions the you will ship that step as there are already configured partitions but my guess is that if there is da driver issue with hpsa on 6.2 that attempt will fail, but the ony thing you can loose is a fresh installed 5.2 so not much risk trying it
With 1.03b, actual installation is not seen... I really need to keep drivers from XPEnoboot5.2...
its not that simple, 5.2 used its own compiled kernel, with 6.0 we use synology's original kernel with all its messy mod's and one sided changes, if they change something in the kernel they dont core if other things break as long as the hardware they use in there own units works and beside the kernel changes there are also external drivers they use (and mod) and dont offer source code
especially when using a older kernel source (or even original from kernel.org) to compile drivers there is always a risk of things not working properly
we hat to use 6.x beta source as base for a long time for drivers and with every update synology made the gap between source used for additional drivers and the source used (by synology) for the kernel grew and if that sap is 1-2 years there might be "some" differences
in general using dsm in a way where raid controllers are involved is not the way its meant to be used as its build all around software mdadm raid with single disks and using raid0 disks as single drives in dsm will result in disks without smart info, no serial number (no way of telling what IRL disk broke from the dsm gui) and will kill a lot of the easy/safe to use features dsm is meant to deliver
like it is with making usb drives part of dsm's raid sets, one can tweak it like that but its a terrible idea to do so
also as further you stray away from its original config you will have much more trouble when updating
in your situation its way better to get around it with other ways like hypervisor (that one will handle hardware raid management  and use its software to monitor the disks and even message you in case of problems properly) or using a controller that is better suited for the task of natively running in dsm on a bare metal system (like the lsi sas in 3615/3617/3622 where the driver is native part of dsm)
PS: you can debug the whole hpsa thing if you want and fix it, i would add you patches to the kernel source and make new drivers but the amount of time needed for that would be way to big on your side and might be better invested in using these skills to backport intel igc driver (2.5G nic) or backport recent i915 driver to have intel qsv support for newer cpu's
(a older lsi sas is less then 100 bugs and using proxmox costs nothing - compared to 20+ work hours for fixing hpsa drivers for dsm)
if you could create HP drivers,
only if you (any one else) can find out whats wrong with the hpsa driver in syno's kernel, code a fix and deliver a patch for the driver source (or the whole fixed driver source)
just compiling a driver did not do the trick (in 6.1/6.2 we tried that with the kernl driver and the one from external source already)
is there any log when booting USB ?
About my issues : i've got a new server, Dell R310, with LSI card and i've added an old Intel Pro network card. Succed to install DSM6.2 with redpill.v0.4.6.
BUT, it seems configuration is not backuped, every time i reboot it, i need to reinstall Surveillance station and cracked it again. Does someone have an idea about reason ?
thanks,
its redirected to com1, if you have that and use a null-modem cable you can use terminal program like putty to display that (on another computer)
this thread is about dsm 6.2.2 and jun's loader so we are done here i guess
please open new topic in another area
  • 1 year later...
@IG-88
I am on DSM 7.1.1.
I got the Club 3D 2.5GB Adapter plugged in a USB3 Port at my Nas
Xpenology 920+ but the CPU is a XEON 1225 V3
I could only install the gemini lake
r8152-geminilake-2.15.0-3.spk so far cuz other packages arent supported - DSM is complaining.
Is there any chance to make it work or do i have to switch to a xpenology version that recognize my Xeon CPU?
off topic here as this thread is about dsm 6.2.2 but dsm 7.1.1 still has the same i915 driver as in 6.2.3
the driver should detect older gpu's as well, only newer gpu's are a problem
this CPU has "Intel HD P4600" and thats gpu gen 7.5
https://en.wikipedia.org/wiki/Intel_Graphics_Technology
so its capability's are limited and there is no guarantee that it will work video station of the face recognition in photos
if there are devices in /dev/dri then the driver is working, your main problem will be is it working with the part of dsm you want to use, as synology did not intent or test if older gpu's will work
what a 7th gen gpu can do can be seen here (compared with newer gpu's)
https://en.wikipedia.org/wiki/Intel_Quick_Sync_Video#Hardware_decoding_and_encoding
no HEVC/h.265 for sure
@IG-88
Thanks, sry for the off topic. Didnt see.
I dont mind about HW Transcoding, just wanna run the 2.5Gbit Adapter. Need to figure out how. The installed gemini lake driver doesnt give me a third entry under network attachments for the dongle so far. Before on a org. Synology it was working flawless.
my interpretation here war that it was about the gpu not being recognized, cpu wise there is nothing to recognize, it just works
if its a bout what you seen in dsm's gui, then dont worry it just a kind of static picture they persent the user but if its important, there is a cpuinfo tool in the software modding section that can make your real cpu to be seen in the gui
arpl loader has its own r8152 driver (version=v2.16.3 (2022/07/06)) that should be working
boot with the usb adapter connected and check if the driver is loaded with "lsmod |grep r81"
also check whats in the log about that with "dmesg |grep r81"
  • 8 months later...
Hi, I would like to solve my problem.
I have an HPE microserver Gen8:
Intel Xeon E3-1220Lv2 CPU
RAM 16 GB
4x HDD and 1x SSD disks (RAID controller disabled)
2x integrated 1 gigabit/s ports
I use arpl for boot DSM
I would like to add an HP NC523 SFP NIC to my configuration, Synology does not detect the card but the HPE server detect it as a QLogic 82XX NIC and activates the SFP ports
Is it a problem of missing the right driver in the loader configuration or something similar?
thanks for help
Edited by Davide03gm
HEP Spec lists it as "QLogic cLOM8214"
https://www.hpe.com/psnow/doc/c04111574.pdf?jumpid=in_lit-psnow-getpdf
the driver would be "qlcnic.ko" and that driver was part of the 3615/17 extra package
pci vendor and device id in the driver are
1077:8430
1077:8030
1077:8020
check if the pci id's match, check log dmesg about "qlogic" or "qlcnic"
that driver was also part of jun's original extra.lzma so most likely its not about the driver being present
afair 6.2 update support ended 6/2023 so you might be better off trying out a newer loader and dsm 7.x
On 1/11/2024 at 9:31 PM, Orphée said:
He is probably using DSM 7 already as he referred to ARPL.
YES you are right i did not read careful enough but the driver required is correct and arpl seems to to have that one, as arpl is unmaintained atm i'd suggest using ARC loader
https://github.com/AuxXxilium/arc
that one comes with a wider selection of drivers and to be sure i just checked for that driver and it is present there, so it should work with this loader
  • 2 months later...
On 1/22/2022 at 7:23 AM, rcached said:
Confirmed links are dead for all but the DS3615 file.
New mirror links below.  Please consult the OP for any additional info needed!
0.8_syno ds918+ - extra.lzma/extra2.lzma for loader 1.04b_mod ds918+ DSM 6.2.2 v0.8_syno
Original: https://gofile.io/d/mVBHGi
Filename: extra918plus_v0.8_syno.zip
SHA256: 21B0CCC8BE24A71311D3CC6D7241D8D8887BE367C800AC97CE2CCB84B48D869A
Mirrors: Clicknupload, Dailyuploads, usersdrive, Zippyshare
0.8_std ds918+ - extra.lzma/extra2.lzma for loader 1.04b_mod ds918+ DSM 6.2.2 v0.8_std
Original: https://gofile.io/d/y8neID
Filename: extra918plus_v0.8_std.zip
SHA256: F611BCA5457A74AE65ABC4596F1D0E6B36A2749B16A827087D97C1CAF3FEA89A
0.8_recovery ds918+ - extra.lzma/extra2.lzma for loader 1.04b_mod ds918+ DSM 6.2.2 v0.8_recovery
Original: https://gofile.io/d/4K3WPE
Filename: extra918plus_v0.8_recovery.zip
SHA256: 5236CC6235FB7B5BB303460FC0281730EEA64852D210DA636E472299C07DE5E5
DS3615: extra.lzma for loader 1.03b_mod ds3615 DSM 6.2.2 v0.5_test
Original: https://gofile.io/d/iQuInV
Filename: extra3615_v0.5_test.zip
SHA256: BAA019C55B0D4366864DE67E29D45A2F624877726552DA2AD64E4057143DBAF0
DS3617: extra.lzma for loader 1.03b_mod ds3617 DSM 6.2.2 v0.5_test
Original: https://gofile.io/d/blXT9f
Filename: extra3617_v0.5_test
SHA256: 4A2922F5181B3DB604262236CE70BA7B1927A829B9C67F53B613F40C85DA9209
Links are dead!!
Can anyone please share all the 08_syno/std/recovery for ds918+?
Thank you very much in advance!!
EDIT: nevermind, I was trying to find it for DSM 6.2.3!!
Edited by ed_co
On 4/9/2024 at 1:38 PM, ed_co said:
Links are dead!!
Edited Tuesday at 02:28 PM by ed_co
Glad you were able to find working links for DSM 6.2.3 instead.
On the off chance that you or anyone else may need the downloads in this thread for DSM 6.2.2, here are fresh download links:
https://gofile.io/d/Otg1w4
https://dailyuploads.net/75vcrg61rsn2
https://usersdrive.com/qhwiez556u7k.html
https://www.zippyshare.day/QkM1RuCZ4WGjJ91/file
https://gofile.io/d/rlPLhM
https://dailyuploads.net/l1v9vaob0k4o
https://usersdrive.com/xyepa6sa4trc.html
https://www.zippyshare.day/NB0AjRJhSL9nRGT/file
https://gofile.io/d/dBMD5e
https://dailyuploads.net/t4grkc3s2hfs
https://usersdrive.com/f28dhpmbjlkf.html
https://www.zippyshare.day/QxWHH3jJ0Q6BvzK/file
https://gofile.io/d/Q8V9iR
https://dailyuploads.net/c8y9jyunl0wg
https://usersdrive.com/nn6ja92hy8a2.html
https://www.zippyshare.day/U9uxXCwpnXwrSlk/file
https://gofile.io/d/44u6er
https://dailyuploads.net/fje0te8ywo9a
https://usersdrive.com/wjsojq787h5w.html
https://www.zippyshare.day/z4Lf0av9njH5dLx/file
Edited by rcached
Здравствуйте! Нужен ваш совет...Я пытаюсь поставить DSM с загрузчиком Arc Loader 24.4.10 на ПК Ryzen 5600G + MCI tomahawk b550... конфигурирую загрузчик под модели Synology c AMD процессором, перепробовал все модели!!! Доходит до того момента, когда Arc Loader выдает локальный адрес http://IP:5000 и на этом все...загрузки DSM не происходит, синолоджи ассистент устройство не находит, более того, через пару минут вообще пропадает устройство с указанным ай пи в локальной сети (у меня Кинетик Гига, и я это вижу в админке роутера) а когда только Arc Loader выдал что можно зайти по http://IP:5000, скорость порта 10мбт/с причем лан порт материнки поддерживает 2,5 Гбт/с. Я думал что не видит этот порт и ставил PCI-E гигабитный контроллер лан...все тоже самое...останавливается все тогда, когда в сети лан должно появиться устройство Synology и должна начаться установка DSM. Я в этом всем профан полнейший и наверняка не вижу чего-то элементарного, поэтому прошу вашей помощи-подсказки!
