Unlicensed Posted April 25, 2020 Share #676 Posted April 25, 2020 В 22.04.2020 в 20:58, IG-88 сказал: ...max disk count for 3615/17 is 12, when having 6 sata and 8 by sas it will be 14 and the last two will not appear with some tweaking of config files it can be extended... IG-88, do you mean the "SataPortMap=XY" arguments in grub.cfg file, or this tweaking is deeper? Can you show the thread with this problem discussion? Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 25, 2020 Author Share #677 Posted April 25, 2020 3 hours ago, Unlicensed said: IG-88, do you mean the "SataPortMap=XY" arguments in grub.cfg file, or this tweaking is deeper? much deeper, its not as simple as changing the grub.cfg for a update safe solution, that need changing a diff/patch file from jun inside the loader and unpacking/repacking the extra.lzma 3 hours ago, Unlicensed said: Can you show the thread with this problem discussion? you can use the forum search and look up thread sinvolving synoinfo.conf AND internalportcfg= also related are esataportcfg= usbportcfg= maxdisks= you can also look on youtube for "Expand XPenology beyond 12 drives" Quote Link to comment Share on other sites More sharing options...
Unlicensed Posted April 25, 2020 Share #678 Posted April 25, 2020 Thanks a lot! I shall look for it. I already have found some question-correspondent threads here: https://xpenology.com/forum/topic/13525-how-to-configure-sata_args-in-grubcfg https://xpenology.com/forum/topic/20863-new-hdd-replacing-slot-of-old-hdd https://xpenology.com/forum/topic/23970-set-sata-args-for-x11ssl-cf-mbrd-with-6-x-sata-8-sata-ports-attached-to-lsi3008-sas-controller https://xpenology.com/forum/topic/14224-tutorial-fix-skipped-hdd-numbers And yes, it is much more complicated, that I previously thought. Quote Link to comment Share on other sites More sharing options...
Messenger Posted April 25, 2020 Share #679 Posted April 25, 2020 22 hours ago, IG-88 said: yes, synology reverted the change made in 6.2.2 so old drivers work again yes, it should work this way so just updated everything worked like expected. Thank you very much. Quote Link to comment Share on other sites More sharing options...
dr400 Posted April 27, 2020 Share #680 Posted April 27, 2020 Hi all, finally got the 6.2.2 24922 upgrade 6 to work on my LENOVO m82 using a modified loader 1.03b with MBR (with extra.lzma provided by IG-88 in extra3615_v.05). I nevertheless got a driver issue that i'd like to fix before moving forward. I 'd like to grab dv videos from a dv camera. I purchased a week ago a ieee1394 VIA pci card. No available BIOS settings (as far as I know) and lspci shows nothing close to the firewire card. I've read the forum to find out a way to make it work but not joy so far. Can you help me in some way ? Quote Link to comment Share on other sites More sharing options...
eszerfrm Posted April 27, 2020 Share #681 Posted April 27, 2020 Hi IG-88, is there any error message or log file I can see and report to you? there are reports from other forum... It seems don't support RTL 8111F dual Lan or something else problem there...? Quote Link to comment Share on other sites More sharing options...
tuanbombt Posted April 27, 2020 Share #682 Posted April 27, 2020 IG-88, after change some setting in bios and remove extra2.lmza, now i can shutdown/reboot nas is normal Quote Link to comment Share on other sites More sharing options...
foot Posted April 27, 2020 Share #683 Posted April 27, 2020 Hi, I have a server with a board supermicro H11DSi-NT and AMD Epyc 7452 processor, is it possible to get xpenology working? tried with the extra v10, but it doesn't work for me. Any solution? Thank you Quote Link to comment Share on other sites More sharing options...
psphd Posted April 27, 2020 Share #684 Posted April 27, 2020 Is there a driver for solarfare sfn5162f network card ds918 +? I would like to give you a download address. Thank you very much!!! Quote Link to comment Share on other sites More sharing options...
Yannis Posted April 27, 2020 Share #685 Posted April 27, 2020 OK... I used your driver extension on an N40L and "revived" my semi-bricked installation of 6.2.2... Thanks a lot! Now it prompts for the Update 6 of DSM 6.2.2-24922... Is it safe to upgrade or it will need the same process again? Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 27, 2020 Author Share #686 Posted April 27, 2020 11 hours ago, dr400 said: Hi all, finally got the 6.2.2 24922 upgrade 6 to work on my LENOVO m82 using a modified loader 1.03b with MBR (with extra.lzma provided by IG-88 in extra3615_v.05). I nevertheless got a driver issue that i'd like to fix before moving forward. I 'd like to grab dv videos from a dv camera. I purchased a week ago a ieee1394 VIA pci card. No available BIOS settings (as far as I know) and lspci shows nothing close to the firewire card. I've read the forum to find out a way to make it work but not joy so far. Can you help me in some way on what dsm version did you had this working`? with what additional software package (just a driver won#t do it) 11 hours ago, eszerfrm said: is there any error message or log file I can see and report to you? there are reports from other forum... participating here is part of the fun but it will be discussed here (open) so we all can learn from it information about the hardware and a complete dmesg log would be useful 8111f is just the normal realtek 8 hours ago, tuanbombt said: after change some setting in bios can you be more precise, that might help other people 3 hours ago, foot said: I have a server with a board supermicro H11DSi-NT and AMD Epyc 7452 processor, is it possible to get xpenology working? tried with the extra v10, but it doesn't work for me. Any solution? did you try loader 1.03b with juns extra.lzma? 2 hours ago, psphd said: Is there a driver for solarfare sfn5162f network card ds918 +? I would like to give you a download address. Thank you very much sfc.ko from the extra.lzma 0.10 is the one from kernel 4.4.59 and supports SFC9120 10G Ethernet Controller (Virtual Function) SFC9120 10G Ethernet Controller SFL9021 10GBASE-T Ethernet Controller SFC9020 10G Ethernet Controller SFC4000 rev B [Solarstorm] SFC4000 rev A net [Solarstorm] the nic you wrote about seems to be 9021 so it might mot with the driver we already have did you try? if it does not and you have a link to linux driver source ... 2 hours ago, Yannis said: Now it prompts for the Update 6 of DSM 6.2.2-24922... Is it safe to upgrade or it will need the same process again? yes, you could even use 6.2.3 when you change (back) to jun's extra.lzma (in 6.2.3. the change that made new drivers necessary was reverted so the old packages work again) Quote Link to comment Share on other sites More sharing options...
dr400 Posted April 27, 2020 Share #687 Posted April 27, 2020 (edited) il y a 4 minutes, IG-88 a dit : on what dsm version did you had this working`? with what additional software package (just a driver won#t do it) migrating from 6.1.7 if recollection is correct ... but on that version (6.1.7) pci card was not recognised either. I upgraded with the secret hope to have it working with DSM 6.2.2. That's the purpose of my request here ... Edited April 27, 2020 by dr400 Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 27, 2020 Author Share #688 Posted April 27, 2020 4 minutes ago, dr400 said: migrating from 6.1.7 if recollection is correct ... but on that version (6.1.7) pci card was not recognised either. I upgraded with the secret hope to have it working with DSM 6.2.2. That's the purpose of my request here .. even if the controller would have a driver, you just can't install a software package like on a normal linux, its a appliance how would you work with your camera to get any date to disk? Quote Link to comment Share on other sites More sharing options...
dr400 Posted April 27, 2020 Share #689 Posted April 27, 2020 il y a 3 minutes, IG-88 a dit : even if the controller would have a driver, you just can't install a software package like on a normal linux, its a appliance how would you work with your camera to get any date to disk? not sure to understand ... my objective was to run a VM with linux distro + dvgrab package and with the help of the pci card to connect to cam via firewire and grab the video ... Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 27, 2020 Author Share #690 Posted April 27, 2020 does syno's VMM support to hand over pci(e) devices to a vm? (pass through) i'm not going to do this for just one person and one purpose that might not even work i wrote a tutorial on how to make your own drivers (i started all this by just wanting a button.ko), you can try making your own driver you just need to compile it and you can load it manually (insmod) before creating a new extra.lzma Quote Link to comment Share on other sites More sharing options...
dr400 Posted April 27, 2020 Share #691 Posted April 27, 2020 (edited) il y a 12 minutes, IG-88 a dit : does syno's VMM support to hand over pci(e) devices to a vm? (pass through) i'm not going to do this for just one person and one purpose that might not even work i wrote a tutorial on how to make your own drivers (i started all this by just wanting a button.ko), you can try making your own driver you just need to compile it and you can load it manually (insmod) before creating a new extra.lzma pass-through comment is a good point, I don't have a clue on the matter. I'm certainly not asking you to build a driver just for me. By reading here and there, other people are using firewire card and might have run into the same trouble. I am considering building it myself (not so sure about my personnal capacity to do it) but I would like to read others' comments whether it is possible or not before going further. Expenology is build on linux, VMM is not even the good option. Once driver is "build" (no the easiest part I agree) it should run smoothly, right ? One may ask why bother with this, the pb is that the only capable (strong, efficient) machine with ieee1394 is presently my xpeno nas ... Edited April 27, 2020 by dr400 Quote Link to comment Share on other sites More sharing options...
eszerfrm Posted April 28, 2020 Share #692 Posted April 28, 2020 (edited) 7 hours ago, IG-88 said: participating here is part of the fun but it will be discussed here (open) so we all can learn from it information about the hardware and a complete dmesg log would be useful 8111f is just the normal realtek It's the problem, I can boot in to the happy hacking screen, but I can't find my machine in "find.synology.com" I've edit the grub.cfg, set extra_args = 'debug loglevel=15' but I cant see any log message on the screen the NIC is dual Lan... not single Lan.... so I've set netif_num=2 I hope I can use demsg, but I don't know how to use it without boot in... Edited April 28, 2020 by eszerfrm Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 28, 2020 Author Share #693 Posted April 28, 2020 2 hours ago, eszerfrm said: but I cant see any log message on the screen log is switched to serial port https://xpenology.com/forum/topic/9394-installation-faq/?tab=comments#comment-81097 without informatin about loader you use and what hardware (cpu, board) ... most likely not a driver problem so read faq and maybe this https://xpenology.com/forum/topic/13333-tutorialreference-6x-loaders-and-platforms/ Quote Link to comment Share on other sites More sharing options...
tuanbombt Posted April 28, 2020 Share #694 Posted April 28, 2020 I change something parameter in settings bios below: Disable Serial Port Disable vt-d Enable EHCI, XHCI hand-off Compability win 7 to win 8.x DSM 6.2.3, I used only extra.lmza (don't used extra2.lmza) from custrom extra v0.10 => I can shutdown/reboot normal Quote Link to comment Share on other sites More sharing options...
Decebalus Posted April 28, 2020 Share #695 Posted April 28, 2020 On 4/24/2020 at 9:28 AM, djvas335 said: 1. Yes 2. Maybe corrupt image ? No need to replace anything except extra.lzma Duh! I did not unmount the USB stick before loading the .pat file. That's why I was getting the error. So after replacing the extra.lzma file, just unplug and plug back in the USB stick, then proceed with update. Hope this helps others. Quote Link to comment Share on other sites More sharing options...
dmtg Posted April 29, 2020 Share #696 Posted April 29, 2020 i update my ds3515xs is working but the upnp is not working.... Quote Link to comment Share on other sites More sharing options...
eszerfrm Posted April 29, 2020 Share #697 Posted April 29, 2020 (edited) 21 hours ago, IG-88 said: log is switched to serial port https://xpenology.com/forum/topic/9394-installation-faq/?tab=comments#comment-81097 without informatin about loader you use and what hardware (cpu, board) ... most likely not a driver problem so read faq and maybe this https://xpenology.com/forum/topic/13333-tutorialreference-6x-loaders-and-platforms/ Thanks for your reply I use GA-J1900N-D3V, it is onboard CPU J1900 (BayTrail) with Dual LAN RTL 8111F Last time all 0.13b loader(3 differnt, std... syno... recov...) changed driver fail, and I have tried 918+ and 3617 one, that means I've tried different loader with differint driver patch at least 9 files, I don't event know what type would works... Later I will try recovery 0.13b one again, use 3617 version (change two 3617 file from pat file 24922 version by hand) and try add driver, too (that means I'll try 3 differnt bootloader). If it still doesn't work, I will try to see serial port message......(I don't have RS232 to USB line yet) Edited April 29, 2020 by eszerfrm add some info Quote Link to comment Share on other sites More sharing options...
djvas335 Posted April 29, 2020 Share #698 Posted April 29, 2020 umount /tmp/mountMe No need to remove usb drive 14 hours ago, Decebalus said: Duh! I did not unmount the USB stick before loading the .pat file. That's why I was getting the error. So after replacing the extra.lzma file, just unplug and plug back in the USB stick, then proceed with update. Hope this helps others. Quote Link to comment Share on other sites More sharing options...
dmtg Posted April 29, 2020 Share #699 Posted April 29, 2020 12 hours ago, dmtg said: i update my ds3515xs is working but the upnp is not working.... solved Quote Link to comment Share on other sites More sharing options...
IG-88 Posted April 29, 2020 Author Share #700 Posted April 29, 2020 16 hours ago, eszerfrm said: I use GA-J1900N-D3V, it is onboard CPU J1900 (BayTrail) with Dual LAN RTL 8111F here is one positive report https://xpenology.com/forum/topic/12867-user-reported-compatibility-thread-for-dsm-62/?do=findComment&comment=139518 16 hours ago, eszerfrm said: Last time all 0.13b loader(3 differnt, std... syno... recov...) changed driver fail, and I have tried 918+ and 3617 one, that means I've tried different loader with differint driver patch at least 9 files, I don't event know what type would works... Later I will try recovery 0.13b one again, use 3617 version (change two 3617 file from pat file 24922 version by hand) and try add driver, too (that means I'll try 3 differnt bootloader). If it still doesn't work, I will try to see serial port message......(I don't have RS232 to USB line yet) maybe try loader 1.04b, mod it with the rd.gz and zImage from DSM_DS918+_25423.pat (DSM 6.2.3, use 7zip to extract the files) and also copy the extra/extra2 0.10 (overwrite old files) https://xpenology.com/forum/topic/28321-driver-extension-jun-104b-for-dsm623-for-918/ Quote Link to comment Share on other sites More sharing options...
