Tribjak78 Posted August 31, 2019 #1 Posted August 31, 2019 Hi i have a big problem with my as on hp 54 NL i have 4 disks wd red for nas and it works fine. I have sata and esata ports activated (i dont’ know the type of bios on the machine) On setup Bios version is bios ID 041 Bios version 10/01/2013 i baught 2 4 to sata III. disks skyhawks ST4000VX07 the problem seems to be on the bios. I try the disk on cd sata port and esata with an adaptator cable esata to sata i also try the disk into the bay an the same problem Bios recongnise the size, type of disk, and paameters disk but with a smart error 400 and smart say disk is bad and as for f1 to continue.I continue and server continue booting.i go to dsm i can see the disk in openology, but when i whant to create a volume it seems to be creatin the volume, but it ceate no nothing disks are neuw , the are never used dsm version is 5.2 5967 what can i do ? it ‘s not compatible 4 to disks ? Can i change the bios with a compatible with to disks ? Best regards Quote
