Subtixx Posted August 20, 2019 #1 Posted August 20, 2019 (edited) As the title says, the Controlpanel -> System has the wrong CPU, which in return tells VMM the wrong CPU / Threadcount. Information on the Controlpanel shows: INTEL Core i3-4130 2.79GHz Is there any way to tell XPenology what my CPU is? EDIT: Also is there any way to get this: Quote Increased vCPU resource allocation to 4 times thread count for VMM Pro. without VMM Pro? Or is there any alternative to VMM? Edited August 20, 2019 by Subtixx Quote
polanskiman Posted September 13, 2019 #2 Posted September 13, 2019 Hello. Clearly you are new here. I strongly suggest you to read the FAQs first. This is explained. If you wish to see your actual CPU information you will need this tool: Note that this will not survive a DSM update so it will need to be re-applied. 1 Quote
