chamurai Posted August 14, 2019 #1 Posted August 14, 2019 I have an xpenology running with DS918+ and bootloader 1.04. I have a network card with 4 nics. But I can only use 2. When i check ifconfig I can see there are 4 eth(x) but only 2 get an IP In /etc/sysconfig/network-scripts I can see with files for eth0 and eth1. I tried to manual create eth2 but after a restart of the system this file is gone. Does anyone know how to activate eth2 and eth3? Quote
Olegin Posted August 15, 2019 #2 Posted August 15, 2019 Edit grab.cfg: add mac’s for 3,4 and change count of nic’s. Quote
chamurai Posted August 15, 2019 Author #3 Posted August 15, 2019 (edited) i have do that, but dsm shows only 2 ds 918+ has only 2 nics. i can nic 3 and 4 up with ssh, but afther reboot the gone Edited August 15, 2019 by chamurai Quote
Olegin Posted August 15, 2019 #5 Posted August 15, 2019 Change mac3 to .....9A, mac4 to ....9B and try again. Quote
chamurai Posted August 15, 2019 Author #6 Posted August 15, 2019 i tryed, but did't not help, i think 4 nics dont work on ds918+ did try on 3617 en all 4 nics work Quote
jensmander Posted August 16, 2019 #8 Posted August 16, 2019 Did you modify the grub.cfg from the startup screen or did you do that on a PC mounting the stick and used Notepad++? Was the Nic already present when you installed Dsm from scratch? I also use a 4-port card from Intel in one of my 918+ and all 4 ports are usable. I used Intel‘s flash tool to hard-code the appropriate Macs on it. Quote
chamurai Posted August 16, 2019 Author #9 Posted August 16, 2019 i did use notepad++, and i did a fresh instal, but only shows 2 nics, i can bring nic3 and 4 up use shh, afther reboot the gone Quote
Selfmade RuLeZ Posted August 20, 2019 #10 Posted August 20, 2019 On 8/15/2019 at 1:24 PM, chamurai said: Mac Numbers are octal and Synology added after the first Mac +1. So your mac3 und mac4 should be ..378A and ..378B and not 9A and 9B as mentioned before Quote
