[Guide] How to post-process Torrents with Transmission
A lot of people are asking me how I managed to let Transmission work alongside Usenet downloaders in CouchPotato, Sickbeard/SickRage and Headphones.
The problem is usenet downloaders have built-in support for category sorting, but transmission doesn't.
This is how I did it:
Warning: You need to use a different repo for filebot now, and I changed the script a bit. Checkout my post beneath.
Connect to your NAS over an SSH session. I used Gate One for this.
1. Create a file in /volume1/@appstore/transmission called postprocess using vi /volume1/@appstore/transmission/postprocess (if your packages are installed on volume1)
2. Paste following code: (change paths when necessary ofcourse)
filebot -script fn:amc --output "/volume1/Download/complete" --log-file amc.log --action move --conflict override -non-strict --def artwork=y "ut_dir=/volume1/Download/complete/Torrents/$TR_TORRENT_NAME"
"ut_kind=multi" "ut_title=$TR_TORRENT_NAME"
rm -r "/volume1/Download/complete/Torrents/$TR_TORRENT_NAME"
chmod -R 777 /volume1/Download/complete
chown -R sabnzbd:users /volume1/Download/complete
3. Make our file executable and readable by using chmod +rx postprocess
4. Install filebot from MissileHugger. (It requires Java from MissileHugger)
5. Modify the file settings.json in the transmission/var directory to contain this line:
"script-torrent-done-enabled": true,
"script-torrent-done-filename": "/volume1/@appstore/transmission/postprocess",
What will this do? Whenever a torrent is completed, Filebot will sort the downloaded file into following folders: Movies, TV Shows, Music.
Create these folders or wait for a torrent to complete, and now point your CouchPotato, Sickbeard/SickRage and Headphones to these folders.
You can manually run the post-processing using ./postprocess when in the folder.
Enjoy! You may have to edit the Transmission settings file again after an update tough.
Edited by Guest
  • 2 months later...
Notice! Filebot now has their own respective package repository, so use this one for the latest version!
(Be sure to remove the old one)
[spoiler=]http://packages.filebot.net/syno
In order to avoid some errors/warnings when there is no torrent given, I modified the script with an extra check;
if [ -n "$TR_TORRENT_NAME" ]; then
filebot -script fn:amc --output "/volume1/Download/complete" --log-file amc.log --action move --conflict override -non-strict --def artwork=y "ut_dir=/volume1/Download/complete/Torrents/$TR_TORRENT_NAME" "ut_kind=multi" "u
fi
