HP N54L - 5.0 4493 - NB X64 5.0.2.4 - Power button?
gurug
Hello to all.
I'm trying to make power button work on HP N54L, so I can power off device with it ... I tried to follow steps to enable this on DSM 4.2 - but I got stuck.
There is no button.ko module loaded in system.
Can anybody get me some advice how to make this work?
Thans in advance!
- open /etc/rc for editing
- search for the first occurrence of the environment variable KERNEL_MODULES and put 'button' at the end of the string.
There is no button.ko on system - I did this already, I don't know much about linux, but if there's no button.ko in modules folder, 'button' can't load it, right?
I just upgraded from Gnooboot to Nanoboot and i got that "Power Button Down" working on my N54L like descriped here:
viewtopic.php?f=2&t=889&hilit=button#p7305
btw, i have a button.ko in my modules folder:
find / -name button.ko
/lib/modules/button.ko
Andywhit sent me button.ko and I copied it to my system and I did everything as in your link. And it is not working for me... When is test acpi, I got no response when I push button...
I guess you are nor having latest Dsm 5,0?
Nanoboot has no enable ACPI option in kernel.cfg file, so on nanoboot no button.ko module.
I do not know whether module from gnoboot will operate, perhaps not :sad:.
Ah, so that's the problem ... not enabled ACPI in nanoboot ... So I guess I'll just have to wait for new version ob NB that will have this enabled ... Thanks for info.
So please, ask nanoboot developer to include ACPI support! I can't understand why not compile the kernel with them.
I like also to have a robuts N54L server with XPEnology working.
Regards.
I would if I knew who is nanoboot developer and how to reach him ...
Sorry, but iam definatly on DSM 5.0-4493-Update 1 and it works for me.
I used to be on latest gnoboot with 4458, got it working there too.
Then upgraded to Nanoboot and to 4493, then manually Update to Update 1
i edit Line 371 in my /etc/rc to:
KERNEL_MODULES="..here comes stuff.. cpufreq_conservative button"
after reboot, i tested with : "cat /proc/acpi/event" which gave me some event and then did the rest like in the manual
i later checked and saw a button.ko:
DiskStation50> ll /lib/modules/button.ko
-rw-r--r-- 1 root root 12764 Jun 9 12:17 /lib/modules/button.ko
i didnt copy it there. (maybe its leftover from gnoboot?)
I did fresh (first install) with nanoboot and DSM 5.0-4494 and then update 1.
And button.ko was not present at all.
So I copied button.ko, made all right permisions (CHMOD), did all steps required to get button working, restarted.
If I list loaded modules now (LSMOD) - I get "button" listed, but "cat /proc/acpi/event" does not give any output when pressing power button.
sorry, iam no expert in this, i just tried out the Manual and i got it working, maybe theres some leftover from gnoboot?
(all i did was to change my usb drive from gnoboot to nanoboot, then choose migration and then went the steps of the manual)
anything i can do to help you?
I guess it's possible that some part of system was leftover ... I'm also no expert :smile:
I did some more reading around internet, and it looks like there is really no ACPI support in nanoboot - so this is the issue.
Thanks for your offer. :smile:
