Yuri_S Posted July 17, 2019 #1 Posted July 17, 2019 (edited) Good day. Working with DSM 5.2-5967 Update 9. For operational needs use WD Blue 500 Gb HDD, which is connected by USB (using external USB-rack). Everything works fine (media streaming and file sharing) except one issue with SMART info and SMART test. Those two button are grey (unavialable) in Control Panel --> External Drive. So my questions is - is it possible to get SMART data for external USB drives? Regards. Edited July 17, 2019 by Yuri_S Quote
polanskiman Posted July 19, 2019 #2 Posted July 19, 2019 Hello and welcome to the forum. To answer to your question, It is possible but not from the GUI. You will need to run certain commands from a terminal. In ssh, run this first: fdisk -l | grep /dev/sd This will bring up all your disks (internal and external) attached to your box. Your usb device should normally be the one that is named /dev/sdq but please check and most certainly the last one on the list. Now that you know your device you can run several tests and commands. To check if the drive supports SMART: smartctl -i -d sat /dev/sdq For the short test: smartctl --test=short -d sat /dev/sdq For the long test: smartctl --test=long -d sat /dev/sdq For the conveyance test: smartctl --test=conveyance -d sat /dev/sdq An indication of the time required to run the test will be given to you after you execute the command. You will see something like this: === START OF OFFLINE IMMEDIATE AND SELF-TEST SECTION === Sending command: "Execute SMART Conveyance self-test routine immediately in off-line mode". Drive command "Execute SMART Conveyance self-test routine immediately in off-line mode" successful. Testing has begun. Please wait 5 minutes for test to complete. Test will complete after Fri Jul 19 14:08:02 2019 To check the results of the tests: smartctl -l selftest -d sat /dev/sdq To check the state of SMART on the disk (note the x is in lower case): smartctl -x -d sat /dev/sdq To abort any ongoing test (note the X is UPPER CASE) smartctl -X -d sat /dev/sdq When running a short or long tests you will get this at the end of the output: Smartctl: Failed to inform synostoraged when testing. Ignore it. The test will be running anyway. Now you can do a script and add it to your task scheduler so that SMART tests can be run at desired intervals. Quote
