Nanoboot Problem on virtual box - Wireless Connecting?
jbugman
Hello,
Trying to get Nanoboot to install on a Windows 7 running Virtualbox. I have downloaded the iso of 4493 and booted with this, so far, so good.
I have got through till the end and it says "Excution Error" followed by asking for a Diskstation login
I guess this is root but the password isnt 101-0101
Any ideas please?
Thanks
J
Edited by Guest
Okay, so more googling around and I have now downloade the synology assistant
I have booted that up and I can see the DSM but i when i get through to the last stage to actully install, it tells me i cant connect
Any ideas?
J
Well quite happily to admit my mistakes
You must connect via a ethernet cable adapter, not a wireless adapter. Thats what you get for trying to install at 3am in the morning!
So, on to the next challenge!
J
So, its up and running but i have one more problem
How to connect it to my wireless adapter. If i include it in the bridge, it fails, so the only way I can connect is to connect via the bridge between my unplugged ethernet connector and the virtual adapter.
Any ideas?
J
