omar Posted July 7, 2019 #1 Posted July 7, 2019 Well as usual my server crashed again. Gonna update it to the new jun loader and got to the part where I need the VID and PID of the microsd card I will be using. So stick it in an adaptor, into my pc, goto properties etc, and get the values there. Except these values didnt match what I had last time. So after some googling I find that I am getting the VID & PID of the card reader! NOT the microsd card itself Tried googling it but I cannot find a way to find the values for a microsd card! Anyone have any ideas? Quote
omar Posted July 7, 2019 Author #2 Posted July 7, 2019 Hmm, so until I can use a microsd card, I just used a usb stick to test out my system. Another problem, also I read you need an intel NIC, so I bought a NC360T for my gen8 Installed it start the server, it wont show up at all! The system loads to the normal xpenology screen asking you to use find.synology.com But I cant find it.. Do I need to install updated drivers for the NC360T? I installed teh latest BIOS as well, VERSION: SP99427 2019.04.04A Quote
polanskiman Posted July 8, 2019 #3 Posted July 8, 2019 On 7/7/2019 at 8:43 PM, omar said: Gonna update it to the new jun loader and got to the part where I need the VID and PID of the microsd card I will be using. A quick search in the forum would have answered your question. An SD card is not a USB device hence no vid/pid. So you need to use the vid/pid of the card reader. Launch a ubuntu live or whatever unix flavored OS you want and run this: sudo lsusb If you can still access DSM through ssh you could also run this: cat /proc/bus/usb/devices | grep -e "^ $" -e "Vendor" -e "Manufacturer" -e "Product" this should output all usb devices in your machine. Look for the card reader and its associated vid/pid. On 7/7/2019 at 11:51 PM, omar said: Do I need to install updated drivers for the NC360T? I installed teh latest BIOS as well, VERSION: SP99427 2019.04.04A There is nothing you need to install. Do you see the NIC in the bios? If not then it means it's not even recognized at boot time and no OS will ever be able to see it. Make sure it's properly connected and powered. Quote
omar Posted July 8, 2019 Author #4 Posted July 8, 2019 (edited) But I dont want to use the card adaptor, I have a HP Gen8 microserver, which has a built-in microsd slot. But yeah atm I am using the adaptor and it's values, though prefer not to. but if sd cards dont have those values, I guess I can ignore that part of the setup then. The PCI network card does appear in the BIOS, each port appears separately. The lights on the ports also turn on, Orange to show it's a 1000mb connection, and the green power LED. But it's stuck on solid, not flashing so that shows no communication is going on even though it's connected and powered..... Wondering if I need the MAC addresses of the pci ports? I read on another thread to change it to MAC1=eth0, but that doesnt work either. Neither does keeping the macs on the onboard ports. Not sure how to disable only the onboard NIC, I looked around and foudn a couple of sections and disabled them, but not sure if that disabled the pci card as well.... Nor is there an option to select the PCI card Edited July 8, 2019 by omar Quote
bearcat Posted July 22, 2019 #5 Posted July 22, 2019 @omar According to a Google translate, If you use MicroSD on HP Gen8: VID 0x0424 - PID 0x4030 this is the internal card reader, (located on the USB bus) 1 Quote
_zer0_ Posted August 16, 2019 #6 Posted August 16, 2019 I am succesfully booting Xpenology from an SD card in the internal SD card slot of a HP DL120 G7. vid and pid settings I use: set vid=0x0003 set pid=0x0000 Running DSM version 6.2.2-24922 Update 2 Jun's loader v1.03b - DS3615xs No custom extra.lzma Quote
luchuma Posted August 16, 2019 #7 Posted August 16, 2019 [mention=9005]omar[/mention] According to a Google translate, If you use MicroSD on HP Gen8: VID 0x0424 - PID 0x4030 this is the internal card reader, (located on the USB bus)Works for baremetal g8and nc 360t 6.2.2 dsm Wysłane z mojego SM-G970F przy użyciu Tapatalka 1 Quote
