fred41 Posted June 30, 2019 Share #1 Posted June 30, 2019 Hi everyone, I updated from "DSM 6.1.3-15152 Update 6 + loader Jun's v1.02" to "DSM 6.2.2-24922 + loader jun's v1.03b", and I have a issue with power off function, not present before update.. When I power off, or restart from DSM UI, everything seems to be shutted down. UI, sonar, transmission etc... are unreacheable, but my computer don't really turn off. The system is off, not the hardware, Boot screen is present on computer monitor (...Happy hacking), ping response is ok, and power is still on, and never turn off. I have to force the power button or use the reset button. I tried to install "Advanced Power Manager" https://sourceforge.net/projects/advpowermgr4ds, great power tool by the way, but the result is the same, no full power off.. I have been advised to try "power button package" https://xpenology.com/forum/topic/7195-power-button-packageBut it seems to be useful only to perform a real "soft power off" when pressing physical computer power button, don't think it would apply to my problem. Is it a known problem, do you have solution to this? Thanks a lot in advance. My config: DS3615xs DSM 6.2.2-24922 loader jun's 1.0.3b CM ASUS M4A7BLT-M LE - Bios rev 0704 - 6 SATA ports AMD Sempron 145 - 2.8 GHz (detected INTEL Core i3-4130) 2048 Mo DDR3-1333 PCI-E to 4 SATA II Card For JMB363 (only 2/4 ports usable) Quote Link to comment Share on other sites More sharing options...
shimss Posted October 24, 2020 Share #2 Posted October 24, 2020 (edited) Same for me. The screen does not turn off after the xpenology is powered off. durability : DS918+ DSM 6..??? Loader June 1.0.4b Samsung Notebook NT371B5J intel core i5-4210 intel HD Graphic Is this a known issue? Is there any solution for this? Many thanks. ============================ 저도 마찬가지입니다. xpenology의 전원을 끈 후에도 화면이 꺼지지 않습니다. 내구성 : DS918 + DSM 6 .. ??? 로더 6 월 1.0.4b 삼성 노트북 NT371B5J 인텔 코어 i5-4210 인텔 HD 그래픽 이것이 알려진 문제입니까? 이에 대한 해결책이 있습니까? 감사합니다. Edited October 24, 2020 by shimss Quote Link to comment Share on other sites More sharing options...
IG-88 Posted November 5, 2020 Share #3 Posted November 5, 2020 On 10/25/2020 at 1:55 AM, shimss said: Is this a known issue? Is there any solution for this? problems with restart and shutdown can be related to crashed drivers during boot, check /var/log/dmesg Quote Link to comment Share on other sites More sharing options...
