Simple package status commands/script help
ilovepancakes
Hi all,
I need a little assistance with direction on how to write a simple script involving the package status (start or stop) for specific packages in DSM. I am setting up a service monitor and want to be able to "read" the status of some of the packages running on DSM (Chat, VideoStation, etc...).
The way it works is, a URL is provided by the service monitor and linux can "check in" using the specific URL to show it is alive. What I want to do is have a scheduled task on DSM execute bash commands (every 5 minutes) to check if a package is started and if it is, then curl or wget the URL to the service monitor. Creating the scheduled task and using curl to ping the URL I have a handle on but what commands can be run before the curl to make sure the package is in a start state before getting to the curl?
Ideally I would imagine a command that returns an error or nothing at all would be best because then I could simply enter "status_check_command && wget https://ping.com/" and I think the wget won't fire unless the status_check_command runs successfully? Is that right?
I have only come across commands (synoservice) though that return something all the time. That command with --status [service name] will output back out if the service is start or stop. But how can I create a command that only moves to the curl if the status returned is started?
Seems something like this
$ sudo synoservicectl --status pkg-Docker-dockerd
pkg-Docker-dockerd start/running
$ sudo synoservicectl --status pkg-videostation-synovideopreprocessd
pkg-videostation-synovideopreprocessd start/running
pkg-videostation-synovideopreprocessd stop/waiting
Names of the packages you саn see in it's config path /etc/init
Edited by Olegin
Example, script Videost.sh:
#!/bin/sh
if synoservicectl --status pkg-videostation-synovideopreprocessd | grep 'start/running'
then echo 'Videostation started...'
else echo 'Videostation stoped...'
fi
Скрытый текст
1989713638_.png.586501bbe6469a1962f21d158d317912.png127787854_.png.509f3b02470797bd9c6a51e0c6ddecf8.png
Скрытый текст
Edited by Olegin
#!/bin/sh
fi
  Task Scheduler settings (Reveal hidden contents)
  e-mail (Reveal hidden contents)
Awesome help! I was able to make it work with that script as a base with some slight modifications. Name of service had to have "ctl" after "pkg" and no "-synovideopreprocessd" after package name.
#!/bin/sh
if synoservicectl --status pkgctl-VideoStation | grep 'start/running'
then curl --retry 3 https://example.com
else curl --retry 3 https://example.com/fail
fi
Thank you @Olegin!
