Demande d'aide pour installer Domoticz sur Xpenology
Tigrou
Bonjour je cherche a installer Domoticz sur mon N54L sous DSM 5
Domoticz sur Synology
J'ai réussi a installer IPKG.
Mais au moment d'installer open Zwave
J'ai une erreur sur la fin du make
make -C /volume1/homes/tigrou/open-zwave-read-only/cpp/examples/MinOZW/ -
make[1]: Entering directory `/volume1/homes/tigrou/open-zwave-read-only/cpp/examples/MinOZW'
make[1]: Leaving directory `/volume1/homes/tigrou/open-zwave-read-only/cpp/examples/MinOZW'
Building Main.o
Linking /volume1/homes/tigrou/open-zwave-read-only/.lib/MinOZW
g++ -o /volume1/homes/tigrou/open-zwave-read-only/.lib/MinOZW /volume1/homes/tigrou/open-zwave-read-only/.lib/Main.o /volume1/homes/tigrou/open-zwave-read-only/libopenzwave.so -pthread
/volume1/homes/tigrou/open-zwave-read-only/.lib/Main.o: In function `main':
Main.cpp:(.text+0xd9b): undefined reference to `__sync_fetch_and_add_4'
Main.cpp:(.text+0xe1e): undefined reference to `__sync_fetch_and_add_4'
Main.cpp:(.text+0xe32): undefined reference to `__sync_fetch_and_add_4'
Main.cpp:(.text+0xee5): undefined reference to `__sync_fetch_and_add_4'
Main.cpp:(.text+0xf6f): undefined reference to `__sync_fetch_and_add_4'
/volume1/homes/tigrou/open-zwave-read-only/.lib/Main.o:Main.cpp:(.text+0xfe1): more undefined references to `__sync_fetch_and_add_4' follow
/opt/lib/gcc/i686-linux-gnu/4.2.1/../../../../i686-linux-gnu/lib/libpthread.so: undefined reference to `__libc_sigaction@GLIBC_PRIVATE'
/opt/lib/gcc/i686-linux-gnu/4.2.1/../../../../i686-linux-gnu/lib/libpthread.so: undefined reference to `_h_errno@GLIBC_2.0'
/opt/lib/gcc/i686-linux-gnu/4.2.1/../../../../i686-linux-gnu/lib/libpthread.so: undefined reference to `__on_exit@GLIBC_PRIVATE'
/opt/lib/gcc/i686-linux-gnu/4.2.1/../../../../i686-linux-gnu/lib/libpthread.so: undefined reference to `_errno@GLIBC_2.0'
collect2: ld returned 1 exit status
make[1]: *** [/volume1/homes/tigrou/open-zwave-read-only/.lib/MinOZW] Error 1
make: *** [all] Error 2
Ne connaissant rien sous linux je nage.
Un coups de mains ne serait pas de refus
bonjour
pourquoi ne pas installer directement synozwave si c'est que pour du zwave ?
http://www.touteladomotique.com/forum/v ... d980115de3
sinon pour domoticz :
http://www.touteladomotique.com/forum/v ... d980115de3 peut etre ici ?
ou ici :
http://www.nas-forum.com/forum/topic/31 ... l=domoticz
mais la s'arretent mes conseils.
cordialement
bonjour
source : posting.php?mode=reply&f=13&t=3157
dans les commentaires
J'ai le meme probleme. J'ai cru, en lisant cet article, que le module SynoZwave etait supporte par cette configuration.
J'ai donc :
- achete un N54L (j'etais deja tente avant)
- installe XPEnology
- achete dongle Usb Aeon Labs
Et tout ca pour rien ... du moins en ce qui concerne l'aspect domotique.
J'ai ecris au developpeur de SynoZwave qui m'a confirme que XPEnology sur le N54L n'etait pas encore supporte.
Répondre
Partager ›
Photo d'avatar
Laurent • il y a 4 mois
J'ai reussi a installer le package sur mon N54L en faisant un petit (mais alors, tout petit) hack !!! Par contre, je n'ai pas encore teste avec mon dongle Usb Aeon Labs ...
Voici ce que j'ai fais :
1- telecharger le dernier build sur ma machine ubuntu :
http://synozwave.com/SPKs/syno...
2- decompresser le fichier dans un repertoire temporaire :
mkdir -p /tmp/Syno && cd /tmp/Syno
tar xvf /tmp/synozwave_0.0.016_x86.spk
3- editer le fichier INFO et remplacer la ligne :
arch="x86"
par
arch="noarch"
4- recompresser le repertoire :
tar -cvf /tmp/synozwave_0.0.016_x86.spk *
Pour finir, j'ai fais une "Installation manuelle" a partir du Centre de Paquets.
Bonjour,
Je chercher aussi à installer SynoZwave ou Domotics sur mon N54L mais je galère un peu.
@ketchoupi : pourrais-tu nous donnez le lien pour télécharger les sources de synoZwave car le lien que tu as mis est KO
Sinon quelqu'un à t-il réussi à installer l'un des deux applications ?
Bonjour
Il faut plutôt demander sur maison et Domotique dans les commentaires ou alors allez voir sur le forum de toute la Domotique topic synowave
Car moi je ai déjà une box Domotique et je n ai pas besoin de synozwave
Cordialement
  • 2 months later...
Le lien complet pour telecharger manuellement le build SynoZwave est : http://synozwave.com/SPKs/synozwave_0.0.016_x86.spk
Une nouvelle version est aussi disponible : http://synozwave.com/SPKs/synozwave_0.0.017_x86.spk
Vous pouvez voir le descriptif complet que j'ai fait a l'epoque sur le site "Maison et Domotique"
http://maison-et-domotique.com/books/gu ... 1231658690
  • 8 months later...
