cahill Posted June 13, 2019 #1 Posted June 13, 2019 Hi Guys, I tried to upgrade my system from 6.1.7 to 6.2.2 with bootloader going from 1.02b to 1.03b on a 3615 system. The upgrade looked to be going fine. The system starts up, i can access the DSM, all apps start working. But after a few minutes all applications shut down ( one reports getting a code15 sigterm signal) and the 2 Nics disappear from the configuration screen and i seem to loose acces as well. any ideas what could be the issue ? regards J. Quote
polanskiman Posted June 14, 2019 #2 Posted June 14, 2019 Not sure what is going on. I would recommend making sure any feature enabled in the bios that is not necessary to be disabled. Is the hardware fully functional? Try installing Windows or Linux and making a hardware test to make sure it's not the hardware. Quote
